Author Topic: [IC] IRON165 by Smith + Rune (GB Dates/Times / FE Raffle Announced)  (Read 323533 times)
Offline voxkey
After almost a year in research and development, we are excited to present the IRON165 by Smith + Rune. Rather than drawing inspiration from things outside our community, we focused on the incredible designs the community itself has created over the years. The IRON165 aims to be a distillation of these positive innovations, included in one premium board.
***** FE Public Raffle Link! *****
First 3-minute window opens at 9am EDT. Use this link to determine your local time: https://everytimezone.com/s/a35cb8be
Second 3-minute window opens at 9pm EDT. Use this link to determine your local time: https://everytimezone.com/s/cfccf7be
Join Smith + Rune Discord
Follow us on Instagram
Please reference the second post for updates
Please reference the third post for additional renders
Group Buy Timeline
Standard Edition
The group buy will go live on October 19th, 2019 at 9am EDT worldwide!
Founder's Edition
The FE public raffle will be comprised of two 3-minute windows on October 12th, 2019 at both 9am EDT and 9pm EDT.
Forms will be linked both here and on our Discord when the raffles open. Please ONLY enter once. Multiple entries will be disqualified. Invoices and payment details will be issued within 24 hours.
Vendors, Quantities, and Group Buy Date
Standard Edition
We're very proud to announce we've partnered up with CannonKeys in the US, MyKeyboard in the EU, and ILUMKB in the AP/China market to handle all sales of the Iron165 SE.
What this hopefully means, and why we're so excited to work with these amazing stores, is that we should be able to offer not only a smoother buying experience, but also a higher quantity of boards than we initially thought possible.
USA - CannonKeys - Up to 100 boards
EU - MyKeyboard - Up to 50 boards
AP - ILUMKB - Up to 50 boards
Founder's Edition
The Iron165 FE will be limited to 26 serialized units, never to be made again. We will be handling the group buy for these directly. There will be a public raffle for 10 total group buy spots.
Features
  • 7 Degree Typing Angle
  • Full Gasket Isolation Mount
  • Low-profile Front Height (less than 17mm)
  • Seamless Design
  • USB-C daughterboard, centered (designed by ai03 and friends)
  • Plate Optimized for consistency on every key press (see analysis below)
  • PCB compatible with QMK, and hopefully VIA support (designed by Upas)
Founder’s Edition Features
  • Full copper base, satin finish, clear-coated
  • Copper plate, satin finish, clear-coated
  • Copper blocker badge, satin finish, clear-coated
  • Stainless steel top shell, available in E-white or E-black
  • Precision-cut foam between PCB and plate by MKUltra Corp
  • Limited to 26 serialized boards
  • Custom hard carrying case
  • $885 USD
Standard Edition Features
  • Aluminum base, anodized
  • Large brass weight, satin finish, clear-coated
  • Aluminum top shell, anodized
  • Aluminum blocker badge, anodized
  • Brass plate, satin finish, clear-coated
  • Accented colors (top shell will be one color, badge and base will be another)
  • $475 USD / 480€ inc/VAT
Standard Edition Colorways
  • Plum with Black base and badge
  • Navy with Silver base and badge
  • Graphite with Silver base and badge
Layout Options (see FAQ for ISO-related info)
Optimized Plate, the Process, and FEA analysis
Keyboard plate FEA analysis was wanted to measure deflection and try to achieve a uniform plate deflection distribution across the keyboard.  This concept has been done before with the Omega60 talking about mounting points.  One of the first criticisms was that without a PCB and switch the study was worthless.  I started out by modeling a small sample before moving to a full size plate.  I constructed a small plate made of brass, switch made of POM, and PCB made of resin injected plastic.
I wanted to see the difference in displacement just a plate and a fully modeled with PCB, switches and Plate.  With modeling of the entire system, there are two options in consideration:
Fully bonded - Solidworks treats the model as though it was fully welded together at every contact point.
No Penetration - Materials wont move through each other but can move independently from other models.
I estimated typing force to be around 2N max on each key as I measured my repeated tapping on a scale at 200g as the hardest I would ever really type (and I like to bottom out).
Next is the fully bonded model with plate and switches.  Again a 2N force is applied to the top of the switch model with fixtures mounted at the four screw holes.
Lastly is the most realistic model the no penetration.  Same force and Fixture as above.  Notice how the displacement doesnt flow as uniformily through the switches vs the fully bonded model above.  You'll also see the displacement pattern is more similiar to that of just the plate.
If you compare the displacement results we conclude that just a plate can be used to model displacement without the extra PCB and switch modeling effort.  The displacement of the plate model is approx 35% more than the plate with stiffness of PCB and Switches added to it.
Since each switch has to be setup and run individually I concentrated on making just the alphas as consistent as possible.  This is still a work in progress, but here are the initial results.
This was the stock designed plate mounted with gaskets.  Numbers in each switch represent the maximum deflection in millimeters for a 2N force:
Adding in relief cuts we can try to make the lower deflecting keys increase to the same deflection of the higher deflecting keys.  This resulted in a decrease in standard deviation of 25% and a decrease in range by 35%.
Prototype Pics
FE Renders by Abec13 (additional renders in the third post)
SE Renders by Abec13 (additional renders in the third post)
FAQ
New studio? New board? Why should we trust you?
While this is a first in the keyboard community for us, we are proud of the team we’ve put together. Combined, we bring ten years mechanical engineering experience and five years of supply-chain management for small-batch, boutique products in other industries.
Smith + Rune is grounded in basic engineering principles, with a touch of magic and mysticism created by this wonderful community.
The rune logo is cool! Does it mean anything?
The two Norse runes featured in our logo, Sowilo and Raido, come from the Elder Futhark alphabet, the oldest form of runic alphabets. Sowilo means strength, power, success, while Raido roughly translates to ride, or journey. Together they form a bindrune, drawing the power of both into one creating a charm to ensure a successful endeavor and bringing a bit of luck to your desktop.
Why is it named IRON165? Where’s all the iron?
The iron industry essentially shaped the industrial revolution of the 1800’s. Its ubiquity has led to its inclusion in nearly every industry. Iron is used to create many of the tools or machine parts we use today.
A keyboard is essentially a modern, but basic tool we use daily and we kept this central in our design choices. While beautiful, we placed function over form when designing the IRON165. In its simplest form, it had to be the best at being a tool first. Something durable, sturdy and a pleasure to use.
While not constructed entirely from iron (although steel is made with iron), we felt this board embodied the more abstract sense of the word. Iron is strong, iron is reliable, iron is long-lasting.
Whoa! Where’s the ISO support?
We will support ISO if enough interest is shown, but all of our plate files will be made open-source (including ISO) regardless. So even if you’re an avid ISO user and we don’t have an ISO plate, you’ll be able to get one made. We will also be optimizing our ISO plate for consistency, just like our other plates.
The PCB will support ISO out-of-the-box.
What parts will be user-replaceable?
Our hope is that everything, except the case itself will be user-replaceable in some form or fashion. One of our main goals when designing this board was to make absolutely sure that no IRON165 will ever become a glorified paperweight.
The renders are amazing! Wow! Who did those?
All of our renders came from the amazing Abec13! We can’t thank him enough!
Interest Check Disclaimer
Keep in mind this is an interest check. Nothing, including options, pricing, etc, is final until the GB starts. This IC represents the most correct, up-to-date information we have regarding the Iron165 at this time. Based on prototyping and manufacturing samples, some things may change.
We will be announcing any changes, if any, here first, and on Discord as well.
Shoutouts
My most sincerest thanks go out to the other half of Smith + Rune, lBaron. Without you, this board would’ve never made it this far.
We want to thank those that have supported us from the very beginning of this project, including Langelandia, bhk1004, Spade, Eskimojo, Full / Aslejoh, Minterly, Oldcat, Capsy, and the rest of the Gray Studio and TYL discords. I likely missed some names, but you know who you are.
We also want to thank the community as a whole including the designers, vendors, and of course, the streamers and content creators. You are part of what makes a project like this so fun and rewarding. Watching this community grow has been incredible!
« Last Edit: Fri, 11 October 2019, 21:01:00 by voxkey »
Offline voxkey
Re: IRON165 by Smith + Rune
« Reply #1 on: Thu, 04 July 2019, 13:29:24 »
Current Progress / Change Log / Updates
Friday, October 11th, 2019
Monday, October 7th, 2019
  • SE price updated
  • SE group buy time announced!
  • FE qty increased by 1 (serialized up to 26, because that's too cool to pass up)
  • FE raffle date and times announced!
  • Custom packaging announced! Custom hard cases, TX-style!
Thursday, September 19th, 2019
  • GB date set! October 19th!
  • SE colorways announced! Yes, we're making all three :)
Friday, August 30th, 2019
  • Prototypes arrived! Pics added to the IC!
Sunday, August 18th, 2019
  • Added SE Color Poll
Sunday, August 11th, 2019
  • More vendor announcements (MyKeyboard in the EU, ILUMKB in AP)
  • Added more SE renders to the third post
Sunday, August 4th, 2019
  • Announced tentative group buy start date (late September, early October)
  • Announced pricing and quantities
  • Announced CannonKeys as USA vendor
  • Updated FAQ.
Saturday, July 20th, 2019
  • Prototypes have been ordered along with ALL color and finish samples for both the FE and SE versions of the Iron165!
  • Colors and finishes have been updated and finalized for the FE version, pending approval of the prototype.
  • Colors for the SE are still being considered. Along with the prototype, we have ordered multiple anodizing color samples and finishes.
  • Renders of the SE version have been added.
  • Supply chain is nearly finalized, provided the prototypes live up to our high quality standards. We are expecting this to be the case.
  • A rough timeline has been set for the group buy. It's looking like September or October.
  • Updated FAQ.
« Last Edit: Fri, 11 October 2019, 20:59:10 by voxkey »
Offline voxkey
« Reply #2 on: Thu, 04 July 2019, 13:29:32 »
« Last Edit: Sun, 11 August 2019, 13:38:10 by voxkey »
Offline Full
« Reply #3 on: Thu, 04 July 2019, 13:30:15 »
Oh wow!! So friggin awesome! :o Good luck guys!
Hi!
Offline Spade
« Reply #4 on: Thu, 04 July 2019, 13:31:32 »
Beeeeg nut
Offline valkyr1e
« Reply #5 on: Thu, 04 July 2019, 13:32:28 »
Oh wow.
Yes please.
Offline enome
« Reply #6 on: Thu, 04 July 2019, 13:32:52 »
POGGERS
Offline Lormania
« Reply #7 on: Thu, 04 July 2019, 13:34:38 »
One of the best boards I have seen!!!!
Offline _ODIN_
« Reply #8 on: Thu, 04 July 2019, 13:34:51 »
Amazing design, I will follow this project closely.
Thank you for releasing the plate files because I would like to use an ISO layout.
Offline eskimojo
    • KeycapLendar
« Reply #9 on: Thu, 04 July 2019, 13:36:25 »
I feel broke just looking at this
I'm so excited you guys
Offline Bhk1004
« Reply #10 on: Thu, 04 July 2019, 13:36:51 »
Ummm. Wtf took so long slacker.
Offline jordowag
« Reply #11 on: Thu, 04 July 2019, 13:38:21 »
I got such talented friends!!!   :)) This is gonna be an awesome board.
Offline pixelpusher
« Reply #12 on: Thu, 04 July 2019, 13:38:40 »
The materials look very nice.  I also like the rune detail.  How far recessed are the bottoms of the keycaps when mounted? There are no renders of a side view so it’s hard to tell.  From the first image, they look almost even with the top edge.  I think most of us prefer the caps to sit slightly lower
« Last Edit: Thu, 04 July 2019, 13:40:23 by pixelpusher »
Offline ogWalker
« Reply #13 on: Thu, 04 July 2019, 13:39:03 »
Looks great! I'm definitely in for this <3
Would love to see a navy or baby blue version too.
Offline Minterly
« Reply #14 on: Thu, 04 July 2019, 13:40:58 »
gimme brass or gimme death
Offline lbaron
« Reply #15 on: Thu, 04 July 2019, 13:42:21 »
Top bezel is 7mm + gasket above the switch plate
Offline lolafineday
« Reply #16 on: Thu, 04 July 2019, 13:42:44 »
Lemme in!
Sent from my SM-G975F using Tapatalk
Offline stuey138
« Reply #17 on: Thu, 04 July 2019, 13:42:56 »
Love the FEA, that rose gold colour better not just be a render because it's so pretty. What's expected cost?
Offline Captain Shwah
« Reply #18 on: Thu, 04 July 2019, 13:43:17 »
This board is so sick. :eek:
Beautiful design and the amount of research you've put into it is impressive.
Offline phunktional
« Reply #19 on: Thu, 04 July 2019, 13:43:57 »
All in
Offline bobdenard
« Reply #20 on: Thu, 04 July 2019, 13:49:45 »
Gorgeous board! All in!
Envoyé de mon iPhone en utilisant Tapatalk
Offline Valian
  • Clicky Neophyte
« Reply #21 on: Thu, 04 July 2019, 13:50:16 »
This is the keyboard I've been looking for. Can't wait for the GB!
Have you considered a metallic grey finish?
Offline Vigrith
« Reply #22 on: Thu, 04 July 2019, 13:50:25 »
Extremely exciting project, beautifully designed and hopefully all that excitement and desire remains once the estimated price is announced (unlike a couple other similar designs).
Offline SolidCactus
« Reply #23 on: Thu, 04 July 2019, 13:50:25 »
Lovely board! Saw this on reddit and was wondering what the board was! Consider me in!
Offline tunadesu
Re: [IC] IRON165 by Smith + Rune
« Reply #24 on: Thu, 04 July 2019, 14:11:06 »
Super clean, been seeing the teasers on IG. The back is giving me some 7V vibes. I dig.
Offline LXVRGS
« Reply #25 on: Thu, 04 July 2019, 14:13:07 »
INJECT THIS INTO MY VEINS
Offline PotatoTM
« Reply #26 on: Thu, 04 July 2019, 14:13:15 »
Looking forward to it!
Offline sl70309
« Reply #27 on: Thu, 04 July 2019, 14:24:16 »
"limited quantity" again... :mad:
Offline urbantheii
« Reply #28 on: Thu, 04 July 2019, 14:27:39 »
IN!
Offline Lelantos
« Reply #29 on: Thu, 04 July 2019, 14:29:52 »
O lawd
Sent from my SM-G960U1 using Tapatalk
Offline gautema
« Reply #30 on: Thu, 04 July 2019, 14:42:10 »
Looks really good. I’ll be trying hard for a spot on this one.
Offline glubazoid
« Reply #31 on: Thu, 04 July 2019, 14:45:36 »
Design looks gorgeous dudes, really digging the back weight/ bottom. It's just so damn clean!
I'll be following this
Offline Xynerorias
  • Lubin' with glicerin
« Reply #32 on: Thu, 04 July 2019, 15:26:49 »
I hate you, I was just beginning to settle down, following my buying plan, and starting to finally have savings.
Offline cijanzen
« Reply #33 on: Thu, 04 July 2019, 16:03:30 »
This is beautiful. Definitely interested depending on availability and price!
Offline KaosJ
« Reply #34 on: Thu, 04 July 2019, 16:31:43 »
Copper base and gaskets? I'm in duder  :thumb:
Offline dreisamkatze
« Reply #35 on: Thu, 04 July 2019, 16:36:41 »
This looks very beautiful. I'm interested.
Offline pixelpusher
« Reply #36 on: Thu, 04 July 2019, 16:40:52 »
Okay, I’m not versed enough in the specifics to judge.  It looks like, from this diagram (which appears accurate since I’ve found the same in other diagrams), that the switch sticks up 6.6mm above the plate and the. Another 3.6mm to the top of the stem.
What I cannot seem to find is the height of a GMK keycap (depth of stem inserts and skirt height), to finish the equation.  Is there a standard that designers use?
Offline mrkantz
« Reply #37 on: Thu, 04 July 2019, 16:47:49 »
Hot damn! Very interested
Offline xondat
  • i'm not a star
« Reply #38 on: Thu, 04 July 2019, 17:14:20 »
Majority of boards are 7mm (including 268.1 for comparison).. Not enough imo, 7.5 is better. 7.8+ drowns the caps too much. Something like M65-A would be 6mm.
« Last Edit: Thu, 04 July 2019, 17:16:13 by xondat »
Offline lbaron
« Reply #39 on: Thu, 04 July 2019, 17:18:46 »
Yeah it seemed that 7mm was standard when designing. Then it’ll be a little bit above cause of gasket compression but no more than .25mm or so.
Offline hansikhouse
« Reply #40 on: Thu, 04 July 2019, 17:20:42 »
In for the white depending on price  :))
Fantastic presentation btw.
Offline pixelpusher
« Reply #41 on: Thu, 04 July 2019, 17:35:12 »
Thanks for the feedback, all.  I own the 268.1 and it is indeed almost exactly flush from case top edge to bottom of GMK caps.  Don’t suppose we convince you to adjust the design closer to 7.5mm? Especially since the inner edge has a fillet
Offline lbaron
« Reply #42 on: Thu, 04 July 2019, 17:42:50 »
It wouldn’t be hard from a design perspective but a huge design goal was to have as low as possible front bezel.
Offline xondat
  • i'm not a star
« Reply #43 on: Thu, 04 July 2019, 17:47:33 »
I learnt with a gasket board that even .1mm off can change it visually a lot. Double the gap sorta thing. Worth considering maybe, sure you have though.
The switches still sit at the same level when changing bezel height though.
I've always argued it's the height the switches sit at, not strictly the front height (due to changing bezel heights).
« Last Edit: Thu, 04 July 2019, 17:49:06 by xondat »
Offline Holicalis
« Reply #44 on: Thu, 04 July 2019, 17:52:41 »
Is that rose gold plate and weight going to be in the gb?
Offline victorpre
« Reply #45 on: Thu, 04 July 2019, 18:01:03 »
Any idea about prices?
Offline jedidood
  • aka neovisual
« Reply #46 on: Thu, 04 July 2019, 18:40:29 »
Why are you doing this to me... Now I want this badly... This is a wallet killing hobby.... but I LOVE IT!
« Reply #47 on: Thu, 04 July 2019, 19:43:36 »
Those are polished copper
Offline cronohack
« Reply #48 on: Thu, 04 July 2019, 20:14:44 »
I hope the pricing is competitive for this! :)
Offline lpop
« Reply #49 on: Thu, 04 July 2019, 20:17:50 »
Oh wow this is a beautiful looking kit. Absolutely looking forward to more information ab it.
