Author Topic: [GB] iNETT Studio:SQUARE.X 60% Keyboard [GB Complete]  (Read 146195 times)
Offline Simen
Re: [GB] iNETT Studio:SQUARE.X 60% Keyboard
« Reply #50 on: Wed, 24 June 2020, 10:44:13 »
Please delete order id 83. I just edited my initial order(26).
 :thumb:
Offline Simen
« Reply #51 on: Wed, 24 June 2020, 10:45:08 »
FYI, OP’s “Items Included in Base Kit” section says +$60 for brass plate, but the form says +$50 for that option.
Thanks for letting me know! I have corrected the form.
Offline Simen
« Reply #52 on: Wed, 24 June 2020, 10:48:35 »
I’m sure it’s subject to change, but do you have an estimated cost for shipping to the US - perhaps based off your previous board?
How much does adding a second board to your order change the total shipping cost? 😁
Previously it costed ~$60 to ship to US, but it costs a lot more now due to the pandemic. Hopefully it will get better later. I do not know how much it will cost to ship another board yet, it all depends on the weight and pricing at the time. It surely won't be more than 2x  :D
Offline Simen
« Reply #53 on: Wed, 24 June 2020, 10:48:48 »
the aesthetics of this board is awesome, definitely joined in
Thank you!  ;)
Offline Simen
« Reply #54 on: Wed, 24 June 2020, 10:49:03 »
Do I need to fill out the sheet again to add a second case?
Yes please  :)
Offline ninjacore
« Reply #55 on: Wed, 24 June 2020, 11:10:20 »
Have you considered going through a US vendor to reduce that cost for the buyers?
Offline Genos
« Reply #56 on: Wed, 24 June 2020, 11:33:15 »
Thank you!  ;)
also! i ended up filling up another form before the order edit form was made, please remove order id 3, i already see my other order on the list ^^
Offline snoofy
« Reply #57 on: Wed, 24 June 2020, 11:52:21 »
please delete order no.66 and no.71
Offline snoofy
« Reply #58 on: Wed, 24 June 2020, 11:53:20 »
Offline Mayflower
« Reply #59 on: Wed, 24 June 2020, 12:42:17 »
Do you have any pictures of the brass plate handy?
Offline surreal19
« Reply #60 on: Wed, 24 June 2020, 14:06:12 »
can you delete 88 and 90
Offline consumer
« Reply #61 on: Wed, 24 June 2020, 16:01:25 »
Where do I check my Order ID?
Offline mrtoniliu
« Reply #62 on: Wed, 24 June 2020, 18:18:06 »
Does pcb support c-c connection?
Offline youreyesonly
« Reply #63 on: Wed, 24 June 2020, 18:27:29 »
have an example of a black case with white plate??
Offline kanki0213
« Reply #64 on: Wed, 24 June 2020, 18:29:50 »
Definitely in, have a few questions, though.
1. Any idea how much heavier the brass weight is than the aluminum? roughly 600g
2. Weight of the brass plate vs. aluminum? roughly 750g
3. Which hotswap sockets are going to be installed in the hotswap PCBs? mill max 7305? kailh
4. Will there be any coating on the brass parts? clear coated
5. Front height? 19mm
=>> Does it mean that the brass weight is 600g heavier than alu weight?
=>> Does it mean that the brass plate is 750g heavier than alu?
Offline Lulu1777
« Reply #65 on: Wed, 24 June 2020, 19:11:27 »
Hi could you delete my order ID 21, order ID 9 is my real order thanks :)
Offline consumer
« Reply #66 on: Wed, 24 June 2020, 20:01:08 »
I would like to edit/change my order. Where is the Order ID spreadsheet posted?
Offline OXY-Gen
« Reply #67 on: Wed, 24 June 2020, 22:21:13 »
is it just me or is the order check sheet not updating?
Offline joe405
« Reply #68 on: Thu, 25 June 2020, 01:26:47 »
Would be nice to have a render of brass plate especially with blockers. I'm leaning towards hhkb brass with PC or black case
Offline Simen
« Reply #69 on: Thu, 25 June 2020, 02:31:06 »
Just added some photos of the brass plate of SQUARE 80
Offline Simen
« Reply #70 on: Thu, 25 June 2020, 02:32:02 »
Do you have a render/picture for a HHKB case with a Sand Blasted Brass plate
I added two pictures of the brass plate from previous GB, hopefully it helps.
Offline Simen
« Reply #71 on: Thu, 25 June 2020, 02:34:02 »
not at this point
Offline Simen
« Reply #72 on: Thu, 25 June 2020, 02:34:34 »
unfortunately I don't have a render of that color combo
Offline Simen
« Reply #73 on: Thu, 25 June 2020, 02:36:31 »
Clarification - those are the estimated weight of the brass weight/plate I got from the manufacturer, I actually don't have the exact weight measured. They also told me today that the brass plate will be closer to 1000g.
Offline Simen
« Reply #74 on: Thu, 25 June 2020, 02:39:49 »
Please check the last 2 photos for reference.
Offline OXY-Gen
« Reply #75 on: Thu, 25 June 2020, 02:44:23 »
Hello there.
can you remove order 204?
Offline ders19
« Reply #76 on: Thu, 25 June 2020, 06:31:20 »
Hello could you please remove order 154 and 156 thanks
Offline Ozakiis12
« Reply #77 on: Thu, 25 June 2020, 07:58:34 »
I've finally decided on full 60 layout instead of hhkb. Please cancel the two previous HHKB orders (same username). Thank you - excited!
Edit: Please cancel order 27 and the placed order for the full 60, which you have yet to add... (sorry, could not make up my mind before lol) Thanks!
« Last Edit: Thu, 25 June 2020, 09:14:54 by Ozakiis12 »
Offline Simen
« Reply #78 on: Thu, 25 June 2020, 10:23:03 »
Yes
Offline Xsty
« Reply #79 on: Thu, 25 June 2020, 10:54:12 »
I just got the invoice and saw that I had an additional PCB ordered, I went ahead and edit my order form to remove the additional PCB, would I be receiving a different Invoice soon?
Offline Simen
« Reply #80 on: Thu, 25 June 2020, 11:42:22 »
Hi,Can you provide me your order number?  I sent it to you after update
Offline nalra8095
« Reply #81 on: Thu, 25 June 2020, 11:46:39 »
Hello : )
I just got invoice from you, but I had changed my order using your google survey.
Could you check my last order and give edited invoice? My order no is 75.
Offline Simen
« Reply #82 on: Thu, 25 June 2020, 12:05:33 »
Hello : )
I see your choice on the form: case color: pc/plate: e-yellow/full plate/layout: hhkb/brass weight.  right?
Offline nalra8095
« Reply #83 on: Thu, 25 June 2020, 12:16:39 »
Hello : )
No, that was on my first form. I changed weight brass to e-yellow and fill the Edit form. Can you check edited form? If you couldn't, I will re-fill google form.
Offline Simen
« Reply #84 on: Thu, 25 June 2020, 12:32:25 »
Hello : )
Ok i will re-send you the new invoice :D
Offline Xsty
« Reply #85 on: Thu, 25 June 2020, 13:09:53 »
I just got an updated invoice, Thanks!
Offline VytrioL
« Reply #86 on: Thu, 25 June 2020, 22:31:27 »
When should I expect an invoice if I submitted a form yesterday?
Sent from my SM-G965U using Tapatalk
Offline Nediah
« Reply #87 on: Thu, 25 June 2020, 22:51:58 »
Is there a “time limit” after receiving the invoice to pay it?  If so, how long would that be?
Offline Simen
« Reply #88 on: Fri, 26 June 2020, 02:08:22 »
I am starting to send invoices out, the deadline to pay is 2 days after GB.
Offline BachNgocLaoHo
« Reply #89 on: Fri, 26 June 2020, 03:06:19 »
I have had invoice from iNETT Studio. If i want update items, how can i do that before i paid invoice?
« Last Edit: Fri, 26 June 2020, 06:46:43 by BachNgocLaoHo »
Offline prizeS
    • TastyKeys
« Reply #90 on: Fri, 26 June 2020, 03:38:23 »
ill keep an eye out and check my paypal everyday then. haven't been receiving email notifications for invoices for some reason.
i lub 65% and wkl tkl.
Offline BanhMi
« Reply #91 on: Fri, 26 June 2020, 04:37:15 »
I got 2 of the same invoices do I just ignore the 2nd one. :blank:
Offline duckunz
« Reply #92 on: Fri, 26 June 2020, 04:41:30 »
I didn't get any invoice.. tho according to the form, I ordered pretty soon.
Offline fzoi79
« Reply #93 on: Fri, 26 June 2020, 05:31:28 »
I have not received an invoice for the second car.
Offline Nediah
« Reply #94 on: Fri, 26 June 2020, 05:39:32 »
So if I was to order on the 28th, the deadline would include the 28th or not?
Offline Ozakiis12
« Reply #95 on: Fri, 26 June 2020, 05:52:12 »
Please cancel order 12. Thank you.
Offline theside123
« Reply #96 on: Fri, 26 June 2020, 06:49:34 »
Housing white
Plate red
Can you see the happy hacking combination render??
Offline rnwns0815
« Reply #97 on: Fri, 26 June 2020, 11:22:53 »
Hey i Have not recieved invoice. My order is 82 and 92. Please check my order^^
Offline supern00b
« Reply #98 on: Fri, 26 June 2020, 11:57:38 »
Please cancel invoice# 289, thanks
Offline Kurigohan
« Reply #99 on: Fri, 26 June 2020, 14:08:18 »
Can you change the plate to e-white for order 217 please? Thanks.
