Author Topic: [GB]Volcano660 (Shipping in process)  (Read 114916 times)
Offline ilouis_07
  • Never Forget Your Origin
    • ILUMKB
« on: Tue, 05 March 2019, 10:24:44 »
Good day everyone!
Hi
it's ilouix_07,
Today, I am very excited to bring this project to the final GB stage, a keyboard which I was working on for half a year and it is also my first personal design:
Volcano660.
IC OP is here: https://geekhack.org/index.php?topic=97773.0
During this half a year project, we are proud to announce that the IC has been viewed 35k times and IC form has received 350 responses, thank you for all your support!
Volcano660 + GMK9009
top view
side view
PC version Volcano660 + Minimal
top view
angle view
(renders done by janglad)
Prototype:
Volcano Grey color + SA Carbon Keycap
Top view
Side view
Typing Sound videos:
GMK Keycap + Retooled Black lubed with Krytox 105&205
SA Keycap + Retooled Black lubed with Krytox 105&205
GroupBuy Link:(limited quantity FCFS, Alum 75 sets, PC 10 sets and brass 5 sets)
GB time will be:
9th March 8am EST /9PM SGT for PC/Brass Kits.
PC/Brass GB link: https://goo.gl/forms/gtMjCVLslBNwBZFm1
9th March 9AM EST/10PM SGT for Alum Kits.(one hour after than PC/Brass GB)
Alum GB link: https://goo.gl/forms/7dTbMbpuikSVpRvT2
Check List: https://docs.google.com/spreadsheets/d/1ekooNEGzRY9cAbULUd4TKG1PERSqm4drg_Fkap6hYyY/edit?usp=sharing
Pls note that there are 2 GB timing!!!!So 2 separate links!
Specifications:
1. Made with 6063 aluminum for case body, brass for plate and weight.
2. Original Gasket Mounting Design. (To read more about the gasket mount: https://goo.gl/LAHjJ6)
3. Typing angle is 5 degrees.
4. Nett weight of each keyboard case is approximately 2.1KG.
5. Premium materials will be used for the packaging of each keyboard. Boxes will include all case accessories inside eg: 16 pcs of rubber dampers, screws in M3 sizing and rubber feet.
Colors:
Volcano grey
Quantum blue
Electronic white
Carbon black
Rose gold
Wine red
Forest green
Color Samples Pic and Videos: https://imgur.com/a/Cz9WJ9r
Please note that there may be a slight color difference between the photo and the real product. So we have prepared a group of videos for all the color chip, it shows more angles of the color reflection.
About the weight design
PCB:
Volcano660 PCB, a QMK PCB designed by u/skullydazed @clueboards!
Matte Black color, arm processor with speaker, type C connector.
Made in USA
Layouts:
Plate:
Plate available for 2 versions: ANSI
and ISO
Price:
375 USD for default kit and PC kit, final price depends on the different crafts, price listed in GB order form. (exclusive PP fee and shipping)
625 USD for PVD full brass kit.
Default Alum kit: Alum top and bottom case, brass plate and weight (default will be sandblasted matte finish+ UV anti-oxidation coating)
PC kit: PC top and bottom case, brass plate, and brass weight.
Full Brass kit: Brass top&bottom case, plate, and weight.
Upgrade crafts:
Chroming for plate and weight (Silver Color, sample:https://imgur.com/a/TqBSJRS)
PVD for plate and weight (Brass Color)
Group Buy timeline:
Group Buy Opening Date: 9th March 2019
Group Buy Ending Date: 14th March 2019
The invoice will be sent in 5 days.
Shipping
Shipping invoice will be sent when the keyboard is ready for the shipping.
Estimated shipping time: middle of June 2019.
Q&A
Where is the LED indicators?
A: I have changed it to invisible micro holes, details: https://imgur.com/a/J7XYOFg
What Gasket we can use?
A: We will provide a set of gaskets for you, but you also can buy whatever gasket, silicon, rubber stripes with the same size we provided. It is not hard to find from the market. (Considered the gasket aging problem in, we have chosen the popular types of gasket instead of customized gasket)
How can I get the PC or brass during the google form GB?
Updates:edit on 7th March
A:many ppl are confusing about the previous solution. I have discussed with many users in my discord server, and here is the new solution: GB will be 2 different timing, same day(9th March)but 1 hour difference. First one will be PC/brass version, second one will be alum version). I will announce the PC/Brass winner few minutes after PC/Brass GB has finished, so all the participants will know whether you get in or out. Good Luck for everyone!
(Here is my solution: FSFC is the baseline, 75+10+5 is 90 pieces, if you are in first 90 orders, you can get the ticket(at least a set of alum kit, because I have alum MOQ and I can't give all of your PC or Brass, if I don't hit Alum MOQ, I am in trouble and I can't answer to factory, hope you can understand). So after choosing your first alum set, you can move to section 2 which is  PC or Brass or None.
At here, at least, you get an alum set.
Second, you can pick PC/Brass/None. It will be a multiple choice.
if you are fast enough(at first 10 PC picker or 5 Brass picker), You can buy (alum + PC, 2 sets) or (alum + brass,  2 sets) or give up your alum kit(Kit will give to No.91 buyer) and just take PC/brass.)
Working hard during this half a year for a project, now I am ready! Are you?
Thanks
iLouiX_07
instagram: https://www.instagram.com/louix_07/
TYL Discord: https://discord.gg/aBU3Zcy
« Last Edit: Wed, 09 October 2019, 02:09:57 by ilouis_07 »
Offline ilouis_07
    • ILUMKB
WINNER!!!
PC kit Winner:
otanishock(Geekhack)
u/abec13(reddit)
heskew(reddit)
Fublamchu(Geekhack)
mgsickler(Geekhack)
forstsiven(Geekhack)
konstantin#6505(Discord)
biothermal(Geekhack)
martink(Geekhack)
furikurichemy(Geekhack)
Brass kit Winner:
sallyday77(Reddit)
tear_rai(Geekhack)
Cornutgi(Geekhack)
g_mr_p(Geekhack)
pino38(Reddit)
Alum kit winners:
https://docs.google.com/spreadsheets/d/1vdhjVfiuV9rKPmMR7BxKcTMqIPZ65YLdwFS6JvBabhs/edit#gid=0
More about weight design
one-off weight design render: https://imgur.com/66Ezg4D
(The reason why I canceled this convex design/craft, it is toooo time-consuming and CNC fee is sky high, and the main reason is: it is very very very very hard to polish, maintain and etc, you can check this link for my one-off prototype: https://imgur.com/a/ia93PvO)
Personal, I want the thing to be unique, creative and perfect. But from this half a year project, it taught me that things cannot be THAT perfect. I just did my best!
So there is my solution for the weight:
https://imgur.com/a/iDDthrW
I have made a hard decision, same design but from convex type to concave type.
« Last Edit: Sat, 09 March 2019, 08:22:30 by ilouis_07 »
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Approved GL w GB
Offline Jinnnxxu
  • U only live once
Go TYL ! Go Volcano 660!!
Ins: Jinnnxxu     Discord:Jinnnxxu#9644
Exclusive: E8V1 | E7V1 x14 | E7-VX | E6V2 x1 | E6V2 PE x7 | E6.5 x9 | E7SE x3 | E8.5 x5
Matrix: 1.0RE | 1.2RE | Abel | Abel+ | Cain | 2.0 x8 | 2.2 x8 | Abel-x x4 | M6 x2 | 1.2OG x15 | Project F x2 | 2.0AD x15 | Noah x3 | Mr. Hat x3 | 2.0VK x1
Rama: M60-A x4 | M65-A x2 | M6-A 88edition | M6-B | KOYU x3 | M60-A SEQ2 X4 | M6-C x2 | U80 x5 | M10-C | M6-C | M60 LNY x2 | M60 Olivia x2 | M65-B x5
FOX: Leaf 80 x4 | Leaf 60 x4 | Key65 x5      TGR:Jane V2 | 910RE | Jane V2 CE x2     Percent: Canoe x3 | Maze x2 | Skog lite | Canoe FE x2
Others: Mira SE x2 | Jermini | C225 x2 | INETT Cross x2 | Kira 80 | Kira 60 | Zephyr 65 R2 | Space 65 x2 | Volcano 660 x3 | INETT Square80 x4 | INETT Square68 x6 | FMJ 80 x2 | Keycult No.2 x1 | Thermal x2
Offline V. Vega
I am ready.
Offline quinnx
Go Volcano go!!
Offline Dovan1405
les gooooo
Offline vegs
GL with the run, looks great
hhkb 4 life
buy less
Offline Kasterborous
    • HEX Keyboards
100% in for one. The PC render looks sick af, Good luck with the buy!
Offline kakiharaOne
How well would that blue go with GMK Bento? From the first photo it looks like a good match.
Offline urbantheii
 I can't wait!!!
Offline kakiharaOne
[GB] TYL Volcano660, an Original Gasket Mount Keyboard Kit, it is Coming!!!
« Reply #11 on: Wed, 06 March 2019, 08:07:51 »
Also...
« Last Edit: Wed, 06 March 2019, 08:10:29 by kakiharaOne »
Offline DetectiveNio
I call dibs!
Offline weirdzx
Bravo.I am glad to see keyboard designers pay more attention to the interior structure and the feedback from keyboard with stunning sound and touch feeling.Cant wait for the GB.
Offline konstantin
  • Formerly constexpr
Supported layouts: http://bit.ly/v660-layouts
The bottom row in the renders is 1.25–1.25–1.25–6–1.25–1.25–1.25–1–1–1.
Offline otanishock
  • One of the cool kids :>
  • ファーストラブ
I will get the #1 spot on both the alu list and polycarb list hihi  ;)
Edit: Will PCB be on the same package with the rest of the kit?
« Last Edit: Wed, 06 March 2019, 08:30:29 by otanishock »
Offline Rubbermilitia
Very excited to see this come to gb stage :)
Offline nhathoangJS
  • 60% WK is the best layout
Mama mia!
Let's the fight begin >.<
Tx60 Champage Gold w SA Chocolatier
Offline donut_sauce
that poycarb with minimal looks amazing
also the video ano samples is a fantastic idea. i think that presentation should be adopted more often since it gives a much clearer idea of the color👍
« Last Edit: Wed, 06 March 2019, 08:41:39 by donut_sauce »
Offline Mtalbert
Nice! GL with the GB
Big fan of Daeru
Offline moitorpsychoo
good luck with GB!!
Offline method_
Huuuuuuh...
...That polycarb looks insane.
thock program.
Offline obtuse
Very excited about this, that Quantum blue looks delicious!
Offline ilouis_07
    • ILUMKB
I am so excited to announce this GB and just now I found that I forgot about the weight design. Just updated*Pls check it!
Offline Jinnnxxu
  • U only live once
really glad for u louix!! GL volcano!
Offline JubJubCity
Gonna have to plan to get the PC  :))
Offline bthezebra
This looks fantastic ilouis can't wait!
Weird Flex but Ok
You did get two keycults so I would not be surprised.
Offline oldcat
  • 65% is Life
GLWS! Louis!
Offline oldcat
  • 65% is Life
Wow! Haha
Offline oldcat
  • 65% is Life
How heavy will this be for brass? Looks really hefty!
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
Such a thoughtful design. Good luck with this group buy :thumb:
Offline darko
Maybe stupid question (I’m newish here) but where does it ship from at the end? US, china.....?
Sorry I'm stupid.... just realised OP account details says Singapore, so I guess that's where it comes from....
« Last Edit: Wed, 06 March 2019, 14:42:29 by darko »
Offline eyedrop
What does the PCB with speaker do?
Offline kakiharaOne
Is the PCB a custom by Clueboard or the same/similar to the one sold on their site? It would be nice to know if something happens down the road and I needed a new PCB, it would be more readily available than waiting for an R2 or being SOL.
Offline tskiller
Def in for one. Up at 6AM for keebs, what a time to be alive.
Offline The_judge_168
Yup, going to be worth it though
Final weight looks good!
Offline TheMastermind
Any news on weather or not the outer case would have a slight slope? Not a huge issue just curious.
Offline oldcat
  • 65% is Life
OP is from Singapore but it may still ship from China where the factory is. It is a legit question I think.
Offline Fatboychard
Hyped for the board! Typing feel was amazing. I'm sure all kits will go fast.
Goodluck for the GB! :thumb:
Offline ilouis_07
    • ILUMKB
Amazing sound recording video done by fatboychard. Thank you!
从我的 iPhone 发送,使用 Tapatalk
Offline RubMyKoala
I was so close to buying the Rama m60A. Definitely getting this instead, the plate design is beautiful. Plan to pair GMK Wavez with the forest green aluminum.
Offline ilouis_07
    • ILUMKB
Approved GL w GB
Thanks my man!
Offline ilouis_07
    • ILUMKB
A: yes, pcb will be bully shipped from USA to China first!
Offline ilouis_07
    • ILUMKB
Thank you for your hard work in discord server my man!
Offline ilouis_07
    • ILUMKB
hi, this is a good question and let me explain:
The Volcano PCB is customized by clueboard team, we did some adjustments for USB port, added 3 led slots and etc. But I have talked with skully from clueboard. They will change their 660 PCB design to V660's type in the future. (Confirmed with skully few mins ago)
Offline jortzii
So excited for this GB! It will be my first and that green will be mine!
Volcano660 | Satisfaction75 | Think6.5 | TGR Jane V2 CE | Preonic | IC Kira | Drop ALT
Offline kakiharaOne
That’s great news! Thanks for the follow up!
Offline method_
Makes me cry a little bit inside knowing that only 10 people will own that PC version..
thock program.
Offline voxkey
Will extra PCBs and/or plates be available during the GB as extras? And if so, how much?
Offline forstsiven
Fingers crossed for a polycarb version. Super excited this has hit groupbuy stage. Congratulations on getting this far!
