Author Topic: [IC] IRON165 by Smith + Rune (GB Dates/Times / FE Raffle Announced)  (Read 327649 times)
Offline 1023andy
Re: [IC] IRON165 by Smith + Rune
« Reply #50 on: Thu, 04 July 2019, 20:44:06 »
WIll there be color options for the logo?
Offline rohangpatil
« Reply #51 on: Thu, 04 July 2019, 20:52:53 »
In
Offline Abdallah9
« Reply #52 on: Thu, 04 July 2019, 20:55:39 »
This looks so beautiful. Definitely interested.
Offline Abdallah9
« Reply #53 on: Thu, 04 July 2019, 20:56:52 »
Definitely buying this.
« Last Edit: Thu, 04 July 2019, 21:03:21 by Abdallah9 »
Offline EMC Labs
« Reply #54 on: Thu, 04 July 2019, 21:39:07 »
This looks amazing! Just waiting to see the price.
Offline luumii
  • A day in life without Keyboard SA
« Reply #55 on: Thu, 04 July 2019, 21:40:02 »
Looks amazing, definitely in for this!
Sent from my SM-G973F using Tapatalk
Offline kitty
« Reply #56 on: Thu, 04 July 2019, 21:54:25 »
very luxurious!! any estimates on when the GB would run, hoping it'll be a while so my wallet has time to recover from all the recent keycap GBs :)
Offline AlcoholEnthusiast
« Reply #57 on: Thu, 04 July 2019, 22:13:54 »
Hoyl ****! This is absolutely gorgeous. I knew you were working on something but this surpassed my wildest expectations. Can't wait to see this GB move forward, and can't wait to see what the final product looks like!
Offline leexy
« Reply #58 on: Thu, 04 July 2019, 22:47:06 »
missing a key m8
Offline cygnus21
« Reply #59 on: Thu, 04 July 2019, 22:54:27 »
That polished copper is going to be hot.
Offline PotatoTM
« Reply #60 on: Thu, 04 July 2019, 23:02:42 »
Why 02 in the top right corner of the back?
Offline toake_01
« Reply #61 on: Thu, 04 July 2019, 23:08:18 »
Love it! Especially that clean white!  But the polished copper badge is bordering pink and it might not match alot of keysets...do you have plans for other colors?
Tapatalk を使用して私の CLT-L29 から送信
Offline KeyT
« Reply #62 on: Fri, 05 July 2019, 00:30:40 »
I love this.
나의 SM-G965F 의 Tapatalk에서 보냄
Offline MatthewPham
« Reply #63 on: Fri, 05 July 2019, 00:37:28 »
I assume we're looking at prices upwards of 600?
Offline happycamper87
« Reply #64 on: Fri, 05 July 2019, 00:39:56 »
This looks amazing. Hopefully, the price won't be too high ($300) or less. A guy can dream.
Offline EMC Labs
« Reply #65 on: Fri, 05 July 2019, 01:15:52 »
That's what I'm hoping. I guess we'll see soon enough.
Offline MatthewPham
« Reply #66 on: Fri, 05 July 2019, 01:41:10 »
copper base and steel top pretty much ensures it's gonna be pretty expensive sadly.
Offline Walnut
« Reply #67 on: Fri, 05 July 2019, 01:43:07 »
this is legit gorgeous. im in for one
Offline Full
« Reply #68 on: Fri, 05 July 2019, 01:50:18 »
It is the limited board numbering, board #02
Hi!
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
« Reply #69 on: Fri, 05 July 2019, 02:38:54 »
Hope ISO support is added in the GB, but the plate files are an alright backup.
Offline gautema
« Reply #70 on: Fri, 05 July 2019, 02:54:22 »
Only the FE has copper base and steel top. This will not be under $300. It will probably be at least twice that. The regular might hit a lower price point, but I'd be really surprised if it was sub $300
Offline teonchien
« Reply #71 on: Fri, 05 July 2019, 05:37:01 »
Interested!! Hoping the price is affordable.
Offline lbaron
« Reply #72 on: Fri, 05 July 2019, 07:47:00 »
That was just an example of numbering for serializing the units. So it’ll start at 01 and go up. We felt doing a 01 / XXX was too busy
Offline EMC Labs
« Reply #73 on: Fri, 05 July 2019, 07:52:51 »
Good idea.
Offline Surefoot
« Reply #74 on: Fri, 05 July 2019, 09:11:09 »
Is there a clear coat or PVD on that copper ? It will get green-ish then black after a while if not protected...
Offline voxkey
« Reply #75 on: Fri, 05 July 2019, 09:32:45 »
Good morning, everyone! Going to try and answer all the questions/concerns posted so far.
"limited quantity" again... :mad:
This is one of the hardest problems to solve unfortunately. While we'd love to make as many boards as needed, it simply isn't feasible when managing risk. As quantity grows so does our financial responsibilities as well as the infrastructure needed to facilitate it. While the FE will be very limited and only ever run once, we'll do our best to make available as many of the standard version as we can handle. If there is still demand after the first run, we will likely run a round 2 at some point in the future as well.
Thanks for the feedback, all.  I own the 268.1 and it is indeed almost exactly flush from case top edge to bottom of GMK caps.  Don’t suppose we convince you to adjust the design closer to 7.5mm? Especially since the inner edge has a fillet
We're still actively talking about this right now. The current idea on the table is to slightly increase the height of the top shell to allow keycaps to recess a bit further without adding any height to where the keycaps themselves sit, so only a visual change without any change in ergonomics. As Xondat mentioned, 7mm may not be enough, but anything over 7.5mm might be too much.
Is that rose gold plate and weight going to be in the gb?
The "rose gold" plate/weight pictured in the renders is supposed to represent mirror-polished copper which is the materials we've chosen for the Founder's Edition of the board. I think Abec did a great job capturing that on the renders.
Any idea about prices?
We are still waiting to hear back from potential manufacturers so I don't want to commit us to any pricing just yet. With that said, our goal is for this to remain a hobby and not replace our day jobs, which gives us room to play with the prices. We've already made some internal changes to reduce machining costs based on recommendations from potential manufacturers and will continue to do so as long as it does not compromise the function or design of the board. You can safely expect the Founder's Edition of the IRON165 to be very expensive given the materials we're using and the increased machine time.
We are still exploring color options for the standard edition release, but the Founder's Edition will likely only have mirror-polished copper be an option for the rune badge.
No estimates for a GB timeline just yet. There is still lots do before setting a date. Once we have a date, we will announce it well in advance though.
The plan is to coat the copper and we're leaning towards clear cerakote right now. It's really, really cool. A raw option will likely be available upon request. Personally, I'd love to see one with intentional patina. Patina on copper can look really amazing.
Offline phlux
« Reply #76 on: Fri, 05 July 2019, 09:44:47 »
This seems to fit the bill perfectly for what I've been looking for. Do the renders only depict the founder's edition, or will the standard edition look the same just with different materials?
Offline jeejax
« Reply #77 on: Fri, 05 July 2019, 09:57:21 »
This looks completely amazing. I am digging the norse rune logo a ton.
Offline voxkey
« Reply #78 on: Fri, 05 July 2019, 10:10:02 »
Sorry for not having renders of the standard edition ready for the IC :(
We haven't settled 100% on the final design for the bottom and base of the standard edition, but you can expect an aluminum top shell, aluminum bottom base, and likely a big brass weight.
Functionally, it will be the same board though.
Offline TheMilkmen
« Reply #79 on: Fri, 05 July 2019, 10:41:28 »
the amount of engineering going into this board shows that we may have crossed into a new generation of keyboards here lol
no longer are they just tools that look or sound nice, its also that there is science behind the creation and more or less actual innovation and change for the modernity of keyboards, that said, I am for sure down on this board.
Offline frostfiree
« Reply #80 on: Fri, 05 July 2019, 14:09:04 »
Wow, I am in on this board if I could get my hands on it. Haven't felt this way about a 65% in awhile.
Jane V2 | Jane V2 CE | Thermal | Kei | GSKT-00 | Duck Orion V3 | U80 | Salvation | 378 | HHKB | Cloudline | Bias | TKL One | Kaze | Jane V2 ME
Offline voight-kampff
« Reply #81 on: Fri, 05 July 2019, 14:23:30 »
looks great
I am in for the FE
Offline chriszhu
  • (* ̄(エ) ̄*)''
« Reply #82 on: Fri, 05 July 2019, 14:31:24 »
Interested!
Offline loopaddiction
« Reply #83 on: Fri, 05 July 2019, 16:17:42 »
Hopeful there are more non-copper color options for the logo & weight (for the standard v.) because although it's undoubtedly beautiful, the copper is a very distinct color that limits the types of keycaps that would match well IMO. More neutral color options would be perfect.
With that said, gorgeous design!
Offline Pmalcolm88
« Reply #84 on: Fri, 05 July 2019, 17:12:18 »
Reserved
Offline krey
« Reply #85 on: Fri, 05 July 2019, 21:08:13 »
Nice
Kepler FC65 | 7v | Think6.5 v1 | Maja | G60 | TX75v2 | Fjell | Klippe x2 | Acrylic Tofu | CA66 | Norbaforce
Offline aleck
« Reply #86 on: Sat, 06 July 2019, 02:47:24 »
I'm gonna sell my kidney for this. I need this in my life.
HHKB Pro 2 Type-S (2016)
Offline distel
« Reply #87 on: Sat, 06 July 2019, 03:59:47 »
Depending on price I am in
Offline EMC Labs
« Reply #88 on: Sat, 06 July 2019, 05:25:01 »
Reserved
Swear I've seen you comment reserved somewhere else. What are you trying to achieve?
Offline breckstar
« Reply #89 on: Sat, 06 July 2019, 09:26:03 »
Depends on price, but looks awesome and could be in.
Offline Ashardalon
  • Ashkeebs
    • Ashkeebs Lubing Service & Shop
« Reply #90 on: Sat, 06 July 2019, 09:27:31 »
Very interested seeing the cost difference between the FE and the Standard Version. Looking great, and love the ingenuity regarding having an even sound and feel across the board.
Offline hyppialonso
« Reply #91 on: Sat, 06 July 2019, 09:37:41 »
this is elegant! hope it can be a reasonable price !
Offline vheissu
  • Pragmatic Geometrist
« Reply #92 on: Sat, 06 July 2019, 16:01:29 »
Keyboard of the year.
Offline ptiede
« Reply #93 on: Sat, 06 July 2019, 19:38:35 »
That thing is beautiful. I'd love to get a founders but I have a feeling those will be reserved for people
Offline justinhigley
« Reply #94 on: Sat, 06 July 2019, 21:12:06 »
I’d be all over a raw copper FE if given the chance.
Offline Unicorncarl
« Reply #95 on: Sat, 06 July 2019, 21:46:41 »
Looks amazing!
Offline Solotov
« Reply #96 on: Sun, 07 July 2019, 07:00:24 »
Really interesting. Will keep an eye on this.  :thumb:
Flex is love, flex is life.
Offline forelsket
« Reply #97 on: Mon, 08 July 2019, 06:40:15 »
Simply gorgeous!
Offline Marutks
« Reply #98 on: Mon, 08 July 2019, 09:56:31 »
looks amazing,   I want this board !
Offline KrasH
    • Instagram Profile
« Reply #99 on: Mon, 08 July 2019, 12:05:29 »
I'm in if there's a black case + black (or brass) badge.
