Author Topic: [GB] GSKT-00 (Shipping almost finished, 80% done)  (Read 1154221 times)
Offline sirieous
  • help
Re: [GB] GSKT-00 (Compiling orders for confirmation)
« Reply #600 on: Sat, 25 January 2020, 10:20:12 »
For real though, I attribute me getting in this time on the second run partly because I saw that post giving us those tips. The one about zooming out so that there was less scrolling was actually big brain. After I filled in the first plate options I zoomed out completely because I just had to hit none for the rest. Shout out that dude.
Offline Zeelobby
« Reply #601 on: Sat, 25 January 2020, 10:26:48 »
100x this. Might have helped more than anything else
Sent from my Pixel 3 XL using Tapatalk
Offline Hoipolloi
« Reply #602 on: Sat, 25 January 2020, 10:29:21 »
what post?
i couldn’t get a spot. would love some tips for future.
Offline sirieous
  • help
« Reply #603 on: Sat, 25 January 2020, 10:44:59 »
First page is your personal info, email user name etc. then it's a lot of multiple choice pages. Board layout, ano colour, pcb 1 and 2 colour, then 4 pages for 4 plates both alps and MX, cerakote option text field, extra gasket and screw set options, "yes i agree to bow to thee" check mark, and then the most important page; trivia! gotta get this one right or else
Also, side note, weaston already said he will be switching things up a bit so this info will probably be outdated.
Also also, it's common speedrunner tradition to not hold secret strats so I will give you an extra tip. Zoom out on the page to have more info on the screen at once. Less scrolling, more time save!
And if you think I am leaking important info that will mess with the competition you can go and sh
Thanks, yo. This is what I was wondering just like a gist of what to expect.
Idk what keyboards you use, but I have a layer on a QMK board that outputs strings such as my paypal email, GH username, etc. I suggest getting that setup. Wouldn't hurt to set up addresses too, but I doubt you would need that for this form
This post and the one that is being quoted is the one that really helped me. Hope it finds you some success in future boards. (Also sorry if this is an incorrect way to reply to the guy above, I'm still new to Geekhack posts and comments)
Offline Fnzzy
« Reply #604 on: Sat, 25 January 2020, 12:08:18 »
I just got the email for the order sheet, thanks. Could you make the row with the "case, plate, pcb" etc. sticky so that we don't have to scroll up every time to see to what item the choice referred to? Just select row 7 and go view > freeze > up to current row.
Offline zekth
« Reply #605 on: Sat, 25 January 2020, 12:18:21 »
I'm in the list and haven't received any email  :eek:
EDIT: Fixed
« Last Edit: Sat, 25 January 2020, 12:27:49 by zekth »
Offline weaston
« Reply #606 on: Sat, 25 January 2020, 12:33:50 »
I was working through some google issues so you might have received a few emails and some of the sheets might be dead so sorry for the extra emails and thanks for bearing with me.
I have sent an email with a sheet containing the order number and the associated username to all the people I have emails for.  If you did not receive an email with the order number sheet then I do not have a correct email for you so please make sure to pm me so we can fix that.  You will still be able to view that sheet if someone sends you a link, so please take the time to make sure you personally received an email with it, otherwise like I said your email needs to be fixed.
Here is a link to a sheet with all order numbers and options.  As changes happen they will reflect on the sheet so make sure to keep checking back after I have said that I adjust your order: https://docs.google.com/spreadsheets/u/2/d/e/2PACX-1vRLejPDSIHsqjFcKOUVX6FZ2zLQnlj2-OIckvNC3iRKImaBA0kIa1XRI-EWQGybS8AOizBPLgyG1SM_/pubhtml?gid=0&single=true
Instructions for modifying your order, including what changes are allowed are outlined in the sheet.
My inbox is open here and on Discord, so feel free to send me a message.  Let me know if there are any questions/concerns.  Thank you all.
Edits are accepted until Monday January 27th at 5pm EST.  After that I will start sending invoices.
(Again there was another sheet I accidentally sent out, which was inaccurate, so please only reference the one above.  Thanks.)
« Last Edit: Sat, 25 January 2020, 12:40:15 by weaston »
DK Saver | Kingsaver | OTD 360 Corsa | OTD 456GT | OTD Cheat | KMAC 1.3 | KMAC 1.2 | KMAC Happy | KMAC Pad | KMAC Mini (Revo) | Singa | HHKB Pro 1 | GSKT-00 | IBM 5251 | IBM Model F XT | IBM Model M | Dolch PAC | Kinesis Advantage
Offline weaston
« Reply #607 on: Sat, 25 January 2020, 13:11:35 »
Apparently some people aren't receiving any email from Google about the new order form sheet so I'm just posting it here.  Google is really giving me a hard time rn.
New Updated Username and Order Form Sheet here: https://docs.google.com/spreadsheets/d/e/2PACX-1vQMHo2QqRLlHx63qiji9BAJ_hCQ99DZ18Yz0rWARaZU7BEm1prhhhWArGpeGd2hQhtdz0dJ-jkFGhZz/pubhtml?gid=0&single=true
OP also updated.
« Last Edit: Sat, 25 January 2020, 13:14:07 by weaston »
Offline zekth
Re: [GB] GSKT-00 (Changes accepted until Monday 5pm EST)
« Reply #608 on: Sat, 25 January 2020, 13:17:14 »
For mailing i'd recommend to use a service like Mailchimp which has a free offer for the size of the GB: https://mailchimp.com/
It would be easier for you to handle all the updates and so on.
Offline noahf
« Reply #609 on: Sat, 25 January 2020, 14:23:58 »
each kit comes with 1 gasket, correct? so if I ordered 2 kits, it comes with 2 gaskets?
Offline jrs
« Reply #610 on: Sat, 25 January 2020, 16:02:34 »
No, it just comes with a tube of silicone caulk that you need to put between the plate and the PCB.
Offline chayu
« Reply #611 on: Sat, 25 January 2020, 16:31:35 »
Some people seem to have responded with wanting an extra plate/plate layout, but not selecting a plate option, or selecting they don't want a plate but then selecting a plate option.
Eg. No to Alps 2 but chose Polycarbonate
Offline weaston
« Reply #612 on: Sat, 25 January 2020, 16:40:19 »
Yeah i'll be cleaning that up as I go through and edit. I thought I got them all already but seems not, no biggie.
In response to earlier, yes each case comes with 1 gasket and 1 set of screws.
Offline jrs
« Reply #613 on: Sat, 25 January 2020, 16:57:56 »
It doesn't look like a lot of people selected Alps plates, which kind of surprised me.  Wasn't the GSKT-00 designed with alps in mind?
Offline loud_asian
« Reply #614 on: Sat, 25 January 2020, 20:25:54 »
Any chance you could post the alps plate options again? I'd love to add one to my order but I forgot what was available.
Offline nikkynak
« Reply #615 on: Sat, 25 January 2020, 21:29:15 »
I was curious about the results on the form, and what everyone got. So I ran a few quick visualizations on the data.
I guess WKL is king
Edit:
Made the full/half difference more apparent through the colors
« Last Edit: Sat, 25 January 2020, 22:33:54 by nikkynak »
Offline Aznguyen316
« Reply #616 on: Sat, 25 January 2020, 21:45:15 »
thanks nikkynak, I just did some Ctrl+F to see some numbers lol.  I am kind of surprised WKL was most ordered for a 60% in all colors. Debating on adding a half plate option.  Already have full POM.
Offline jrs
« Reply #617 on: Sat, 25 January 2020, 21:50:28 »
I got the black HHKB with red half plate.  Still trying to decide on keycaps, but I'm leaning towards JTK BRED.
Offline joe405
« Reply #618 on: Sat, 25 January 2020, 23:00:48 »
I didn't get an email either. My order and username are correct though. Have PM'd Weaston
Offline weaston
« Reply #619 on: Sat, 25 January 2020, 23:19:00 »
Yeah i don't think it sent an email like I expected it to, really not sure why. If anyone thinks they had a problem with their email then pm me, otherwise I suppose we'll find out when invoices start rolling out around Monday-Tuesday hopefully.
« Reply #620 on: Sun, 26 January 2020, 00:26:24 »
When will we have a chance to review our orders?  cuz I think I incorrectly entered one of the fields for plate options.
For what it's worth, from the IC thread.
well that is unfortunate, especially considering the practice form was incomparable to the actual form.  nbd, guess I'm not getting a half plate then  :D
what other GB has had a practice form anyways, not sure why it matters that is was different, you usually don't even know what in it till you open it
none which is why this gb is art
Offline zekth
« Reply #621 on: Sun, 26 January 2020, 03:00:45 »
PM sent. GH + Discord  :thumb:
Offline msvming
« Reply #622 on: Sun, 26 January 2020, 11:02:46 »
PM Sent regards order  ;D
Offline chayu
« Reply #623 on: Sun, 26 January 2020, 13:37:13 »
Some other data points on the orders after cleaning up some of the entries when it was released on Friday:
- Total of 447 plates
- 217 are full (48.55%), 214 are half (47.84%)
- 224 are alu (50.11%), 102 are PC (22.82%), 97 POM (21.70%), 18 Steel (4.02%), 6 Acrylic (1.34%)
- 77 people got just 1 plate; 92 got 2, 24 got 3, 27 got 4, 1 person got 6, and 5 people have no plates (at least one of these people put partial/incomplete answers for plate options)
I ignored the Alps entries where a layout or full/half wasn't specified.
Offline weaston
« Reply #624 on: Sun, 26 January 2020, 14:52:10 »
I've gotten a lot of pms since editing opened.  Have been letting them accumulate so I can tackle them all at once.  Will be doing the first edit wave tonight some time.  Thanks all.
Offline happa
« Reply #625 on: Sun, 26 January 2020, 15:39:21 »
PM'd!
Offline Obe
« Reply #626 on: Sun, 26 January 2020, 19:46:01 »
PM on GH and Discord.
Offline weaston
« Reply #627 on: Sun, 26 January 2020, 20:48:40 »
I've gotten through about half of the change requests.  If I changed it then I responded, so if you have not received a response then you have not had your order updated yet.  Even if I did respond please check the public order sheet and double check, it's entirely possible I messed up or missed something so let me know if I did.
Remember requests for edits end tomorrow at 5pm so get them in before then.
Thanks all.
Offline Quriosity
« Reply #628 on: Mon, 27 January 2020, 01:31:45 »
PM sent.
Offline mech0nly
« Reply #629 on: Mon, 27 January 2020, 02:19:23 »
PM sent. Thanks weaston!
356mini | 360C | G81-3000SAT | G81-3000SAU | G80-3000LPCXY-2 | G80-3485LWNUS-2
Diamond Polished Cherry Switches!
Offline ymaaan
« Reply #630 on: Mon, 27 January 2020, 05:31:40 »
PM sent in Geekhack as well. Thanks!
Sent from my SM-A505GN using Tapatalk
« Last Edit: Mon, 27 January 2020, 15:22:21 by ymaaan »
Offline Azirez
« Reply #631 on: Mon, 27 January 2020, 07:40:49 »
PM sent yesterday. Don't see any changes in spreadsheets.
Offline mycarrotbroke
« Reply #632 on: Mon, 27 January 2020, 08:32:14 »
Pm sent!
Offline Haskel
« Reply #633 on: Mon, 27 January 2020, 10:11:23 »
PM sent on Discord. Thanks for accommodating.
Jane V2 CE | Frog TKL | GSKT-00 | TKL One (PC) | RS60
Offline infinitecurry
« Reply #634 on: Mon, 27 January 2020, 12:18:59 »
Sent pm yesterday
Offline aslanxdeft
« Reply #635 on: Mon, 27 January 2020, 13:09:48 »
Pm sent
Offline jn_hanone
« Reply #636 on: Mon, 27 January 2020, 13:24:22 »
PM sent!
Offline catamscott
« Reply #637 on: Mon, 27 January 2020, 14:39:13 »
pm sent yesterday or day before (forget which), just wanted to note that here too before 5pm est.
Offline vegs
« Reply #638 on: Mon, 27 January 2020, 14:43:18 »
PM sent as well :thumb:
hhkb 4 life
buy less
Offline hawkz
« Reply #639 on: Mon, 27 January 2020, 15:06:31 »
PM sent on discord
Offline jpg2401
« Reply #640 on: Mon, 27 January 2020, 15:09:14 »
I sent my PM on Geekhack two days ago. Noting that here now
Edit: It doesn't look like it went through, so I have just now sent a message.
« Last Edit: Mon, 27 January 2020, 15:13:52 by jpg2401 »
Savage 65 | GSKT-00 || Valhalla | X60 V2
Offline Zeelobby
« Reply #641 on: Mon, 27 January 2020, 15:18:32 »
Pmed on discord with the additional gasket/screw
Offline frostfiree
« Reply #642 on: Mon, 27 January 2020, 15:21:35 »
PM'd on GH about switching from full to half plate.
Jane V2 | Jane V2 CE | Thermal | Kei | GSKT-00 | Duck Orion V3 | U80 | Salvation | 378 | HHKB | Cloudline | Bias | TKL One | Kaze | Jane V2 ME
Offline Zurg Eon
« Reply #643 on: Mon, 27 January 2020, 15:50:47 »
PMEMED!
Offline sJ1N
« Reply #644 on: Mon, 27 January 2020, 15:53:41 »
PM'd as well on GH
Offline weaston
« Reply #645 on: Mon, 27 January 2020, 16:07:26 »
Change requests are now closed.  I will start working on getting all the changes in.
Hopefully will start on invoicing tomorrow.
Thanks all :thumb:
Offline cdhoffmann
« Reply #646 on: Mon, 27 January 2020, 16:14:20 »
Thanks all :thumb:
NOICE
Offline mrpetrov
« Reply #647 on: Mon, 27 January 2020, 17:26:43 »
Thanks all :thumb:
Hey weaston, I dm'd you on here and on GH but the google doc doesn't show my additional order request (extra pcb and alu mx half plate) - so not sure if you've changed to order doc online or just missed my dm's perhaps? Thanks mate!
Offline tkh531
« Reply #648 on: Mon, 27 January 2020, 18:39:27 »
Thanks all :thumb:
I also sent a PM on GH, this past Saturday (1/25). I'm sure hes just backed up with a bunch of messages.
Offline weaston
Re: [GB] GSKT-00 (Changes closed - updating totals - invoicing soon)
« Reply #649 on: Mon, 27 January 2020, 20:37:58 »
Just got a lot of changes done, still have one more page of them to get through, should all be fully sorted by tomorrow night, then invoicing after that.  Thanks for being with me.
As I said before, if I made the requested changes I will have responded to you so check your pms then check the public sheet a while after, sometimes the changes take a few minutes to reflect.
