Author Topic: [GB] iNETT Studio:SQUARE.X 60% Keyboard [GB Complete]  (Read 146029 times)
Offline Amorou Kithkin
Re: [GB] iNETT Studio:SQUARE.X 60% Keyboard
« Reply #100 on: Fri, 26 June 2020, 14:50:15 »
Please remove order 181. Thank you.
Offline consumer
« Reply #101 on: Fri, 26 June 2020, 18:54:58 »
Please cancel/remove order 167. I submitted an edit for my order two days ago, spreadsheet still showing the initial details. PM'd but still no reply or changes on the spreadsheet. Got an invoice today, so I'm not too sure what I'm pre-ordering. Sorry this is not good enough.
Offline Simen
« Reply #102 on: Fri, 26 June 2020, 19:49:10 »
I got 2 of the same invoices do I just ignore the 2nd one. :blank:
Yes please, sorry about that!
Offline Simen
« Reply #103 on: Fri, 26 June 2020, 19:49:49 »
I have had invoice from iNETT Studio. If i want update items, how can i do that before i paid invoice?
Please PM me with the Order ID and what you want to change, thanks!
Offline Simen
« Reply #104 on: Fri, 26 June 2020, 19:53:12 »
My sincere apologies. The amount of edits I am receiving is just too much so I have changed the way for doing edits. I have crossed out your order, please submit another GB form if you change your mind. Sorry again!
Offline OXY-Gen
« Reply #105 on: Sat, 27 June 2020, 01:21:38 »
When will order edits appear? got 2 invoices today even though I thought i canceled the other one. I also have no idea what im buying because the sheet hasnt updated to the edit form.
It also seems that both invoices i got is outdated from edited.
#205
« Last Edit: Sat, 27 June 2020, 01:28:32 by OXY-Gen »
Offline Simen
« Reply #106 on: Sat, 27 June 2020, 01:44:22 »
#205
I have updated the invoice according to your order.  Please proofread :thumb:
Offline prizeS
    • TastyKeys
« Reply #107 on: Sat, 27 June 2020, 03:08:08 »
Poor Simen with all these edits. Y'all the GB is open for a week make up your mind before submitting it lol
i lub 65% and wkl tkl.
Offline OXY-Gen
« Reply #108 on: Sat, 27 June 2020, 03:10:35 »
#205
Received and correct. Thanks
Offline Lotsati
« Reply #109 on: Sat, 27 June 2020, 04:02:24 »
Looking to buy just the PCBs from this GB if anyone is interested in throwing extra ones on their order (I'm not getting a case myself). Can pay up front as well.
Offline ZangKurry
« Reply #110 on: Sat, 27 June 2020, 04:53:42 »
hi, i got my invoice for order 120, but the details on it is not correct since I updated my entry. Also, I am not sure if the invoice is hot swap or not since i changed that to be hot swap. Can I get a new invoice? thank you !
Offline Simen
« Reply #111 on: Sat, 27 June 2020, 06:11:32 »
I have updated the invoice according to your order.  Please proofread  :D
Offline Tekilashot
« Reply #112 on: Sat, 27 June 2020, 06:29:06 »
Is there a photo of the keeb with the half plate ? Does it change something to the aesthetic ?
Offline ninjacore
« Reply #113 on: Sat, 27 June 2020, 10:54:41 »
Should we PM you w order-related questions, OP, or post here?
Offline kabocha
« Reply #114 on: Sat, 27 June 2020, 13:02:14 »
just put in my orders!
*crud just realized that I picked a wrong option. Going to submit another order and cancel the other when the order checks are up for them
« Last Edit: Sat, 27 June 2020, 13:07:10 by kabocha »
Offline Simen
« Reply #115 on: Sat, 27 June 2020, 14:41:16 »
There is an exploded view on the IC page. You can't really tell the difference visually once keycaps are on.
Offline OXY-Gen
« Reply #116 on: Sat, 27 June 2020, 16:25:44 »
Whats the due date for the invoice?
Offline prizeS
    • TastyKeys
« Reply #117 on: Sat, 27 June 2020, 21:05:21 »
it says on the invoice itself. june 30.
Offline ninjacore
« Reply #118 on: Sat, 27 June 2020, 21:14:01 »
For those who ordered more than 1 board, did you receive multiple invoices?  Is it possible to have my two orders combined into one invoice, OP?  I would obviously like them to go out at the same time (same shipment).  Thanks
Offline thestrayed
« Reply #119 on: Sat, 27 June 2020, 21:58:04 »
Can you cancel order #332? I wanted to update my configuration. So I added another order with the new config. So I don't need a previous order (#332) anymore.
Offline Simen
« Reply #120 on: Sat, 27 June 2020, 22:00:12 »
We will invoice for shipping again later when the units are ready to ship. Combined shipping will be handled at that time.
Offline Simen
« Reply #121 on: Sat, 27 June 2020, 22:00:53 »
Please fill out an order cancel form if you haven't already done so. Thanks!
Offline Rew23
« Reply #122 on: Sun, 28 June 2020, 00:02:33 »
Is it possible to purchase more than one additional PCB?
Offline Simen
« Reply #123 on: Sun, 28 June 2020, 06:31:21 »
Can add an additional pcb
Offline Curin Derwin
« Reply #124 on: Sun, 28 June 2020, 08:59:04 »
Can I order two keyboards? How can I do that?
Offline Simen
« Reply #125 on: Sun, 28 June 2020, 09:13:37 »
Just fill in the form record twice :D
Offline yhs
« Reply #126 on: Sun, 28 June 2020, 09:56:25 »
Invoice 316 - possible to change plate from WKL to HHKB and to half-coverage?
« Last Edit: Sun, 28 June 2020, 09:59:43 by yhs »
Offline Simen
« Reply #127 on: Sun, 28 June 2020, 10:39:29 »
I have updated invoice
Offline Axariel
« Reply #128 on: Sun, 28 June 2020, 16:45:52 »
Will the clear brass coating be PVD? Is there an image of the coated brass?
Clear coating is not PVD, it's just a clear coating to prevent the brass from rusting.
What will you be using if you hop on before GB close?
Offline Ozakiis12
« Reply #129 on: Sun, 28 June 2020, 18:49:30 »
Hey, just a headsup;
Please cancel all my orders. I’ve done some math and rn is not the time to join a group buy unfortunatly. Thanks!
Nvm, just placed a new order!
« Last Edit: Sun, 28 June 2020, 21:53:06 by Ozakiis12 »
« Reply #130 on: Sun, 28 June 2020, 20:36:11 »
What is the gain/difference/benefit of a half-plate? More flex for linears?
Also, are all PCBs yellow/orange? If so, is there a blocker to block the color of the PCB in PC?
« Last Edit: Sun, 28 June 2020, 21:12:15 by Curin Derwin »
Offline Simen
« Reply #131 on: Mon, 29 June 2020, 01:23:26 »
Half plate offer a softer typing experience. PCBs will be yellow. Not sure what you meant on the last question, please check the photos.
Offline Simen
« Reply #132 on: Mon, 29 June 2020, 01:27:29 »
Hi all. Thank you for participating in this group buy. The order phase has completed and the rest of the invoices will go out soon. Please pay your invoice before the deadline to avoid cancelation of your order.  :thumb:
« Reply #133 on: Mon, 29 June 2020, 04:54:07 »
Got it. Can I please add an additional HHKB ewhite half-plate and solderable PCB. Can I also please purchase extra sets of screws? Order# 405
Offline Simen
« Reply #134 on: Mon, 29 June 2020, 05:05:54 »
I checked your order and found that you have purchased additional plate and pcb.So it can't be added anymore :)
« Reply #135 on: Mon, 29 June 2020, 06:29:28 »
Thank you. PM'd
Offline fzoi79
« Reply #136 on: Mon, 29 June 2020, 06:59:53 »
Are there plenty of LED effects to choose from?
Offline ninjacore
« Reply #137 on: Mon, 29 June 2020, 08:18:40 »
^^ This guy only has one kidney now!
Offline Ozakiis12
« Reply #138 on: Mon, 29 June 2020, 10:02:21 »
You gotta do what you gotta do  ;D
Offline Droplit
« Reply #139 on: Mon, 29 June 2020, 10:37:16 »
Hello!
Is there any chance you could change the case in order 212 from ano-black to Polycarbonate?
Thank you
« Reply #140 on: Mon, 29 June 2020, 11:12:14 »
It looks like my last PM may have been lost in transmission. Resent. Thank you!
Offline crash74
« Reply #141 on: Mon, 29 June 2020, 11:34:51 »
a summary...
Offline Simen
« Reply #142 on: Mon, 29 June 2020, 11:37:56 »
Hello!
Thank you
no problem
« Reply #143 on: Mon, 29 June 2020, 12:45:29 »
a summary...
Great pivot!
I wonder if the the color of the PCB inside of the clear housing played a role in the plate color selection. Hypothesis: it did.
Offline Droplit
« Reply #144 on: Mon, 29 June 2020, 12:59:26 »
Hello!
Thank you
no problem
Thanks! Will I need a new invoice? Or if I pay the one I already got it will be updated correctly. The invoice says it's still ano black
Offline Simen
« Reply #145 on: Mon, 29 June 2020, 13:19:21 »
Hello!
Thank you
no problem
Provide your invoice number, I will update :D
Offline Droplit
« Reply #146 on: Mon, 29 June 2020, 13:23:23 »
Hello!
Thank you
no problem
It's order #0358! Thanks for the help
Offline ninjacore
« Reply #147 on: Mon, 29 June 2020, 14:09:53 »
a summary...
Great pivot!
Also playing a part: the 2 YouTube reviews :)
« Reply #148 on: Mon, 29 June 2020, 14:36:46 »
« Last Edit: Mon, 29 June 2020, 18:21:50 by Amorou Kithkin »
Offline Rhapsodixx
« Reply #149 on: Mon, 29 June 2020, 17:52:11 »
order id 343 paid broo  :) there goes my savings
