Author Topic: [IC] Switch MousePad  (Read 19204 times)
Offline Astrasa
Re: [IC] Switch MousePad
« Reply #50 on: Thu, 07 June 2018, 18:53:17 »
These look good, been looking for a long mouse pad for my desk
Kyuu Proto | Quasi Alice | Duck Viper | Tx87-Se
Offline ilouis_07
  • Never Forget Your Origin
    • ILUMKB
« Reply #51 on: Thu, 07 June 2018, 22:21:31 »
Has this gone live yet? I've been waiting to pick 1 of these up
Hi, the group buy haven't start yet, i will update here once it is live. Thanks
Offline ilouis_07
    • ILUMKB
« Reply #52 on: Thu, 07 June 2018, 22:28:11 »
Thanks:) i will update more choices when group buy is on.
Offline ZROGST
« Reply #53 on: Fri, 08 June 2018, 18:09:48 »
I will absolutely be in for design "Order Number 15: Geeks" (the rainbow fractal pattern); Depending on my funds when GB goes live I may also be up for ~2 others. Thanks for doing this, I've been jealous of the switch pads I see in everyone's show-and-tell
Offline meepmeep
  • meep meep meep, meep meep meep. Meep!
« Reply #54 on: Fri, 08 June 2018, 21:25:22 »
Nice!
Offline ilouis_07
    • ILUMKB
« Reply #55 on: Sat, 09 June 2018, 07:51:13 »
Tiffany is the way to my heart... interested!
Thanks for your interested! group buy will on next week:)
Offline ilouis_07
    • ILUMKB
« Reply #56 on: Sat, 09 June 2018, 07:53:14 »
Thanks for your interested:)
Offline ilouis_07
    • ILUMKB
« Reply #57 on: Sat, 09 June 2018, 07:55:23 »
@iLouis_07 Finally you started your groupbuys on Geekhack, as usual I will want a bunch of mats to match my keysets. :D
Sent from my G8142 using Tapatalk
i will update some more designs when gb, hope you like some of them:)
Offline ilouis_07
    • ILUMKB
« Reply #58 on: Sat, 09 June 2018, 08:04:09 »
updates: factory told me 6mm is doable but it is hard to stitch the edges, i think i should ask them to do a prototype with 6mm thickness and see how is it first:)
Offline ilouis_07
    • ILUMKB
« Reply #59 on: Sun, 10 June 2018, 02:58:49 »
Hi guys this is the final version, you guys think it is OK?
Offline _ODIN_
« Reply #60 on: Sun, 10 June 2018, 03:07:45 »
in the last sentence ach needs to be each.
Offline Hokabuki
« Reply #61 on: Sun, 10 June 2018, 03:08:05 »
The paragraph on the left side of the mat is much improved. Other than the E on each missing, looks great!
Offline ilouis_07
    • ILUMKB
« Reply #62 on: Sun, 10 June 2018, 08:03:39 »
Oh! My mistake, thanks man !
Offline ilouis_07
    • ILUMKB
« Reply #63 on: Sun, 10 June 2018, 08:07:06 »
Fixed the problem, thanks for help:)
Offline nimblejacks
« Reply #64 on: Sun, 10 June 2018, 09:09:17 »
I'd buy one if the odd writing was ever fixed.
Offline ZROGST
« Reply #65 on: Sun, 10 June 2018, 09:18:36 »
imo the spacing between the text block and the diagram needs to be slightly increased.  the text block would look much better if it was Justified alignment.  With these two things fixed I think you would have a perfect pad.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #66 on: Sun, 10 June 2018, 09:48:35 »
I agree. Justified alignment example below:
Sent from my mobile using Tapatalk
Offline ArchDill
« Reply #67 on: Sun, 10 June 2018, 10:40:50 »
I would LOVE to see a Purple mat with Cyan ink
Offline RSC
« Reply #68 on: Sun, 10 June 2018, 11:29:01 »
I'm in as well.
Can you just clarify the sizing? On the initial post is says it's 800x400, but on the imgur album all mats say 900x400...
Offline ilouis_07
    • ILUMKB
« Reply #69 on: Sun, 10 June 2018, 20:41:46 »
I'm in as well.
i just realized i made a mistake, it is 900 x 400 mm. i already corrected on the initial post, thanks man :)
Offline ilouis_07
    • ILUMKB
« Reply #70 on: Sun, 10 June 2018, 20:46:59 »
yup i have tried justified, but looks like AI doesn't have this function(maybe i am wrong:P), it only have align either right or left. i will double confirm it tonight when i back home, if doesn't have,i can justify manually if possible:)
Offline ilouis_07
    • ILUMKB
« Reply #71 on: Sun, 10 June 2018, 20:48:38 »
Thanks for the suggestion! I will improve it later on!
Offline ilouis_07
    • ILUMKB
« Reply #72 on: Mon, 11 June 2018, 00:48:42 »
I fixed:)
Offline ilouis_07
    • ILUMKB
« Reply #73 on: Mon, 11 June 2018, 12:28:16 »
I submitted the Gb already, thanks for you guys helped me and gave me a lot of good suggestions!!!i really appreciated that !
Offline jlee755
« Reply #74 on: Mon, 11 June 2018, 13:02:31 »
You're famous man.
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
« Reply #75 on: Mon, 11 June 2018, 13:20:28 »
