Author Topic: [GB] The Adélie - Premium 50%+ Keyboard | Concluded  (Read 131232 times)
Offline VellFlamm
Re: [GB] The Adélie - Premium 50%+ Keyboard | Sept 26th 11am EDT
« Reply #100 on: Thu, 24 June 2021, 22:12:32 »
Attached to this message is the plate file for the adelie with the LED holes and the leaf spring cuts. Enjoy!
Thank you! I'm thinking of ordering it w/ and w/o the leaf spring design considering the softness of the POM and PC.
I'll post it here or in the 40% discord when I receive them!
Offline Jo_hannes
  • You can never learn less. You can only learn more.
« Reply #101 on: Sat, 26 June 2021, 11:22:04 »
At the moment the QMK and Via file are in the works.
I am a total noob in regards to this. I don't see the Adélie in the Via compatibility list, and it's not being recognized by the software (based on what I read). Can someone point me to some type of support for getting the Adélie to work in Via?
Again, sorry of this sounds idiotic to you seasoned 40s people, and thanks in advance for any help you can offer.
Best,
Johannes
Offline VellFlamm
« Reply #102 on: Sat, 26 June 2021, 11:28:50 »
Best,
Johannes
https://github.com/awkannan/qmk_firmware/tree/202006_adelie_firmware/keyboards/cannonkeys/adelie
Until the VIA officially supports the keyboard, use the info.json from here.
Offline well_cooper
  • Turn metal in to typing machine
    • Thocc Supply
« Reply #103 on: Sat, 26 June 2021, 21:03:35 »
Not sure what other people experience with VIA at the moment, I've build mine and VIA recognised as Engima Infinitum 87. Seems like to have the correct layout I'll have to compile QMK code and reflash with a new hex.
VIA doesn't want to play ball with info.json from GitHub repo out of the box as well and side loading Definition with this json is throwing errors
I'm also new to 40%, github and coding for QMK in general
« Last Edit: Sat, 26 June 2021, 21:06:14 by well_cooper »
Offline Abec13
« Reply #104 on: Sun, 27 June 2021, 03:09:56 »
I was just playing with this tonight and experiencing exactly what you're talking about. I will resolve this ASAP and post back here with it. Upas from cannon keys has been handling the qmk for this as I am in a similar boat to you 😅
Thanks for your post and patience I will post back here with a solution hopefully within the day.
45-ATS | Adelie | Gentoo | Volcano 660 | Think 6.5 v2 | SKOG | 7V | Hello M0110
[/url]
Offline well_cooper
    • Thocc Supply
« Reply #105 on: Sun, 27 June 2021, 06:34:46 »
Thank you! I love this board and I managed to compile a VIA hex file from their repo and now the keyboard layout appears to be correct after flashing. No luck with making a json for VIA or having layer status LED to light up.
Looking forward to the solution cause I want to type on this so much
Offline Abec13
« Reply #106 on: Sun, 27 June 2021, 12:06:52 »
Okay, so here:
Flash the board with the attached hex file then drop the JSON file into VIA under the design tab. Should work out! Let me know if you have further issues. I am going to work on getting these into the discords.
[/url]
Offline Curin Derwin
« Reply #107 on: Mon, 28 June 2021, 16:19:12 »
Is there somewhere I may purchase extra gaskets and rubber feet?
Offline well_cooper
    • Thocc Supply
« Reply #108 on: Tue, 29 June 2021, 06:47:21 »
Thank you very much!  :thumb:
Offline blaze3j
« Reply #109 on: Mon, 19 July 2021, 01:36:01 »
Sorry in advance if it is inappropriate to ask since the GB just concluded. Will there be the possibility of a R2 release of the Adélie in the near term future?  Thanks!
Offline Abec13
« Reply #110 on: Tue, 27 July 2021, 19:05:57 »
In the future, perhaps but definitely not soon.
[/url]
Offline grundlemere
« Reply #111 on: Tue, 17 August 2021, 13:06:46 »
Just built mine, amazing board! Any way to change the RGB HSV settings for the layers? I'd love to match them to my build if possible.
Offline Abec13
« Reply #112 on: Tue, 17 August 2021, 13:27:47 »
It is possible but I'm not sure that it's strait forward if you are using VIA. You would have to edit the keymap file from this repo and compile it for QMK.
[/url]
Offline grundlemere
« Reply #113 on: Tue, 17 August 2021, 14:51:31 »
Not too much of a problem, I had to edit knob controls and OLED printouts for my Launchpad. This should be a piece of cake. All I'm concerned about is, if I make changes to the keymap and compile a hex based on it, will I still be able to otherwise use VIA to program the board with the product? If you don't know, I can experiment and report back.
Offline Abec13
« Reply #114 on: Tue, 17 August 2021, 15:07:58 »
At this time, I am not aware. I can't imagine it would break it with VIA. Let me know please!
[/url]
Offline nettik
Re: [GB] The Adélie - Premium 50%+ Keyboard | Concluded
« Reply #115 on: Sat, 21 August 2021, 02:15:18 »
Hi, I was wondering: will the Adelie layout be added to the QMK Configurator site? I know you've uploaded the QMK file to github, but as someone who's not tech savvy, I've never been able to get the QMK environment to work.
Offline Abec13
« Reply #116 on: Thu, 02 September 2021, 14:12:42 »
From my understanding it was in queue to be added, I will have to ask CK about that. Get back to you.
[/url]
Offline nettik
« Reply #117 on: Fri, 15 October 2021, 16:36:28 »
Hi, any news on adding Adelie to QMK Configurator? It's a lovely board and I just got Dracula, I'm hoping I can use them together soon!
Offline Abec13
« Reply #118 on: Sat, 16 October 2021, 01:01:21 »
Cannon Keys is ultimately in charge of the qmk branch of this board, I have asked Upas to push on the QMK submission which is about all that can be done atm. I recommend using VIA in the meantime, unless you have some fancy things planned for QMK that VIA cannot handle.
[/url]
Offline Abec13
« Reply #119 on: Sat, 16 October 2021, 01:02:26 »
For anyone interested, there are extra boards still available to ship world wide on iLumKB: https://ilumkb.com/products/extras-adelie-keyboard-kit
[/url]
Offline ChrisGVE
« Reply #120 on: Sun, 21 November 2021, 08:18:56 »
Hello I was wondering if there is any source for additional Adelie PCB? Just bought one of the last from iLumbkb but they are out of PCB as I can tell. Thanks
Offline Zamoth
« Reply #121 on: Sun, 28 November 2021, 20:24:37 »
Sorry to bump this but I couldn't find anything with a google search. Is it possible to change the colours of the LED? Not really a fan of red as default layer colour.
Offline Abec13
« Reply #122 on: Wed, 01 December 2021, 19:06:03 »
Yes, you would have to adjust the original keymap.c that is in the repo for this board then compile it for QMK/VIA
[/url]
Offline Oddstag
« Reply #123 on: Sun, 16 January 2022, 17:34:17 »
Round 2 a future possibility?
Offline Abec13
« Reply #124 on: Sun, 16 January 2022, 20:52:37 »
Cannon Keys and I have talked about it in the past. Possible? Yes. Soon? I don't think so.
[/url]
Offline Oddstag
« Reply #125 on: Mon, 17 January 2022, 03:18:39 »
Cool, happy it's being considered.
Offline Luna
« Reply #126 on: Mon, 04 July 2022, 08:23:40 »
Can anyone who has a red one tell me if it's a dark red as in the IC pictures or a much lighter red like in the pictures on Cannonkeys?
Offline Abec13
« Reply #127 on: Sun, 21 August 2022, 22:11:52 »
This is an adelie hex file that is via enabled and changes the colors of the LEDs to something I prefer more and has no LEDs on the default layer like the version that is in the Git Hub repo.
[/url]
Offline ThreadyKeycaps
    • ThreadyKeycaps
« Reply #128 on: Mon, 22 August 2022, 00:08:39 »
wow i love this layout, love small boards so this is perfect!
Offline loudiddly
« Reply #129 on: Tue, 10 January 2023, 23:49:10 »
I saw the plate files got shared, any chance PCB files are available?
Didn't have a chance to get an extra when I got the board.
Offline El Kinoflop
« Reply #130 on: Wed, 11 January 2023, 11:20:16 »
I'd be interested in either the PCB files or just buying a PCB too.
Offline Sawuking
« Reply #131 on: Tue, 12 December 2023, 02:04:34 »
Also curious about extra pcbs, hopefully someone has a solution
