Author Topic: [GB] GRAY STUDIO- HB85(Finished)  (Read 84978 times)
Offline AIRPOTTER
  • Owner of Gray Studio
Re: [GB] GRAY STUDIO- HB85
« Reply #50 on: Sat, 27 October 2018, 07:21:39 »
I am actually liking the design. Daring and something new. Good luck for the gb!
Thks!
Offline poolside
« Reply #51 on: Sat, 27 October 2018, 13:32:20 »
The bottom-right blocker length is shorter in this render than on the Basic mockup or prototype pictures.
How long will it be on the actual production boards?
Offline pixelpusher
« Reply #52 on: Sat, 27 October 2018, 15:27:13 »
Good eye.  Looks like the board has a 6.25 space bar but the render used a 7u
Offline Jkush463
« Reply #53 on: Sun, 28 October 2018, 02:31:55 »
is there any way to add a mid to my order without getting nailed the 16.80 extra shipping?
Offline elmo
  • Hello I like keyboards
    • Elmo's keyboards
« Reply #54 on: Sun, 28 October 2018, 06:42:27 »
I was thinking about putting SA Lime on this board but can't decide on the colors.
Grey-Silver or Silver-Gray or maybe something completely different?
Any suggestions?  :blank:
Offline AIRPOTTER
« Reply #55 on: Sun, 28 October 2018, 06:54:43 »
Just a minute. I'll check with zf's customer service and get back to you.
Offline AIRPOTTER
« Reply #56 on: Sun, 28 October 2018, 06:56:15 »
It's a tough choice, but it doesn't matter. Give me a minute. I'll show you two renders on my computer, and then you can make a decision
Offline AIRPOTTER
« Reply #57 on: Sun, 28 October 2018, 08:00:48 »
OhOh!Oh, I just read it wrong.
About silver-Gray You can refer to these pictures.
More:http://www.zfrontier.com/post/detail/10123
Gray-silver
 I like  silver-Gray  more...
Offline elmo
    • Elmo's keyboards
« Reply #58 on: Sun, 28 October 2018, 08:13:39 »
Gray-silver
Hm yeah I think the Silver-Gray will fit the SA Lime the most. Going with green would probably be too much color.
Offline Poesjuh
« Reply #59 on: Sun, 28 October 2018, 08:22:51 »
Still kinda bummed that the blue isn’t darker :(
Offline elmo
    • Elmo's keyboards
« Reply #60 on: Sun, 28 October 2018, 08:33:11 »
I just saw the built video from KeyClack on Youtube and I'm a bit confused with the key placement options for the modifier keys (ctrl, alt, super) on the right side of the spacebar.
Is it possible to place two 1.25 keys and one 1.0 key there on the AOP version?
In the layout preview for AOP it looks like there are three 1.0 keys placed next to each other but that wouldn't work with SA Lime since it doesn't have the R3 keys in that size.
Edit: A higher resolution image of the PCB might be helpful for this.
Edit No.2: I took a close look at all pictures and it seems that the bottom row is 16.25 keys wide. With the STT layout having a 0.25 spacing between the left arrow and the rightmost modifier key.
So it should be possible to fit two 1.25 keys and a 1.0 key next to a 6.25 spacebar on the AOP layout. Or have I miscalculated that? :)
Layout would be:
1.25 1.25 6.25 1.25 1.0 1.25 1.0 1.0 1.0 1.0
« Last Edit: Sun, 28 October 2018, 09:13:21 by elmo »
Offline AIRPOTTER
« Reply #61 on: Sun, 28 October 2018, 12:01:32 »
Layout would be:
oops,layout is:
STT 1.25 1.25 6.25 1.25 1.25(0.5 block) 1 1 1 1
AOP 1.25 1.25 6.25 1  1 1 1 1 1 1
Offline elmo
    • Elmo's keyboards
« Reply #62 on: Sun, 28 October 2018, 12:29:36 »
oops,layout is:
hm ok so what I though about will not work.
Too bad that the lime set doesn't have enough row3 keys in single width size...
Edit: Just realized that there is the newer version of SA Lime by Signature Plastics that has more R3 modifiers in single width size. Will probably go with that even if it is more expensive.
Should be better anyways since the Maxkeys version had the bad crackling problems...
« Last Edit: Sun, 28 October 2018, 12:43:37 by elmo »
Offline AIRPOTTER
« Reply #63 on: Mon, 29 October 2018, 03:47:34 »
Oh, my fault.  This is the case, the rendering  is the old version (just to show the effect has not been updated, sorry), the layout diagram is a new version.
About the production cycle, This time it should be soon,in fact,the CNC of bottom shell has all been finished .
After the end of the GB, production and oxidation should be completed within 2-3 weeks. The rest is packing, because I try to lighten the overall weight.
Offline AIRPOTTER
« Reply #64 on: Mon, 29 October 2018, 04:02:13 »
I'm really sorry for that.
Offline elmo
    • Elmo's keyboards
« Reply #65 on: Mon, 29 October 2018, 05:20:51 »
Are there Pantone color codes for the case colors? Because I'm still not really sure about the gray.
In the black-gray comparison renders the gray mid-piece looks much darker than in the picture with the macbook (where it looks nearly white).
Edit: speaking of these two images.
Edit2:
Is it normal that the zFrontier support takes forever to answer emails?
« Last Edit: Mon, 29 October 2018, 12:06:24 by elmo »
Offline AIRPOTTER
« Reply #66 on: Mon, 29 October 2018, 20:51:23 »
Oh, customer service says: order and ask them to change the price.
Offline AIRPOTTER
« Reply #67 on: Mon, 29 October 2018, 21:04:51 »
Edit2:
It should be the problem of light :(. Look at this picture about gray.
« Last Edit: Wed, 31 October 2018, 07:42:07 by AIRPOTTER »
Offline Jkush463
« Reply #68 on: Mon, 29 October 2018, 21:30:07 »
Sweet bought it and they refunded the shipping, thank you! Very excited, cant wait
Offline mast3rwanderer
« Reply #69 on: Tue, 30 October 2018, 02:57:02 »
Will the nametag just have the boards name on it? ie HB85?
Offline mxgian99
« Reply #70 on: Tue, 30 October 2018, 09:49:16 »
hi, is the half-plate option only available for extra plates?  i don't see it as an option with the kit.
Offline AIRPOTTER
« Reply #71 on: Tue, 30 October 2018, 10:07:05 »
[/quote
I'll ask ZF's customer service. But it may take hours to get back to you (it's 11 p.m. in China now, it's off work and it's going to be back in the morning)]
Offline AIRPOTTER
« Reply #72 on: Tue, 30 October 2018, 10:08:53 »
aye,its HB-85 :)
Offline AIRPOTTER
« Reply #73 on: Tue, 30 October 2018, 10:10:13 »
Thank you for choosing hb85. I will send it to you as soon as possible.
Offline sleepybrett
« Reply #74 on: Tue, 30 October 2018, 10:44:29 »
No joystick cluster NO DEAL
Offline vewy_nice
« Reply #75 on: Tue, 30 October 2018, 11:16:24 »
Time for some modding, then?
Offline elmo
    • Elmo's keyboards
« Reply #76 on: Wed, 31 October 2018, 04:53:43 »
Does anybody how long it usually takes the support to answer mails?
I sent them a question about 3 days ago and still no answer.
I also replied to their autoreply yesterday to maybe bump the ticket in their support system but still nothing.
Getting ignored by the support is not really cool since the GB ends in a few days.  :(
Anybody know another way of how I can contact them?
Offline Skryzskruzzle
« Reply #77 on: Wed, 31 October 2018, 05:27:03 »
Id say that sounds about normal. I had a missing keycap from a JTK set I bought from them, and a representative (not bot) responded to me only after 6 days.
Once they do respond, theyre really helpful though.
Offline elmo
    • Elmo's keyboards
« Reply #78 on: Wed, 31 October 2018, 05:28:36 »
Yeah 6 days won't help at all since the GB ends in 4 days...
Edit: Guess I won't buy the board then. For such high-priced products I was expecting a little bit better support...
« Last Edit: Wed, 31 October 2018, 07:13:23 by elmo »
Offline AIRPOTTER
« Reply #79 on: Wed, 31 October 2018, 07:36:14 »
Er,say sorry frist. but it is really  make me a little dizzy, because I remember  I replied to your  question.
You asked me about the layout of the bottom line, and I replied.
You asked me about color, and I replied.
now I really don't know what kind of problem you are talking about?Now let me ask you a second question, and then I'll reply to you.
Offline AIRPOTTER
« Reply #80 on: Wed, 31 October 2018, 07:42:07 »
Sorry,man.I really don't know what problems you are referring to.
If it's about the MAXKEY, I can't help you either,because I don't know them  more than you.
If it is the color of the case, I  rember I have sent you many pictures.
Offline elmo
    • Elmo's keyboards
« Reply #81 on: Wed, 31 October 2018, 07:44:42 »
Dont' worry. It's not about you. You helped me great.
It's just something with zFrontier.
I asked them a few things about the shipping and customs handling and they simply do not answer any emails at all.
Offline AIRPOTTER
« Reply #82 on: Wed, 31 October 2018, 07:46:55 »
Really sorry to hear that...
Offline AIRPOTTER
« Reply #83 on: Wed, 31 October 2018, 07:48:08 »
Edit2:
OMG, are you talking about ZF?
If you have any questions, you can leave a message to me. I'll ask them.
Offline elmo
    • Elmo's keyboards
« Reply #84 on: Wed, 31 October 2018, 07:58:50 »
Yes I was talking about zFrontier :D
If they would reply to my email that I sent to contact@zfrontier.com I would already be happy.
According to the autoreply mail the ticketnumber is 7019
« Last Edit: Wed, 31 October 2018, 08:01:21 by elmo »
Offline AIRPOTTER
« Reply #85 on: Wed, 31 October 2018, 08:02:04 »
So depressed... :( :(
Offline AIRPOTTER
« Reply #86 on: Wed, 31 October 2018, 08:04:18 »
Oh, actually, I didn't contact them today either. They probably haven't seen your letter yet.
I also gave them a screenshot you , if they saw it, they would definitely reply.
Say sorry again...
Offline elmo
    • Elmo's keyboards
« Reply #87 on: Wed, 31 October 2018, 08:06:39 »
Say sorry again...
Thanks for the help :)
I definitely want this board so it would be a shame if something like this came in the way of it :D
Edit: Got a reply now and problem got solved :D
« Last Edit: Thu, 01 November 2018, 05:49:07 by elmo »
Offline Vermilionone
« Reply #88 on: Thu, 01 November 2018, 14:56:19 »
I just put in my order. This will be my first really premium keyboard and I have it mostly planned out already, so I'm super excited. I do have a question though. It is possible to add per-key LEDs, but will there be a way to adjust brightness?
Thank you
Offline tchalikias
« Reply #89 on: Thu, 01 November 2018, 16:11:43 »
Thank you
While this hasn't been clarified, the PCB clearly supports through hole leds for each switch and since it uses Bootmapper at the very least I think one will be able to adjust led brightness through the utility
Offline tchalikias
« Reply #90 on: Fri, 02 November 2018, 17:33:16 »
Well, I went ahead and took the plunge (Gray/Silver). My first expensive GB! Can't wait to tinker with it!
Offline AIRPOTTER
« Reply #91 on: Fri, 02 November 2018, 23:38:08 »
Thank you
Sorry, I saw the news. Yes, each axis has a LED hole,and it can adjust brightness.
And thank you for choosing hb85.
Offline AIRPOTTER
« Reply #92 on: Sat, 03 November 2018, 00:42:57 »
Thank you
Yes, absolutely!
Offline AIRPOTTER
« Reply #93 on: Sat, 03 November 2018, 00:44:19 »
Thank you for choosing hb85. It will not disappoint you.
Offline AIRPOTTER
« Reply #94 on: Sat, 03 November 2018, 07:51:51 »
Say sorry again...
Hwllo,did they reply to your email?
Offline elmo
    • Elmo's keyboards
« Reply #95 on: Sat, 03 November 2018, 08:32:45 »
Jep. Problem got solved and I placed my order yesterday  ;D
Offline AIRPOTTER
« Reply #96 on: Sat, 03 November 2018, 11:46:24 »
Wow! I'm so glad to help you!
Offline DoCallMeKing
Re: [GB] GRAY STUDIO- HB85(Last oneday)
« Reply #97 on: Fri, 16 November 2018, 11:28:53 »
On ZFrontier it looks like I can still order. Is that true? Is it in stock and shipping now since the group buy period is over?
Offline Aox
« Reply #98 on: Sat, 17 November 2018, 12:39:35 »
I just placed an order on zFrontier for a Red with black mid.
Will I get in the group buy?  I figure it had been extended since I could still order.
Offline Jkush463
« Reply #99 on: Sat, 17 November 2018, 16:54:51 »
just saw this as well and if i can still order i may grab another mid and plate  ;D
