Author Topic: [IC] GMK M_ss_ng K_ys (Kit Updated)  (Read 32079 times)
Offline pngu
  • send noots
« on: Sat, 08 June 2019, 13:25:14 »
Hi there fellow Geeks! Posting on behalf of Discord user jani80k#5980 whose idea this set was. He talked to Wodan at Clack in Cologne about releasing a fix kit for OG sets, which was approved, so long as it isn't named HADapter. So without further ado, let me introduce
GMK M_ss_ng K_ys
Old kit proposal:
Goals of this set
  • Convert vintage Cherry ISO sets to ANSI
  • Provide compatibility for smaller form factors (60/65/75)
  • Convert vintage text+icon mod ANSI sets to icon mod ANSI sets
  • Act as a mod kit for obscure layout vintage boards so their alphas can be used in modern layout builds
  • Maintain a reasonable price point
To be figured out in this IC
  • Keys to add
  • Keys to remove
  • General interest
If you're interested in this set, please take a second to fill out this google form and/or leave any feedback as a reply to this thread.
Availability, GB Timeline and Prices
EU Proxy: mykeyboard.eu
NA Proxy: cannonkeys.com
Other regions: If you're a vendor from another region and want to proxy this set, please get in touch with jani80k#5980 on discord.
MOQ: 150
Price: TBA
GB Timeline: TBA
Changelog
  • 2019-06-09: Fixed mixup in the render (PgUp and PgDn are now R2 and R3 as intended), fixed set name (apparently it could be read as something that's not very nice), fixed form link
  • 2019-06-28: Updated kit based on IC feedback
« Last Edit: Sat, 29 June 2019, 05:58:15 by pngu »
Offline jani80k
  • In the hobby for a good time.
Re: [IC] GMK M ss ng K ys
« Reply #1 on: Sat, 08 June 2019, 13:26:22 »
Thanks for the help pngu!
FAQ
What is the target price?
The goal is to keep the set reasonably small and the price as low as possible. Will keep you updated once I have more info.
What are the color codes?
Alphas: L9 base, CR legend
Mods: U9 base, CR legend
Example of an Cherry OG Keycap set?
This is what we get in Germany usually.
Are you not stealing from Wodan?
No, he approves and appreciates this GB and will even buy some kits.
« Last Edit: Tue, 11 June 2019, 07:09:54 by jani80k »
« Reply #2 on: Sat, 08 June 2019, 13:28:52 »
target price?
Offline Emir
  • icon mods
  • Bandit
    • Discord
« Reply #3 on: Sat, 08 June 2019, 13:49:35 »
In  :cool:
Offline jihadu
« Reply #4 on: Sat, 08 June 2019, 14:02:19 »
Cool
Offline dexie
« Reply #5 on: Sat, 08 June 2019, 14:22:06 »
I was just recently looking for fix kit, and here we go! Definitely in!
ISO Life
Offline wixxzblu
« Reply #6 on: Sat, 08 June 2019, 15:12:42 »
mod colored tilde and pipe? otherwise i dont see any problems with this kit, it looks amazing  :thumb:
Offline manzel
« Reply #7 on: Sat, 08 June 2019, 15:36:40 »
Do the molds for R5 'Code' and 'Menu' exist? Carbon used 'Super' and 'Meta', which I also prefer. Apart from that, I second mod-coloured tilde and pipe.
Offline Warrenified
« Reply #8 on: Sat, 08 June 2019, 16:49:04 »
I think this is a great idea! I'd be in :)
Offline bnhw
« Reply #9 on: Sat, 08 June 2019, 17:01:46 »
The kit looks great either way, but would you consider adding a 1.25u R3 key to make it compatible with a whole bunch of staggered 40% keyboards?
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #10 on: Sat, 08 June 2019, 19:26:36 »
In for multiple sets easily.
That said, +1 to the 40% key.1.25 R3 key for 40s compat.
I also think I'd prefer the classic text + icon rather than just icon.
Edit: your Google form link doesn't work
« Last Edit: Sat, 08 June 2019, 19:28:14 by tex_live_utility »
Offline glubazoid
« Reply #11 on: Sat, 08 June 2019, 20:12:47 »
This is cool, I'd be in
Offline depletedvespene
    • Keyboard-related resources.
« Reply #12 on: Sat, 08 June 2019, 20:14:02 »
In! Terested!  :thumb:
Can we consider adding R2 PgUp, R3 PgDn and R4 End?
What will be the exact color codes for the caps and legends?
Will this be "M ss ng K ys" or "M ss ng K ys", if you know what I mean?  :D
Offline OracleKev
« Reply #14 on: Sat, 08 June 2019, 21:27:06 »
Can you do some analysis on a single large kit versus multiple small kits?
HAD adapter was like 20 euro and pricing picture is different nowdays.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #15 on: Sat, 08 June 2019, 22:14:39 »
Offline yui_
« Reply #16 on: Sat, 08 June 2019, 22:15:56 »
7u spacebar?
Offline cldskt
  • Wallet and hobby aren't friends
« Reply #17 on: Sat, 08 June 2019, 22:37:22 »
7u spacebar?
This is usually already included in the og sets.
"Addiction is buying the things that I don't need with the money I don't have." - me
"Spending $500 on your first custom is justified." - also me
Offline wodan
« Reply #18 on: Sun, 09 June 2019, 01:56:14 »
Thanks for running this :)
Love the R5 keys!!!
Offline pngu
  • send noots
Re: [IC] GMK M_ss_ng K_ys (Form link fixed)
« Reply #19 on: Sun, 09 June 2019, 02:54:42 »
Thanks for all of your feedback. The form link has been fixed, please consider filling out the form if you're interested, thanks. All suggestions will be taken into account.
That's a good point, we'll get in touch with GMK and find out if those molds exist. If they don't, to keep cost low, the set would be updated to use Super/Meta instead of Code/Menu.
« Last Edit: Sun, 09 June 2019, 02:56:34 by pngu »
Offline Acereconkeys
  • Happiness = life - expectations
« Reply #20 on: Sun, 09 June 2019, 03:06:37 »
I'd prefer it be icon + text, but cool project. Always nice to have more options to utilize all the great OG iso sets out there. Also what's the point of the "control" key if the sets icon mods? Am I missing something?
TMO50 | Jane V2 CE Incoming | Realforce 87u 55g | Aergo
Aergo design and build log: https://geekhack.org/index.php?topic=103681.msg2840918#msg2840918
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #21 on: Sun, 09 June 2019, 03:55:52 »
Yeah I think I'd rather have that be a stepped key with the down arrow icon.
(God forbid the Purse Lock)
Offline Poesjuh
« Reply #22 on: Sun, 09 June 2019, 05:21:34 »
This should be icon+text imo, and I second the motion for mod colored tilde and backslash.
Other than that, great idea, very usefull. Price will be the main factor here I think.
Offline ctrlshiftba
    • ctrlshiftba
« Reply #23 on: Sun, 09 June 2019, 05:52:22 »
Thought about adding more kits for ortho or 40’s?
Offline appaboy
« Reply #24 on: Sun, 09 June 2019, 06:07:28 »
Very much in, but i would much prefer a windows logo (preferably 7) to the 'code' legend, similar to hadapter
PC Singa, MIR80, TX84se, g80-3314, g80-0427, g80-5000 + 5700, G80-3700, g81-3000 HBU (og wob)
HASRO keycaps
OG POM keycaps
SAI OG Italian dyesubs
Scarface Fn blank
Offline yui_
« Reply #25 on: Sun, 09 June 2019, 08:15:50 »
7u spacebar?
OG 9009 has 8u spacebar, though I suppose there is HADapter for that set, it's just harder to find now which is why I would have liked the 7u support in this set.
Offline megaforce
« Reply #26 on: Sun, 09 June 2019, 11:38:13 »
ne iso avial?
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
Offline SlipperyPeteED
« Reply #27 on: Sun, 09 June 2019, 13:05:15 »
Wow this is an awesome idea! Cant believe nobody has thought of this before now!
Offline hineybush
  • student of error
    • hineybush keyboards
« Reply #28 on: Sun, 09 June 2019, 13:19:21 »
Ne wkl/tsangan bottom row avail
Asking bc a decent amount of the cheaper/easier to find boards will have the 6u+1u bottom row or the 6.25-based with off-center caps etc.
« Reply #29 on: Sun, 09 June 2019, 16:24:27 »
1800 baybee
Offline Applet
« Reply #30 on: Sun, 09 June 2019, 16:48:14 »
;In for sure. Any chance to get a 1u U9 grave "~" key, for 60% symmetry?  :cool:
Personally, I'd prefer the text and icon legends, but this is fine :D
« Last Edit: Sun, 09 June 2019, 16:50:58 by Applet »
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #31 on: Mon, 10 June 2019, 20:28:37 »
GMK M_ss_ng K_ys
Goals of this set
  • Keys to add
  • Keys to remove
  • General interest
MOQ: 150
Price: TBA
GB Timeline: TBA
Changelog
Just my thoughts
Offline otanishock
  • One of the cool kids :>
  • ファーストラブ
« Reply #32 on: Mon, 10 June 2019, 22:40:52 »
Ever thought of just running a full GMK OG Cherry set instead of just add-ons? I would be into that!
Offline appaboy
« Reply #33 on: Mon, 10 June 2019, 22:42:58 »
gmk 9009 and gmk classic retro exist, im not sure if i misunderstood what you asked though
HASRO keycaps
OG POM keycaps
Scarface Fn blank
Offline ArchDill
« Reply #34 on: Mon, 10 June 2019, 22:44:56 »
That with JP subs is the dream. Would love to have a set like that.
Offline Emir
  • icon mods
  • Bandit
    • Discord
« Reply #35 on: Tue, 11 June 2019, 13:32:49 »
I suggest to run a WoB Icon kit together with this in a separate kit.
A lot of people have been waiting for another run of that since the first buy in 2016. I feel that it's time to move on and stop waiting for the original runner to do it again (last login was 2017 on GH).
Please consider it.
Offline tron
« Reply #36 on: Thu, 13 June 2019, 14:47:29 »
I have an OG Cherry set but some of the alphas are scratched a bit due to age. An option to get a full kit would be great. IMO there is no need for the 9009 accent keys and extended compatibility, just a basic set for most people with TKL or 60 percent boards.
Offline guzzi
« Reply #37 on: Fri, 14 June 2019, 08:23:17 »
Agreed.
In for one, two if the price is right.
Offline cdaman
« Reply #38 on: Sun, 16 June 2019, 10:00:58 »
I like! I'm in!
Offline phinix
« Reply #39 on: Mon, 17 June 2019, 08:30:17 »
Cool, AS I have ISO set of these, would be good to have ANSI caps to complete the set.
Offline vikipedeer
« Reply #40 on: Mon, 17 June 2019, 22:47:43 »
yes please
Current board:KBD75V2, Whitefox, Time TKL
say yes to bacon overlord
Offline vegs
« Reply #41 on: Tue, 18 June 2019, 03:28:07 »
I'd be in for at least a couple of sets :thumb:
hhkb 4 life
buy less
« Reply #42 on: Tue, 18 June 2019, 08:48:41 »
I'd still prefer a minimal $35 addon/fix kit over a full blown $75 mod kit.
Offline OracleKev
« Reply #43 on: Tue, 18 June 2019, 09:15:25 »
Agree. Better to wait for something like 9009 R2 rather than $75 mod kit
Offline vikipedeer
« Reply #44 on: Thu, 20 June 2019, 00:49:42 »
2U shift please?
Offline japanesehorrorwriter
« Reply #45 on: Sat, 22 June 2019, 15:11:49 »
Finally. Love this. In for 3x at least.
Offline gfreeman11898
« Reply #46 on: Sat, 22 June 2019, 17:44:49 »
I need this in GMK WS1 on N9 for my Originative GMK Dolch.  :thumb:
Offline Applet
« Reply #47 on: Mon, 24 June 2019, 08:38:32 »
Any plans for adding a U9 tilde/pipe key?
I'd also prefer "super" instead of "code" legends.
« Last Edit: Mon, 24 June 2019, 08:41:25 by Applet »
Offline PlastikSchnittstelle
« Reply #48 on: Mon, 24 June 2019, 12:10:31 »
FINALLY!
I need this badly,
please hurry  ;D
Offline Mcnos
    • GMK Fuyu
« Reply #49 on: Mon, 24 June 2019, 12:29:41 »
I want in just so I can add this to other sets as well.
