Author Topic: Realforce 87u Caps Lock Oddity?  (Read 3500 times)
Offline haydoselefantes
« on: Fri, 25 May 2018, 16:54:02 »
I have two Realforce 87u's.  A stock variable force that I use at work, and an all-45g EK edition dome swapped to BKE ultra-lights at home.  I've noticed a weird caps lock behavior on both of them: it only works about two thirds of the times I hit it.
I posted about this earlier in another thread.
I can feel the key spring back up, and I can hear the thock, but it doesn't register.  You can hear the sound on these videos.
The variable from the office yesterday:
The all-45g w/ BKE ultra-lights at home today in slo-mo:
Am I only person to whom this has even happened?
Offline xondat
  • i'm not a star
Re: Realforce 87u Caps Lock Oddity?
« Reply #1 on: Fri, 25 May 2018, 16:56:55 »
Are you bottoming out?
Topre reads an actuation as a number between 0 and 1, whereas Cherry style is 0 or 1. What's probably happening is it's going just short of the actuation value.
« Reply #2 on: Sat, 26 May 2018, 02:20:44 »
No, not bottoming out. I was forgetting how the capacitance works on Topre switches. Thanks for the reminder.
I suddenly realize that the APC in the Realforce RGB would probably take care of this for me.  I wish the TKL version would come out already.
Offline 00
« Reply #3 on: Sat, 26 May 2018, 02:22:11 »
Topre offer an R2 TKL with APC
It's like, dude, you gotta re-evaluate
Your perspective and your priorities, because
You started doing this because it was ****ing fun, you know?
It has to be fun
Otherwise, you're just torturing yourself, you know?
You're... you're just stuck inside your own ****ing head
« Reply #4 on: Sat, 26 May 2018, 18:12:17 »
I’m still holding out hope we’ll see this rgb tkl with mx sliders in ANSI.
Offline ag36
« Reply #5 on: Sat, 26 May 2018, 19:38:42 »
I wonder if it will come before R2 ansi.
Model M*5, SSK*4, M13 black*1, Model F XT*1, AT*1 F107*1, Unicomp*1, 3278 *1, Leopold FC750R*2, 980M*2 FC980C*1 Filco majestouch 2 TKL*1, Cooler Master MasterKeys S PBT*1, Uniqey Q100*2, Ducky pocket*1, KBD75*2, KBD19X*2, HHKB pro 2*1, Type-S*1 Topre Realforce RGB*1, 108 all 30g*1, numpad*1, 87U*1 Dell AT101W*2, Alps64*2, V80 matias quiet click*2, Quiet liner *1, WYSE ASCII *1
« Reply #6 on: Thu, 31 May 2018, 15:00:15 »
I guess if I had the same problem on an FC660C, I could try using APC on hasu's contoller.
Offline hasu
  • @tmk
« Reply #7 on: Sat, 02 June 2018, 18:10:57 »
well, did you test this on Mac? If so you should try on other OS's, I mean decent one.
I remember that Mac OS ignores fast tap of CapsLock as a design, it needs 100ms or so between press and release. I think this is .. ****ty decision by Apple.
EDIT:
For reference for Mac CpasLock issue:
https://github.com/tmk/tmk_keyboard/issues/390
EDIT2:
I tested FC660C(with original Topre controller) on Linux(unbuntu 16.04) and CapsLock works reliably to me.
« Last Edit: Sat, 02 June 2018, 18:39:26 by hasu »
« Reply #8 on: Sun, 03 June 2018, 21:50:45 »
EDIT:
ED
Thanks for the info, hasu!  This was on Mac. Come to think of it, I’ve never noticed this caps lock behavior on Windows, but I only game on Windows. I only use a real OS for real work 🙂
