Author Topic: [GB] Fox Lab Leaf 80  (Read 102410 times)
Offline senter
« on: Wed, 15 August 2018, 08:22:34 »
IC: https://geekhack.org/index.php?topic=96716.0
Leaf 80 - 80% custom keyboard kit
Information:
    • Default kit:
      • aluminu top and bottom cases
      • aluminum plate (MX or 1.2mm ALPS)
      • ATmega32A PCB with USB Mini
      • aluminum bottom leaf shape accessory
      • rubber feet and screws
  • Price for default kit: $320 without shipping
  • 2kg with aluminum bottom accessory or 2.8 kg with brass weight
  • 19mm front
  • 5.5 degree angle
  • Case layout: standard, WKL
  • PCB layout:
    • MX switches: ANSI and ISO for both WK and WKL
    • ALPS switches: ANSI WKL, staggered capslock
Colors
Case colors:
  • E-coating black *
  • E-coating white *
  • MAO white
  • Anodizing yellow
  • Anodizing red
  • Anodizing blue
  • Anodizing green
  • Blue=>purple gradient anodizing **
0. Brass: only available for plate and weight. Brass parts will be polished or sand-blasted.
* Electrophoretic coating (e-coating) is technically similar to powder coating but way smoother, even smoother than most anodizing. The black and white e-coating are both matte colors.
** Gradient anodizing: blue on left and purple on the right side. The proportion of two colors will be 5:5 to 7:3. The separation line of top and bottom housings won't be exactly the same.
- GB link on zFrontier: kit, extra parts
- GB opens until 08/25 Eastern Time (ET)
- Expected shipping date: November 2018
Update: As several people asked, I decided to make a small batch of leaf 80 without the "leaf" engraving on the top case. Please PM me with your order # and screenshot if you want to remove the engraving. [/list]
« Last Edit: Sat, 25 August 2018, 22:20:38 by senter »
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: [GB] Fox Lab Leaf 80
« Reply #1 on: Wed, 15 August 2018, 09:22:31 »
Approved :D
Offline senter
« Reply #2 on: Wed, 15 August 2018, 09:24:47 »
Offline s3vv4
« Reply #3 on: Wed, 15 August 2018, 10:01:49 »
Great price! Could you take photos with Cherry profile caps on?
Offline gt1989
« Reply #4 on: Wed, 15 August 2018, 10:10:16 »
Would the plate and pcb from this board work with the TIME tkl?
Offline senter
« Reply #5 on: Wed, 15 August 2018, 10:16:21 »
Will update photos in OP
Offline senter
« Reply #6 on: Wed, 15 August 2018, 10:16:35 »
Yes
Edit: the pcb works with Time TKL. the place doesn't
« Last Edit: Wed, 15 August 2018, 19:25:46 by senter »
Offline Etherealsound
« Reply #7 on: Wed, 15 August 2018, 10:25:11 »
Is it possible to get one without the leaf name imprinted on the top?
Offline nzhoward
« Reply #8 on: Wed, 15 August 2018, 10:35:10 »
are there any pictures of the PCB? is mx and alps pcb the same? i dont see any distinction being made on the order page
Offline senter
« Reply #9 on: Wed, 15 August 2018, 10:37:31 »
unfortunately no
Offline senter
« Reply #10 on: Wed, 15 August 2018, 10:38:53 »
The PCB is a revised version of the Time TKL PCB which supports both MX and ALPS. Some issues have been fixed in this version.
Offline //gainsborough
  • MATRIXの日常
« Reply #11 on: Wed, 15 August 2018, 10:40:39 »
What color is the plate/insert in the yellow prototype you have?  I thought it was silver or grey but neither of those are options.
Offline senter
« Reply #12 on: Wed, 15 August 2018, 10:44:35 »
That's MAO white
Offline nzhoward
« Reply #13 on: Wed, 15 August 2018, 10:48:16 »
are extra aluminum plates sold out already?? :eek:
  • MATRIXの日常
« Reply #14 on: Wed, 15 August 2018, 10:54:22 »
Bought one with extra PCB!  I'm so hyped!  Thanks, Senter!!
Offline senter
« Reply #15 on: Wed, 15 August 2018, 11:00:15 »
Hi nzhoward. You need to choose both of the two options.
  • MATRIXの日常
« Reply #16 on: Wed, 15 August 2018, 11:02:32 »
would the plate from the leaf80 fit inside a TIME TKL?  I'm thinking about taking this opportunity to upgrade my TIME TKL plate to brass.
Offline HappyCatFish
« Reply #17 on: Wed, 15 August 2018, 11:32:30 »
Hm, thinking about making this my first alu custom Alps build... Now to hunt for keycaps!
Offline senter
« Reply #18 on: Wed, 15 August 2018, 11:41:05 »
Time TKL plates can fit into leaf 80 but Leaf 80 plates won't fit into Time TKL.
Offline senter
« Reply #19 on: Wed, 15 August 2018, 11:49:44 »
It's a pity there are so few options for ALPS keycaps. I'm using AT101 caps right now. It's enjoyable to type on nice ALPS but AT101 caps are a little too thin for me.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #20 on: Wed, 15 August 2018, 12:01:58 »
What is the programming for the PCB like? QMK? BMC?
Offline aznreaper
« Reply #21 on: Wed, 15 August 2018, 13:13:14 »
Is the normal weight silver for all colours? Would have been nice to have it green by default
Offline Maxusy
« Reply #22 on: Wed, 15 August 2018, 13:53:29 »
Very nice to see a good custom kit without 8+degree angles! I love smaller angles (<5 ideally) and you guys are one of the few designers that make this type of keyboard.
The corners are a bit too rounded for my liking, but besides that it's a unique and beautiful design. Good luck with the gb.
b.face x2
Offline senter
« Reply #23 on: Wed, 15 August 2018, 13:59:42 »
can be programmed using BMC
Offline senter
« Reply #24 on: Wed, 15 August 2018, 14:00:43 »
The weight is in the same color as the plate.
Offline mkarlsson
« Reply #25 on: Wed, 15 August 2018, 14:01:37 »
+1 for smaller angles. I like something between 5 and 6 degrees.
And that price... it’s just too good to resist!
Offline bciamny
« Reply #26 on: Wed, 15 August 2018, 14:08:38 »
no numpad :(.
in for one though. thanks senter.
Offline meiosis
  • Time
« Reply #27 on: Wed, 15 August 2018, 15:02:16 »
Can we order it without the leaf writing engraving? D:
Keyboards:
Aripeko TKL
Offline codyeatworld
« Reply #28 on: Wed, 15 August 2018, 15:04:03 »
+1
Offline senter
« Reply #29 on: Wed, 15 August 2018, 15:49:32 »
+1
Offline Jkush463
« Reply #30 on: Wed, 15 August 2018, 16:45:25 »
snagged a yellow, is there a limited number or before this ends will i be able to snag another?
Offline senter
« Reply #31 on: Wed, 15 August 2018, 17:00:44 »
No limits
Offline MxBlue
  • buy my keyboard
« Reply #32 on: Wed, 15 August 2018, 21:30:13 »
A bit of a stretch, but any chance for a ANSI only plate?  :p
Just a bit tired of having a wonky pipe key haha.
Offline senter
« Reply #33 on: Wed, 15 August 2018, 21:40:47 »
No problem my friend. Just tell me the layout you want.
Offline nurupism
« Reply #34 on: Wed, 15 August 2018, 22:01:31 »
Senter, I notice that there isn't an option for an WK Alps kit. If I ordered the Winkey MX kit + extra Alps plate, would that offer WK Alps support?
Offline senter
« Reply #35 on: Wed, 15 August 2018, 22:12:40 »
The PCB was designed to support ALPS + WKL only. If you have some nice WK ALPS caps, I would suggest you to drill holes on the PCB and do the wiring. It requires some skills but it's feasible. I did it once. I can help you to change the case layout to WK if you want to do it. I can't guarantee it will work tho.
Offline FireBazooka
« Reply #36 on: Wed, 15 August 2018, 22:32:49 »
Will the brass have some kind of coating to protect it from getting a patina?
And is it possible to get a different color plate and insert color?
Offline GeneriksGiraffe
  • Living the Rubber Life
« Reply #37 on: Wed, 15 August 2018, 22:50:48 »
This looks amazing!! I just wish the GB didn't close in 10 days, I have to get my stuff together fast.
What case color/plate combo do you guys think looks best with a 9009/beige keyset?
SOMEONE PLEASE SELL/TRADE ME AN HHKB PRO 1
Offline spyruf
« Reply #38 on: Wed, 15 August 2018, 22:54:48 »
Any idea on how much shipping would be to USA? Would like to get an idea before I commit to purchasing.
Offline catamscott
« Reply #39 on: Wed, 15 August 2018, 23:24:24 »
glad the gb is finally started, now to just decide what color i want........man, this decision may take the whole gb period  :))
Offline bciamny
« Reply #40 on: Thu, 16 August 2018, 01:17:32 »
seriously. i'm still thinking about whether i made the right choice. i think the e-coating chance for this board is too good to pass up but i love the gradient effect.
Offline Peppermint216
« Reply #41 on: Thu, 16 August 2018, 01:19:39 »
It's great you have allowed this but now I have a hard decision to make :)). The font on the logo is beautiful but I do love a clean design.
« Reply #42 on: Thu, 16 August 2018, 01:20:55 »
Also any word on the pcb colour?
« Reply #43 on: Thu, 16 August 2018, 01:24:29 »
No option to select raw or bead-blast brass parts?
Offline senter
« Reply #44 on: Thu, 16 August 2018, 06:26:48 »
no coating and not possible
Offline senter
« Reply #45 on: Thu, 16 August 2018, 06:28:23 »
should be around $45
Offline senter
« Reply #46 on: Thu, 16 August 2018, 06:33:11 »
matte black
Offline senter
« Reply #47 on: Thu, 16 August 2018, 06:35:40 »
bead-blasting is the default option.
Offline Bubblegum
« Reply #48 on: Thu, 16 August 2018, 08:57:41 »
I'm in for the white/green combo! :)
Offline itskuroi
« Reply #49 on: Thu, 16 August 2018, 09:17:31 »
ordered! tried to resist but couldn't say no to a low angled board...
