Author Topic: [IC] GMK Grey on Black  (Read 57498 times)
Offline reidd
Re: [IC] GMK Grey on Black
« Reply #50 on: Tue, 05 June 2018, 19:52:52 »
I'm in.
Offline Dan_Boulet
« Reply #51 on: Tue, 05 June 2018, 21:38:07 »
This looks really good, the R2 1.5u Delete key and R4 1.5u Code keys are great for us Mac users.
One question: what is an “Alt Gr” key?
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #52 on: Tue, 05 June 2018, 22:13:22 »
How about a gray accent spacebar? Or even a separate spacebar kit, although I think you can get those from Oco (unless you include small spacebars for split space or 40% layouts).
Offline noobas4urus
  • Mod Munky of another realm
    • The Mod Zoo
« Reply #53 on: Tue, 05 June 2018, 23:53:47 »
I would love to see traction on a full grey mod kit (space bar too).  I think it would be really easy to accent other key sets and would look sweet in general with the inverse alphas.
"You miss 100% of the raffles you don't enter."
-Wayne Gretzky
Offline zap2oz
« Reply #54 on: Wed, 06 June 2018, 22:15:40 »
Seconded!
Offline Lndefinite
« Reply #55 on: Wed, 06 June 2018, 22:30:15 »
Dark theme is so dank. I'm in.
Offline donutcat
  • I have ideas. Sometimes they're even good ideas.
    • Donut Cables
« Reply #56 on: Thu, 07 June 2018, 08:48:48 »
Perfect. Now kindly take my money, sir.
PS: Having H J K L with arrows, as GMK Terminal, would also be sweet.
No plans for VIM arrows as it's not relevant to the set theme currently.
maybe the accents would look better with white legends?
I think they'd be too bright for the rest of the set that way.
Alt Gr is another name for the RAlt, most commonly used in layouts such as ANSI-Intl where you need to access sublegend layers. I like having it in my kits since I think it looks neat and some people may find use for it.
No plans currently for a spacebars kit currently as that's just another kit to worry about hitting MOQ with, and I don't currently see enough interest to develop it.
No plans for a grey mods kit. The plan is keep the colorway uniform and not put effort into child kits that will be difficult to move.
Offline base
« Reply #57 on: Thu, 07 June 2018, 09:31:42 »
I'm in on this set as well, probably regardless of what kind of accent pack is settled on.
Offline RobotRogue
  • No.
« Reply #58 on: Thu, 07 June 2018, 10:34:10 »
This set would be tricky to use in low light - for those of us who occasionally have to look at our keys. Otherwise, cool concept.
Offline RSC
« Reply #59 on: Thu, 07 June 2018, 15:10:41 »
In all honesty, I don't really understand that. First because, at present, this set has no theme, it's just a colourway taken from GMK Doom (RIP). Secondly, I fail to see how having 4 keys with arrow sublegends (that is great for anyone running 60% boards or smaller) can be anything but a plus for this set...
Offline xondat
  • i'm not a star
« Reply #60 on: Thu, 07 June 2018, 15:14:32 »
Terminals theme was programming etc, where they're relevant. They aren't relevant here.
The keys will add cost, and/or, take up space used for keys to give better compatibility.
If you believe it is "anything but a plus", my suggestion would be to put an IC up yourself, and see how much actual interest there is. I imagine it'll be less than the ISO crowd.
Offline RSC
« Reply #61 on: Thu, 07 June 2018, 15:20:32 »
Rama's Heavy Industry also has arrow keys sublegends and it's not themed for programming. Be that as it may, it's super simple for donutcat to see if there is interest on this or not, just start a poll here. This is an interest check, right?
Offline tanvir175
« Reply #62 on: Thu, 07 June 2018, 16:29:43 »
He can but VIM key's really aren't "anything but a plus." They increase cost for the majority and the majority probably won't even use it.
I wouldn't be opposed to it being in a different kit but then it also will likely not make MOQ. Just doesn't seem necessary.
In the end, I'm pretty sure it's all aesthetics, anyways. If you're constantly using arrows in that layout, I'm pretty sure you don't need legends to know where they are.
Offline meepmeep
  • meep meep meep, meep meep meep. Meep!
« Reply #63 on: Thu, 07 June 2018, 17:19:23 »
nice!
Offline Dennyroxsox
  • a.k.a. Lollipopsaurus
« Reply #64 on: Thu, 07 June 2018, 18:25:10 »
I'd be in for this since I'm an idiot and missed out on Doom. A lack of theme I think is actually a bonus if it can keep the price down.
No VIM caps please.
Offline Zuology
  • Why does this rabbit-hole have so many side-quests
« Reply #65 on: Thu, 07 June 2018, 19:02:38 »
No VIM caps please.
I wouldn't say you "missed out on doom" since capsunlocked aborted his own project last minute. This is the resurrection/continuation of doom without the orange accents (which weren't much of a theme at all tbh).
Agreed on no vim caps in base for added cost that a very small minority of buyers will use. You can always run a separate gb for just vim caps, ortho, 40%, and ISO keys (too soon?) for those that will definitely use them, seeing as the kits usually fail moq the vast majority of the time.
75%: Scarlet Bandana (TBD) | Singa75 Polycarb (TBD) | SKB75 (TBD) | YMD75 (Box Navy) | XD84 (Outemu Ice) | Plum84 (BKE Redux Heavy)
TKL: ALF X1.1 SE (TBD) | LZ Iron White (TBD) | Fox Labs Orange (TBD) | Alu WASDv2 (Cherry Green) | MechkeyAlpha MA87 (Kailh Box Burnt Orange) | Archon RE:AL Superior EX (Nopre 65g)
Full+: Clueboard Double 1800 (Vint Clears) | IBM Model M | IBM Model F XT
Offline SingSong
« Reply #66 on: Thu, 07 June 2018, 20:00:40 »
So this is like a Cherry Ninja set? Sweet!
Offline krey
« Reply #67 on: Thu, 07 June 2018, 22:45:43 »
Nice. I am interested in this.
The idea of an inverted colourway sounds good as well.
Kepler FC65 | 7v | Think6.5 v1 | Maja | G60 | TX75v2 | Fjell | Klippe x2 | Acrylic Tofu | CA66 | Norbaforce
Offline sth
  • 2 girls 1 cuprubber
« Reply #68 on: Thu, 07 June 2018, 23:46:36 »
GMK GOB
Offline toastyparty
« Reply #69 on: Fri, 08 June 2018, 13:53:23 »
I love this. this is perfect to mix and match with different sets lying around.
Offline jlee755
« Reply #70 on: Fri, 08 June 2018, 14:32:23 »
GMK GOB
I didn't even know I wanted this until I saw this.
I want a "SAME" key.
Offline Yeoh
« Reply #71 on: Sat, 09 June 2018, 12:11:41 »
I have no interest in the inverse colored accents. The Grey on Black colorway is already available as an epbt set.
Any chance we can move accent keys + ISO to separate kits, in order to make it cheaper for the vast majority?
Seeing as though there is no longer a theme tying the set together, and people basically just want a base kit in this colorway - no need to throw in any extras to a set that is basically half sold already.
« Last Edit: Sat, 09 June 2018, 12:16:27 by Yeoh »
Offline JamesShaw
« Reply #72 on: Sat, 09 June 2018, 12:18:42 »
Nice one!
speaking of Accent, what do you think of something unconventional?
Only Esc and Return but in three/four different colors? (One of those must be orange anyway....)
Something like this is what I originally had in mind, either this and a single kit, or expand them by adding spacebars and make them each individual accent kits available for lots of sets.
+1 for RGB accents
Yes, please! GMK Grey on Black with RGB mod
Offline Atredl
« Reply #73 on: Sat, 09 June 2018, 13:32:29 »
If the ISO enter key is moved to a separate kit, it won’t get made. We can’t afford to alienate every single ISO country.  Not having their correct legends is one thing. Not being able to cover their keyboards at all, is a completely different story.
Looks like the accent keys have a good amount of support. You’d probably be be outnumbered on that.
Offline Yeoh
« Reply #74 on: Mon, 11 June 2018, 01:47:56 »
There are already plenty of successfully run GMK sets without any ISO support at all. Moving them to a separate child kit and lowering the base price would probably help sell more sets overall.
This is a keyset that has already generated alot of interest, but doesnt have alot of inspiration as far as a theme at this point. It would make alot more sense if the project was streamlined by running the basic GoB set that everyone was originally interested in, especially if we can do so for a more affordable price compared to other GMK sets.
Also, while there are already a few accent kits out there, im sure there a much broader section of buyers outside this ic that would enjoy a separate gb for an accent kit. Perhaps suited not only to this keyset, but designed to match multiple GMK colorways. I know I would enjoy something like that.
Offline icho
« Reply #75 on: Mon, 11 June 2018, 04:48:20 »
I'd be in with an additional ISO-DE kit to the base kit.
Offline oluigenuma
« Reply #76 on: Mon, 11 June 2018, 06:34:27 »
As much as I‘d like to see that, ISO-DE is never gonna make it. Just like every other addon kit. Either include it in base or don‘t bother at all.
I think the size of the original doom basekit is the way to go. Good compatibility for everyone without exploding costs.
If you want accents, include it in base or make a separate GB. Considering the participation in the original buy, I really don‘t see anything but a basekit hit moq.
Offline Mearaz
« Reply #77 on: Mon, 11 June 2018, 08:31:49 »
Split Spacebar in a GMK base set? Am I dreaming? Count me in!
Offline tanvir175
« Reply #78 on: Mon, 11 June 2018, 15:39:32 »
This. Please, don't do anything that'll increase costs. $145 was already high and we only made it a little over halfway for MOQ, last time.
Offline goodman247
  • It's confirmed, I'm an idiot.
« Reply #79 on: Mon, 11 June 2018, 23:33:30 »
This does really remind of Ninja a lot, I would say the black on the key might be different but overall might want to add some "personality" to differentiate and standout.
Offline Yeoh
« Reply #80 on: Wed, 13 June 2018, 11:09:31 »
SA Ninja has more in common with epbt black on grey than this set, as far as colors go.
This set uses the inverse grey on black, arguably even more stealth than SA Ninja. Indeed, that is literally the appeal to most of the people interested in this project.
Offline donutcat
    • Donut Cables
« Reply #81 on: Wed, 13 June 2018, 12:52:59 »
My phone kicking the bucket has made it difficult to keep up with comments on all my threads, so I'll try to cover notable stuff since the last update.
Seems that most of the interest here is keeping this fairly plain in the interest of cost. To that extent, I think The current base kit is where it needs to be to do this: good compatibility with just a touch of accents. GMK charges a flat fee per color that's included in the kit, therefore cutting the base kit here down by removing the orange should have brought the price down enough to justify the increased compatibility.
Currently I have the set mocked up with text only mods. I enjoy text only, but I know mod options are pretty controversial, so I'll check what the opinion is on that.
Still no plan for VIM arrows. That'd be five dupes in the kit that the majority of people won't be using and that don't add any alternate layout support, so "dead" keys for the most part.
ISO is a touchy subject. I personally am of the opinion that minimal ISO support is a small price to pay in order to open the set up for a not insignificant proportion of people in the community. At the minimum I advocate carrying the bare four keys needed to physically support any number of ISO layouts even though the legends won't. Currently in the base I have a total of nine keys for ISO support and I think that's fine, but if need be I can poll if people would like to pinch ~$2-$3 from cutting back.
Accents are also a bit of a situation to work with. I figure the four simple ones in the base kit are fine for now. In regards to the RGB ones, I'm not sure what exactly to do with them right now. If I cut that kit down to like Esc and Enters and kept them as a single kit, that could work as well. Maybe a separate buy for the accents would be good, but also consider the fact that as a child kit they only need 100 MOQ instead of the 150 MOQ as a separate buy. There's always costs and benefits to each choice in kits.
I'll leave with a couple of polls to see where we stand on some of this
RGB Accents - https://www.strawpoll.me/15889870
Mods - https://www.strawpoll.me/15889895
If I missed anything lemme know and I'll try to catch it next time I have a chance.
Offline RSC
« Reply #82 on: Wed, 13 June 2018, 13:56:51 »
If there's no ISO support with legends, I'm instantly out.
Offline donutcat
    • Donut Cables
« Reply #83 on: Wed, 13 June 2018, 15:13:01 »
I should have specified "proper" legend support, as in no ¬, '', or £ on ~, 2, and 3, or '@ key, so just ISO Enter, R3 #~ key, ISO Shift, and R4 \| key. So it's still legends, just bare minimum.
Offline Atredl
« Reply #84 on: Wed, 13 June 2018, 15:41:50 »
No! Text mods are losing. There aren’t enough text only option out there.
Offline dohmain
« Reply #85 on: Wed, 13 June 2018, 23:29:11 »
Would it be possible to still include both standard Alt keys per size along with the AltGr keys?
The AltGr is really killing this for me.
Offline Dan_Boulet
« Reply #86 on: Thu, 14 June 2018, 00:14:28 »
To me, the icon + text mods wouldn’t fit for this set. The whole point of the dark grey on black colourway is to have subtle, minimal legends, and text-only mods help achieve that.
Offline RSC
« Reply #87 on: Thu, 14 June 2018, 01:34:44 »
I agree with this. Text mods only please.
Offline donutcat
    • Donut Cables
« Reply #88 on: Sun, 17 June 2018, 14:56:33 »
If it seems like a problem I'll switch back to just Alt since I wouldn't want to fluff the kit with useless dupes.
Good news is text mods are currently in the lead by 22%.
Offline Vypr
« Reply #89 on: Mon, 18 June 2018, 12:05:30 »
I'm definitely interested
current keyboard: VE.A (home) WhiteFox TrueFox (home)  MD1 Infinity (Home)  Infinity Ergodox (work)
future keyboards:
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #90 on: Mon, 18 June 2018, 12:40:07 »
The real solution is to never use ISO tbh
Also interested  :p
Offline Yeoh
« Reply #91 on: Mon, 18 June 2018, 13:46:36 »
Would appreciate another alt vs alt gr.
I have to admit, I impulsively voted icon mods. I got swept up in the hype, but thankfully ive come to my senses and realized I was wrong to do so.
Forgiveness please!
Offline scud80
« Reply #92 on: Wed, 20 June 2018, 00:08:31 »
i might be interested in this.  i'm curious about the possibility of a blanks kit for ergodox to run alongside it.  they would likely offer a lower MOQ for that since it would be small and all blanks, and it would then make any GMK set with a black base color usable on ergodox.
« Reply #93 on: Wed, 20 June 2018, 00:23:15 »
if donut doesn't do this i can add it to my agenda for blank sets
but might not be possible with JTK, they have a weird process
Offline donutcat
    • Donut Cables
« Reply #94 on: Wed, 20 June 2018, 01:11:39 »
Terminal is already basically doing this. N9 instead of true black, but I'm not sure there's much that actually uses full black. Plus the prices really aren't that good based on past ergodox kits.
Offline Atredl
« Reply #95 on: Wed, 20 June 2018, 02:10:54 »
Terminal’s N9 Ergodox kit would match too since the legends of GoB are N9
Offline scud80
« Reply #96 on: Wed, 20 June 2018, 09:26:35 »
zero interest in an n9 blanks set.
Offline donutcat
    • Donut Cables
« Reply #97 on: Wed, 20 June 2018, 16:43:59 »
Unfortunately I'm not interested in devoting time to designing and having quoted a child kit that will cost more than people want to pay, struggle to hit MOQ, and cause people to drop base kit orders when the kit doesn't hit MOQ, especially when Terminal is getting ready to run a very similar kit that will most likely draw in the people that would want it. Maybe in the future a dedicated CR Ergodox kit could be run, but I don't think it belongs with this set.
Offline tanvir175
« Reply #98 on: Wed, 20 June 2018, 19:02:17 »
^ Yeah, lets just keep this set as simple as possible.
Offline donutcat
    • Donut Cables
« Reply #99 on: Wed, 27 June 2018, 13:19:50 »
Small update since this hasn't been poked in a bit, looks like 61%+ want RGB accents to be another GB as opposed to tacked onto this one, and ~59% want text only mods over text+icon, so that's the way I'll be heading with this. Once images are back up working on here I'll post current mockups, see if everyone's happy with those, then start talking with Cartel about the set since there's really not a whole lot more to do with it developmentally.
