Author Topic: [IC] 60% Keyboard Case made of MARBLE : "FirstSlab60"! (GB on 06/13)  (Read 83271 times)
Offline MarbleKeeb
  • Bring Marble to Keyboards
    • MarbleK Website
Re: [IC] 60% Keyboard Case made out of MARBLE : "FirstSlab60"! (06/27)
« Reply #100 on: Tue, 04 August 2020, 11:47:09 »
Following this prototype, I decided to made a few changes on how the PCB will be fixed to the marble.
I will use a aluminum plate glued to the marble.
I may not be understanding, but wouldn't this prevent the switches from being soldered into the PCB? Or would whoever is building the board glue the PCB and/or plate? What about if any modifications have to be made?
Different plate, not the switch plate. I think the idea is to glue a piece of aluminum to the bottom of the cavity in the marble to use as an attachment point for the standoffs that hold the actual switch plate in place
Splodeybaloney got the idea.
The FirstSlab60 will be a tray mount case, so the customized plate in steel (MOQ too high for alu) will be used to attach the standoff, as to drill in marble to put inserts is more complicated..
And the PCB will lay on these standoffs.
An image to help clarify all :
248713-0
definitely in the market for this, and the bigger bezels the better (IMO)!
I know that the estimated pricing is 200-300USD, but is there an estimate on the price of shipping to the States? With it being so heavy and a bit fragile, I imagine it can't be cheap...
It will probably be a package of around 3.5 kg shipped with DHL, so 40~45 USD of shipping, not too crazy :)
Offline Anthixious
« Reply #101 on: Thu, 06 August 2020, 05:08:12 »
Ok here me out. This might sound like too much, but if you guys were to do a traditional full-size, or an 80% TKL/WKL, with a separate numpad perhaps, I would smash the GB form/process so hard. A marble keyboard would be absolutely tremendous.
Offline VagueOrigin
Lol yikes... hope someone will acquiesce to you, but geez that'll be a heavy beast.
Sent from my SM-G975U using Tapatalk
Offline CustomerSupport
  • 🕸 developer
    • Discord
« Reply #103 on: Thu, 06 August 2020, 13:44:48 »
Ahh that does make more sense. Thanks!
Offline Anthixious
It'll for sure be a beast, but it'll be so worth it, because how many made-from-marble keyboards do you know of? ;) plus it'll be a typing experience unlike any other. Only thing that should break is the PCB and MAYBE the switches if I live that long lol.
Offline MarbleKeeb
    • MarbleK Website
Re: [IC] 60% Keyboard Case made out of MARBLE : "FirstSlab60"! (10/03)
« Reply #105 on: Sat, 03 October 2020, 06:40:05 »
Hello !
Here is an update on this project.
All details on the first post of this topic with a lot of photos !!
Only one here :
252915-0
Complete album :https://imgur.com/a/DulQHWu
Offline piercejenkins
« Reply #106 on: Sat, 03 October 2020, 07:00:38 »
This is almost perfect. Love how thicc it is!! Only thing I would change is making it higher profile by about 2mm so the you can’t see under the keycaps. I’m not a fan of floating keycaps. Could this be accomplished by making the pcb air a little deeper in the case? Otherwise this my end game 60%. Love the concept and I love SA caps. Seems this board was made for them!!
Offline MarbleKeeb
    • MarbleK Website
« Reply #107 on: Sat, 03 October 2020, 07:08:10 »
When taking the photos i did not screw down the PCB (because going back and forth).
Because of the rubber on the standoffs,  it would at least lower its position by 1 mm.
I will take better photos when I get it back from the manufacturer with the last modifications  :thumb:
Offline splodeybaloney
« Reply #108 on: Sat, 03 October 2020, 10:53:08 »
I'm so ready to give my money for this. Looks like an amazing case and a new, interesting material. Would absolutely love to have one
Offline pixelpusher
« Reply #109 on: Sat, 03 October 2020, 11:18:39 »
Makes sense.  But I definitely want to see it screwed down.  I don't know that 1mm is going to be enough to sink the caps in/lower the PCB so that the switches don't show.  Would really seal the deal if it was more sunken in.
Offline asdds22
« Reply #110 on: Sat, 03 October 2020, 20:32:56 »
I received your mail and came here to tell that the keyboard looks awesome! :thumb:
Offline jaykeebz
« Reply #111 on: Sat, 03 October 2020, 21:16:02 »
The prototype bezels, finish, etc. looks fantastic. Really well done!
I have to agree with the above users though, that gap between the bottom of the key caps and the case is a big turn off. It just doesn't look right as is, especially with those high profile keycaps :/
This is the kind of perfect flush fit that I would hope for: https://i.redd.it/xqusr13s6lx31.jpg
« Last Edit: Sat, 03 October 2020, 21:19:52 by jaykeebz »
Offline ZavaZ86
« Reply #112 on: Sun, 04 October 2020, 15:23:22 »
Any plans on selling matching wrist rest with it?
Offline MarbleKeeb
    • MarbleK Website
« Reply #113 on: Thu, 08 October 2020, 04:58:10 »
Thank you all for the feedback.  :thumb:
All the comments have been duly noted.
I daily use a low profile case, so I did not mind seeing the switches, but as it is the biggest request, I will abide and make sure we do not see the switches even if I have to make the case a little bit higher/deeper.
I made a draft of a wrist rest that would fit with this case, but I haven't confirmed yet.
Because quantities will be really low, it would be difficult for me to have a good price on it.. It is still an open part.
Offline pixelpusher
« Reply #114 on: Thu, 08 October 2020, 07:34:12 »
Nice  :thumb:
Offline Tom94
« Reply #115 on: Tue, 08 December 2020, 06:32:17 »
Just wanted to say that this looks _amazing_. Great work! I'll 100% buy it when it's available.
Offline Havattack
« Reply #116 on: Tue, 08 December 2020, 11:48:16 »
Me: Marble? Eh, remind me of gaudy 90's white-trash, New Jersery "rich", like the Sopranoe's house, but I'll check it out I guess..
clicks link*  BEZELS! Never-mind, give me 2! Still think it would look WAY better in concrete.
« Last Edit: Fri, 01 January 2021, 14:10:38 by Havattack »
Offline Petertoan
« Reply #117 on: Fri, 01 January 2021, 09:02:53 »
Interested! Looks awesome any updates regarding this?
Offline Havattack
« Reply #118 on: Fri, 01 January 2021, 14:13:57 »
This had me thinking (along the idea of "stone" as a keyboard material" I wonder how feasible it would be to do a GB or something, where you could just sell a 3D printed concrete form, and people could fill it with concrete at home, and make their own concrete keyboard case.. Yeah...I like my idea.
Offline dibstern
« Reply #119 on: Fri, 01 January 2021, 19:24:17 »
Okay I *need* a sound test for this
Offline MarbleKeeb
    • MarbleK Website
« Reply #120 on: Tue, 05 January 2021, 09:46:01 »
Thank you ! I truly appreciate  :thumb:
Need to show this beautiful material with some thick bezels
Yes, time for a small update.
The project is still going on, but I  had to slow down a bit on that and work on other projects.
I redesigned the metal parts used to attach the PCB, to be sure the keycaps sit well in the case.
I just passed the orders for these samples, then if all good.. everything should be good to go  :cool:
Offline oyinbo_pikin
« Reply #121 on: Sat, 20 February 2021, 23:55:15 »
I would pay for a marble case for Whimsy keyboard. Or at least a guide on how to cut marble to account for screw holes and such.  ;D
Offline Timception
« Reply #122 on: Sun, 21 February 2021, 04:59:51 »
Something I have never seen before, cool. Interested to see the weight of this.
Offline Ramjet151
« Reply #123 on: Fri, 26 February 2021, 20:50:47 »
What is the rough width. Just wondering since I may be buying a civilization wrist rest from you  ;D
Offline TomatoMan
« Reply #124 on: Sun, 18 April 2021, 17:28:52 »
Make this happen please!  :))
Offline MarbleKeeb
    • MarbleK Website
« Reply #125 on: Sat, 01 May 2021, 08:19:20 »
Hello !
I kept things a bit quiet but we were working hard on this project.
We finalized all the parts to make this marble keyboard case happen !
We will open the GB around the end of this month (May)   :eek:
More details to come soon   :thumb:
Offline Rumblethumps
Yessss, I thought I missed this!
Offline Starius
Excellent news!  :thumb:
Offline pixelpusher
Offline Finite
  • peer pressured into mk hobby, pls send help
« Reply #129 on: Sun, 02 May 2021, 15:26:24 »
Hello !
Yes! This is one of my peak interests right now! My wallet is about to get absolutely decimated by all the GBs that will be happening this May, but it's 100% worth it for something as unique as this.
« Last Edit: Tue, 01 June 2021, 16:11:07 by Finite »
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
Woah this kinda lit, have a few keysets in mind that would look nice with it.
Offline jakk
i love the concept! hope it does well in sales
Offline OmikronApex
« Reply #132 on: Tue, 01 June 2021, 07:30:53 »
Hello !
It's now the 1. of june, any updates on the GB?
Offline MarbleKeeb
    • MarbleK Website
Hello,
I finally made a sound test video !!
The quality is still far from our best keyboard youtubers but I really tried :)
I hope it helps people. :thumb:
Now I can work on preparing the GB launch, please book your Sunday 13th June  :p
Offline PradyXT
Marble case :O
This case looks amazing and I want one. Sadly I don't have the funds and the GB appears to be a small run :(
Offline MarbleKeeb
    • MarbleK Website
Re: [IC] 60% Keyboard Case made of MARBLE : "FirstSlab60"! (GB on 06/13)
« Reply #135 on: Mon, 07 June 2021, 07:27:16 »
Hello !
Thanks again for all the feedback and the support !! :thumb:
The GB is now announced and its thread is opened : https://geekhack.org/index.php?topic=113222.0
