Author Topic: [IC] GMK Arch | Pricing! | Major IC Changes | Collab Prototypes  (Read 340346 times)
Offline acitrin
    • https://acitrin.design/
Re: [IC] GMK Arch | Collaborations and 2nd Deskmat Announced!
« Reply #150 on: Wed, 23 December 2020, 14:04:33 »
Congrats, Ram!!! Proud of you :D
Offline paulgali
    • SKME
« Reply #151 on: Wed, 23 December 2020, 15:57:46 »
No Ubuntu hate. This is weird.
Offline Milky_Mooncake
« Reply #152 on: Wed, 23 December 2020, 17:01:44 »
I honestly don't like dark keysets but this set is awesome!
Especially the Deskfetch Mat, i need it!
(i use arch btw)
Offline crestia
Re: [IC] GMK Arch
« Reply #153 on: Wed, 23 December 2020, 20:03:52 »
I love how all four of the renders show the colors differently
Offline IceHawk
« Reply #154 on: Thu, 24 December 2020, 00:58:23 »
Nice set. I'm in, if you add NorDE kit
Offline paperassgasket
« Reply #155 on: Thu, 24 December 2020, 16:18:25 »
Arch users are superior. They don't piddle with things like concerning themelves with the shortcomings of lesser OS'
That's what Gentoo is for.
Oh yeah what's going on with 40's support? Have you considered making any changes?
« Last Edit: Thu, 24 December 2020, 16:51:02 by paperassgasket »
Offline Ram
« Reply #156 on: Thu, 24 December 2020, 18:16:51 »
Demand is showing so I'm considering a dedicated 40s kit, but for now I'm waiting on quotes before making any major decisions, tho physical 40s compat will be on the base kit, I just need to update it.
Offline Ram
Re: [IC] GMK Arch
« Reply #157 on: Fri, 25 December 2020, 01:29:28 »
The following keys can be removed from the kits since they either serve no practical purpose or are not commonly used. Sorted top to bottom from “totally useless” to “somewhat useful but may not be worth including”.
  • 1.75c keys in spacebars — not used outside of a small number of 40s boards (which this set doesn't support);
  • second 1c and second 1.25c in spacebars — not used outside of a small number of ortho boards (which this set doesn't support);
  • second R4 1u Alt in base and GUI — only useful if there are 1.5u Super keys;
  • R1 1u Backspace in base — not commonly used;
  • R4 1u 00 — only useful for standalone numpads;
  • R4 2u Shift — popular in East Asia for GK64 and similar 60% layouts w/ arrows, but not commonly used elsewhere.
In place of these, keys to consider adding are F13 to base (as previously mentioned in the thread) and 2× 1.5u Super to base and GUI (in which case you would keep the second 1u Alt keys).
I feel like text mods would be more fitting for an Arch based/inspired set
Same, I feel like this would look 110% better with just text mods and maybe a separate icon mod kit.
I'm inclined to say that text mods would be a good idea. It would probably give the set a bit more character and tie in a bit better with the theme. On the other hand, I think that keeping the current look and adding the GUI kit mods on top is also a nice prospect.
Edit: correction
Just realized I had missed this, thanks Konstantin! Definitely will be putting most of these changes in,
Offline underling
« Reply #158 on: Fri, 25 December 2020, 02:26:37 »
Holy ****, the real logo is in?! <3
I am buying everything. Hell, whatever kits you make I'll buy two of each.
Offline Ram
« Reply #159 on: Fri, 25 December 2020, 15:41:53 »
Dang haha, thanks
Sent from my SM-G960U using Tapatalk
Offline Ram
« Reply #160 on: Mon, 28 December 2020, 13:54:04 »
small update, Samples are inbound from Mechfashion that should be here hopefully by Mid-Late Jan, the same may happen for our metal Artisans from Asero! Updates with photos of the samples will be posted then along with kitting updates assuming that quotes from GMK are back by then,
Offline chaoticgood
« Reply #161 on: Fri, 01 January 2021, 03:42:52 »
very naice. much like. arch hype.
Offline hottrout
  • I'd Hit Dat Key
« Reply #162 on: Fri, 01 January 2021, 04:46:40 »
I will buy this kit to fit on a keyboard of choice to use with my Ubuntu server, then some things will be complete.  Is there any possibility of adding UK ISO to a kit or maybe a NordeUK kit?
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline IceHawk
« Reply #163 on: Fri, 01 January 2021, 04:55:09 »
Hoping for a NorDE/UK Kit as well. These are very nice keycaps, but I will not buy it without a NorDE kit.
Offline Applet
« Reply #164 on: Fri, 01 January 2021, 06:07:12 »
Looks great! :D
Would it be possible to add a blank 1.25u in spacebar-profile for the common 6.25-split space (2.25 - 1.25 - 2.75) to the Powerline-kit?
EDIT: Found the missing B
« Last Edit: Fri, 01 January 2021, 06:13:35 by Applet »
Offline Ram
« Reply #165 on: Fri, 01 January 2021, 13:15:43 »
Looks great! :D
There actually used to be 2 1.25us in that kit, so adding one back can definitely be done.
At this point I'm waiting on quotes before drafting a full nordeuk kit, but most likely it will happen based on the responses I saw
Offline dodoegg00
« Reply #166 on: Fri, 01 January 2021, 21:35:19 »
I know there's a pretty long earlier thread on Arch's original icon and colors, but just wanted to double-check.  Is it a foregone conclusion that the original Arch blue won't be in the set, not even as part of an add-on kit?
Offline Ram
« Reply #167 on: Sat, 02 January 2021, 13:43:26 »
No, if you want to get as close to the arch blue in a set, you'd have to get GMK Umbra, because my set would too close to it if I used it.
« Last Edit: Sat, 02 January 2021, 13:46:23 by Ram »
Offline R4YN3
« Reply #168 on: Sun, 03 January 2021, 20:31:15 »
1This set is awesome! Can't wait to buy all the things!
Offline psycherhexic
« Reply #169 on: Tue, 05 January 2021, 06:13:59 »
The reason this set uses a different color than the original Arch blue is because some other set previously used a similar colorscheme? This does not make much sense. This design is obviously not a copy of GMK Umbra, but instead inspired by something completely different; that something of course being Arch Linux, where there is an obvious choice for the colorscheme. Any Linux user knows, at least roughly, what "Arch blue" looks like.
I do not understand why, in this hobby, some people think select colorschemes are reserved. There are people that jump into new threads and say, "The colorscheme of this set of keycaps is too similar to that of set x, which ran once y years ago, so you cannot make this."
We are talking here about blue and dark grey/black, a common combination all over the world.
We should let people have what they want and vote with their money. If there can be a bunch of cyberpunk keysets, many run at the same time and which all use relatively similar colors, then there can be more than one blue and dark grey keyset.
Offline Ram
« Reply #170 on: Thu, 07 January 2021, 15:37:50 »
This is a valid belief, but first personally, I don't feel it's right to be selling a near identical set for profit. When you said that the community should vote with their money, they do, and almost always its against too similar colorways. As much as I'd want to use the true Arch colors, my personal morals and the ethics of our community don't support it. By the way, there are no cyberpunk  keysets, all of the ones that were put up were trolls haha
Offline NoteMakoti
  • for sale, baby shoes, never worn
« Reply #171 on: Thu, 07 January 2021, 19:21:50 »
I agree, the community is too protective of colorsets.
« Reply #172 on: Fri, 08 January 2021, 10:29:07 »
I think these people are more just being vocal about it, I am guessing the number of people that would actually boycott a set for too similar colors based on some principle would be very few. You'd probably just lose some sales from people that like the color but bought the older set that is similar to the new one being run.
There is a lot of gate keeping in this hobby.
Offline Ram
« Reply #173 on: Fri, 08 January 2021, 12:47:44 »
(Posting the same update I put on the discord)
Kitting overhaul is likely, and will be confirmed once I have quotes for current kitting,
any major changes to lower cost(if it ends up being needed) will be left up to a poll of Kit Ver 1 vs Kit Ver 2, with a "price tag" for each to show the difference in overall value. For new kits, 40s and NorDeUK will happen based on the IC form responses, Ortho/Ergo is a hard maybe and if I do add it they'll be one kit. Numpad kit is possible if costs do need to be cut down for shell, along with moving all 40s compat and iso compat to respective kits(this is what the poll will decide). I'll keep you guys updated on this.
Btw If you wanna be able to vote on any of hte polls I put up or be up to date on any small updates, join the discord, will make mnaging things way easier on my end
Offline nvh2092
« Reply #174 on: Fri, 08 January 2021, 16:36:11 »
I recommend this kitting for base kit: https://geekhack.org/index.php?topic=109588.0 with/without a few minor tweaks, like adding that accent 6.25 space bar to base  ;D
« Last Edit: Fri, 08 January 2021, 16:37:43 by nvh2092 »
Offline Ram
« Reply #175 on: Fri, 08 January 2021, 23:56:16 »
Will take a look at it, thanks!
« Reply #176 on: Sat, 09 January 2021, 09:00:56 »
I agree, Think was one of the better kitted sets.
Offline fatpolomanjr
« Reply #177 on: Sun, 10 January 2021, 22:44:36 »
I'm going to install arch on a 51nb Thinkpad so I can live up to the "I Use Arch BTW" enter key. Thank you for the inspiration.
Some guys keep on saying they believe in Jesus, and keep doing a lot of shameful things.
Current GH Classified Post (LF Arcade Floor, Garbield and CYM Otter and Keyng)
Offline Ram
« Reply #178 on: Sun, 10 January 2021, 22:48:33 »
Offline scoopbb
« Reply #179 on: Tue, 12 January 2021, 02:40:54 »
this set is a banger.
know it probably wouldn't happen but a nord style ergo/ortho/40s kit would be killer
Offline Arch4Life
« Reply #180 on: Tue, 12 January 2021, 03:21:56 »
well, this is definitely a must-have set for me lol
Sent from my SM-N960U using Tapatalk
Offline Ram
« Reply #181 on: Tue, 12 January 2021, 11:58:02 »
A combo of all 3? I was most likely going to do just a 40s and a ortho/combo but I can definitely do this.
Edit: ignore every comma I type I have an issue w overusing them in the worst places
« Last Edit: Tue, 12 January 2021, 12:50:27 by Ram »
Offline scoopbb
« Reply #182 on: Tue, 12 January 2021, 12:46:39 »
A combo of all 3? I was most likely going to do just a 40s, and a ortho/combo, but I can definitely do this.
oh baby yes please
Offline knam316
« Reply #183 on: Wed, 13 January 2021, 09:49:45 »
I love the dark sets with subtle color accents :)
Offline candravamsa
« Reply #184 on: Wed, 13 January 2021, 10:42:38 »
YES. I repeat. YES.
Offline crispgm
« Reply #185 on: Wed, 13 January 2021, 11:04:02 »
also want a RAMA Arch artisan  ;)
Offline catbus
« Reply #186 on: Wed, 13 January 2021, 11:22:23 »
YES. I repeat. YES.
I would be in instantly if we got an assembly kit
Sent from my SM-G965W using Tapatalk
Offline Ram
« Reply #187 on: Wed, 13 January 2021, 13:20:31 »
small update, the Accentlegend/mod color ral is now 260 20 05 instead of 260 20 10, it's a less bluish shade and more true to the renders.
Offline iknowreal
« Reply #188 on: Wed, 13 January 2021, 16:35:40 »
as an arch user I told myself this was not going to just spread my wallets legs but It has been spread. The more I look at this set more I like it. It's those Alpha's I love so much. Sudo  and that enter key. I use arch btw.
Offline Owitzo
« Reply #189 on: Thu, 14 January 2021, 10:03:55 »
A nordic / iso option would be amazing. Loving the kit
Offline GMK_Andy
    • GMK
« Reply #190 on: Tue, 19 January 2021, 16:07:52 »
I wanted to check on this actually, and see if you have permission to be using the Arch logo? According to their trademark policy it can't be used if there is commercial intent, or for merchandising purposes, e.g. on t-shirts etc.
It would also require "TM" be included on the logo as well - if approved. Just an FYI and something that should be looked into.
Arch Trademark Wiki Page
« Reply #191 on: Tue, 19 January 2021, 16:30:54 »
That is covered near the bottom of the OP:
Use of the Arch Logo and Name Approved by the Arch Trademark team
I Understand that This Set Does Look Like GMK Apollo, but I have recieved permission from
Octix to run this set.
Proof of This can be sent by request
Contact
/u/Plasmusang on Reddit
@kushpapi._._ on Instagram
Ramlord#2733 on Discord
Not sure about the trademark.
Offline MrGuccu
« Reply #192 on: Tue, 19 January 2021, 17:23:07 »
This is so amazing
Offline Ram
« Reply #193 on: Tue, 19 January 2021, 19:40:56 »
Like poloman said I got explicit permission from them to run the set with the logo but they never mentioned that I would have to add the tm to the novs, I'll email them again to make sure
Offline GMK_Andy
    • GMK
« Reply #194 on: Tue, 19 January 2021, 19:49:27 »
Ah, very good! I read over the thread but must have missed that.   :-X
I believe as long as you got approval then it should be fine, I was simply going off of what the Wiki was stating! Seems like you have it all covered and did your homework, I'll send you a DM just to make sure we get any information needed so there are no surprises or delays regarding this from our end down the line and go ahead and let the team know that this logo should be fine for production.
Great efforts and design :thumb:
« Last Edit: Tue, 19 January 2021, 19:53:05 by GMK_Andy »
Offline Ram
« Reply #195 on: Tue, 19 January 2021, 20:24:17 »
Thanks again!
Offline GMK_Andy
    • GMK
« Reply #196 on: Tue, 19 January 2021, 20:26:41 »
I have all the information needed for logo use on the GMK side - this won't be a problem to manufacture. Giving this set a huge thumbs up on my end  :thumb:
To fit the theme you should make a keyboard that requires the firmware to be programmed before each use   :p
« Last Edit: Tue, 19 January 2021, 20:28:16 by GMK_Andy »
Offline Ram
« Reply #197 on: Tue, 19 January 2021, 20:40:00 »
Ofc Ofc, also forgot to ask, I'm pretty sure the cuts in the arch logo would need to be removed(I swapped the arch logo from a simplified one to the real one a few days after sending the original kits for quotes) do you know yourself if they need to be or not? I'll dm you the svg if you need it.
Offline GMK_Andy
    • GMK
« Reply #198 on: Thu, 21 January 2021, 12:37:53 »
Yeah, send me over the .svg and I can take a look at it for you :thumb:
Offline dimamantra
  • | (• ◡•)| (❍ᴥ❍ʋ)
« Reply #199 on: Thu, 21 January 2021, 12:55:47 »
Would love the mountains desk mat without the details in the lower right  :thumb:
That one is SLEEK!
