Author Topic: SA Keycaps - Best Non-Linear Switch Compliment?  (Read 8083 times)
Offline Meowsaur
  • I don't like that.
« on: Thu, 23 August 2018, 18:47:09 »
TL;DR: What are the best non-linear switches to compliment SA profile key-caps?
Long Version: Traditionally my favourite Cherry switch is MX Green, but I want to branch away from Cherry for my next build and try something new. I have a board with SA profile caps on Zealios and I'm not too keen. Having a tonne of wobble on the stems due to the higher profile, exacerbated by the tactile bump, doesn't feel great. I'm keen not to make the same mistake again. I've heard that heavier is better when it comes to SA caps, and I'd like to go for a clicky switch if possible (tactile is an option if not).
Recently I had the opportunity to try out some BOX Whites.
I found the feel intriguing, but they felt a bit light with SA caps.
Would BOX Navy/Jades work well, with the thicker clickbar?
If so, which do you think would feel better?
This is all a matter of opinion, of course.
Interested to see what people think.
(Next build will be plate mounted if that makes any difference).
« Last Edit: Thu, 23 August 2018, 18:52:18 by Meowsaur »
Offline BobCarltheThird
Re: SA Keycaps - Best Non-Linear Switch Compliment?
« Reply #1 on: Thu, 23 August 2018, 21:11:25 »
I personally love the hell out of my CA66 with box Navies and SA Strong Spirit. It's just so much fun to use.
***loads of Vaseline for my meme TMO50 -- Acereconkeys
Offline Rubbermilitia
« Reply #2 on: Thu, 23 August 2018, 21:48:48 »
I really enjoyed box white with maxkeys SA WoB. But I have since embraced linears :)
Offline allofthemeat
« Reply #3 on: Fri, 24 August 2018, 09:49:39 »
Box Navys sound and feel great. They're my favorite switch by far. Just make sure you're ordering from NovelKeys to ensure you get new stock.
« Reply #4 on: Fri, 24 August 2018, 10:14:13 »
I just ordered some old stock box blacks off of reddit...how bad is the old stock in terms of destroying keycaps?
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #5 on: Fri, 24 August 2018, 15:40:00 »
I really wouldn't trust SA caps with them. They didn't outright DESTROY my Dashers, but it's not as if I'm going to put them on again or anything.
« Reply #6 on: Fri, 24 August 2018, 18:25:04 »
Hmm thanks for the info. It's a shame that I tend to love SA, lol. Why do they hurt SA and not other caps?
Offline ramblinrose
« Reply #7 on: Fri, 24 August 2018, 18:31:38 »
I personally didn't enjoy SA caps on my cherry clear board - much prefer that one with cherry profile pbt. I'm going to try linear switches for my SA set next, but otherwise I bet the click bar switches would be satisfying with them... but I don't plan to try kailh anytime soon after all the horror stories!
« Reply #8 on: Fri, 24 August 2018, 18:58:40 »
Yeah I enjoyed Kailh box white with my SA caps. What Kailh horror stories have you heard?
Offline zslane
« Reply #9 on: Fri, 24 August 2018, 19:59:55 »
https://geekhack.org/index.php?topic=96323.0
« Reply #10 on: Sat, 25 August 2018, 11:16:34 »
click bar switches because sound meme best meme
Offline chyros
  • a.k.a. Thomas
« Reply #11 on: Sat, 25 August 2018, 12:53:00 »
Well...
Offline Meowsaur
« Reply #12 on: Sat, 25 August 2018, 14:24:48 »
That is the biggest damn spacebar I've ever seen.
In any case. Looks like the consensus is new-stock BOX Navies.
I'm holding you all personally responsible if they're awful.
Not really - they were my more or less my default choice anyway.
Thanks all!
« Reply #13 on: Sat, 25 August 2018, 15:08:38 »
Thanks all!
I put box navies on my Contra and couldn't stand them. I'm gonna try to desolder them but I have to desolder the controller first which is gonna be a *****...
They're way too heavy and way too tactile
Offline zslane
« Reply #14 on: Sat, 25 August 2018, 17:05:01 »
Well...
Dang. That thing looks and sounds amazing!
Offline chyros
  • a.k.a. Thomas
« Reply #15 on: Sun, 26 August 2018, 09:05:37 »
Thanks all!
Just remember they're REALLY STIFF. If you don't like stiff switches, you'll hate them.
Well...
Thank you  ^^ .
