Author Topic: [IC] Jūbi | 60%+ Layout Custom Keyboard [GB Date 2/28 12:00PM PST]  (Read 33906 times)
Offline Pwner
  • soon™
Pricing & Availability:
50 units
GB Date: February 28th
-Time: 12:00PM PST
-Price: $450
Vendor: Switchplate Peripherals
Specs & Features:
  • 6° typing angle
  • 6063 aluminium
  • 17mm front height
  • Seamless
  • Top mounted Red aluminum plate or pcb mounted (modified version of what was used on the Equinox)
  • Semi-fixed aluminum plate (plate file will be made available)
  • WT70-A USB-C PCB by wilba.tech (QMK/VIA)
  • Case colors: Black, Silver, Dark Gray
  • Case options: Standard or WKL top
  • Polished stainless weight
Layout support:
More images:
*Please note: The prototype was intentionally left raw, as such all machining marks are visible.*
Proto --> Production changelog:
  • Front edge of the top even with the base
  • Case corners increased fro 3mm to 5mm
  • Base corner fillets changed to match the top corner fillets
  • Top mount positions overhauled
  • PCB mount style overhauled
  • PCB mount positions overhauled
  • Weight position and size overhauled
FAQ/Other notes:
  • This board will NOT be made at the same factory as the Southpaw boards.  This will be made at a factory that I have personally used and I will have full communication with the rep that will be handling this project.  I will be providing all updates.
  • The dual mounting options will not interfere with each other no matter which option you choose to use.
  • Ion Keyboards Discord Server
Special thanks:
@gang - <2
Kafka - For the name and the initial inspiration
amtra5 - For the prototype PCB
reconsiderit - For the proto, storefront and logistics
« Last Edit: Thu, 27 February 2020, 11:16:13 by Pwner »
Offline would?
  • Formerly wouldworks
    • Finder Works
Re: [IC] Jūbi | 60%+ Layout Custom Keyboard
« Reply #1 on: Mon, 30 December 2019, 04:18:32 »
GL with the GB, i love this board and i love you
Offline Jae-3soteric
  • https://www.youtube.com/channel/UCAIHiFKJt69HNad6r
    • Jae | Top Clack
« Reply #2 on: Mon, 30 December 2019, 04:19:00 »
Yes. Need to add this to the collection
Sent from my iPhone using Tapatalk Pro
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #3 on: Mon, 30 December 2019, 04:20:32 »
Interested. Will be watching this sporadically.
Offline Furikurichemy
« Reply #4 on: Mon, 30 December 2019, 04:22:29 »
Very nice. Hope it's closer to $4.
Offline reconsiderit
  • I'm actually not left handed www.switchplate.co
« Reply #5 on: Mon, 30 December 2019, 04:28:02 »
Should have a final price as soon as the quote comes back. Initial quote was for brass weight at 35qty which is what the estimate is based off of. Will update as soon as I know.
Southpaw 65 || Southpaw Full Size || Trinity XT TKL || TGR Jane V2 || TGR 910 RE || Duck Jetfire || Matrix Lab 1.2 OG || Jubi || Lunar || Lunar II || g80-1800 HEU
switchplate.co
Offline snelltrail
« Reply #6 on: Mon, 30 December 2019, 04:37:10 »
Why is this being offered with winkeys?
Offline belgium_waffles
« Reply #7 on: Mon, 30 December 2019, 04:48:18 »
yeah it's pretty cool i guess
Offline PeenixStarr
« Reply #8 on: Mon, 30 December 2019, 04:51:41 »
Finally! Providing plate files and supporting ISO on the PCB is the way to go  :thumb:
Offline Quinella
« Reply #9 on: Mon, 30 December 2019, 05:15:00 »
nicenicenicenicenicenicenicenicenicenicenicenicenicenice
Offline modeseven
« Reply #10 on: Mon, 30 December 2019, 05:41:12 »
Fcfs? Raffle pretty please?
Offline bthezebra
« Reply #11 on: Mon, 30 December 2019, 06:06:48 »
I've been following since Kafka's IC and glad this is finally getting completed!
Offline TheArcticFox_27
« Reply #12 on: Mon, 30 December 2019, 06:52:45 »
Noice.
Offline Visionaire
« Reply #13 on: Mon, 30 December 2019, 09:46:12 »
Neat board. I'm taken back a bit on the price. $400-500 for a 60% seems a bit steep imo.
Offline noorejji
« Reply #14 on: Mon, 30 December 2019, 10:38:11 »
Is there any merit to running this particular board plateless, or is it just for those who will be adding their own plate? Will it be cheaper plateless? What kind of plate material do you reckon would be ideal for this board?
Offline mrpetrov
« Reply #15 on: Mon, 30 December 2019, 11:16:47 »
I love it, definitely very very keen.
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #16 on: Mon, 30 December 2019, 11:23:07 »
Fingers crossed it's priced closer to $400 than $500, but either way I am pretty interested in this design! Definitely will be keeping an eye out for updates!
Offline AuthenticDanger
« Reply #17 on: Mon, 30 December 2019, 11:27:07 »
Gunna start saving my pennies for this!  :thumb:
F Keys belong on the left.
Offline pikku-allu
  • IG: @kinnalek
« Reply #18 on: Mon, 30 December 2019, 12:07:39 »
Yes, it's stunning! I vote for PCB mount. Weirdflex?
Offline DukeEsquire
« Reply #19 on: Mon, 30 December 2019, 12:28:17 »
You son of a *****. I'm in.
Offline Rob27shred
« Reply #20 on: Mon, 30 December 2019, 12:36:54 »
The PCB mount option is pretty interesting! I really want to try out a plateless build that is mounted any other way than tray mount. I did a scratch plateless 60% build that I have in a KBDfans 5° case & it feels great compared to a build with a plate in it. I can only imagine how soft & flexy a plateless build would be without any standoffs under it!
Offline Pwner
  • soon™
« Reply #21 on: Tue, 31 December 2019, 07:22:10 »
All depends what kind of typing experience you prefer/ what switches you want to use.  You'll get everything in the kit to run it either way you choose, be it with a plate or plateless.
Plateless is the best, imo.
We are legitimately doing what we can to keep it as low as possible, tariffs don't help.
<3
Offline nicx
« Reply #22 on: Tue, 31 December 2019, 10:24:31 »
Gonna be watching this one closely, but anything above $400 would be a deal break for me personally. Hope it works out!!!
Offline pixelpusher
« Reply #23 on: Tue, 31 December 2019, 11:12:12 »
Teacher says, every time a pwner board drops, a bank account loses some digits.
Happy New Year!  Gotta figure out what I could put on this board.  She's a looker.
Offline VXQN
« Reply #24 on: Tue, 31 December 2019, 12:01:56 »
Excited that this is seeing the light of day but yikes-ing a bit on the price. Any paricular reason for the change from the brass weight of the proto to a new stainless weight?
Offline jimboytacos
« Reply #25 on: Tue, 31 December 2019, 13:53:52 »
Haven't been around this community long enough, but are owner board high quality and sought after like them the boards that sell for $$2.5k-5k on r/mk?
Genuinely asking.
Offline DukeEsquire
« Reply #26 on: Tue, 31 December 2019, 17:23:39 »
Genuinely asking.
Def more than that.
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #27 on: Tue, 31 December 2019, 18:23:26 »
Genuinely asking.
Don't join a group buy just to flip the keyboard.
Offline Mekuno
« Reply #28 on: Tue, 31 December 2019, 19:22:11 »
Genuinely asking.
yikes.
Offline hottrout
  • I'd Hit Dat Key
« Reply #29 on: Wed, 01 January 2020, 05:04:32 »
nice design
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline Artemie
  • Don't Let Your Memes Be Dreams
« Reply #30 on: Wed, 01 January 2020, 07:42:38 »
Nice i69.
| 420CL | Fanoe | Porpoise | KFE R1 Silver| MxSS |  is0 Pink & Silver | HBCP Polycarbonate | Matrix 2.0 Additional Purple | TGR Police | Singa Jaguar Green | KFE R2 Blue | RS so lit | Dolch CR Black | Jelly 60 Blue | Belle en Rose | Kei R2 Olive | Dalco 959 Mini | Aripeko
Boards in GB: | IU board |
Previous Boards: QXP | Singa  | UTD | Taichi | Jane v2 Red | Jane v2 CE
Offline chriszhu
  • (* ̄(エ) ̄*)''
« Reply #31 on: Wed, 01 January 2020, 08:52:36 »
Lovely
Offline Sup
« Reply #32 on: Thu, 02 January 2020, 02:08:03 »
Genuinely asking.
Yikes don't join a GB just to make money. Cmo bruh
« Last Edit: Thu, 02 January 2020, 02:11:20 by Sup »
current
Coming soon
Offline The Equals D
« Reply #33 on: Fri, 03 January 2020, 00:55:27 »
I like it, the design is neat, happy to see more boards with the left side macro rows.
Offline CherryTeam
  • Cherry Cherry Lady
« Reply #34 on: Fri, 03 January 2020, 01:20:29 »
Nice !  :thumb:
Offline MMKB
« Reply #35 on: Fri, 03 January 2020, 01:21:05 »
Stunning. Could totally use the bottom left four keys as the arrow cluster
Offline grav3serker
  • graves + berserker = grav3serker
« Reply #36 on: Fri, 03 January 2020, 03:41:43 »
I really dig this. 4th color is TBD - maybe E-White?
Offline fireworm
« Reply #37 on: Tue, 07 January 2020, 19:01:13 »
Yes, please.
I'll ask my two typical questions:
Ne Alps Support avail?  (This would work great with some of the vintage AT Alps caps, IMO.)
Ne Split Space avail?
Offline VXQN
« Reply #38 on: Wed, 08 January 2020, 04:10:14 »
Yes, please.
I'd also like split space.
Offline fireworm
« Reply #39 on: Thu, 09 January 2020, 09:37:26 »
Yes, please.
Looks like the ship has sailed.
Discord is easier to talk about these things.  I got a response there right away.
I think I'm gonna work with them and get a handful of custom alps-mx + split space pcbs. No smd components, which saves money, means you would need to solder everything (like the mcu, and diodes).
Offline Quriosity
« Reply #40 on: Fri, 10 January 2020, 14:02:05 »
Interested
Offline Pwner
  • soon™
« Reply #41 on: Sat, 15 February 2020, 10:28:20 »
Working out final pricing, group buy date to be announced soon.
Offline pixelpusher
« Reply #42 on: Sat, 15 February 2020, 11:01:11 »
Hype intensifies  :eek:
Offline bthezebra
« Reply #43 on: Sat, 15 February 2020, 11:08:55 »
So much ready
Offline rmendis
  • Artisan addict
« Reply #44 on: Mon, 17 February 2020, 00:02:33 »
Nice design - different! Would join if layout supported arrow cluster. Will be watching the fun. GLWB!
Offline Gert Fischer
« Reply #45 on: Fri, 21 February 2020, 06:06:57 »
arrow cluster would destory the clean look
Offline Pwner
  • soon™
Re: [IC] Jūbi | 60%+ Layout Custom Keyboard [GB Date 2/28]
« Reply #46 on: Fri, 21 February 2020, 06:46:21 »
Group buy starting next Friday, February 28th.  Price & time to be announced asap.  Group buy will be live until March 28th or until the 50 units are sold out.
Offline Eviscerae
« Reply #47 on: Fri, 21 February 2020, 08:11:18 »
Do you plan to make the PCB available as a separate item? And, is it QMK Configurable?
Offline Jaltr
« Reply #48 on: Fri, 21 February 2020, 08:53:32 »
yes. just. yes.
Offline lunr
« Reply #49 on: Fri, 21 February 2020, 18:02:06 »
glad this is coming to gb soon. been looking forward to this.
