Author Topic: [IC] SP SA Yuri / DCS ALPS Yuri (dropping in October)  (Read 131912 times)
Offline konstantin
  • Formerly constexpr
Re: [IC] SP SA Yuri / DCS ALPS Yuri
« Reply #200 on: Thu, 18 July 2019, 11:11:40 »
I like Del PgUp PgDn Fn. I don't use the pg keys but I use Del a lot and Fn its good for a combination keys like media or so
This and similar right columns (starting with Del) that others mentioned don't work that well with split backspace layouts. PrtSc–Del–PgUp–PgDn (WhiteFox layout) is the most common right column setup on 65% boards with split backspace.
R1 Page Down is for 1800 layout support, i believe.
Good catch i forgot about these completely. I will then replace these with R3 PGUP and R4 PGDN keys.
Hurray
« Last Edit: Thu, 18 July 2019, 11:18:12 by constexpr »
Offline T0mb3ry
  • https://www.instagram.com/t0mb3ry_gh/
    • Flickr
« Reply #201 on: Thu, 18 July 2019, 12:26:43 »
Update
DCS ALPS Yuri kit
- Removed 1800er nav cluster keys since there is no numpad available.
- Added R3 PgUp and R4 PgDn keys.
- Added Yuri Novelties and АЛЬПС (ALPS phonetic in Russian) enters.
Offline konstantin
« Reply #202 on: Thu, 18 July 2019, 12:29:54 »
The Альпс novelty looks absolutely amazing!
Offline Capsy
« Reply #203 on: Thu, 18 July 2019, 13:01:48 »
Looks really good. Thanks tombery. Excited for the ALPS set.
Offline pixelpusher
« Reply #204 on: Thu, 18 July 2019, 13:05:13 »
The poor, innocent  R1 delete key in the Alps set.  I mourn his death.  RIP
Offline Vireca
« Reply #205 on: Fri, 19 July 2019, 07:53:09 »
Why don't work? But anyways i dont think much people use split backspace, in alps either
Offline konstantin
« Reply #206 on: Fri, 19 July 2019, 08:04:50 »
Because Del makes more sense placed next to Backspace. If you're like me, you use split BS on every single board you can, even TKL, CP and larger. Not everyone is like that, but a lot of people do use split BS on 60%/65%/66-key/75%, which is what the set is primarily meant for. Some modern Alps PCBs do support split BS.
« Last Edit: Fri, 19 July 2019, 08:12:16 by constexpr »
Offline Vireca
« Reply #207 on: Fri, 19 July 2019, 16:39:32 »
Dunno, I never used it. I feel more confortable with a standard backspace. Im sure i will missclick with 1u backspace
Offline konstantin
« Reply #208 on: Fri, 19 July 2019, 16:50:12 »
It's 1.5u. And you're less prone to mispressing it than standard Backspace. Try it, you'll see :)
Offline T0mb3ry
    • Flickr
« Reply #209 on: Fri, 19 July 2019, 17:02:47 »
R1 Del key will come back because we don't have a 1u backspace (Del fulfills this purpose).
Once i got enough stuff for the update i will publish the current kits.
Offline Applet
« Reply #210 on: Sat, 20 July 2019, 11:45:13 »
Yay! Happy for the Alps set! :D
Offline AuDiTH
« Reply #211 on: Sat, 20 July 2019, 12:43:28 »
HYPED for the alps set  ;D
SSK | AEK64 | TX-CP | HHKB | Acrylic Pearl | Duck Orion V3 | LZ MP | Kyuu Sakura
Offline Poohammer
Re: [IC] SP SA Yuri
« Reply #212 on: Wed, 24 July 2019, 04:49:23 »
The Cosmos version.
LOVE the look of this set and the dual legends.
Offline EMC Labs
« Reply #213 on: Wed, 24 July 2019, 04:54:51 »
Hyped for the Alps return.
Offline CodeMayhem
Re: [IC] SP SA Yuri
« Reply #214 on: Wed, 24 July 2019, 21:26:36 »
Update
Novelties
- Added Glorious keys in Yuri colors for R1 and R3.
wait no glorious kit?
 :D
I'm with you comrade!
« Last Edit: Thu, 25 July 2019, 06:46:32 by CodeMayhem »
Offline d.caminero
« Reply #215 on: Thu, 25 July 2019, 01:49:06 »
Update
DCS ALPS Yuri kit
Is there any way that you add keys to support split spacebar? Even if they are just extra shifts in the accent color? or just blanks?
Offline T0mb3ry
    • Flickr
« Reply #216 on: Thu, 25 July 2019, 12:26:24 »
Update
DCS ALPS Yuri kit
Unfortunately not this time. Current alps kit is just an experiment and i want to offer it with the lowest MOQ and because of that it will have quite high price tag. With higher sold numbers it will of course drop but i have no idea how many people are interested in it. Nobody can tell it at this moment. Also i think if this experiment goes well then i am sure some designers will also try to offer alps kits in the future. So probably and hopefully it will fruit in more individual alps sets.
Offline konstantin
« Reply #217 on: Thu, 25 July 2019, 17:39:17 »
Any fresh progress on the русские легенды and Gorton Modified Cyrillic? :)
Offline T0mb3ry
    • Flickr
« Reply #218 on: Thu, 25 July 2019, 17:45:34 »
I am doing mod kits overhaul. Dual mods are already done but i would not make an update without every kit covered.
Offline T0mb3ry
    • Flickr
« Reply #219 on: Fri, 26 July 2019, 15:11:25 »
Update
- Modifiers extension kit has been removed.
- Modifiers kit has been reworked and new modifiers kits were added
Modifiers kit
Cyrillic modifiers kit
ps. Ignore that blank key in row1 i just oversaw it. It will be removed in the next update.
Dual modifiers kit
DCS ALPS Yuri
- Added R1 1u Delete key.
In the next update
I will rework all alphas and the numpad kit. There will be latin and cyrillic alphas in regular color and there will be latin and dual alphas in cosmos color. The numpad kit will get both alpha colors.
« Last Edit: Fri, 26 July 2019, 15:18:31 by T0mb3ry »
Offline konstantin
« Reply #220 on: Fri, 26 July 2019, 16:57:28 »
ne R3 PgUp, R4 PgDn avail?
Anything better than ЭКРАН for ScrLk? I get what you were going for, but honestly it reminds me of PrtSc much more than ScrLk. КУРСОР, at least?
Speaking of PrtSc, what do you think about ПЕЧАТЬ instead of ПРИНТ? Or ЭКРАН, even?
Did you give up on СМЕНА for Alt? ВАРИАНТ is kinda... bleh. Plus, it's too wide compared to ALT, whereas the other mod legends (e.g. КОМАНДА) match their English counterparts in width pretty well.
This feels like a lot of criticism, but in reality the kits are looking much better now imo! Keep up the good work.
« Last Edit: Fri, 26 July 2019, 17:09:19 by constexpr »
Offline digid3ar
« Reply #221 on: Fri, 26 July 2019, 17:51:52 »
one Cyrillic modifiers kit pls, i need it now
Offline CodeMayhem
« Reply #222 on: Fri, 26 July 2019, 18:23:24 »
he just added it?
Edit: lul I can read
« Last Edit: Sat, 27 July 2019, 08:34:44 by CodeMayhem »
Offline CodeMayhem
« Reply #223 on: Fri, 26 July 2019, 18:25:14 »
does you adding the dual font mods mean that a dual alphas kit is coming? preferably in cosmos  ;D
Offline sncbraxsc2
  • ⭐Domesticated Dweeb⭐
« Reply #224 on: Fri, 26 July 2019, 18:27:57 »
In the next update
So many good options!  :cool:
Offline Katsurio
« Reply #225 on: Fri, 26 July 2019, 18:33:13 »
I'm in for everything SA Yuri!!!
Offline konstantin
« Reply #226 on: Fri, 26 July 2019, 19:38:04 »
I see ScrLk in the Alps set is still using "Scroll Lock" for the legend. Is this deliberate? There's still time, do the right thing and change it to "Scroll" :D
Offline T0mb3ry
    • Flickr
« Reply #227 on: Sat, 27 July 2019, 03:32:04 »
Yeah will add in the next update.
I think ЭКРАН does match pretty well. Thing is the scroll lock does change the arrow key behavior. ScrLk toggles into "screen mode/browse mode" (in case your current application supports this mode at all).
КУРСОР is the default mode. Say if its not toggled on.
The direct Russian translation of scroll does not match the real purpose. In that mode you don't scroll (прокручиваешь) but you are browsing by using arrow keys. Anyway most of those words are too long.
Well ПРИНТ is a direct translation and there is actually no direct synonyms for it. I know what you mean with ПЕЧАТЬ but it does not really match the translation. Printer is called принтер in Russian and not печатныи станок/агрегат/диваис итд.итп.
So for an alternative we need too look that this key actually does nowadays. And actually this key has nothing to do more with print. It does make screen shot and copies it into clipboard. So as you suggested ЭКРАН does match it pretty well but it is already on the ScrLk key and as long as i don't have proper alternative it shall stay there. So another word which might match the purpose is the БУФЕР for clipboard.
I don't think СМЕНА match it very well. СМЕНА does match more Shift. ВАРИАНТ is an indirect synonym for АЛЬТЕРНАТИВА and it does match the real purpose of the key. I am open for another indirect synonym but it should match the real purpose of the key.
Btw. ALT is a shortcut of ALTERNATIVE or ALTERNATE and i can try to full word it. I think ALTERNATE might match at least on a 1.25u key.
Nah everything is alright. Keep on going, it helps me to find alternatives.
Yeah i change it to "Scroll" ;)
Offline norb
« Reply #228 on: Sat, 27 July 2019, 04:13:16 »
cyrillic-only mods <3 now i won't have any reason to sell my GMK Yuri bc it will have a different look while still remaining the same :thumb:
Nice.
Offline konstantin
« Reply #229 on: Sat, 27 July 2019, 04:24:12 »
How about using ФИКС for ScrLk to match the English LOCK legend, and then using ЭКРАН for PrtSc?
I like this idea,
В А Р И А Н Т
ALTERNATE
could work. And I like that the set is going with longer legends in general, so it would match well. But I'll try to come up with another alternative for the Alt legend in any case.
:thumb:
« Last Edit: Sat, 27 July 2019, 04:43:33 by constexpr »
Offline mimalik
« Reply #230 on: Sat, 27 July 2019, 20:24:25 »
Plz plz plz dual alphas in regular colours as well, not cosmos only.
Offline mimalik
« Reply #231 on: Sat, 27 July 2019, 20:26:00 »
After SA Laser, this ll be my most expensive caps purchase, can easily see the bill going well over $600.
Offline CodeMayhem
« Reply #232 on: Sun, 28 July 2019, 10:47:42 »
same so many kits i want. really just too many keysets i want rn; serika, dracula, sanctuary, and kaiju. plus i already got oblivion and olive. rip wallet
Offline Anakey
« Reply #233 on: Mon, 29 July 2019, 05:29:05 »
will there be a Cyrillic numpad and 1.25 ISO shift?
« Last Edit: Mon, 29 July 2019, 05:32:31 by Anakey »
Offline T0mb3ry
    • Flickr
« Reply #234 on: Mon, 29 July 2019, 12:17:22 »
There will be no Cyrillic numpad unfortunately. It is already a dilemma with all the alphas and modifiers varieties. ISO shift is available in UK ISO but only in latin.
Offline harlekein
« Reply #235 on: Tue, 30 July 2019, 02:50:47 »
In the next update
I'm begging you, cyrillic mono alphas in cosmos color would be amazing.
Offline Anakey
« Reply #236 on: Tue, 30 July 2019, 06:07:01 »
are there supposed to be 2x 2.25 shift keys?
Offline T0mb3ry
    • Flickr
« Reply #237 on: Tue, 30 July 2019, 06:27:56 »
Yes for the leopold 660 like layout.
Offline Anakey
« Reply #238 on: Tue, 30 July 2019, 06:51:46 »
i see, didn't realise such a layout existed
Offline d.caminero
« Reply #239 on: Tue, 30 July 2019, 07:16:45 »
In the next update
+1 to that. Cyrillic mono alphas look far better than dual IMO, specially in Cosmos color.
Offline Dumble_Hub
  • Lets Go Bills!!!
« Reply #240 on: Wed, 31 July 2019, 20:01:38 »
Now this is the set I need, finally an alps set that steps outside the box. Count me in!
Offline tuppaware
« Reply #241 on: Thu, 01 August 2019, 21:48:48 »
Just waiting for this one nowwww .. Plus all the other kits over Aug/Sept I want to buy
Offline CodeMayhem
Re: [IC] SP SA Yuri
« Reply #242 on: Sat, 03 August 2019, 10:57:53 »
Update
Novelties
 :D
not super important but are you willing to add the OG glorious key too??
Offline T0mb3ry
    • Flickr
« Reply #243 on: Sat, 03 August 2019, 11:47:01 »
Update
Novelties
 :D
If I remember right, it was yellow on red. Well that's quite possible. I'll look into it.
Offline iammeuru
« Reply #244 on: Sat, 03 August 2019, 12:34:19 »
I know you can't satisfy everyone, but it kinda sucks that the alps set had 1800 and full size support removed. I mostly want it to be able to cover 1800s (so few alps sets can do that)
Offline Capsy
« Reply #245 on: Sat, 03 August 2019, 13:30:22 »
Seconded. The TKC 1800 R3 is alps compatible but it sucks that I won't be able to put this on it.
I know that 1800 support might make the set expensive but given SP's low MOQs it might be a good idea to look into it.
Offline euphxenos
« Reply #246 on: Sat, 03 August 2019, 13:33:54 »
Would you be willing to offer Alps numpad support in a separate kit from the base Alps kit?  Let it hit MOQ or not on its own, and see if the interest is there.
Offline konstantin
« Reply #247 on: Sat, 03 August 2019, 13:59:28 »
+1 for this idea. If 1800/full-size support is offered, it should be in a separate kit.
Offline shensmobile
« Reply #248 on: Sat, 03 August 2019, 19:42:41 »
For the Ergodox kit, is it possible to swap the R4 Raise and Lower caps for "Enter" and "Fn" caps instead?
Offline CarlQs
« Reply #249 on: Sat, 03 August 2019, 22:26:33 »
alps keyset with good compatibility >.> yes yes yes and close enough to gulf racing colors too im so ready for this to be in my life
