Author Topic: [IC] Aluminum Switch Opener: "The Nutcracker"(GB is LIVE, Link in GB OP)  (Read 42167 times)
Offline ctrl
Re: [IC] Aluminum Switch Opener: "The Nuts"(compatible with MX & Kailh switch)
« Reply #100 on: Mon, 19 November 2018, 04:46:16 »
Does one of these support the opening of Outemu switches?
Looks like the Kailh cracker might work.
I think kailh cracker may work.
Could you test it with Outemu switches and let us know? Would be a total instabuy if it'd also cover those switches!
Would be awesome if the MX and Box openers can be "screwed" on and off the top, just a thought.
But either way, awesome job! Can't wait for the GB, this is a godsend :)
Hi it is a good idea and i also planned to do, but cost is much more then 2x individual crackers. So i stick with current one so far, thanks for your advice:D
You get this to cover MX, Kailh, Gateron and Outemu and I'd throw a sack of gold on you to include threading! It'd be a switch modding endgame tool! :cool:
Offline ilouis_07
  • Never Forget Your Origin
    • ILUMKB
Ok my partner on hands doesn’t have. I will buy some online and ship to him now. Wait for updates:)
Offline 82d28a
Not clear from pics and thread. Can you make one that opens both Kailhs and Cherry by rotating the switch by 90 degrees? This instead of 2 separate jigs.
Offline Gobluebro
« Reply #103 on: Mon, 19 November 2018, 08:30:21 »
Saw this IC on your instagram. Just confirming my interest on the thread.
Offline ilouis_07
    • ILUMKB
there are 2 type of crackers. Not one cracker can open both mx and kailh.
Offline 82d28a
But can you make one that opens both?  Seems like it almost could.
Offline ilouis_07
    • ILUMKB
I'd love to make a two in one nut cracker, but unfortunately it is not possible. This is because MX switches have 2 pins on both sides, and Kailh has 1 on each side. Both MX and Box have very different clasps. And to do one with both together is not possible because the front and back of the tops will be damaged.
Offline 82d28a
Ok. I am still in it for both. Thanks for the innovation.
Offline oldcat
  • 65% is Life
« Reply #108 on: Mon, 19 November 2018, 12:41:46 »
All in
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #109 on: Mon, 19 November 2018, 13:04:38 »
I'd definitely buy one. Looks neat.
Offline Korseir
« Reply #110 on: Mon, 19 November 2018, 14:48:16 »
Definitely interested
Offline mike-y
« Reply #111 on: Mon, 19 November 2018, 22:31:00 »
Also In.
Offline AIRPOTTER
  • Owner of Gray Studio
« Reply #112 on: Mon, 19 November 2018, 23:43:43 »
What an interesting tool!
Offline ian13
« Reply #113 on: Tue, 20 November 2018, 00:54:47 »
Will definitely buy this!
Offline neralo
« Reply #114 on: Tue, 20 November 2018, 01:52:10 »
Support Local! Seriously though, I would totally get one. Opened 300 switches last night with a pair of tweezers, my fingers still hurting.
HHKB Pro 2 55g | TGR 910 55g Vintage Blacks | Apple Standard M0116 Orange Alps | Rosewill RK9000 Cherry MX Blues | Diverge TM 2 WKLears
Offline enrique.aliaga
Totally in for two!
Offline PikaJoyce
« Reply #116 on: Tue, 20 November 2018, 02:41:09 »
It would be interesting to see this! I feel like you could combine the kailh and max switch opener all in one. One type of opener for each side and that way you'd have two caps on each end to cover the other side when not in use, if that makes any sense! Either way, I'd be totally down for one.
Offline _ODIN_
Gesendet von meinem H8416 mit Tapatalk
Offline catamscott
« Reply #118 on: Tue, 20 November 2018, 14:54:53 »
i have a switchcracker, but would hop on this in a heartbeat. the switchcracker does great on box-style switches but i still have to pry the tops off the cherry-style switches, and i just prefer the look of this over 3d printed plastic. i like the removable top on this too, seems like a nice place to put the top housing/spring/stem while lubing each switch. very excited for this!
Offline oh_chesteroni
This!
Seriously, please consider this.
Offline Acereconkeys
  • Happiness = life - expectations
This!
+1 for this. I'd love to at least hear how expensive doing something like would be. I would pay extra for it.
TMO50 | Jane V2 CE Incoming | Realforce 87u 55g | Aergo
Aergo design and build log: https://geekhack.org/index.php?topic=103681.msg2840918#msg2840918
Offline dPaK
« Reply #122 on: Tue, 20 November 2018, 20:58:04 »
Another for me! Looks cool
Offline ReverbSlush
  • 16/52 RNG score
« Reply #123 on: Tue, 20 November 2018, 21:01:55 »
I'd be down for one.... following this thread now.
Offline airlangga07
« Reply #124 on: Wed, 21 November 2018, 00:42:23 »
definitely join la
Offline ctrl
« Reply #125 on: Wed, 21 November 2018, 01:12:23 »
Awesome! Looking forward to the test results. :thumb:
Just to underscore, I'm in for both crackers, but if a two-in-one solution is at all doable, I'd be ok with the higher price.
I've often thought that considering the interest in building customs and switch modding, it's really strange there aren't more custom tools available. The tools that are available are either out of stock or 3D printed stuff. I think you're doing really important work to expand the keyboard builder's toolbox here. Thank you!
Offline ilouis_07
    • ILUMKB
« Reply #126 on: Wed, 21 November 2018, 07:05:16 »
Good idea! i will consider it for the next version:) Thanks
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #127 on: Wed, 21 November 2018, 07:16:12 »
Awesome design & name, LOL! Also I'm very glad to see this being made with metal, I have felt the same way about the 3D printed ones. I just have doubts that they'll stand the test of time, while there is no question with these guys. Awhile ago I was on the fence about switch openers like these as I could do just fine with the tongs from MK.com for MX style & a razor blade for Kaihl style. Although after getting my batches of Halos & opening 240 of them with a razor blade I am ready to grab something like this. Definitely will be in for at least one!
Offline Kerasan
« Reply #128 on: Wed, 21 November 2018, 07:25:17 »
oh yessa.... you created the panic with this "trinket"  :)) :)) :))
KMK Labs
Offline SolidCactus
I’m in for one!
Offline dario
  • obsessive–compulsive hardware slut
« Reply #130 on: Wed, 21 November 2018, 15:37:39 »
Will this be able to open Holy Jesus switches?
This is all I pray for.
Offline mkarlsson
Offline ilouis_07
    • ILUMKB
« Reply #132 on: Wed, 21 November 2018, 20:37:09 »
Kailh cracker Version 2 is prototyping now.
Offline hhkbp2
« Reply #133 on: Wed, 21 November 2018, 22:52:13 »
Interested. I wish it has a base attached to table or something so I could use it with one hand.
« Last Edit: Fri, 23 November 2018, 08:06:56 by hhkbp2 »
Offline Jae-3soteric
  • https://www.youtube.com/channel/UCAIHiFKJt69HNad6r
    • Jae | Top Clack
« Reply #134 on: Fri, 23 November 2018, 08:02:09 »
will def get one of these
Offline Jkshowman
« Reply #135 on: Fri, 23 November 2018, 10:13:56 »
oh ya, count me in
Offline Eldr1tch
« Reply #136 on: Fri, 23 November 2018, 11:30:57 »
Definitely interested.  :-*
Offline oldcat
  • 65% is Life
« Reply #137 on: Fri, 23 November 2018, 15:29:53 »
when will GB start?
Offline online
« Reply #138 on: Sat, 24 November 2018, 07:35:59 »
I'm in
Offline Gati
« Reply #139 on: Sat, 24 November 2018, 09:38:25 »
Any idea yet on the lead time on something like this?
Offline masterzen
« Reply #140 on: Sat, 24 November 2018, 10:41:52 »
I also have a switchcracker (which works reasonably well after a break-in period), but I'd prefer the metal finish :)
Count me in.
masterzen
Offline ilouis_07
    • ILUMKB
Offline dmxtrix
« Reply #142 on: Sat, 24 November 2018, 22:11:37 »
I'm in
Offline Sdhebert
« Reply #143 on: Sun, 25 November 2018, 08:01:59 »
I'm in.  Nice work.
Offline Kirkladc
« Reply #144 on: Sun, 25 November 2018, 16:33:37 »
I'm in for the mx nut.
Offline William_S_Jones
  • Best Prime Ever!!!
I’m interested in both switch opener models.
Offline ilouis_07
    • ILUMKB
GB will be today! And also production is in progress, to shorten the group buy period.
How long will your GB be?
Offline TheMastermind
Is this able to open both box switches and mx with one tool?
Offline ilouis_07
    • ILUMKB
Will be one week, From Monday 26th Nov to 2th Dec. Total 300 pcs cherry style and 100 pcs kailh style(box switch compatible). First come first serve.
