Author Topic: [IC] CA66 Custom Keyboard Round 2 (follow lastest quote for updates!)  (Read 101830 times)
Offline PlayKeyboardTW
    • Shop
Re: [IC] CA66 Custom Keyboard Round 2 (follow lastest quote for updates!)
« Reply #300 on: Mon, 06 August 2018, 19:42:16 »
I saw that the led strip is going to be raised up a bit higher from the pcb to prevent light bleeding. I wonder if a more frosted strip will be necessary on the case to prevent led hotspots and to keep a more gradient look.
The part you were saying was already frosted. ;)
Oh, I know that but I’m wondering if it’ll be made thicker to account for the fact that the leds will be closer to the surface and might cause led hotspots instead of a nice ambient light. Perhaps it’s negligible in terms of how much it’s raised. Have you tried one of the new pcbs in the case with the leds on? Does it look fine still?
Yeah it's tested. Still have some distance between leds and top. ;)
Thanks for feedbacks guys. :thumb:
The alps option will only be in Bluetooth PCB. If you guys are okay with the layout it provided, we'll stick to this pic below.
Will there be a non-ALPS option? I'd like to solder on Holtites but the ALPS slots will make that rather difficult
No sorry. But the truth is that you can't mount PCB to top case unless you solder switches in it.
I beg to differ :)
I have several top mounts with Holtites. Even though I can't swap switches without opening the case to support the PCB from below when putting new switches in, the Holtites will hold on to the switches enough to keep the PCB floating.
That'll cost more according to the expected quantity of PCB selling. Yang will tend to keep what it looks like right now. :-X
Offline kokoon
« Reply #301 on: Tue, 07 August 2018, 00:43:12 »
So will there be a white option now?
Offline befbef
« Reply #302 on: Tue, 07 August 2018, 02:12:42 »
Hot-swap would really be a big  :thumb:
Thanks for checking again!
Offline krey
« Reply #303 on: Wed, 08 August 2018, 04:28:29 »
i want a ca66 to call my own!
Kepler FC65 | 7v | Think6.5 v1 | Maja | G60 | TX75v2 | Fjell | Klippe x2 | Acrylic Tofu | CA66 | Norbaforce
Offline ye_cole
« Reply #304 on: Wed, 08 August 2018, 12:46:03 »
Hot swap would be great. Seconded!
Offline cijanzen
« Reply #305 on: Wed, 08 August 2018, 13:09:28 »
You people gotta commit on your switches! Solder em in!
    • Shop
« Reply #306 on: Wed, 08 August 2018, 20:44:17 »
Morning from Taiwan guys!
We are planning to start CA66 GB on 15th. :))
My mate will be going to anodizing factory to check all final color options.
And we'll be uploading modded plate and alps plate pics for you guys to have a look.
About PCB, there will be 2 kinds:
1. Normal wire version: with modded RGB led strip and a bit change for fully supporting QMK. USB C to C also supports
2. Bluetooth version: BT4.0, compatible with MX switches and ALPS switches. TMK firmware.
About Hotswappable PCB. Since CA66 wasn't designed for using this way to install and build, the PCB will need some screws to mount to the top case as you guys can see what m60-A did. It should be re-layouted and tested, which is going to cost lots of effort.
We don't think it's a good idea to just produce some PCBs, and you guys are on your own after sending them away.
So sorry to say HS PCB is not available. We'll come up with it in other design to follow the trend. :thumb:
Offline ipreferpie
« Reply #307 on: Wed, 08 August 2018, 20:46:00 »
So excited for this! Is this a limited number GB or open pre order? Just wondering if I need to press F5 like crazy!
Offline cijanzen
« Reply #308 on: Wed, 08 August 2018, 20:57:34 »
Awesome! Super excited for this!
Few questions,
Will the Bluetooth option not have QMK support and LED strip modifications like on the non-Bluetooth option?
Will we be able to purchase more than one PCB and plate per order?
    • Shop
« Reply #309 on: Wed, 08 August 2018, 21:14:07 »
Few questions,
No QMK for BT PCB. RGB led strip will remain it's fancy. You still can change it's settings.
Extra parts are surly available to be purchased. :thumb:
Offline cijanzen
« Reply #310 on: Wed, 08 August 2018, 21:15:15 »
Few questions,
Sounds good! Depending on pricing I might pickup Bluetooth and non-Bluetooth options. Either way thanks for another round!
Offline York Chan
« Reply #311 on: Wed, 08 August 2018, 21:19:12 »
I m verrrry love it. And i render it with keycaps set 2600~ :thumb:201580-0
Offline jrfhoutx
  • Post count is meaningless if the content is trash.
« Reply #312 on: Thu, 09 August 2018, 00:03:04 »
Few questions,
has the work to port the bluetooth version to qmk just not been done, or is it not possible?
I know qmk supports the bluefruit boards, but considering that qmk is based off of tmk, if it's possible to support this board's bluetooth setup in tmk, then it should be possible to support qmk on the same board.
Offline silversung
« Reply #313 on: Thu, 09 August 2018, 01:06:32 »
literally signed up with GH to join this GB!
beautiful design with retro feel, and BT. That's like an endgame for me.
DARK RED, here I come!
Offline slxdegrees
  • Nerds With Keebs
    • Donate to Room To Read!
« Reply #314 on: Thu, 09 August 2018, 05:51:50 »
Is it possible to start the GB a little later? GBs for so many great-looking keyboards are starting at around the same time and our wallets could really do with a bit of time to catch up.
Offline Photoelectric
« Reply #315 on: Thu, 09 August 2018, 12:30:20 »
That's probably always going to be the case at this point, just as it is with keycap sets.  I anticipate the rate to increase even further.
Offline Cktenders
« Reply #316 on: Fri, 10 August 2018, 16:02:30 »
Will the BT PCB be using USB-C as well?
Offline gregoryturtle
« Reply #317 on: Fri, 10 August 2018, 21:49:38 »
How long will the group buy be opened for?
DZ60 | M60A LAKE | M60A KURO
Offline dantambok
« Reply #318 on: Sun, 12 August 2018, 10:45:40 »
I have a CA66 from the original run in China. Can i just order a bluetooth PCB and plate from this GB?
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
Offline typischt
« Reply #319 on: Sun, 12 August 2018, 15:54:13 »
Yes, that will be possible.
Offline dantambok
« Reply #320 on: Sun, 12 August 2018, 17:46:49 »
Stuff  I have
100+ GMK sets
    • Shop
« Reply #321 on: Tue, 14 August 2018, 11:02:31 »
Hi, guys.
We are trying hard to make the GB happen on time. Please forgive us if we can't make it on 15th. :(
We'll make it live asap.
Offline Lormania
« Reply #322 on: Tue, 14 August 2018, 11:26:35 »
Thanks for the update and no worries!
Offline dondongler
  • Gotta Light?
« Reply #323 on: Tue, 14 August 2018, 11:28:06 »
Take your time, really excited to see what colors you'll be offering. Hoping for that dark blue.
Offline roymt76
« Reply #324 on: Tue, 14 August 2018, 12:23:56 »
Hi, guys.
Thank for update  ;)
I have more time to save my money
Offline cijanzen
« Reply #325 on: Tue, 14 August 2018, 12:24:40 »
Hi, guys.
Thank for update
Hopefully only a day or two! I’m so ready this round.
Offline Ephemeral
« Reply #326 on: Tue, 14 August 2018, 12:34:09 »
Same. I would love for this to happen at some point this month if not the 15th.
I won't be able to get in on it otherwise.  :(
Collection:
E6.5 (Lubed 50g MX Blacks) | Preonic (55g MX Clears) | CA66 (Zealios V2 65g) | budget96 (MX Red) | Infinity 60% (Zealios 78g) | Phantom TKL (Gateron Black) | MiniVan (Zealios 78g) | Helix (?)
[Incoming: Polaris (?) |  KBDFans 8X Mk II (v2 Tealios)]
Offline KingzandBean
« Reply #327 on: Tue, 14 August 2018, 16:03:15 »
Wait so is there a finalized color option list?/ Will there the round 1 colors be available?? :0 *drools a little*
Offline Lormania
« Reply #328 on: Wed, 15 August 2018, 00:49:50 »
Hoping for the same purple!
Offline Lyle88
« Reply #329 on: Wed, 15 August 2018, 02:19:10 »
I'm very much considering going for the purple with SA troubled minds
Offline redjarojam
    • Instagram
« Reply #330 on: Wed, 15 August 2018, 10:09:15 »
I am looking for that brown to come back...Standing by with a fistful of money.
Offline cijanzen
« Reply #331 on: Wed, 15 August 2018, 14:50:47 »
Any updates as to when the gb will start? I know there’s a delay but do you have an estimate?
    • Shop
« Reply #332 on: Wed, 15 August 2018, 20:16:26 »
Sorry for the delaying. :'(
We are pretty much done for the GB page. Just waiting to do the final check and we are good to post it to GB forum.
Might be show up anytime in these two days. :thumb:
Thanks for all the patience from you guys!
Offline cijanzen
« Reply #333 on: Wed, 15 August 2018, 21:10:31 »
No worries! better to have a slightly delayed but smoother GB  :)
Thanks for the update. I'll wait patiently now!  :thumb:
« Reply #334 on: Thu, 16 August 2018, 04:18:43 »
Interested to see the final color options!
« Reply #335 on: Thu, 16 August 2018, 04:22:15 »
Offline garbo
« Reply #336 on: Thu, 16 August 2018, 05:11:37 »
Oh, so there's no way to get one of the carbon fibre plates from the original BT PCB run? That's a shame :(
Offline wowremy
« Reply #337 on: Thu, 16 August 2018, 06:11:55 »
Any way to get the brown color?
Offline typischt
Offline cijanzen
« Reply #341 on: Thu, 16 August 2018, 08:43:21 »
what color is this?
https://cdn.shopify.com/s/files/1/0014/1934/6038/products/1_1024x1024@2x.jpg?v=1534347943
Grey blue
Are you sure? I actually think it‘s just grey.. It‘s always hard to tell with the CA66!
On second glance you’re right. Might be grey. At first I thought it was a mix of GMK Yuri and another set and the navy modifiers matched the case so I thought it must be navy but I realize now this is probably GMK Carbon which has grey mods. So yeah, grey case? 🤷🏼‍♂️
Offline bcbishop
« Reply #342 on: Thu, 16 August 2018, 08:46:07 »
Definitely looks like the grey case I bought last round.
Offline Taques
« Reply #343 on: Thu, 16 August 2018, 08:48:52 »
Whew, I'm glad the $340 price is all-in and pretty close to the original GB price. Don't think I could have made an extra $45 on top of that work.
Can't wait to put in my order!
Offline cijanzen
« Reply #344 on: Thu, 16 August 2018, 08:49:28 »
I don’t know if this was answered before, but how many devices can the Bluetooth pcb remember? And can you switch between devices?
Offline Vizir
« Reply #345 on: Thu, 16 August 2018, 08:55:10 »
@PlayKeyboardTW can you please mark which color is in each image of the keyboard. not, the samples, since those are hard to visualize, the full keyboard. maybe just write the color at the bottom of each keyboard image on the shop page.
Offline redjarojam
    • Instagram
« Reply #346 on: Thu, 16 August 2018, 10:33:59 »
One tear fell out of my eye when I didn't see brown in that drop down list. Dark red it is I guess.
Offline cijanzen
« Reply #347 on: Thu, 16 August 2018, 10:40:24 »
what color is this?
Grey blue
Just realized, at least on desktop, that the feature picture changes when selecting the colour from the dropdown menu. When you pick grey, then the picture you were asking about becomes the featured one so I guess that's the final answer!
    • Shop
« Reply #348 on: Thu, 16 August 2018, 10:46:00 »
It was not made by us. We did a little modification for both alu and brass plate for signal to pass through. ;)
We canceled it according to the quantity of last round. Sorry about that. :-X
what color is this?
It's a dark grey. The commercial color. :thumb:
Thanks! ;)
The BT module it used is for one device at a time only. That's the only disadvantage of it.
But the module is very efficient and supports far distance. Made in TW. :thumb:
We did it in product page. Now it shows up the color matches your color choice.
Some colors were not showed up. We will try to put them in asap. :thumb:
Offline roymt76
« Reply #349 on: Thu, 16 August 2018, 12:16:52 »
wait there is no gold rose like last GB ?
