Author Topic: [GB] Fox Lab - Time 80 Reforged  (Read 298378 times)
Offline senter
« on: Mon, 31 August 2020, 14:45:23 »
About Time 80 Reforged
Time 80 was the second design of Fox Lab back in 2017.
It has also become an iconic keyboard design of Fox Lab.
Time80RE kept most of the original weight design.
The clock has become thinner now and has a tempered glass cover.
The front height of the keyboard has greatly reduced for optimizing for comfort.
The ratio between the top and bottom cases has been adjusted for a cleaner side view.
Link to the IC: https://geekhack.org/index.php?topic=107276.0
Group Buy Information
1. How to order:
GB closed
2. What does a kit include?
The case & weight bundle includes
  • Top and bottom cases
  • PCB
  • Bottom weight/accessories
  • Bottom tempered glass cover
  • Rubber sheet under the plate
  • Screws and rubber feet
The plate & badge bundle includes
  • Plate
  • "Time" badge
  • LED cover/badge
You also need:
  • Switches
  • Keycaps
  • Stabs
3. Can I order additional plates and PCBs?
Yes.
https://foxlab.store/products/time-80-reforged-additional-plates
https://foxlab.store/products/time-80-reforged-additional-pcb
https://foxlab.store/products/time-80-reforged-additional-rubber-sheet
Weight parts cannot be ordered seperately
4. What are the options?
  • For the case, you can choose the color from Matte Clear PC, Anodized Black, Anodized Silver, E-White, Powder Coating Sky Blue, Powder Coating Lilac, and Powder Coating Grey. Here is an album of photos of all colors
  • For the weight, you can choose the color/material from Anodized Gold Aluminum, Anodized Pink Aluminum, and E-Clear Brass
  • For the PCB, you can choose either hot swappable version or the solder version
  • For the plate, you can choose either split style or regular style. You can find more information about the split plate design in the IC thread.  Here's an illustration.
  • The plate and 'Time' badge are restricted to be the same color from Gold, Pink, Black, White, Gray, Red, and Brass.
  • The LED cover are available in Gold, Pink, Black, White, Gray, and Red
5. What's the price?
  • A base kit with all aluminum parts: $480+shipping. 4.4% transaction fee and 2% platform charge are included. It equals to $450 plus transaction fees.
  • Upgrading the weight material to brass (E-Clear finish): $88
  • Upgrading the plate and "Time" badge material to brass (E-Clear finish): $45
6. Timeline and limits
The GB starts whenever the GB post gets an approval. It will open for 7 days unless the number of orders is getting too big.
A soft top limit is 500 kits in total.
The expected lead time is 5 months due to the complexity of manufacturing the small parts.
Minterly's build stream
Build guide and plate files: https://fox-lab.github.io/gbs/Time80RE.html
« Last Edit: Thu, 08 April 2021, 18:52:45 by senter »
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: [GB] Fox Lab - Time 80 Reforged
« Reply #1 on: Tue, 01 September 2020, 03:20:48 »
Approved!
Very busy with studies atm.
Offline Boy_314
« Reply #2 on: Tue, 01 September 2020, 03:48:25 »
yeet, im in :thumb:
Offline Vov
« Reply #3 on: Tue, 01 September 2020, 03:50:30 »
opted in for a silver one~
1.2 og | 2.0 add | Fallacy | Alpha65 | Ojou | Orion v2.5 | Kei | FMJ Poker | GSKT-00 | Unikorn 2.1
Offline iNv_ForEveR
« Reply #4 on: Tue, 01 September 2020, 04:12:34 »
Do we have any pictures for clear PC and brass weights etc?
Offline Jinho
  • hello
    • i used to build keyboards
« Reply #5 on: Tue, 01 September 2020, 04:34:50 »
ever since i saw the lilac hhk+b and perry's yeri, i've wanted a lilac board... this may have to be it
iu / jinsoul / xiyeon / ogre / nunu / 378 / x60 v2 / derivative / unikorn hk / lamy / calliope / dolice / harbour / xeno / 87u
Offline Surefoot
« Reply #6 on: Tue, 01 September 2020, 04:35:44 »
In for a e-white/brass/gold.
Will plate files include the single plate and split plate versions ? (going for ISO, so i'll need one of these)
Saw it in the photo album linked from 1st post.
Offline GaNeBaL
« Reply #7 on: Tue, 01 September 2020, 04:57:08 »
guess i'm not upgrading my pc this month
Obsessed with 60%TKLs
Offline Minam
« Reply #8 on: Tue, 01 September 2020, 05:15:52 »
Hi, I accidentally ordered aluminum-gold instead of getting the brass weight, is there any way to fix this?
Offline Minam
« Reply #9 on: Tue, 01 September 2020, 05:20:48 »
I also accidnetally ordered the plate and the keyboard separately and got charged with shipping twice, can you combine these orders? thanks.
Offline Minam
« Reply #10 on: Tue, 01 September 2020, 05:50:03 »
sent an email to you at runninghack@gmail.com with the details! Thanks.
I really scrwed up the orders, could you refund the order so I can make another order with the correct selections? Sorry...
Issue solved! thank you fox lab!
« Last Edit: Tue, 01 September 2020, 09:41:13 by Minam »
Offline marshskitow
« Reply #11 on: Tue, 01 September 2020, 05:56:18 »
Can someone tell me what to say to my girlfriend when i’ll come back home ?
Ahah. Seriously, i don’t remember is it iso compatible ?
Envoyé de mon iPhone en utilisant Tapatalk
Offline enchiyaki
« Reply #12 on: Tue, 01 September 2020, 06:08:51 »
Is there photos of the WKL version? Let me know if I'm just blind and not seeing it.
Will there be issues if we go with a WKL version with a hot swap PCB?
Offline wholypantalones
  • text and icon mods plz.
« Reply #13 on: Tue, 01 September 2020, 06:15:57 »
apologies if it's already been answered, but what is the typing angle on this bad boy? Same as the last run 5.5?
« Last Edit: Tue, 01 September 2020, 07:05:29 by wholypantalones »
Offline upas
« Reply #14 on: Tue, 01 September 2020, 06:31:36 »
Definitely in for this one
Offline marshskitow
« Reply #15 on: Tue, 01 September 2020, 06:40:56 »
Just got my answeer. There is no ISO.
Offline Oracules`
« Reply #16 on: Tue, 01 September 2020, 06:55:07 »
Down for a sky blue version! Usually into 65's/60's but this weight is gorgeous
I've also accidentally ordered the hotswap PCB rather than the solderable one so I've sent an email for that, sorry!
Offline DetectiveNio
« Reply #17 on: Tue, 01 September 2020, 07:25:39 »
Dang I woke up 5am and the GB went live. Rushed to get one without buying the plate and got charged shipping twice haha. Wheww thought I'd misses this masterpiece.
Emailed to combine and refund shipping
Offline isaackang7
« Reply #18 on: Tue, 01 September 2020, 07:27:26 »
Sent an email too for a refund so I can order again. Thanks
Offline o3okevin
« Reply #19 on: Tue, 01 September 2020, 07:43:59 »
Ordered!
Offline moremilk
« Reply #20 on: Tue, 01 September 2020, 08:15:06 »
Ordered one in E-white and brass.
Hyped for my first TKL :)
Offline jdbaker82
« Reply #21 on: Tue, 01 September 2020, 08:21:00 »
Confused about the powder coated gray color the pictures show the top as gray but the bottom looks silver?
Offline jdbaker82
« Reply #22 on: Tue, 01 September 2020, 08:27:41 »
Are all of the plates standard 1.5mm alu except for brass option of plate being 1.5mm brass?
Offline Kinesiologist
« Reply #23 on: Tue, 01 September 2020, 08:38:03 »
guess its "time" to spend more money :D
Offline kiyoboard
  • https://www.youtube.com/kiyoboard
« Reply #24 on: Tue, 01 September 2020, 08:40:32 »
It is happening!
Offline Kookiekurls
« Reply #25 on: Tue, 01 September 2020, 08:43:17 »
Out of nowhere... haha. So glad I got one!
Offline Mearaz
« Reply #26 on: Tue, 01 September 2020, 08:46:33 »
Anyone else getting lilac and pink? Not very often we get this color combination in a group buy, instant pick for me.
Offline kmao
« Reply #27 on: Tue, 01 September 2020, 08:56:09 »
I got it myself.
I was wondering if OP had an email address or a form to contact him? I recently ordered but I would also like to add an additional plate and badge kit onto my order. Is it possible to just get an invoice for these extra items and then for it to be added to my previous order?
Offline andrewregal
« Reply #28 on: Tue, 01 September 2020, 09:06:19 »
Wow, didn't think I'd wake up to this! Was tempted to go for the grey powder coat for a bit but in the end just opted for black with brass accents. Can't wait!  :p
Discord: andrewregal#7830
Offline lazergician
« Reply #29 on: Tue, 01 September 2020, 09:12:33 »
Went for the grey powder coat. Can't wait! These are really amazing.
Offline Spressa
« Reply #30 on: Tue, 01 September 2020, 09:26:08 »
Polycarb + brass. Excited.
Offline outerspace
« Reply #31 on: Tue, 01 September 2020, 09:26:27 »
Yeah, that combo is incredibly pleasing on the eyes ... couldn't resist!
Offline //gainsborough
  • MATRIXの日常
« Reply #32 on: Tue, 01 September 2020, 09:34:51 »
went with e-white + brass!  I was originally going to buy two and make one of them alps, but since I upgraded everything to brass and got some extras I could only do one >_<
Thanks, senter!
edit: this only just occured to me, but the hotswap PCB will be fine with WKL layout, yeah?
« Last Edit: Tue, 01 September 2020, 09:45:24 by //gainsborough »
Offline the_onlyhope
« Reply #33 on: Tue, 01 September 2020, 09:39:05 »
Can someone provide their order #? If they ordered around the release of the website. I am wondering if I made it into the first 500 orders.
Offline TheGenericAsian
« Reply #34 on: Tue, 01 September 2020, 09:49:38 »
In for powder grey with black accents and gold LED cover!
Probably going to call it quits after this keyboard. Feels like endgame material...if it even exists  :'(
Super excited and hope I'm in
Offline geshuni
« Reply #35 on: Tue, 01 September 2020, 09:50:07 »
I just ordered and got #1225. I hope it'll be fine. :-[
Offline IMZO
  • Matrix shill, and TKL WKL Lover
« Reply #36 on: Tue, 01 September 2020, 10:04:07 »
Ok, purchased. Thanks!
Current boards: Jane V2 CE , Matrix 1.2og Silver WKL , Matrix 2.0add coating black WKL, Matrix 2.0add WKL Coating yellow, Satisfaction75 R1 Cloud white, Korno65, Bloop65, HHKB Pro 2 white,Lin Whale Pink WKL, Gok 7v White, Gok 7v Black, Orion V3 Silver WKL, Orion V2.5 Red WKL, Geon F1-8x Silver WK, Haus65 BlueGray, Plume65, Vertigo, Frog TKL WKL GreenF13
« Reply #37 on: Tue, 01 September 2020, 10:07:36 »
Dang shoutout to senter with the quick refund and order update!
Will the plate file be the same as the OG Time TKL? It'd be great to try CF or FR4 down the line
Offline Seydoux
« Reply #38 on: Tue, 01 September 2020, 10:57:59 »
Hi, i noticed that the hot swap option comes with LED on the PCB? can anybody confirm this? if it is im going to order normal plate with hotswap.
« Last Edit: Tue, 01 September 2020, 11:52:51 by Seydoux »
Offline Deskdogs
« Reply #39 on: Tue, 01 September 2020, 11:22:24 »
What is the front height of the keyboard (just the case not including keycaps)?
zzzzzzzzz
Offline stein3
« Reply #40 on: Tue, 01 September 2020, 11:50:45 »
It looks like there is no way to order just extra badges and LED covers without ordering the Plate and Badge kit?
Offline Angelsin
« Reply #41 on: Tue, 01 September 2020, 12:07:04 »
Same thing with me man, what email did you send to? They haven't emailed me back
buy the set for good luck on your next raffle
Offline KurageOuji
« Reply #42 on: Tue, 01 September 2020, 12:22:38 »
Just joined with a brass PC WKL! I would love an option to buy more led badges if possible too.
Offline Kolby
« Reply #43 on: Tue, 01 September 2020, 12:25:56 »
I made a mistake with my order.
Is there any way to contact foxlabs at all? I can't find email or contact forms anywhere.
Offline vtachkov
« Reply #44 on: Tue, 01 September 2020, 12:27:47 »
Looking good Senter, my OG Time will have a little brother soon. Can you confirm that the powder coated grey the same one in the picture with the e-white? It might be my eyes but I'm having trouble picking out which one of the pictures is the silver and which one is the grey.
Offline jynh
« Reply #45 on: Tue, 01 September 2020, 12:35:32 »
I emailed runninghack@gmail.com with my order #.  Didn't get a reply, but got an updated order confirmation.
Offline ScurySnek
« Reply #46 on: Tue, 01 September 2020, 12:40:17 »
If only i had the funds  :(
good luck with the group buy, looks amazing!
Offline KurageOuji
« Reply #47 on: Tue, 01 September 2020, 12:54:06 »
also can you please confirm the hotswap pcb layout? i think i see that its 7u tsangan bottom row? thanks!
Offline thumbyyy
« Reply #48 on: Tue, 01 September 2020, 12:59:53 »
Did anyone not receive email confirmation besides from paypal?
Offline Jefff
    • jlabs.co
« Reply #49 on: Tue, 01 September 2020, 13:03:56 »
How well does the grey LED cover match the grey case? Is it exactly the same finish?
