Author Topic: [IC] Bushwacker - super wide, southpaw  (Read 19663 times)
Offline Croktopus
« on: Fri, 18 December 2020, 12:55:19 »
258189-0          258209-1
Bushwacker
An extra-wide rubber grommet mounted leafspring keyboard
IC Form
Discord
Layout
  • Left-handed numpad allows comfortable simultaneous numpad & mouse use, and brings hands closer together for right-handed mouse users in normal operation
  • Extra right-side column allows for full nav cluster functionality, without typical 65% compromises
  • Optional 2u delete for more natural homing, and optional right-side 2u enter to hit with your mouse hand thumb
  • Wider gaps (6.35mm instead of typical 4.7625mm) make separation more concrete, and the 12.7mm gap between numpad and 60% block mitigates mistypes when reaching for left control.
  • Plate(s) will have limited compatibility - rather than providing a universal plate, it can be built plateless
  • IC form will mainly be used to refine the specific plate options offered at GB - plate files will also be available for less popular layouts and so they may be cut in other materials
258211-2
Internals
  • Grommets isolate the PCB/plate assembly from the metal case, and self-align for easy assembly
  • Leaf spring PCB allows for plenty of evenly distributed flex, with slightly softer spots intentionally placed near the center of the typing position and spacebar
  • Aluminum plate & plate foam clean and warm the sound, in addition to further evening out the flex and only slightly decreasing flex overall
Externals
  • All aluminum, with a mass of roughly 2KG unbuilt (case, pcbs, plate) and 2.5KG built
  • Low front height, with an EKH of roughly 22mm (read more about EKH here)
  • 6 degree typing angle
  • Colors TBD, but currently plan on black, gray, silver, and red, with potentially some two-toned configurations as well (or instead)
258195-3          258197-4
258191-5          258193-6
Electronics
  • STM32 controlled PCB using an ESD & fuse protected daughterboard
  • QMK & VIA support planned, with additional firmware support planned
  • RGB lock lights, with light piping for superior visibility
258205-7258207-8
Price TBD
Vendors HMU
More Renders
258201-10
258203-11
« Last Edit: Fri, 18 December 2020, 13:00:58 by Croktopus »
Offline Croktopus
Re: [IC] Bushwacker - super wide, southpaw
« Reply #1 on: Fri, 18 December 2020, 12:57:05 »
FAQ
Vendors?
I would love to have a vendor run this, as based on my experience with the Timber Wolf, I don't think I'm very good at that stuff. I've contacted a couple already, and if you are a vendor and are interested in running this please reach out, but I'm also considering using something like a fulfillment service. We'll see.
Pricing?
TBD, but likely not super low - despite there not being a weight, some of the geometry isn't the most friendly to machine, and it's kinda huge. I'd say midrange.
ETA?
TBD, I wanna get it perfect first, and I need more prototypes.
Files?
I'll release a bunch of plate files so people can get their own cut in exactly their desired layout and material, and I also plan to open source the PCB after the GB.
2U vertical keys?
I love the 2U delete in this position because it fits as the solution to these 3 criteria:
1) I want the delete key to be directly to the right of backslash, just like on a full-size or TKL
2) I don't want any additional keys below the delete key, which might get in the way of my pinky when I hit delete, or mess up my homing
3) I don't want a gap between the up arrow and the delete key
Obviously, we're left with the problem of there being no properly legended 2U delete keys, but I make do with a numpad+
The enter is because I like to hit enter with my mouse hand thumb after typing something brief, say into the address bar, or an excel document. Just fits my use pattern, and I've heard from a few other people that they do something similar.
Alternative Firmwares?
Long story short, Mr. xyz is working on a new qmk gui thing called vial. The raison d'etre is more to do with being open source and not requiring changes be made to the central repository when designers want to add their keyboard, but one of the neat side benefits is that he was also able to add support for instant remapping of encoder behavior and it even has layer functionality for the encoders. I'm using it right now and it's great, and this particular feature is perfect for the Bushwacker, but the one eh thing is that it's super early development and it might not be out or have a stable release when the Bushwacker comes out, so I'm not gonna commit to it being a feature of this board (tho I will provide files for anyone who lives the beta testing lifestyle).
« Last Edit: Sat, 19 December 2020, 08:23:32 by Croktopus »
Offline jestemfranklin
« Reply #2 on: Fri, 18 December 2020, 13:03:07 »
Whoa...should I wait until the kids leave the room to watch that Bushwacker Explosion video? Age restricted?
Offline Zeelobby
« Reply #3 on: Fri, 18 December 2020, 13:04:55 »
Oh buddy. Haha. It's here
Offline $W4GK!NG
  • Cars/Racing/Keyboards/Watches Enthusiast
    • Linktree
« Reply #4 on: Fri, 18 December 2020, 13:06:52 »
Very interesting layout and mounting style, I'm definetly intrigued, GLWIC
Offline Baka Bot
« Reply #5 on: Fri, 18 December 2020, 13:12:26 »
interesting yes.
Offline catamscott
« Reply #6 on: Fri, 18 December 2020, 13:34:41 »
that pcb mounting looks nice, and a good looking board overall!  :thumb:
Offline ddrfraser1
  • RIP Neil
« Reply #7 on: Fri, 18 December 2020, 13:46:41 »
I guess the Bone Ranger, Disco Stick and Poonpounder didn't make the cut.
WANG was already taken.
Offline Croktopus
« Reply #8 on: Fri, 18 December 2020, 13:54:01 »
put the kids to bed
kept you waiting huh
i name my mechs after mechs actually
Offline OtherAndrew
« Reply #9 on: Fri, 18 December 2020, 14:18:18 »
what happens when i use jarate with this
Offline ddrfraser1
  • RIP Neil
« Reply #10 on: Fri, 18 December 2020, 14:38:02 »
Thinking about doing a 40 and calling it the "Eshlonggate"
Offline paperassgasket
« Reply #11 on: Fri, 18 December 2020, 16:31:37 »
Finally!
Offline niakulah
« Reply #12 on: Fri, 18 December 2020, 17:36:19 »
Hell yes!
Offline rooski15
« Reply #13 on: Fri, 18 December 2020, 17:45:48 »
Definitely going to be following this one - excited to see where it goes.
Offline stoffelduss
« Reply #14 on: Fri, 18 December 2020, 18:03:37 »
cool layout, interested!
Offline Havattack
« Reply #15 on: Fri, 18 December 2020, 18:46:04 »
I have no need or want of a num pad, but that keyboard looks amazing. looks great next to your avatar pic too.
Offline lush_bunny
« Reply #16 on: Fri, 18 December 2020, 22:05:53 »
YES YES YES I HAVE WAITED SO LONG FOR THIS
Clicks watch and notify; IC filled
« Last Edit: Fri, 18 December 2020, 22:13:40 by lush_bunny »
Offline Koatl
  • Kozahtli on reddit, etc.
« Reply #17 on: Fri, 18 December 2020, 22:10:32 »
Would love white or black/white mix.
...also what do these knobs even do?
Offline lush_bunny
« Reply #18 on: Fri, 18 December 2020, 22:18:25 »
C-Can any keyboard survive jarate?
If this knob serves the same function as the one in the Timber Wolf (Crok's previous GB, see me stanning it in my signature), then volume control by default. I use for mute/unmute and play/pause as well.
« Last Edit: Fri, 18 December 2020, 22:20:54 by lush_bunny »
Offline Croktopus
« Reply #19 on: Sat, 19 December 2020, 01:26:47 »
Hell yes!
there's dozens of us!
so hm i shoulda written more on this. basically, this board was originally designed to be my keyboard-designing keyboard. as such, personally, ill be using the knob for things like changing grid size in kicad, switching between tools in fusion 360, etc. however, default behavior will be volume & mute because that i think will be the most popular use
Offline lush_bunny
« Reply #20 on: Sun, 20 December 2020, 19:34:56 »
Hell yes!
I used to doubt, but now I am a believer.
Offline vilagefool
« Reply #21 on: Thu, 11 February 2021, 11:11:05 »
I'm in! Got the Timber Wolf and love it! The right 2u enter and 2u delete are crazy useful, and this has MOAR!
Offline MIGHTY CHICKEN
« Reply #22 on: Thu, 11 February 2021, 11:31:09 »
good
Offline NorrittMTG
« Reply #23 on: Thu, 11 February 2021, 11:42:20 »
this is incredible!
Offline Rx003
« Reply #24 on: Fri, 19 February 2021, 05:50:42 »
Long boi I like  :thumb:
Offline lush_bunny
« Reply #25 on: Thu, 18 March 2021, 06:47:53 »
any updates 👀
Offline sybase
« Reply #26 on: Thu, 18 March 2021, 14:24:45 »
The more I look at this, the more I want it. I appreciate the split spacebar options :thumb: and that right nav cluster looks aesthetic and functional. If possible, would like to see prototypes sent out to streamers/reviewers.
Offline lush_bunny
« Reply #27 on: Sun, 04 April 2021, 07:47:17 »
April bump.
Offline Vibex
  • Love y'all
« Reply #28 on: Sun, 04 April 2021, 08:21:41 »
Really hope this board isn't dead, its such a novel concept!
Offline yotasan
    • ARCANE - PHOTOGRAPHY ARCHIVE
« Reply #29 on: Sun, 04 April 2021, 08:34:13 »
i do see the usage in the left numpad, im definitely into this
Offline iinko_mk
  • Status: broke
« Reply #30 on: Sun, 04 April 2021, 08:53:01 »
this is the innovation this community needed.
I'm really interested in this, if it is possible to keep under or around the 450-500 USD range...
Offline Croktopus
« Reply #31 on: Fri, 23 April 2021, 01:44:17 »
Quick update: vendor search has gone so well that I'm waiting for the other shoe to drop. New proto ordered with slight geometry update and some small internal tweaks, I think y'all are gonna like it. Sorry for the lack of updates but I didn't have much to say. I'll post a big IC 2 update when the new proto's in and vendors are locked.
Offline lush_bunny
« Reply #32 on: Fri, 23 April 2021, 02:16:30 »
Happy to hear about the vendor update! Can't wait to see the changes you've made with the new prototype.
Offline Vibex
  • Love y'all
« Reply #33 on: Wed, 14 July 2021, 12:51:26 »
Any new updates here?
Offline lush_bunny
« Reply #34 on: Tue, 19 July 2022, 08:52:26 »
Yo dawg I heard there was a prototype :D
