Author Topic: RealForce keyboard friction issue  (Read 3024 times)
Offline laqq3
« on: Wed, 23 May 2018, 19:37:00 »
I am having a problem with my RealForce keyboard.
I use the Caps Lock key as a Ctrl key and hit it a lot. Now, when I try to depress Caps Lock by pressing down it on from the right edge (or the lower right corner), the keycap "resists" being depressed, probably because the stem pushes sideways against the underlying mechanism.  It feels like there is some sort of friction that pushes against the the key being depressed.
Anyone have insights on what is causing this and how this might be fixed?
« Last Edit: Wed, 23 May 2018, 21:10:05 by laqq3 »
Offline ag36
Re: RealForce keyboard friction issue
« Reply #1 on: Wed, 23 May 2018, 20:10:13 »
Sound like stabilizer is out of place, do you have keycap puller?
Edit: Sorry, seems there's no stabilizer underneath capslock.
« Last Edit: Wed, 23 May 2018, 20:12:25 by ag36 »
Model M*5, SSK*4, M13 black*1, Model F XT*1, AT*1 F107*1, Unicomp*1, 3278 *1, Leopold FC750R*2, 980M*2 FC980C*1 Filco majestouch 2 TKL*1, Cooler Master MasterKeys S PBT*1, Uniqey Q100*2, Ducky pocket*1, KBD75*2, KBD19X*2, HHKB pro 2*1, Type-S*1 Topre Realforce RGB*1, 108 all 30g*1, numpad*1, 87U*1 Dell AT101W*2, Alps64*2, V80 matias quiet click*2, Quiet liner *1, WYSE ASCII *1
Offline laqq3
« Reply #2 on: Wed, 23 May 2018, 21:10:55 »
I do have a keycap puller and pulled off the Caps Lock keycap to inspect it. By a visual inspection, nothing seems out of place.
« Reply #3 on: Wed, 23 May 2018, 22:20:54 »
I always felt the novatouch stabilizer is mechanically superior/smoother
but in this case, it'll probably smooth out after some breaking in.
Offline laqq3
« Reply #4 on: Wed, 23 May 2018, 23:28:32 »
Actually I got this keyboard a while ago (about 2 years ago). I started noticing the problem maybe about 3 months in. I ordered some lubricant on Amazon to see if that'll help.
Offline ag36
« Reply #5 on: Thu, 24 May 2018, 05:56:19 »
Do you plan to open it up to check is there's anything wrong inside?
Offline haydoselefantes
« Reply #6 on: Thu, 24 May 2018, 15:22:21 »
Caps Lock is the only issue I've had on my Realforce boards:
If I press the edge of the caps lock key, it only activates about two thirds of the time.  I use Caps Lock as Caps Lock so it's not a deal breaker.
Both my 87u's did this out of the box, a variable and an all-45g "EK" edition.  I swapped the domes on my "EK" for BKE ultra-lights and it still happens.  I've swapped all the keycaps a few times as well.
Offline laqq3
« Reply #7 on: Thu, 24 May 2018, 15:29:17 »
I will look into it if lubricant doesn't do the trick. Though after pulling the keycap off, pushing the 'stem' is smooth enough that I don't think it's an internal problem.
Hmm, could be a production issue with RealForce + CapsLock keys.
Offline Polymer
« Reply #8 on: Fri, 25 May 2018, 04:21:47 »
It looks like you're not pressing it far enough?  Having used/had a number of different RFs..I've never seen this problem...but if I press it how you are I can see how I would...
Topre is incredibly reliable and it doesn't have issues where keys don't work randomly...
« Reply #9 on: Fri, 25 May 2018, 13:23:24 »
Agree about the reliability.  I'll stop hijacking this thread, maybe I'll start another one for discussion about my caps lock pressing technique :)
