Author Topic: [IC] Mekanisk Type X  (Read 30924 times)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« on: Thu, 28 November 2019, 13:43:04 »
Alongside the Klippe S, we will launch a tray mount.
This is a tray mount, It has 4 mounting points with silicone standoffs over so the PCB is isolated.
The typing experience is flexible, and I recommend foam to go with it(so the PCB has something to hit other than metal, if you type hard). I have personally used this case for a good while now, and it is the best tray mount experience I have personally had.
All the pictures use a much rougher anodizing than the final product.
Product page:
https://mekanisk.co/collections/type-x-1/products/type-x-mechanical-keyboard
Pricing:
$219 for a full kit with the case, PC plate and a WT60-D PCB.
$165 for just case + PC plate.
This case provides a fantastic typing experience, with an affordable price. Additionally it provides a great typing sound.
17 mm starting height. Walls reach up to cover the gap between keycaps and switches. This also helps with sound.
All cases ship with an PC(polycarbonate) plate. There is also limited color options. This is to save costs. You can buy additional plates, in the store.
Colors:
Ultramarine
Black
Silver
« Last Edit: Sat, 25 April 2020, 08:24:33 by LeandreN »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [IC] Mekanisk Type X
« Reply #1 on: Thu, 28 November 2019, 13:44:31 »
Reserved.
Also, extra parts that go along with this case can be found here:
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #2 on: Thu, 28 November 2019, 13:52:46 »
Oof, I literally just ordered a R3 Klippe from 1UP today & now you drop this, LOL! Looks like the wallet is gonna get quite a bit thinner than I had planned this week.
Edit: When will the sale be live on your site?
« Last Edit: Thu, 28 November 2019, 13:55:44 by Rob27shred »
Offline eniigma
    • Storefront:
« Reply #3 on: Thu, 28 November 2019, 13:58:19 »
very interested
Offline Rob27shred
« Reply #4 on: Thu, 28 November 2019, 14:04:32 »
Nevermind about my question on the release date, I checked your site & saw that it is coming soonTM. Anyways count me in for one when it does go live!
« Last Edit: Thu, 28 November 2019, 14:08:40 by Rob27shred »
Offline Nigolski
« Reply #5 on: Thu, 28 November 2019, 14:41:42 »
nice
Offline HanaDesu
Re: Mekanisk Type X
« Reply #6 on: Thu, 28 November 2019, 15:48:56 »
Very nice
Offline SirAnti
Re: Mekanisk Type X
« Reply #7 on: Thu, 28 November 2019, 17:08:44 »
Very interested as well! I like the design and the price! Can't wait  :eek:
Offline jrs
Re: Mekanisk Type X
« Reply #8 on: Thu, 28 November 2019, 17:12:46 »
Will the PC plate support ALPS?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: Mekanisk Type X
« Reply #9 on: Thu, 28 November 2019, 17:21:24 »
I also think I will be able to offer worldwide shipping of $25 for this case ;)
Offline pixelpusher
Re: Mekanisk Type X
« Reply #10 on: Thu, 28 November 2019, 21:09:21 »
What’s the typing angle?
Offline Mcnos
    • GMK Fuyu
« Reply #11 on: Thu, 28 November 2019, 23:19:01 »
Wait hold up,
You're saying this exceeds that of the Fjell?  :eek:
Offline macclack
  • The rhythm of the game
    • Macclack
« Reply #12 on: Thu, 28 November 2019, 23:19:38 »
Very interesting
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #13 on: Fri, 29 November 2019, 00:37:30 »
Sorry, that should have definitely have been in the info. It is 8 degrees.
Wait hold up,
Personally, yes. You have to remember that this is all subjective.
Very interesting
Thank you for your support.
Offline DJ Clicks
« Reply #14 on: Fri, 29 November 2019, 01:16:44 »
Does this only fit the WT60-D pcb? Or other pcbs can fit too like the kbd6x?
Offline funderburker
« Reply #15 on: Fri, 29 November 2019, 03:02:59 »
I'm quite sure it fits most standard 60% PCBs given it's a tray mount.
Keyboard design by Skepur
Offline VXQN
« Reply #16 on: Fri, 29 November 2019, 04:17:46 »
Can we see what a fully built one looks like?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #17 on: Fri, 29 November 2019, 07:24:02 »
Go to Mekanisk.co.
Offline pockydavid
« Reply #18 on: Fri, 29 November 2019, 08:01:00 »
Was this possible in the end, LeandreN? Currently have Type X in cart but it is 78USD shipping to Australia :(
Offline DJ Clicks
« Reply #19 on: Fri, 29 November 2019, 08:06:22 »
Still kinda confused about the ansi plate. Does this ansi plate allow for tsangan layout? If not, how do i tell if a plate does?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #20 on: Fri, 29 November 2019, 08:40:41 »
Can you check if you have the correct quantity in the card, Shipping to Aus should be half that cost.
Yes it does.
Offline equalunique
« Reply #21 on: Fri, 29 November 2019, 08:42:06 »
I wonder if I could put a Boardwalk PCB into this. Might go for an ultramarine one if that's possible.
Sent from my Ono-Sendai Cyberspace 7 using Tapatalk
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #22 on: Fri, 29 November 2019, 08:43:07 »
Should be possible.
Offline pockydavid
« Reply #23 on: Fri, 29 November 2019, 08:45:01 »
Would it be because I added the foam? Is the shipping cost correct if it doubles when I add that to my cart?
Offline Rob27shred
« Reply #24 on: Fri, 29 November 2019, 08:53:15 »
Hey LeandreN, how long will the Type-X be up for order & is there a cap on the number of them you will be making? I am very interested in one, but just bought a Klippe for my ALPS64 build from 1up yesterday & my wallet could use some recovery before I order this.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #25 on: Fri, 29 November 2019, 08:56:04 »
I changed some settings, can you try again? I have no idea why this is happening, I have no shipping rate that is $78.
There is no cap on the Type X and it will be open for a week or two more.
Offline Rob27shred
« Reply #26 on: Fri, 29 November 2019, 08:57:54 »
Awesome, thanks for the quick response! Now I know I can safely wait till next week to order one of these bad boys!
Offline Sup
« Reply #27 on: Fri, 29 November 2019, 10:34:13 »
inb4. BuT ItS nOT GasKET/TrAy MOunt euh. Very nice looking keyboard if i didn't jump on the Duck orion keyboard would have probably jumped on this.
current
Coming soon
Offline Steezus
  • Keeper of Facts
« Reply #28 on: Fri, 29 November 2019, 10:45:55 »
This is tray mounted.
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #29 on: Fri, 29 November 2019, 13:20:14 »
Combined with foam under the PCB this will be an excellent purchase. I have basically that configuration in my T60 (90a o-rings, thick shelf liner, plastic plate), it feels and sounds excellent. Brass also gets more comfortable to use in this kind of setup.
« Last Edit: Fri, 29 November 2019, 13:24:42 by tex_live_utility »
Offline Warrenified
« Reply #30 on: Fri, 29 November 2019, 20:54:48 »
I ordered a Type X with Foam to CONUS. Was shipping supposed to be $50?
Offline Skeezy
« Reply #31 on: Sat, 30 November 2019, 01:57:55 »
I'm having the same problem. Is the shipping suppose to be $78?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #32 on: Sat, 30 November 2019, 04:10:50 »
This is my experience with the prototypes also, you get more of a soft landing experience, even on brass.
I will go through and double check all shipping prices and refund if there are anyone that was charged the wrong amount.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #33 on: Sat, 30 November 2019, 04:11:21 »
No, please check again, I think I have solved this issue.
Offline Skeezy
« Reply #34 on: Sat, 30 November 2019, 07:58:18 »
Still having the same problem :(.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #35 on: Sat, 30 November 2019, 14:09:14 »
Can you order without the foam, and add a note that you want the foam?
Offline Skeezy
« Reply #36 on: Sat, 30 November 2019, 17:24:38 »
I removed the foam and added a note and the shipping is still $78.
Offline cong314159
« Reply #37 on: Sun, 01 December 2019, 01:58:47 »
Do you guys have a picture of the back and the bottom of the case?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #38 on: Sun, 01 December 2019, 06:36:27 »
Hmm, I will look at this before the pre order closes. I am so sorry for the issue.
You can order, and I will refund the shipping cost, or you can wait a couple of days and I will have to find a solution.
There are some pictures on the website.
Offline Skeezy
« Reply #39 on: Sun, 01 December 2019, 08:25:46 »
I'll wait for a couple of days. Hope to hear back from you soon :).
« Reply #40 on: Sun, 01 December 2019, 08:31:09 »
surprised to hear you made a tray mount better than fjell... interesting. I kinda wanna try one lol
Offline renolo
« Reply #41 on: Sun, 01 December 2019, 08:47:29 »
So, when is this running?
Doritos, Cheetos, or Fritos.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #43 on: Sun, 01 December 2019, 16:36:16 »
Try again!
Offline Rob27shred
« Reply #44 on: Sun, 01 December 2019, 17:55:14 »
Try again!
Hopefully the shipping bug is fixed soon, as i was planning on ordering my Type-X in the next few days & will be ordering the foam as well.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #45 on: Sun, 01 December 2019, 19:17:09 »
Try again!
It should have been fixed now.
Offline kaisn
« Reply #46 on: Sun, 01 December 2019, 20:25:02 »
A soundtest would be most splendid
Offline renolo
« Reply #47 on: Mon, 02 December 2019, 01:18:33 »
Whats the typing angle of the Type X?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #48 on: Mon, 02 December 2019, 05:16:44 »
Will try to make one very soon!
8 degrees
« Reply #49 on: Mon, 02 December 2019, 09:25:07 »
What's the hardness of the rubber standoffs?
