Author Topic: [GB] Doyu Studio Chiwi60 kit R2 - a 60% kit [DLC Stainless Steel][ED Aluminum]  (Read 81309 times)
Offline sennin32
    • Doyu Studio
[Update Mar 20 '19]
Hi,
We found we got some error paypal setting last week.
Some of orders can not go through.
This groupbuy will extend a week to late Mar :)
[End of Mar 20 '19]
Hey, everyone! I'm Shiang Yu from Doyu Studio.
This is group buy for Doyu Studio - Chiwi60 kit R2.
The Chiwi60  was conceived by the mechanical keyboard community member gok from New Zealand who named the keyboard after a colloquial term that was short for Chinese Kiwi.
The board is designed to have medium sized bezels with a 30 degree chamfer on the top face to provide visual interest to the most visible face of the keyboard.
30 degrees has been specifically chosen so that the top and side bezels still have presence from natural viewing angles despite the faces tapering away and also makes the keyboard appear shorter and sleeker.
The design aims to provide the keyboard with a seamless aesthetic and underglow that is integrated rather than just an afterthought.
A unique features of the keyboard are the optional dual 3u spacebar layout which allows for splitspace with convex spacebars rather than what you would usually have with the 2.25/1.25/2.75 split.
Pics
Pic from geeks!
See more images with larger size here!
PVD/DLC
Anodized
Some more
R1 products
Major changes in R2 :
  • Stainless steel instead of brass for DLC/PVD kitsDO60s PCB
  • Major parts made in Taiwan
  • Removed unpopular layout to reduce cutouts
  • Removed universal USB port option
  • Change to screw-in stabilizers
  • upgrade to DO60s PCB (Kit compatible with DO60)
Links :
Buying page : Check here
Interest Check Thread : https://geekhack.org/index.php?topic=92790.100
Group buy thread of round 1 : https://geekhack.org/index.php?topic=93969.0
Kit include :
  • Body
  • Mount plate
  • Bottom plate
  • Name plate
  • Screws
  • Round rubber feet
  • Manual cards
  • PCB
  • Glove(DLC body kit only)
Features/Specs/Design :
  • Non-floating
  • 7 deg angled
  • Aluminum Body /  stainless steel Body
  • Brass plate and name plate
  • PVD gold brass with mirrored polishing.
  • PC bottom plate with sandblast
  • 1.5mm thickness mount plate
Surface finishing:
  • Black DLC with mirror polished stainless steel.
  • Sandblasted raw stainless steel
  • Sandblast & ED aluminum for white
  • Sandblast & Anodized
*Why not powercoating for white one?
1. ED offer a thinner and controllable coating layer
2. ED is much more even than powercoating
3. Lesser human work, stable quality, powercoating rely on worker skill more
Add-ons and Upgrades :
  • Wedged shape bottom piece
  • Flat DLC/PVD bottom
  • Extra PCB and plate
  • Screw-in stablizers by Cherry
  • Other combination? contact us!
Wedged shape bottom design
Time frame & to do :
Collecting orders till : Mar 18 '19 Extend to late Mar
Est. deliver : Sep, '19
For more details please Find out on Trello
* stabilizer pack contains :
  • plastic part for up to 6 caps (Genuine Cherry parts)
  • 4*2u wires, 2*3u wires, 1*6.25u wire, 1*7u wire
Things you might want to know / FAQs :
  • Will XXX PCB fit this kit? :
    Quick answer : NO.
    Details : we made USB port fit with only 0.5mm tolerance for the cutout.
    That means no other PCB will fit the design unless they made their PCB based on out design.
    Which means the only 1 fit I know is PCB for Chiwi60 made by Maarten.
  • Shipping cost :
    put item into cart and you can check it before payment made.
    If it not shows up, contact us with following info, so we can check shipping table db and spot issue:
    1. Destination country
    2. Address include will be appreciate
    3. Order details include quantity.
  • Weight for kit(switches and cap included, cable not included)
    Aluminum : around 1.2 kg
    Stainless : around 1.8 kg
    DLC bottom : around 0.8~1 kg
    * weight might vary due to different layout or parts using
  • Will bottom and plate fit R1 ki?
    Yes, but we didn't list it.
    If you want one of them, please contact us include one of the following info, we'll check what layout you have :
    1. directly tell us your layout include pics (sorry, we found there's people confused with layout name)
    2. Order number
    3. Order mail (not paypal id if you use 2 mail address)
    4. Other info, ie. paypal transaction id, paypal user id, name of billing or shipping. (Other info might hard to find correct info or take longer time)
  • Will we run away with your money?
    Maybe A_A
« Last Edit: Wed, 20 March 2019, 21:53:43 by sennin32 »
Offline sennin32
    • Doyu Studio
Re: [GB] Doyu Studio - Chiwi60 kit - a 60% kit
« Reply #1 on: Sun, 24 February 2019, 02:11:23 »
update : 2019 Feb :
Update imgur gallery for R1 products.
Add sandblasted raw stainless steel bottom into upgrade option.
« Last Edit: Mon, 25 February 2019, 21:13:35 by sennin32 »
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
« Reply #2 on: Sun, 24 February 2019, 11:02:29 »
Approved, Gl w GB!
Offline sandragm
« Reply #3 on: Sun, 24 February 2019, 11:20:17 »
Which layout should I pick in order to include arrows?
Offline wixxzblu
« Reply #4 on: Sun, 24 February 2019, 11:30:49 »
I have the R1 chiwi, and it surprisingly is one of my best sounding board even tho others have said it sounded hollow, just wishing i could get my hands on the 6u hhbk variant this round, but it looks like this option have been scrapped.
Offline sennin32
    • Doyu Studio
« Reply #5 on: Sun, 24 February 2019, 12:05:12 »
Offline sennin32
    • Doyu Studio
« Reply #6 on: Sun, 24 February 2019, 12:06:24 »
HHKB has no arrow.
The rest has it.
Offline F2F4
« Reply #7 on: Sun, 24 February 2019, 13:28:05 »
Can I do split space hhkb?
Offline tunadesu
« Reply #8 on: Sun, 24 February 2019, 15:01:33 »
Any pictures of the Tiffany ano? I think it may be the wrong pic on the site when you choose the option
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #9 on: Sun, 24 February 2019, 16:49:38 »
I built a tsangan layout chiwi and I understand what you mean about the spacebar being thocky but I think you would lose it if the spacebar is shifted to the left since the switch would be close to the mounting point and make the spacebar sound less consistent.
Offline Minterly
« Reply #10 on: Sun, 24 February 2019, 22:25:20 »
What are the differences in the bottom upgrades?
Offline sennin32
    • Doyu Studio
« Reply #11 on: Mon, 25 February 2019, 12:12:21 »
1. 7 deg bottom : For better dsound
2. brass bottom : for those who want full metal kbs
work now :)
gallery updated.
Offline joe405
Will this work with other USB-C 60% PCBs? Would you add a no PCB option?
Offline sennin32
    • Doyu Studio
Both answer is no.
Offline ReAvenger
  • Sydney
If I opt for the DLC bottom as an upgrade, is there a way to get the regular pc bottom as well?
Offline gok_nz
  • Enjoy your PBT
    • Website
You can contact sennin for custom orders like that.
Offline Minterly
« Reply #16 on: Thu, 28 February 2019, 16:02:18 »
2. brass bottom : for those who want full metal kbs.
is brass bottom PVD/DLC option?
edit: I'd also be interested in PC bottom + upgraded option.
« Last Edit: Thu, 28 February 2019, 16:18:32 by Minterly »
Offline Bizpit
That Stainless Steel DLC Black option looks fantastic. I'd be all over this if it wasn't a 60%.
Any pictures of the 7 degree PC base vs the stock base?
Offline sennin32
    • Doyu Studio
Image added
Hi,
there's 2 options of stainless bottom.
1 is raw with lower price, and the other one is DLC.
Offline Minterly
What are the differences in the bottom upgrades?]
Hi,
sweet. any way to add extra bottom? kinda want the PC & DLC
Offline voight-kampff
Hi
can I use holties with the DO60 pcb?
thanks
How can I modify my order please?
Sent from my MIX using Tapatalk
Offline menuhin
If I cannot join this round, when will be the next round?
I really need the HHKB 6u layout - there are only 1 or 2 keyboard kit that support this true HHKB layout for now.
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline sennin32
    • Doyu Studio
msg me or mail sy_yang@doyustudio.com
Hi
thanks
some pads is cut by others, might not stable enough.
Otherwise, it should work nice.
new pcb will not solve this problem(PADs are cut and not complete), although we reduced layout, it still a lot.
Offline sennin32
    • Doyu Studio
Hi, guys!
We found we got some error paypal setting during last week.
How can I see if my order is O.K.?
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
Will the 6u HHKB top support the 2x3u Split layout?
7u is supported. So no 6u I quess
Offline menuhin
No 6u HHKB top???
I don't need to care about this GB anymore - and 7u top HHKB are also everywhere
IBM M13 black
HHKB Pro 2 HasuBT
Offline Blank
Does the Doyu split also support ISO layout?
I am really in into the sandblasted steel DLC version
it will be a really special board
Offline Blank
Is the RGB visible with the PVD/DLC bottom upgrade? Any pictures with that?
No 6u HHKB top???
The 6u top is right there on the store page. I think he just means you can't use the 2x3u spacebars with the 6u top.
Offline kakiharaOne
Has there been any updates to the plate since R1?  Not sure how big of an issue it was but apparently there was a bit of play when inserting the switch. Also will there be better QC on the plate finish? Most videos and photos I’ve seen have heeps of scratches.
Can anyone with an R1 confirm if these were real issues or just minor?
QC should be good now. They produce this in Taiwan with companies nearer to Doyu Studio, so it is easier and faster for QC.
I talked to Gok some days earlier, he said the plates will be changed to eliminate the problems.
Offline kakiharaOne
Was on the fence for those concerns so thanks for the feedback!
Offline DubbleYew
No 6u HHKB top???
Pretty sure you can do 2x3u. I found this while I was doing my pre-buy research.
https://www.reddit.com/r/MechanicalKeyboards/comments/7wquzp/chiwi60_hhkb_body
https://imgur.com/FaBbFy1.jpg
Sennin posted the second imgur link and it shows 2x3u is supported.
No 6u HHKB top???
Thanks.
Sennin, can you confirm that this layout is possible?
Edit: just talked to him on Discord, it's NOT possible. Look at the position of the switch cutouts -- the blocker would interfere with the switches.
« Last Edit: Thu, 21 March 2019, 22:20:23 by tex_live_utility »
Offline sennin32
    • Doyu Studio
Hi, No, sorry :(
It only support ANSI enter.
Hi,
PCB support it.
But we make 7u HHKB this time.
Since we've made 6u in R1. Give 7u a shot!
No 6u HHKB top???
Hi,
RGB will be blocked if you chose a full metal bottom upgrade.
No 6u HHKB top???
Sorry, we offer 7u this time.
It did has scratches on the plate during R1.
We modified some designs of plate.
Make it easier to do surface processing easier by reducing holes on.
Also, we find another manufacturer to make some brass parts samples.
Although the sample is not good because of too many times rework.
(grind too many times, inner side does not process properly in the beginning and it is hard to do it correctly again)
Surface treatment is pretty nice though except some impure spot.
Those lighter spot is easy to find with black DLC coating, that's why we use stainless steel to avoid it this time.
Plate is still brass. But gold is lighter, the spot with lighter color is not easy to find.
For scratches, new manufacturer is in Taiwan, we can compare and visit more companies which we've done and make decision.
Also we're able to monitor manufacturing and check for major steps before it finished.
Offline sennin32
    • Doyu Studio
No 6u HHKB top???
Thanks.
No 6u HHKB top???
Hi,
Sorry, this layout is available in R1.
We offer 7u HHKB in R2.
Quantity is not enough, we can't make 2 at the same time.
Offline DubbleYew
No 6u HHKB top???
Thanks.
No 6u HHKB top???
Hi,
So there is no option for 6u HHKB at all? This is an option on the buying page and I have already paid for it.
Sent from my SM-G955F using Tapatalk
Offline osamine
Does the chiwi60 support usb c to usb c?
Offline Aerizu
  • Professional Lurker
Hi,
Can you clarify if you will be offering 6u HHKB top for R2? Thanks!
Offline sennin32
    • Doyu Studio
Hi,
Might not be.
It has to be 10 pcs at least for each color...
If stainless orders are not enough.
We might make some origin HHKB layout and sell them later.
Won't make dessicion before May, unless there's 10 people want the same color for layout not that popular.
It's a little difficult, the only option might work should be white ED and stainless.
 But we will not order extra aluminum since the MoQ is not as hard to reach as stainless one.
Yes, it does have issue during R1 sampling.
But we've fixed it before R1.
It won't have issue in R2.
Offline gordonderp
Did the black chiwi reach the moq?
Offline sennin32
    • Doyu Studio
Stainless?
Around 10 short @Q@
Offline gordonderp
Stainless?
Around 10 short @Q@
Nah just the normal allu one
Offline sennin32
    • Doyu Studio
Stainless?
Around 10 short @Q@
Not reach MoQ, but only few pcs short.
I'm asking if manufacturer are willing to make it.
White is okay, tiffany blue will cancel.
Offline sennin32
    • Doyu Studio
Two days left from GB ends!
If you love this kit but not yet join it.
Check it now!
We'll make 15 kits of origin HHKB layout (with 6u space) with stainless steel.
Join group buy if you are interested in it :)
CHiwi60 : https://shopkey.doyustudio.com/projects/chiwi60
Buying page : https://shopkey.doyustudio.com/dy01b6
Offline gordonderp
Stainless?
Around 10 short @Q@
If the black one doesn't reach moq I down to change to the white if that's possible
