Author Topic: [IC] GMK 80082 | GB LIVE  (Read 131832 times)
Offline GarrettSucks
  • All project timelines at at timelines.omnitype.com
    • Omnitype
« on: Tue, 24 November 2020, 14:28:40 »
GROUPBUY THREAD HERE
DECEMBER 6-31 2020
GMK80082.COM
After being asked many times every single day for a year,
GMK 8008 IS BACK WITH ANOTHER COLOR OPTION!
I am very happy to introduced the BL00 Alternate Standard kit!
Ever since I first designed this set, I wanted to do a blue version of it.
I did not feel confident enough in Round 1 to run two base kits, but Round 2 allows me to have a little more fun!
I hope y'all like it as much as we do!
KIT FEEDBACK
I spent a really long time going over many different kitting routes for this project
and landed on two possible kit "packages". Please take a look at the form to see both packages
and see which one you would rather see in the groupbuy.
IF NO ONE FILLS THIS OUT, I WILL NOT KNOW THAT THERE IS ENOUGH INTEREST TO DO ERGO ALICE IN THE BASE.
>> FEEDBACK FORM <<
PRODUCT INFO
PRODUCED BY GMK
PROFILE: CHERRY
SCULPT: 1-1-2-3-4-4
PLASTIC: ABS
LEGENDS: DOUBLESHOT
MODIFIERS: ICON
COLORS:
There will be no color matching needed in this set.
PINK: CUSTOM (Already matched in round 1)
ALPHA LIGHT BLUE: CUSTOM (Already matched in round 1)
MODS DARK BLUE: CUSTOM (Already matched in round 1)
BLUE: CUSTOM (Already matched in Dracula)
REGIONAL VENDORS
US - Dixie Mech
CA - Desk Hero
EU - Oblotzky Industries
OCEANIA - Daily Clack
ASIA - iLumkb
CHINA - zFrontier
FINAL KITS
STANDARD
Support for TKL, 75%, 65%, 60%, Alice-like layouts, Mod colored pipe and grave
BL00 STNADARD
Support for TKL, 75%, 65%, 60%, Alice-like layouts, Mod colored pipe and grave IN BL00
ALTERNATE
Dual colored modifier support for TKL, 75%, 65%, 60%, Alice-like layouts, Mod colored pipe and grave.
ADDITION
Support for F13, alternate caps lock keys, alternate 65% columns, Basic ISO, HHKB bottom row, 660, 60% with arrows, as well as Type-K from gok.
NUMBERS
Adds support for numpad, 1800, and 1800CP layouts.
BL00 NUMBERS
Adds support for numpad, 1800, and 1800CP layouts in BL00.
AESTHETIC
Adds accent spacebars and arrows, plus 6u alpha colored spacebars.
BL00 AESTHETIC
Adds accent spacebars and arrows, plus 6u alpha colored spacebars in BL00.
MODERN
Adds macOS icon modifiers with alternate tab and esc keys.
BL00 MODERN
Adds macOS icon modifiers with alternate tab and esc keys in BL00.
COMMAND
Adds macOS text modifiers for the bottom row and R3 Caps Lock position.
OBSCURE
Adds support for boards under 60%, ortholinear, and other obscure layouts such as Minila with 2x 3u spacebars.
INTERNATIONAL
Adds legend correct support for many European layouts and accent ISO enters for both pink and BL00 colorways.
FINAL KIT IMAGES
ORIGINAL KIT OPTIONS
Below you can see the two kit "package options" that I have compiled.
Package A: This package is very similar to our past groupbuys (MoDoL, MoDo2, Minimal 2).
Package B: A new take on adding ergo "Alice" compat to the base kit, which in turn changes some things around in other kits.
See below for comparisons of the changes in each package.
You can also go to our website for a better formatted side-by-side comparison. Use this when filling out the feedback form above. Only one of the packages will be available at groupbuy. Not all of them lol
PACKAGE A
S T A N D A R D
Our normal Standard kit with support for TKL, 65%, 60%, 6.25u and 7u bottom rows, with nub homing added.
B L 0 0
Alternate Blue version of 8008. Same as the Standard kit.
A D D I T I O N
Additional compatibility for 65%, basic ISO, HHKB bottom row, F13, FC660, 60% w/ arrows, and options for the caps lock position.
N U M B E R S
Adds compatibility for full size, 1800, 1800CP, and other similar layouts with numpads.
A E S T H E T I C
Accent spacebars & arrows and 6u spacebars.
M O D E R N
macOS Icon modifiers with alternate tab and esc keys.
C O M M A N D
O B S C U R E
Adds support for boards under 60%, ortholinear, and other obscure layouts.
N O R D E
Adds legend correct support for many European layouts and an accent ISO enter.
PACKAGE B
S T A N D A R D
Ergo “Alice” style support added. Removed R1 1u mod color grave and R2 1.5u pipe to try to keep the price the same.
B L 0 0
Ergo “Alice” style support added w/ 2u bar since Addition is all pink caps). Removed R1 1u mod color grave and R2 1.5u pipe.
A D D I T I O N
Added the 2.00c spacebar for the other option for ergo “Alice” style layouts. Moved R1 1u mod color grave and R2 1.5u pipe from base.
N U M B E R S
No change from Package A’s kit.
A E S T H E T I C
M O D E R N
C O M M A N D
O B S C U R E
Removed the second B, 2.25c bar, and 2.75c bar because they are in the base. Added a second 3.00c bar.
N O R D E
LEFT: PACKAGE A     RIGHT: PACKAGE B
I am going to attempt to have the two kits from each package side by side below for comparison,
but if Geekhack formatting fails, you can go here to see them formatted better.
DESKPADS
8008 X RAMA
RENDERS
PROFILE BANNER
For those of you who want to support the set, feel free to add this signature to your profile!
Code: [Select]
[url=https://geekhack.org/index.php?topic=109800.0][img width=480 height=120]https://i.imgur.com/tnCNFL1.png[/img][/url]
(You can do this via Profile -> Modify Profile -> Forum Profile -> Signature)
SPECIAL THANKS
GMK for sticking with me through the quotes of all the different kit options.
Janglad for helping me learn how to actually render things for myself after all these years.
█████████ for always helping me think through the insane amount of kit variations.
Everyone who has supported this set from round 1 until now. :)
« Last Edit: Mon, 07 December 2020, 16:19:15 by GarrettSucks »
    • Omnitype
Re: GMK 80082 | December 2020
« Reply #1 on: Tue, 24 November 2020, 14:29:14 »
Reserved
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #2 on: Tue, 24 November 2020, 14:30:05 »
hi will this pink match the advertised renders this time
thank you
Offline cong314159
« Reply #3 on: Tue, 24 November 2020, 14:31:05 »
Thank you! Finally a set where base set has Alice layout support.
Offline fropsie
« Reply #4 on: Tue, 24 November 2020, 14:31:48 »
That blue kit is looking awesome! Pumped for this
« Reply #5 on: Tue, 24 November 2020, 14:34:51 »
the Blue kit looks awesome but it's a huge shame that there's no support beyond the base
Offline vixixtryx
« Reply #6 on: Tue, 24 November 2020, 14:39:57 »
Will you be using the same pink from the last 8008 or will it be re-done for this run?
Offline baccaan
« Reply #7 on: Tue, 24 November 2020, 14:44:49 »
Would love to see some Vim keycaps in one of the add-on sets. So hyped this is running again!
Offline IOVERCALLHISTIOCYTES
« Reply #8 on: Tue, 24 November 2020, 14:45:50 »
Same. Think you could get 100 blue numpads. I’d bloo myself for numpad and modern.
Offline GaNeBaL
« Reply #9 on: Tue, 24 November 2020, 14:46:35 »
can we have row 5 and rename the set to 80085
Obsessed with 60%TKLs
Offline Nonnegaard
« Reply #10 on: Tue, 24 November 2020, 14:46:57 »
i absolutely love this. well, guess im buying another set
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline Nonnegaard
« Reply #11 on: Tue, 24 November 2020, 14:49:37 »
they say it was already matched in r1 so its the same
Offline treeleaf64
    • treeleaf64
« Reply #12 on: Tue, 24 November 2020, 14:50:17 »
Good job Dixie let us hope that base kit is 99.99
Everyone must pay the cat tax
Offline 1391401
  • MX CLEAR
« Reply #13 on: Tue, 24 November 2020, 14:50:54 »
i sAW A sLusHy AnD WAS iNSpIrED
People I've given money to from this webform who never respond to me and have not shipped me anything: ctrlalt.io 1 2, Team Readline Reputable alternatives to GH group buys: http://pimpmykeyboard.com, https://www.massdrop.com,
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #14 on: Tue, 24 November 2020, 14:51:04 »
thank you
okay i got my answer ty dixie
Offline Wickles
« Reply #15 on: Tue, 24 November 2020, 14:52:11 »
Ah, will defo think seriously about buying this set. Just the the huge norde addon puts me off, I'll obviously purchase it for the UK ISO options, maybe can split it with someone. Great looking set as always.
Offline Nonnegaard
« Reply #16 on: Tue, 24 November 2020, 14:52:34 »
the new blue kit makes the mods look very blue
Offline vixixtryx
« Reply #17 on: Tue, 24 November 2020, 14:54:48 »
Unfortunate
Offline baobaozi
« Reply #18 on: Tue, 24 November 2020, 14:55:15 »
I know it'll probably never happen, but if I ask enough times maybe it'll one day get enough attention .. I'd love a Colemak kit  ;D
« Reply #19 on: Tue, 24 November 2020, 14:56:39 »
package b but add blue numpad
Offline of_sam
« Reply #20 on: Tue, 24 November 2020, 14:57:58 »
I have mixed feelings about the proposed changes. While I don't use mod-colored pipe or grave, I think it's a step in the wrong direction to take those two keys out in favor of the additions. I think they are absolutely necessary to include in the base kit. As much as would like to have Alice support, I wouldn't want to achieve that support by taking out two keys that have been included in most base kits for a while now.
Even with the proposed changes to include Alice support, I maintain that I would love to see numpad + basic iso in the base kit. In a perfect world I would have wanted to have seen a comparison of prices of the current base kit vs. a full base kit. I'm sure this is not feasible at this point but I would be really curious to see how people felt about paying a little bit more for a fleshed out kit. A full base kit would have also given people the opportunity to run the blue kit on more boards, since it seems iso and numpad are not supported in that color.
Thanks for asking the consumers what they would like to see and for considering feedback.
Typing on: HHKB Pro 2 - Stock :aware:
Collection: F1.69, Police, Jubi, RF 87U, En Dash, Rosenthal, Soulless, Frog, Calliope, GAF 910, Sabre, W1-AT
Offline Father
« Reply #21 on: Tue, 24 November 2020, 15:01:20 »
totally agree
« Reply #22 on: Tue, 24 November 2020, 15:01:30 »
mod color pipe and grave are pretty universally decided to be uggo by what appears to me to be the majority of people, i rarely see them used in pictures if ever
it was a big deal to me when i was new and didn't know what i liked but even then it's a stretch, sets have been omitting them for a while and it's barely even been noticed
as long as numpad and iso being removed actually lowers the price then i don't really care about it, but i've seen some vendors remove them but price sets as if they're there
i don't know if GMK is raising their prices or something but it's definitely a little odd to me
Offline toumatakeshi
« Reply #23 on: Tue, 24 November 2020, 15:04:16 »
Quick kitting error, right shift on the kits is labeled 2.25u when it should be (I'm hoping LOL) 1.75u.
Also, was the blue set inspired from a blue sports bra?  ;D
    • Omnitype
« Reply #24 on: Tue, 24 November 2020, 15:07:14 »
Just fixed. And no it wasn't. Seeing that the grays are blue-gray, it was just natural that a blue accent would mesh perfectly with the set.
Offline kraize
« Reply #25 on: Tue, 24 November 2020, 15:11:56 »
So if no color matching is happening, can I assume the blue will be just as dull IRL as the pink was versus the render?
Offline lush_bunny
« Reply #26 on: Tue, 24 November 2020, 15:12:06 »
December?? Damn, so fast. I actually want that blue.
    • Omnitype
« Reply #27 on: Tue, 24 November 2020, 15:13:28 »
The renders above reflect the colors IRL.
Offline of_sam
« Reply #28 on: Tue, 24 November 2020, 15:13:40 »
Yes I agree they are uggo. The main point I guess I was trying to make is stripping down kits even more isn't the answer imho.
Offline Ivo_Ruiter
« Reply #29 on: Tue, 24 November 2020, 15:16:02 »
I think the 1.75c spacebar in the aesthetics kit is 2.00c right?
Offline SenseiJia
  • Hey you.
« Reply #30 on: Tue, 24 November 2020, 15:16:25 »
The blue kit looks sick!
Offline kraize
« Reply #31 on: Tue, 24 November 2020, 15:17:38 »
In the kit renders, maybe. Definitely doesn't look like that in the board renders. Looks more gray than the blue gray it is IRL. It would be a lot more helpful in determining that if the background and board were the same colors for both.
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #32 on: Tue, 24 November 2020, 15:18:20 »
I guess instead of telling people to calibrate their monitors vendors can simply lie now.
Offline FireLock
« Reply #33 on: Tue, 24 November 2020, 15:20:04 »
Hell yeah! Let's go!
Skickat från min SM-G960F via Tapatalk
Offline vixixtryx
« Reply #34 on: Tue, 24 November 2020, 15:25:10 »
Could the lighting be re-done to be consistent to match the original one in that case? If you put them side-by-side they are different due to the lighting in the renders presumably.
https://i.imgur.com/IX7Kgt9.png
Pink is more vibrant, mods are lighter, and alphas look lighter.
Edit : I misinterpreted what you said, this set of renders is more accurate I'd say I sold my original 8008 set so I can't compare them myself. My issue with the original run was the pink was more of a vibrant/hot pink than the pink that was delivered. Granted it does look better in person but 8008 with the current iteration of pink is not ideal IMO in a perfect world the pink would be re-color matched but sounds like it's gonna run as is. Anyways good luck with sets blue one looks great.
« Last Edit: Tue, 24 November 2020, 15:36:25 by vixixtryx »
Offline ossetepo
« Reply #35 on: Tue, 24 November 2020, 15:26:22 »
Am I the only person who strongly prefers mod-color pipe and grave?  I never realized that was a minority opinion.
Also, missed opportunity to name it 80085 or 8008135.
Offline Zaprey
« Reply #36 on: Tue, 24 November 2020, 15:33:05 »
it's a joke that you even considered not having mod coloured pipe and tilde in base..
Offline ZongZiWang
« Reply #37 on: Tue, 24 November 2020, 15:35:31 »
Really prefer mod color grave (`~) when using HHKB layout or WKL layout with split backspace (cause it's more symmetric), and I also want ergo support on the base kit (yeah I wish I can have both).
As someone who does not care about nubbed homing keys, my ideal world is removing nubbed homing keys and bringing back mod color grave in package B.
Offline Zaprey
« Reply #38 on: Tue, 24 November 2020, 15:44:15 »
Additionally, I think it would be good to see numpad and/or physical iso in base with the localised legends in NordeUK kit.
Finally I think the blue kit should be more expansive, covering numpad and physical iso, as there are no child kits for it.
Offline steezkeez
« Reply #39 on: Tue, 24 November 2020, 15:48:34 »
alice support in base is greatly appreciated
should be the standard imo
Offline Azekk
« Reply #40 on: Tue, 24 November 2020, 15:49:12 »
When do you think this would go into GB if there's enough interest? There's another GMK set that's going into GB and I will have just enough money to get it, but I don't want to miss out on this one either. Also it would be cool to see some novelties for this set! Not that I can really think of what they would look like, but still, it could potentially be cool.
Offline upas
« Reply #41 on: Tue, 24 November 2020, 15:49:59 »
I like kitting A better.
Also, I wish there was a blue numpad!
Offline s24752
« Reply #42 on: Tue, 24 November 2020, 15:53:07 »
I am thinking about getting both kits. Is there any way to get just the mods so I don't have 2 sets of alphas?
Offline Poesjuh
« Reply #43 on: Tue, 24 November 2020, 16:00:27 »
Joining the "no mod colored pipe and grave in base B is horrible" camp. Filled the form.
Also, no blue numpad.... ? Really?
Offline Lenux
« Reply #44 on: Tue, 24 November 2020, 16:00:38 »
I wanted the 8008 in blue i got it. Definitely taking it. GLWIC!
Sent from my Mi A2 Lite using Tapatalk
Offline mgsickler
« Reply #45 on: Tue, 24 November 2020, 16:07:31 »
Bloo. Haha
Offline Starston3
« Reply #46 on: Tue, 24 November 2020, 16:07:47 »
I’m fine with Option B and the lack of BL00 numpad, but would like to see a BL00 Aesthetic kit.
I understand that BL00 Command and Modern kits would be a difficult sell and added complexity of SKUs.
Offline gilbert
« Reply #47 on: Tue, 24 November 2020, 16:12:19 »
gilbert does not support this kitting
Collection: F1.69, G80-5K, Bliss TKL, Ecliptica, Cypher, Safa S588, Southpaw Fullsize, HHKB Pro2, Zenith G80-1192HAD
Offline Maniac
« Reply #48 on: Tue, 24 November 2020, 16:12:45 »
The Blue is very nice indeed. But kinda pointless for me as it is missing BL00 ISO, Numpad, International...  :D
Offline xanserkx
« Reply #49 on: Tue, 24 November 2020, 16:14:55 »
Nice boob! I mean 8008..
Oblotzky AIS65 - Rama Zenith - RME Studio Emery65 - TGR Tomo - Hex 4B - Cablecar Design Angel - Cablecar Design Phoenix - Cablecar Design Cypher - Hand Engineering Haus - TX HJ75 - Parallel Limited Portal -  SingaKBD Kohaku -  and bunch of prototypes that I made :(
Sold: Merisi Ottantaquatro
