Author Topic: [IC] grid 650, GB is live, update with typing sound tests 3  (Read 162811 times)
Offline pool
Re: [IC] grid 650, a QMK BLE keyboard with interchangeable modules
« Reply #50 on: Mon, 02 November 2020, 23:58:52 »
Your site's https cert is broken/expired by the way. Getting an SSL error when I enter it.
Offline paulgali
    • SKME
Re: grid 650, a QMK BLE keyboard with interchangeable modules
« Reply #51 on: Tue, 03 November 2020, 00:30:20 »
The second image, the sceond and forth from the last image are one of our actaul prototypes with final Hub and Front LED indicator design.
Plate option is something we are still working on and would love get feedback from you guys.
Get rid of the side mounting points, it feels terrible and really ruins a board. You rendered a thick plate, but please consider a 1.5mm plate alongside the non-hotswap PCB.
Offline Rooke-Design
« Reply #52 on: Tue, 03 November 2020, 01:33:50 »
YES! Keen to see the different module options!
Offline Narf
    • Krado Industries
« Reply #53 on: Tue, 03 November 2020, 01:36:26 »
  • All new modules will be available for grid600 as well.
Does that mean that mean that grid 600 is getting another run soon? Or does that mean that the modules will be interchangeable between grid 600 and grid 650?
Will plate and/or PCB be open-sourced?  Very interested in doing a small/private run of Boardwalk PCBs for this if so.
Would love to do that.
Then put me down for two!
I want in on this so bad. But would that mean a 65% Boardwalk? Or is 600 happening at the same time? Would that mean a BLE Boardwalk? Would the USB hub still work? I am salivating over here.
This checks pretty much every box for me that are just not available in most customs: Hotswap, BLE, USB Hub. If a Boardwalk version of this were available it would be actually be a dream board. If there were some way to get RGB underglow going (even just a small diffuser) somewhere would make it perfect.
I hope the Flash module will be available in a few different colors.
Offline sleepybrett
« Reply #54 on: Tue, 03 November 2020, 07:39:34 »
Split spacebar support?
Offline xarly06
« Reply #55 on: Tue, 03 November 2020, 12:48:12 »
Good job, it looks amazing
Offline ceconds
« Reply #56 on: Tue, 03 November 2020, 15:02:27 »
yes.
Offline GeekLevelAsian
    • Geek Level Asian
« Reply #57 on: Tue, 03 November 2020, 16:32:30 »
I need this.  I liked the 600 but I'm a 65% lover.  I can't wait for this to come out.
Offline keebpleeb
« Reply #58 on: Tue, 03 November 2020, 17:31:02 »
The amount of thought and attention to detail that has gone into this board is truly stunning. I love seeing this hobby move forward inch by inch but frankly, this is pretty revolutionary.
Likely can't cop due to getting in on the recent S75 drop but GL with GB - If I somehow have extra coin lying around, I'll be sure to try and snag!
Offline rogersmj
« Reply #59 on: Tue, 03 November 2020, 19:06:19 »
I’m in. I’ve been looking for a quality 65% with Bluetooth, this is amazing.
Offline MadBinton
  • 40/45/65/75% user
« Reply #60 on: Tue, 03 November 2020, 19:19:40 »
Yup, this could be my endgame 65%.
I really hope the price is going to be agreeable.
Offline divergentos
« Reply #61 on: Wed, 04 November 2020, 03:50:50 »
going to be my end game, at least for the nearest future :D
Offline gminso
« Reply #62 on: Thu, 05 November 2020, 10:18:20 »
any rough timeline? this year had alot of stuff to buy near end of the year
Offline gridishere
« Reply #63 on: Thu, 05 November 2020, 15:36:18 »
Unfortunately nope, need that space for the BLE chip.
Offline gridishere
« Reply #64 on: Thu, 05 November 2020, 15:38:46 »
Yeb... will get it fixed when we put 650's content on that. We are collecting info and feedbacks and we might change some details.
Thanks for pointing that out.
Offline darthcapn
« Reply #65 on: Thu, 05 November 2020, 19:18:02 »
Approximately how much time before the gb start date would we be informed about the gb?
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline drfilco
« Reply #66 on: Wed, 11 November 2020, 13:01:52 »
YES! Absolutely want this.
Offline MrFixIT12
« Reply #67 on: Wed, 11 November 2020, 13:57:49 »
This looks gooood
Keebs | Think6.5V2 LE | Bear65 - E-white | No. 1/65 Black/Brass |
Soon |  Satisfaction 75 Black | Iron165r2 Graphite/Stainless Steel | J-01 Rev1 Red | Bauer2 Black/Brass  | No. 2/65 Commission |
Caps | GMK Oblivion V2, GMK WOB, GMK Bleached, GMK Copper
Soon |  GMK Bushido, GMK Hammerhead, GMK Apollo, GMK Classic Red, GMK Masterpiece, GMK Sumi, GMK Stealth, GMK Modo R2, GMK Striker R2 |
Wish list | Cloudline | Type K, Venn, GMK Dracula |
Offline gridishere
« Reply #68 on: Fri, 13 November 2020, 09:02:26 »
There will be a thinner plate for the non-hotswap PCB. Thanks for pointing that out!
Offline gridishere
major updates on Module designs for grid 65
« Reply #69 on: Fri, 13 November 2020, 11:13:37 »
Hi there, gird is here.
After hearing some feedback and some talk with you guys. We decided to do a limited run of WKL version of the keyboard.
We spent some time to implement WKL layout support in the non-hotswap board.
So the layout now is a little different. See here.
GB will be held at zFrontier this decemeber.
Expected fulfill date: MAY 2021.
Still working on the colorway, and suggestions are more than welcomed.
All existing 5 module designs will come in the 650's version. We will be producing 5 new modules for grid 650, and 4 of them will be available for grid 600.
Module Type-01 CLASSIC
IBM Model-F inspired flat top with a pen holder.
Module Type-01S CLASSIC-S
Upgrade the pen holder into a hand-polished, high shine, stainless steel.
Module Type-02 NEON
Features 3 self-luminous tritium vials, delivers a clean and retro look in the dark.
Module Type-03 PEAKS
Facet design inspired by the form of mountains.
Module Type-04 FLASH
Flat top with addressable RGB lighting. With two buttons to adjusting light effects and colors.
Module Type-05 PRESS
Four extra keys at a higher platform, virtually create an "R5" height and feeling.
Module Type-06 WAVE
Organic shape inspired by ocean waves.
Module Type-07 ARRAY
A module utilizes vintage LED displays to indicates time, personal texts, or computer hardware info (PC only).
Module Type-08H LINEAR-H
Module Type-08V LINEAR-V
Two modules share the same simple aesthetic.
Module Type-09 STAND
A phone stand module. Compatible with devices within 95mm or 3.74 inches wide and have a thickness between 6.5mm to 12.5mm. It is made of aluminum like most other modules. Its surface contacting with phones will be covered with artificial leather like Alcantara or Thorp.
Module Type-10 CIRCLE
A module comes with a knob and a switch to select functions. For example, you can switch from volume adjustment or webpage scrolling. The knob also has a sophisticated design to provide a satisfying feel, commonly seen in the high-end audio system.
Let us know what's your favorite module, and we'd love to hear your feedback.
« Last Edit: Fri, 13 November 2020, 11:38:54 by gridishere »
Offline avifo98
Re: [IC] grid 650, updated with new module info
« Reply #70 on: Fri, 13 November 2020, 12:21:05 »
Will the price be similar to the Grid 600?
Offline MrFixIT12
« Reply #71 on: Fri, 13 November 2020, 13:16:16 »
Nice on WKL and I really like modules 1s, 4,6, 7 and 10
Offline careless_esper
« Reply #72 on: Fri, 13 November 2020, 13:45:17 »
Any possibility of some of the older modules returning for the Grid600? I missed out on the Neon module the first time around, and they aren't exactly common, so buying it on /r/mechmarket isn't really an option.
Also, which of the new modules will be made for the 600?
Offline Havattack
« Reply #73 on: Fri, 13 November 2020, 14:45:57 »
I wish i could have FLASH and Circle on the same mod..
I think it would be cool to divide the mod section into 2 mod sections.
1 smaller, taking up a 1/3 to the left, where you could have smaller versions of the Circle, Stand, Array, Press, and Neon.
And the 2nd, taking up the rest of the original mod section 2/3, where the options could be the Classic, Classic S, Peaks, Flash, Waves, and Linear.
Maybe you could take that idea and run with it on a TKL version next time, I guess.
Offline i luv chuletas
« Reply #74 on: Fri, 13 November 2020, 15:24:40 »
Any word on how many will be made?
Offline Jolt
« Reply #75 on: Fri, 13 November 2020, 16:53:35 »
Peaks, flash and the press are the ones that I plan on getting.
I may also get the knob.
Offline DukeEsquire
« Reply #76 on: Fri, 13 November 2020, 17:08:17 »
I would love to see the screen and the knob combined into one module.
Offline richard912
« Reply #77 on: Fri, 13 November 2020, 18:51:09 »
Liking what I see. Will be in if the price is right
Offline iNv_ForEveR
« Reply #78 on: Fri, 13 November 2020, 19:07:03 »
Will there be build guide for this board? Looks kinda complicated...
Offline lakeboredom
« Reply #79 on: Fri, 13 November 2020, 19:55:39 »
Will winkey blockers be available for the Grid600?
« Last Edit: Sat, 14 November 2020, 03:13:29 by lakeboredom »
Offline coffeeshopcoder
« Reply #80 on: Fri, 13 November 2020, 21:20:38 »
Thank you Thank you !!
I’m most interested for the Array. I’ll also be getting neon for my grid600.
And likely the linear. The grid design is very retro and the dolch like Linear -V is very appealing.
Can the array be programmed ? If so how ?
More than time or texts, I’m more interested in hacking together notifications or some kind.
Offline glowcloud
« Reply #81 on: Fri, 13 November 2020, 22:59:29 »
Ooh, very nice! I like Peaks and Array best, I think, maybe Linear (it's hard to choose!). I think a lot of people would be into Stand, I see people wanting a place for pens/phones/etc on their keyboards fairly regularly.
Offline KevinSanToast
« Reply #82 on: Fri, 13 November 2020, 23:25:11 »
I'm so down for this! Though isn't this board bigger than the Boardwalk's 60%?
Offline Mechkeeb
« Reply #83 on: Sat, 14 November 2020, 01:01:02 »
Wait so what is the gb date and estimated price?
Sent from my SM-G985F using Tapatalk
Offline mrchan
« Reply #84 on: Sat, 14 November 2020, 01:29:10 »
Looks really great, any updates on pricing? Limited group buy?
Offline ajsunglao@gmail.com
« Reply #85 on: Sat, 14 November 2020, 02:05:09 »
Pretty excited. Not a lot of DIY options that are BT capable.
Offline mechs
  • www.mechs.io
    • The Mechanical Keyboard Directory
« Reply #86 on: Sat, 14 November 2020, 02:14:53 »
 :eek: Looks amazing. Cannot wait!
Offline OlaffLudwig
« Reply #87 on: Sat, 14 November 2020, 02:55:48 »
Oh boy. These are so cool. I love PEAKS, FLASH and WAVE. I hope I will be able to get one of these.
Offline cmanon
« Reply #88 on: Sat, 14 November 2020, 07:31:33 »
I also would like to see the knob and display modules combined. Pretty exited for this.
Offline treeleaf64
    • treeleaf64
« Reply #89 on: Sat, 14 November 2020, 09:12:58 »
Ok thank you
Everyone must pay the cat tax
Offline hottrout
  • I'd Hit Dat Key
« Reply #90 on: Mon, 16 November 2020, 04:28:06 »
Excitement grows for this 2nd run.  I sadly missed out on the 1st time round, but I hope not to this time.  I will take all the modules as well please, they all look cool.  I also love the new development on the design and engineering.  Keep up the good work.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline woyaodapian
« Reply #91 on: Mon, 16 November 2020, 06:49:45 »
Gorgeous. Would also like to know price and quantity of the sale. Very keen and amazing work!
Will there be other colors beside white and black for base?
Offline rogersmj
« Reply #92 on: Mon, 16 November 2020, 09:12:17 »
Agreed, being able to program the screen to do things based on knob input would be amazing.
Other than the screen and knob modules, I like Peaks.
Offline SirKhamenman
« Reply #93 on: Mon, 16 November 2020, 15:35:26 »
Love it! When will the GB start?
Offline BrainBunker
« Reply #94 on: Tue, 17 November 2020, 04:25:26 »
From the new modules, I would have to say I like Type-07 ARRAY the most. Do you have any prototypes of the display itself? It looks like a 16-segment display design with a retro nixie tube feel in the renders and just wondering how you were planning on achieving that effect. Great work!
« Last Edit: Tue, 17 November 2020, 04:33:13 by BrainBunker »
Offline neutralstate
Re: major updates on Module designs for grid 65
« Reply #95 on: Tue, 17 November 2020, 08:09:12 »
hello there, would it be possible to provide the dimensions for the options in the bottom row?
in particular, i am not sure what the cap dimensions are for the 1st alternative bottom row (the top most green option)
Offline TPSM_00
« Reply #96 on: Tue, 17 November 2020, 10:24:55 »
Reserved
Offline eeyu
« Reply #97 on: Tue, 17 November 2020, 10:31:33 »
whoa!!!
Offline luke2fr
« Reply #98 on: Tue, 17 November 2020, 15:06:38 »
You made me register here :)
Offline Havattack
« Reply #99 on: Tue, 17 November 2020, 15:58:34 »
Nixie tube made me think of vacuum tubes.... vacuum tubes made me think of amps.... MAKE A VACUUM TUBE HEADPHONE AMP MODULE!!!! Vacuum tubes sticking out of keyboard would look dope.
It is kind of crazy, given that the mech and audio communities seem to share many of the same constituents that no one has yet come up with a keyboard with an amp/DAC in it.... (if only i had the motivation..)
