Author Topic: [GB] Fox Lab - Key 65  (Read 763426 times)
Offline Quasimodo
Re: [GB] Fox Lab - Key 65
« Reply #300 on: Fri, 04 October 2019, 05:20:17 »
The logo on the weight can only be seen if the keyboard is turned upside down right? (even if it is PC clear)
Yup, it's on the bottom.
Offline noodleman
« Reply #301 on: Fri, 04 October 2019, 10:48:41 »
Is the PCB QMK ? And is the Hotswap pcb supporting SMD rgb led as in, can i solder them on myself?
Yes, QMK.
SMD LEDs are pre-soldered on hotswap PCBs. They are not RGB tho.
what colour are the per key lighting leds if they are not RGB?
Offline JacobTN
« Reply #302 on: Fri, 04 October 2019, 10:50:02 »
Yes, QMK.
I would assume just a white light?
Offline senter
« Reply #303 on: Fri, 04 October 2019, 14:11:42 »
Yes, QMK.
I was wondering what you mean by not RGB. What colour will the LEDs be?
White
Offline senter
« Reply #304 on: Fri, 04 October 2019, 14:12:22 »
Yes
Offline senter
« Reply #305 on: Fri, 04 October 2019, 14:12:46 »
Super hyped to start my first build! Will the hotswap pcb work with 7u space bar + wk top plate?
Yes.
Offline jadverkko
« Reply #306 on: Fri, 04 October 2019, 14:27:59 »
Is there something wrong with form atm? I tried editing my order but all i get is: "There was a problem submitting your response"
Offline Aox
« Reply #307 on: Fri, 04 October 2019, 17:13:30 »
On the key logo version, where would the FN key be?  I know it's assignable, but is there a default location?
EDIT: Specifically for WKL
« Last Edit: Fri, 04 October 2019, 17:16:14 by Aox »
Offline Little4Real
« Reply #308 on: Fri, 04 October 2019, 17:17:46 »
Caps Lock
Offline Aox
« Reply #309 on: Fri, 04 October 2019, 17:27:54 »
Caps Lock
That's... fantastic!  Thanks for the reply.
Offline kurple
« Reply #310 on: Fri, 04 October 2019, 17:50:26 »
They might be doing invoices right now or at the time you got the error.
Offline olsen34
« Reply #311 on: Sat, 05 October 2019, 11:27:16 »
Just paid for the second batch invoice. No spreadsheet for the second batch yet I assume?
Offline MK47
  • Don't talk to me
« Reply #312 on: Sat, 05 October 2019, 12:37:34 »
Just submitted my order. Can't wait.
Offline noahf
« Reply #313 on: Sat, 05 October 2019, 15:52:53 »
go to the order google sheet, then click on "Sheet 2" that is where the 2nd round of invoices are living.
Offline Fnzzy
« Reply #314 on: Sat, 05 October 2019, 21:14:05 »
I couldn't find anything about this after a short search so apologies if this has been asked yet, does the PC version have brass inserts for the screw threads like the acrylic Tofu case? I assume this would improve longevity greatly.
Offline rmendis
  • Artisan addict
« Reply #315 on: Sat, 05 October 2019, 21:28:55 »
Yes, QMK.
White
So on the non-hotswap pcb, we can solder SMD RGB LED, which the firmware will support cycling through?
Offline thecheeselouise
« Reply #316 on: Sat, 05 October 2019, 22:33:47 »
Invoiced and paid! Super excited. Did we ever get a picture of the hotswap PCB?
Offline prangano
« Reply #317 on: Sun, 06 October 2019, 00:13:19 »
Yes, here:
The hotswap prototype PCB is finished as well. Will test it later.
Offline chozn1
« Reply #318 on: Sun, 06 October 2019, 01:05:18 »
 Hot swap, 65%, blocker, PC. Man RGB would have made this a must buy. So close :(
Offline prangano
« Reply #319 on: Sun, 06 October 2019, 02:16:53 »
Yes, QMK.
White
Hope you consider changing the LEDs to rgb
Offline anonthing00
« Reply #320 on: Sun, 06 October 2019, 02:20:45 »
Would I be able to change my shipping address before the keyboards gets shipped out?
Offline vi0till
« Reply #321 on: Sun, 06 October 2019, 02:35:50 »
Yes, QMK.
White
Yeah, hope you can consider rgb if it don't require redesign the pcb.
Sent from my VOG-L29 using Tapatalk
Offline PotatoTM
« Reply #322 on: Sun, 06 October 2019, 04:28:32 »
Ended up jumping in, GLWGB!
Offline muppen
« Reply #323 on: Sun, 06 October 2019, 07:27:59 »
When will you release the plate files?
Offline maxmakyk
« Reply #324 on: Sun, 06 October 2019, 09:58:53 »
Do you have the weight of the components so I can have a brief idea of how much my board will weigh?
Offline nicx
« Reply #325 on: Sun, 06 October 2019, 10:12:22 »
Yes, QMK.
White
Same here. Still on the edge for this one but RBG would make it an insta-buy.
Offline DaneOne
« Reply #326 on: Sun, 06 October 2019, 10:17:36 »
I've put in my order already, just waiting to get invoiced, but I also would love for the LEDs to be RGB. RGB per key is a game changer for layers. Still very excited though, checking multiple times a day if I've recieved the invoice!
Offline stillzman
« Reply #327 on: Sun, 06 October 2019, 10:43:52 »
when is the last day to place an order?
Offline Aox
« Reply #328 on: Sun, 06 October 2019, 13:34:28 »
RGB per key would indeed require a board redesign, so don't get your hopes up.
Offline Surefoot
« Reply #329 on: Sun, 06 October 2019, 14:30:50 »
I didnt receive the invoice yet ? Sent my order 2 days ago.
Offline KayVS
« Reply #330 on: Sun, 06 October 2019, 14:43:31 »
Will there be a typing test anytime soon?
Offline OmniSzron
« Reply #331 on: Sun, 06 October 2019, 17:01:56 »
GB started on 2019-09-25 and it's meant to run for two weeks, so that would make the final day of the group buy 2019-10-09 (Wednesday).
Fox Lab Key 65 split space
Offline suparnemo
« Reply #332 on: Sun, 06 October 2019, 17:03:59 »
They go out in waves, so you won't get invoiced right away
Offline Trixxur
« Reply #333 on: Sun, 06 October 2019, 21:59:28 »
Just put my order in. Waiting on invoice now   :D
Offline victorpre
« Reply #334 on: Mon, 07 October 2019, 04:19:30 »
I'm not sure if this was already asked but here it goes:
Are you making the plate files available for us to cut our own? :)
Offline zkurix
« Reply #335 on: Mon, 07 October 2019, 05:32:53 »
Hi, I got an invoice and paid but the information in the google form doesn't have the correct info. Does it just need to update?
Offline senter
« Reply #336 on: Mon, 07 October 2019, 08:25:57 »
Yes
Offline senter
Re: [GB] Fox Lab - Key 65 (Last two days to join)
« Reply #337 on: Mon, 07 October 2019, 08:39:16 »
ISO plate files have been attached in OP as promised. They are NOT fully tested tho.
Offline chakkii
« Reply #338 on: Mon, 07 October 2019, 09:10:28 »
so should I just get this file to lasergist or should I wait? will you fully test it?
Offline vsrnth
« Reply #339 on: Mon, 07 October 2019, 13:45:53 »
Is there a discord server or email which we can use to reach out to Fox Lab?
Offline muppen
« Reply #340 on: Mon, 07 October 2019, 15:05:46 »
there are no pieces sticking out on the bottom and top of the iso plates to hold it in a topmount, am i dumb or is it not finished completely?
Offline senter
« Reply #341 on: Mon, 07 October 2019, 15:36:42 »
The files look correct to me but I don't plan to do prototyping for them. You need to check the files by yourself and take the risks.
Offline senter
« Reply #342 on: Mon, 07 October 2019, 15:38:14 »
We don't have a discord server now.
You'll know my email address after I send out the confirmation email to you.
Offline senter
« Reply #343 on: Mon, 07 October 2019, 15:38:42 »
It's not top mount. It's gasket sandwich.
Offline senter
« Reply #344 on: Mon, 07 October 2019, 15:41:01 »
I plotted some figures according to the current orders. Hope it will help with your choices.
For top, middle, and bottom combinations.
Offline mg53
« Reply #345 on: Mon, 07 October 2019, 16:02:50 »
This looks great. I've submitted my order. I guess I need to keep my eye out for an invoice?
Offline Quasimodo
« Reply #346 on: Mon, 07 October 2019, 20:31:19 »
Oooh just had an idea for anyone wanting the ISO plate, in the UK or EU. I'd be very happy to organise a mini group buy, so we could get them slightly cheaper. I personally want brass, so I can't order from Lasergist, so I'm looking at UK laser cutting services. I'm going to get one made for myself regardless, but I thought I'd offer everyone the option to maybe get them slightly cheaper if we all pool together :) The website I'm currently looking at is Lasermaster.co.uk. I've sent a quote request in already with the plate file, so I'm waiting to hear how much it'll cost to make just one. If you are interested, they offer various steels, aluminium, copper and brass.
Offline Lil
    • designedbydark
« Reply #347 on: Mon, 07 October 2019, 20:54:54 »
Yeah cool I'd like to know how much a copper or steel plate would be
Sent from my G8341 using Tapatalk
Offline Pikeo
« Reply #348 on: Mon, 07 October 2019, 21:42:28 »
Is there a possible way solder rgb smd led on the hotswap pcb in place of the white smds?
Offline victorpre
« Reply #349 on: Tue, 08 October 2019, 01:16:47 »
Do you think plastic(PC) is also a possibility?
