Author Topic: [IC] GMK Oni 💧💧 GB LIVE AUG 4 - SEP 1 "Bapo x Miraie"  (Read 285956 times)
Offline BuddhaBen
Re: [IC] GMK Oni - VENDOR UPDATE 4/3/2020
« Reply #50 on: Sun, 05 April 2020, 01:46:08 »
Any chance of a RAMA artisan?
Offline BapoDonu
« Reply #51 on: Sun, 05 April 2020, 10:23:02 »
Working on Rama Enter.Yes there is chance.
Offline BapoDonu
« Reply #52 on: Tue, 07 April 2020, 07:14:19 »
Small update-I found a very closely matched RAL colors ,so working on switching everything from pantone to RAL.
Offline Magas
« Reply #53 on: Sat, 11 April 2020, 15:57:21 »
I NEED THIS
Offline DrHigsby
  • The doctor is in.
« Reply #54 on: Sat, 11 April 2020, 16:14:24 »
How’s that coming along? How “accurate” are they? Would be cool to see a side by side comparison.
Offline BapoDonu
« Reply #55 on: Sat, 11 April 2020, 17:23:14 »
So alphas are pretty close, I think they look even better with RAL it's more blueish.I've changed the mods to be darker so i can put a white accent piece instead of the dark blue ones.Renders soon.
Offline Mcnos
    • GMK Fuyu
« Reply #56 on: Sat, 18 April 2020, 16:18:26 »
Not sure about the set but
Rem > Emilia.
Offline jonathanyu
« Reply #57 on: Sat, 18 April 2020, 19:59:19 »
im in.
Offline BapoDonu
« Reply #58 on: Sun, 19 April 2020, 11:24:37 »
Thanks a big big update is coming our way so those renders are technically outdated.
Offline prettydouchebag
« Reply #59 on: Sun, 19 April 2020, 14:40:52 »
Is there anywhere to get updated on the board that is running alongside this set?
Offline Novafish
« Reply #60 on: Fri, 24 April 2020, 11:25:17 »
unit 00 discord server
« Last Edit: Sun, 10 May 2020, 14:55:35 by Novafish »
Offline hmmmwhatsthis
  • no
« Reply #61 on: Fri, 24 April 2020, 13:33:55 »
Rem > Emilia.
how dare you
hiragana-less alphas make it look v clean  :thumb:
Offline BapoDonu
« Reply #62 on: Fri, 24 April 2020, 13:46:59 »
Rem > Emilia.
how dare you
Update in around 3 days.Base kit will be Latin only and add on kit will be mono Hiragana.
Offline blizzara01
« Reply #63 on: Fri, 24 April 2020, 22:00:15 »
Rem > Emilia.
how dare you
oof thats nice.
Offline BapoDonu
« Reply #64 on: Sat, 25 April 2020, 12:53:02 »
Rem > Emilia.
how dare you
oof thats nice.
Just something to chew on.This is not a base kit render neither the mods are correct just to showcase how the new colors will look like,all of them are RAL.
  • no
« Reply #65 on: Sat, 25 April 2020, 18:06:47 »
Rem > Emilia.
how dare you
oof thats nice.
actually quite like this aesthetic especially with the accents. nice job bapo
Offline dannyny
Re: [IC] GMK Oni
« Reply #66 on: Sat, 25 April 2020, 18:52:18 »
Put me down for one set.
Offline xia0ti
Re: [IC] GMK Oni
« Reply #67 on: Sat, 25 April 2020, 21:13:44 »
Rem > Emilia.
how dare you
oof thats nice.
Love it!Wanna have white or pink arrows.
从我的 iPhone 发送,使用 Tapatalk
« Last Edit: Sun, 26 April 2020, 03:58:10 by xia0ti »
Offline BapoDonu
Re: [IC] GMK Oni
« Reply #68 on: Sun, 26 April 2020, 10:52:31 »
Rem > Emilia.
how dare you
oof thats nice.
:O
Offline xia0ti
Re: [IC] GMK Oni
« Reply #69 on: Sun, 26 April 2020, 11:24:22 »
Rem > Emilia.
how dare you
oof thats nice.
:O
Thank you!!Im IN!!
Offline dannyny
Re: [IC] GMK Oni
« Reply #70 on: Sun, 26 April 2020, 21:26:43 »
pink arrows!
Offline chrislatiox
Re: [IC] GMK Oni
« Reply #71 on: Mon, 27 April 2020, 21:40:02 »
tried adding you on discord but says not available and just copied like in the google docs post, I really need this for my KB and can't miss this drop D:  looks so perfect
Offline BapoDonu
Re: [IC] GMK Oni
« Reply #72 on: Mon, 27 April 2020, 21:59:24 »
BapoDonut#5682
Offline neilli
Re: [IC] GMK Oni
« Reply #73 on: Mon, 04 May 2020, 11:48:52 »
any update recently?
Offline Magas
Re: [IC] GMK Oni
« Reply #74 on: Mon, 04 May 2020, 12:06:37 »
UPDATE US WEEEEEEEEB!
I'M SO EXCITED!
Offline BapoDonu
Re: [IC] GMK Oni
« Reply #75 on: Mon, 04 May 2020, 12:37:01 »
I'M SO EXCITED!
Be patient soon it's done.
Offline Magas
Re: [IC] GMK Oni
« Reply #76 on: Mon, 04 May 2020, 12:44:04 »
<3
Sent from my iPad using Tapatalk
Offline kidviddy
    • 駄日記
Re: [IC] GMK Oni
« Reply #77 on: Mon, 04 May 2020, 13:28:22 »
For the hiragana mono legends, please consider:
  • Including an R4 「ろ」 key (possibly replacing the R4 「む」 if you have one)
  • Including an R3 「む」 key (you may already have this for ISO support)
  • Including an R1 「ー」 key (possibly replacing the R1 「む」 if you have one)
  • Including a 3U Space key
  • Including a 2U Shift key
In lowering order of importance.  This set of keys is all JIS users need on top of ISO to be able to use the keyboard to actually type using kana.  The first two are the most important, and relatively easy to add if you already support ISO.  The third also makes a big difference, otherwise we have to take the "-" from the number pad which works but looks a bit weird.  The 3U space is required to make space for the 英数/かな keys either side of the space bar (these can be bought individually from AliExpress, but so far I've only found them in black or white so they won't match).  And the 2U Shift makes for a nicer-looking layout but we can get by with two 1U keys if needs be.
I know you have a lot of considerations to balance so I will understand if you can't manage all of these requests, but I wanted to make you aware of them in case there are any you can incorporate relatively easily.
Offline neilli
Re: [IC] GMK Oni
« Reply #78 on: Tue, 05 May 2020, 01:38:18 »
Can you consider adding led window keycaps?
Offline KRY2SOON
  • Divine Studios
Re: [IC] GMK Oni
« Reply #79 on: Tue, 05 May 2020, 17:09:11 »
I have a crazy amount of love for blue sets, especially sky or baby blue! :-*
Offline Apatite
Re: [IC] GMK Oni
« Reply #80 on: Sat, 09 May 2020, 15:07:59 »
Any updates on the set?
Offline BapoDonu
Re: [IC] GMK Oni
« Reply #81 on: Tue, 12 May 2020, 09:45:54 »
Offline Jampot_298
Looks great! Can't wait for this one
Offline Scucka
I'm in
Offline GhostEther
Interested.
Offline Daddyfatsax
Definitely in for the set. Is the Alice clone from the V1 renders still on the table?
Offline BapoDonu
Will have an update to that soon.
Offline Magas
I’m gonna be THAT guy but I actually preferred V1 over V2
Offline belerian
I'm going to have to agree :(
Offline Magas
I’d rather keep V1 but add that Pink in for sure!
« Last Edit: Tue, 12 May 2020, 16:19:35 by Magas »
Offline yoot
    • none
Agreed. Now it looks too much like KAT Goddess
Sent from my Pixel 3 XL using Tapatalk
Offline sjg412
I would be interested !
Offline BapoDonu
This was one of the versions we scrapped do you like those more ?
Offline Oddstag
Personally would much prefer weeb keys as the base set and latin legends as the alternative, but looks like this is coming along very nicely.
Offline Oddstag
Also, crazy pitch: What about black icons/text on the white modifiers to pull in more of her uniform? Has that been tried?
Offline BapoDonu
OO Thats a good one i will try that and see how it looks.
Offline yoot
    • none
The lighter mods definitely look better with the alphas.
Offline noorejji
I think the lighter mods definitely makes for a more coherent design overall.
Offline BapoDonu
We will def consider making them lighter.Prob we will make a poll about that.
Offline DNWMN
Looking very good so far!
