Author Topic: [GB] An aluminium switch opener: The Nutcracker  (Read 83635 times)
Offline ilouis_07
  • Never Forget Your Origin
    • ILUMKB
Re: [GB] An aluminium switch opener: The Nutcracker
« Reply #50 on: Wed, 28 November 2018, 00:50:44 »
That was fast  :D
Is Kailh nutcracker compatible to all Kailh switches (I believe so  :p)?
yup, that is correct.
Offline ilouis_07
    • ILUMKB
« Reply #51 on: Wed, 28 November 2018, 18:55:58 »
more photos from production side.
从我的 iPhone 发送,使用 Tapatalk
Offline oh_chesteroni
« Reply #52 on: Wed, 28 November 2018, 19:06:25 »
I assume if it says "no" under invoice number that means the invoice will be generated at a later date? Also, would that mean that we did not make it into the early production round if it says "no" under invoice number?
Offline ilouis_07
    • ILUMKB
« Reply #53 on: Wed, 28 November 2018, 19:09:15 »
Hi “no” means I haven’t send invoice out yet. Will send it out later one by one :)
« Reply #54 on: Wed, 28 November 2018, 19:12:48 »
Offline ilouis_07
    • ILUMKB
Re: [GB] An aluminium switch opener: The Nutcracker(Last 3 days)
« Reply #55 on: Thu, 29 November 2018, 21:23:51 »
Last 3 days, thanks all for the support:3
Offline ilouis_07
    • ILUMKB
« Reply #56 on: Fri, 30 November 2018, 07:42:27 »
All the invoices sent so far.
Offline lovetree
« Reply #57 on: Fri, 30 November 2018, 11:07:38 »
OP, PMed.
Offline sythie
« Reply #58 on: Fri, 30 November 2018, 12:57:45 »
What is the grade of the aluminum used?
Offline RETURNISO
  • I do get excited about keyboard stuff..
« Reply #59 on: Fri, 30 November 2018, 20:13:03 »
Just ordered!  :thumb: is there any video of the nuts in the works?  :p
Offline a_ak57
« Reply #60 on: Fri, 30 November 2018, 20:47:47 »
Offline missylo
« Reply #61 on: Fri, 30 November 2018, 20:58:44 »
There are 2 videos in the IC link for the nutcracker!
(give me a while to dig up the link)
Edit: here you go!
https://geekhack.org/index.php?topic=98204.100
Sent using Tapatalk
« Last Edit: Fri, 30 November 2018, 21:00:20 by missylo »
Offline tunadesu
« Reply #62 on: Fri, 30 November 2018, 23:59:10 »
just joined! :o
Offline Luciqueii
  • 【Luciquell & Co.】
Re: [GB] An aluminium switch opener: The Nutcracker(Last 2 days)
« Reply #63 on: Sat, 01 December 2018, 13:09:17 »
I joined the GB now... and I would like you to declare 10usd to Sweden bcs of customs. Thanks!
Offline oldcat
  • 65% is Life
« Reply #64 on: Sat, 01 December 2018, 14:54:47 »
In for 2 MX and 1 Kaihua
Thanks Louis
Offline hammerbrotha
« Reply #65 on: Sat, 01 December 2018, 15:50:32 »
I see my name on the list (closer to the bottom). do you know when invoices will be sent out?
Offline Pitrek
  • deskpads gallery
    • deskpads gallery
« Reply #66 on: Sat, 01 December 2018, 16:27:14 »
Hi Louis,
I've been searching for such a tool for quite some time. I need to open plenty of switches to make keychains with my own keycap (a little gift for clackers who order my sleeves from Mechfashion) It's going to be very useful for me! Thanks for making these. I've had plastic, 3D printed one in the past, guess what happened 15 switches later ;-)
How much for shipping to Poland? Most likely I'm blind, but I couldn't find the price of shipping.
Offline RETURNISO
Offline missylo
« Reply #68 on: Sat, 01 December 2018, 20:52:40 »
Hi Louis,
Hi there,
Prices include shipping to a list of 39 countries. U will. See this list in the GB form (newly added feature).
If the country is not in the list, u can select #40. I'd suggest that you PM Louis here. He'll need to look up shipping for countries outside of the list.
I think it best you submit an order form first and then get in touch with him to work out the shipping charges (to countries not on the list).
Hope that helps!
Sent using Tapatalk
Offline neojonathan
« Reply #69 on: Sat, 01 December 2018, 21:21:46 »
Ordered two of these awesome tool !!!
Looking forward to these !
Offline oldcat
  • 65% is Life
« Reply #70 on: Sat, 01 December 2018, 21:24:34 »
Hi Louis,
Included i think
Offline oldcat
  • 65% is Life
« Reply #71 on: Sat, 01 December 2018, 21:25:28 »
Also in for one of each ! Guess i'll be in the 2nd production run tho.. any estimates on shipping for the 2nd batch ?
Hmm what do you mean? First production run is done?
Offline missylo
« Reply #72 on: Sat, 01 December 2018, 21:29:22 »
Hi there,
Batch 2 estimates are in the timeline section, written in between prices and shipping countries
Sent using Tapatalk
Offline missylo
« Reply #73 on: Sat, 01 December 2018, 21:32:14 »
Production for the first batch was underway before the GB started (I believe he linked to that post in this GB post. The original comment was made in the IC.)
Louis wanted a shorter GB time frame, so went ahead and began 400 (the 300/100) aka batch 1.
He'll produce as many that are ordered during GB though!
Sent using Tapatalk
Offline oldcat
  • 65% is Life
« Reply #74 on: Sat, 01 December 2018, 21:32:58 »
Sent using Tapatalk
nice thanks!
Offline missylo
« Reply #75 on: Sat, 01 December 2018, 21:42:29 »
Last 12 Hours to get your nutcracker!!!
Sent using Tapatalk
Offline missylo
« Reply #76 on: Sat, 01 December 2018, 21:44:08 »
Sent using Tapatalk
nice thanks!
Found where the links are: in the GB FAQ section up top
Sent using Tapatalk
Offline ilouis_07
    • ILUMKB
Re: [GB] An aluminium switch opener: The Nutcracker(Last 12 Hours)
« Reply #77 on: Sat, 01 December 2018, 22:46:02 »
Last 11 hours
Offline Luciqueii
  • 【Luciquell & Co.】
« Reply #79 on: Sun, 02 December 2018, 06:25:10 »
Last 11 hours
Bro I paid and joined the GB but can you declare 10usd to sweden and not 25usd please bcs of customs?
Thank you!
Offline Helcera
« Reply #80 on: Sun, 02 December 2018, 07:19:32 »
Last 11 hours
Thank you!
I can't believe you're trying to goad him into participating in tax evasion over like a couple of euros :D Or Kronor I guess, since you live in Sweden.
Offline ilouis_07
    • ILUMKB
« Reply #81 on: Sun, 02 December 2018, 07:40:44 »
Last 11 hours
Thank you!
will try
Offline ilouis_07
    • ILUMKB
Re: [GB] An aluminium switch opener: The Nutcracker(Last 4 Hours)
« Reply #82 on: Sun, 02 December 2018, 07:57:07 »
Last 2 hours:)))
Offline ilouis_07
    • ILUMKB
« Reply #83 on: Sun, 02 December 2018, 10:01:46 »
GB closed at 3rd Dec 00:00AM , Thanks everyone:3
Offline SomePunkassKid
Invoice paid.
Nice!
Offline ItsAllen
****, I just missed it.
Offline Oni74
Although i've a few switch opening tools, this looks too good to pass up - in for one!
Offline enrique.aliaga
Damn it... I just missed it
Any estimates of when (and if) are we going to get Round 2?
Offline dyka.tran
Actually this was round #2  ;D since the first round went out of stock way too quickly so OP had to open the #2 round right after that
Offline ilouis_07
    • ILUMKB
Batch one sold out in 13 hours. So I had prepared batch 2:) All consider as R1:)
Offline ilouis_07
    • ILUMKB
Guys, invoice will due by tmr. Pls pay the invoice before i cancel your order, Thanks.
Offline juaninamilli
The hard part will be putting all my projects on hold while I wait for this. lol
Sent from my Pixel 3 using Tapatalk
Offline Knxwledge
I can't believe I missed out on this!
Offline ilouis_07
    • ILUMKB
I just set up a server, for better communication and progress updates purpose, feels free to join:)
TianYue Lab Discord Link:
https://discord.gg/cdQfxt
Offline japanesehorrorwriter
I got billed for three but only needed two. Tried to reach out via email to reduce the invoice but never heard back so i just ended up purchasing all three. If anyone wants to buy my extra pm me.
Offline ilouis_07
    • ILUMKB
Hi,
You can pm me on geekhack. Me or my team may miss the email, apologize :p
Hi,
No worries. The extra was already sold. Will remember for next time!
Offline Vireca
It os posible to take a spot for one nutcracker? I think I'll need one for the new Holy Pandas
Offline gutsack
Is everyone in the checklist in batch one? Or does it still need to be determined?
Offline voight-kampff
yes, that would be good to know, who is in or who is out for whatever reasons
