Author Topic: GB CLOSED  (Read 28280 times)
Offline RIFT
    • RiftKeys
GB CLOSED
« on: Sun, 17 January 2021, 02:01:56 »
GB CLOSED
« Last Edit: Mon, 08 February 2021, 07:06:45 by RIFT »
Offline gMit
Re: [IC] Emeralds 70g PME Tactile Switch - RiftKeys
« Reply #1 on: Sun, 17 January 2021, 02:04:31 »
Can you add any more details on this new PME housing? Who's the manu for this switch?
Offline Pluto19
  • All who break the taboo will be eliminated.
« Reply #2 on: Sun, 17 January 2021, 02:06:10 »
did you mean to post this in the group buy subforum?
Offline RIFT
    • RiftKeys
« Reply #3 on: Sun, 17 January 2021, 02:15:24 »
It is Polycarbonate Blend that is still a proprietary material compound mixture.
The manufacturer and i cant really disclose at this current time. May do in the future.
« Last Edit: Tue, 19 January 2021, 21:57:20 by RIFT »
Offline RIFT
    • RiftKeys
« Reply #4 on: Sun, 17 January 2021, 02:15:49 »
Was not meant to add dates. Still TBC
Offline Pluto19
« Reply #5 on: Sun, 17 January 2021, 02:41:09 »
Ah gotcha.
Also no clue who Mechs & Co is other than that board Yoni was supposed to run with them until he chose to not work with them anymore.
I guess they've done a deskmat group buy so that's at least something. Seems to have just absorbed any and all keysets though :/ Slight concern there
Offline Keeblet_257
Re: [IC] Emeralds - 70g PME Tactile Switch - RiftKeys
« Reply #6 on: Sun, 17 January 2021, 04:36:54 »
I am not that into switches and have like minimum knowledge about switches but can anyone tell me how a takticle stem and linear can be in the same switch?
Offline caronte0
« Reply #7 on: Sun, 17 January 2021, 04:50:29 »
Is there any force curve to see how it compares to other tactile switches?, how is the bump more like rounded or more snappy?
Offline RIFT
    • RiftKeys
« Reply #8 on: Sun, 17 January 2021, 05:14:46 »
More information will be coming soon with force curves of springs etc.
I can tell you that the bump is a nice rounded bump up top that continues for most of the down stroke.
Offline PhantomTaco
« Reply #9 on: Sun, 17 January 2021, 06:07:17 »
Can you provide a datasheet or the full chemical name of PME? Curious about the material as I haven't heard of it before.
Offline Zanhana
« Reply #10 on: Sun, 17 January 2021, 06:14:16 »
    so like a U4T stem?
    other questions:
    • does it bottom out on the rails or on the stem pole?
    • actuation and total travel distances?
    • your description says a linear force curve spring but the image says progressive, which is it?
    [/list][/list]
    « Last Edit: Sun, 17 January 2021, 06:17:25 by Zanhana »
    Offline lush_bunny
    « Reply #11 on: Sun, 17 January 2021, 06:47:43 »
    Very interested in what PME is all about and how it's different from Polycarbonate, Nylon, and POM when it comes to housing materials. Also interested in the sound profile as well.
    Offline ChromePcok
    « Reply #12 on: Sun, 17 January 2021, 09:30:56 »
    Tecsee?
    Offline CrispFunk
    « Reply #13 on: Sun, 17 January 2021, 10:13:07 »
    My bet is Tecsee.
    Sent from my GM1910 using Tapatalk
    Offline CosminOance
    • 'tis the season to be yourself
      • PixelDrama.club by Cosmin Oance
    « Reply #14 on: Sun, 17 January 2021, 10:28:35 »
    What is PME and why/how is it better/special? The response to this should trigger interest.
    Offline Nuclear Nachos
    • Anima and Animus
    « Reply #15 on: Sun, 17 January 2021, 11:35:35 »
    when they say linear i believe theyre talking about the spring, the switch/stem is tactile. heres a graph from sprit that shows the different types of springs (that he sells at least) https://www.spritdesigns.com/mx?pgid=jlv17iwk-d78fac7d-26d1-479d-9b28-c6b225b3b5b4
    Offline Ram
    « Reply #16 on: Sun, 17 January 2021, 12:42:22 »
    nice job rift!
    Offline Anthixious
    « Reply #17 on: Sun, 17 January 2021, 13:14:50 »
    Awaiting more info myself as well, but these have a nice color to them!  :thumb:
    Offline RIFT
      • RiftKeys
    « Reply #18 on: Sun, 17 January 2021, 17:05:30 »
    Sadly i cannot offer a datasheet on the chemical compounds. I can however tell you its a Polycarbonate Blend that is a proprietary compound mixture.
    So PME is a Polycarbonate blend that is a proprietary compound mixture.
      so like a U4T stem?
      other questions:
      [/list][/list]
      - Bottom out is on the stem
      - Am getting graphs for this as soon as possible and will update
      - Totally missed this, its a linear curve spring, will change image
      « Last Edit: Tue, 19 January 2021, 21:59:48 by RIFT »
      Offline NovaRMK
      « Reply #19 on: Mon, 18 January 2021, 16:47:00 »
      Reserved.
      Offline RIFT
        • RiftKeys
      « Reply #20 on: Tue, 19 January 2021, 23:23:41 »
      Reserved
      Offline Patosdon
      « Reply #21 on: Wed, 20 January 2021, 17:23:44 »
      This is the perfect switch to pair with GMK Aurora Polaris. Definitely looking forward to getting these!
      Offline lakeboredom
      « Reply #22 on: Wed, 20 January 2021, 18:10:49 »
      Oh thank god, another top-bump style tactile switch. I was running out of options this past year...
      Offline Bantalope
      « Reply #23 on: Wed, 20 January 2021, 18:14:40 »
      We going to be getting sound tests prior to GB?
      « Last Edit: Wed, 20 January 2021, 22:41:38 by Bantalope »
      Offline RIFT
        • RiftKeys
      « Reply #24 on: Wed, 20 January 2021, 19:44:53 »
      We going to be getting a sound tests prior to GB?
      Correct, Have samples coming now
      Offline iinko_mk
      • Status: broke
      « Reply #25 on: Wed, 20 January 2021, 21:05:56 »
      poggies
      Offline ItszBrian
        • GMK Devoted
      « Reply #26 on: Wed, 20 January 2021, 21:33:20 »
      The rise of the tactiles
      Offline RIFT
        • RiftKeys
      « Reply #27 on: Thu, 21 January 2021, 22:38:36 »
      Offline RIFT
        • RiftKeys
      « Reply #28 on: Sun, 24 January 2021, 15:45:16 »
      Product page has been listed for anyone wanting to get more information
      www.riftkeys.com
      Offline CustomerSupport
      • 🕸 developer
        • Discord
      « Reply #29 on: Sun, 24 January 2021, 17:28:33 »
      Always interested in a nice tactile. The bump sounds a tad big for my taste, but i'll have to grab a sample pack or 2 to try them out
      Offline RIFT
        • RiftKeys
      « Reply #30 on: Tue, 26 January 2021, 16:19:03 »
      Vendor and GB Dates announced.
      OCE Listing is up for more information - HERE
      Offline Anthixious
      « Reply #31 on: Tue, 26 January 2021, 16:59:57 »
      Wow that means 5am Eastern Time in the states, better be some damn good switches LMAO  :))
      Offline RIFT
        • RiftKeys
      « Reply #32 on: Tue, 26 January 2021, 17:05:06 »
      They will be live for a month, no need to wake up at 5am, Sleep in  :)
      Offline Anthixious
      « Reply #33 on: Tue, 26 January 2021, 17:24:43 »
      Oh sweet, I'll drink to that! *clink*  :D
      Offline Lemmy
      • what
      « Reply #34 on: Tue, 26 January 2021, 18:12:37 »
      How accurate are the renders in terms of the stem? That looks like a pretty wildly different shape from anything I've seen, is that just due to rendering capabilities or is this how they'll actually be shaped?
      I moderate the discord server
      http://discord.gg/mechkeys
      Offline RIFT
        • RiftKeys
      « Reply #35 on: Tue, 26 January 2021, 18:17:33 »
      That render may be slightly exaggerated and does not reflect the final product, i will have stem images soon :)
      Offline Beerbezerker
      « Reply #36 on: Sat, 30 January 2021, 20:37:57 »
      Offline Cubic // esc lab
      • Formerly 'esclab'
        • esc lab
      « Reply #37 on: Sat, 30 January 2021, 22:30:43 »
      Ah gotcha.
      Mechs & Co is a newer vendor but Patrick, Mike, Chris, and the rest of the team are nothing but professionals.
      Offline RIFT
        • RiftKeys
      « Reply #38 on: Sun, 31 January 2021, 20:56:29 »
      Ah gotcha.
      The boys at Mechs & Co are 110% professional and passionate about everything they do.
      GB will be LIVE this SUNDAY 7/2/21 for 4 Weeks
      Offline iinko_mk
      • Status: broke
      « Reply #39 on: Mon, 01 February 2021, 13:26:00 »
      Ah gotcha.
      Mike, Chris and Patrick are some of the most professional people out there. There are currently running GMK Civ and Kam 80s after dark. Two very successful sets so far
      • 🕸 developer
        • Discord
      Re: [IC] Emeralds - 70g PME Tactile Switch - GB DATE ANNOUNCED
      « Reply #40 on: Mon, 01 February 2021, 15:57:04 »
      (Planned) Shipping in April? Fantastic.
      Looking forward to grabbing a few packs.
      Offline RIFT
        • RiftKeys
      « Reply #41 on: Tue, 02 February 2021, 16:18:35 »
      Hoping for April shipping but cant 100% guarantee anything as that's the nature of business. Will do my best to get them out in April.
      Offline RIFT
        • RiftKeys
      Re: [IC] Emeralds - 70g PME Tactile Switch - GB DATE & VENDORS ANNOUNCED
      « Reply #42 on: Tue, 02 February 2021, 16:19:09 »
      GB Live this Sunday 7/2/21
      « Last Edit: Wed, 03 February 2021, 05:24:25 by RIFT »
      Offline hyppialonso
      « Reply #43 on: Thu, 04 February 2021, 22:59:27 »
      interested in this and is waiting for a sound test or review
      Offline Groom
      « Reply #44 on: Fri, 05 February 2021, 11:46:48 »
      nice color , but 70g maybe tired for me
      Offline Friendship
      « Reply #45 on: Fri, 05 February 2021, 12:29:59 »
      interested! 70g is strong but could be great for numpad/macropads. is there a sound test?
      Collection: LZ GHv2, Esheu Fallacy, Moesode Bliss, Daji Ocho Cuatro, Ace Saturn60, Bolsa Midway60, MLI NUM1, MLI VISION, PW ROTR
      Offline Aeterna
      « Reply #46 on: Sat, 06 February 2021, 07:55:47 »
      Any vendor for SEA? Really interested on this switch, hoping for a 67g spring but 70g will do.
      Offline hyppialonso
      « Reply #47 on: Sat, 06 February 2021, 10:19:39 »
      it will be going live soon but other regions' vendors are still not up, does it mean there is no?
      Offline RIFT
        • RiftKeys
      « Reply #48 on: Sat, 06 February 2021, 16:43:44 »
      Vendors will be announced today for all regions.
      Currently no soundtest for the switches but we are trying to get a detailed video on the switches done today
      There will be international vendors that will be announced today
      Offline RIFT
        • RiftKeys
      Re: [IC] Emeralds - 70g PME Tactile Switch [SOUND TEST LIVE]
      « Reply #49 on: Sat, 06 February 2021, 19:01:00 »
      Sound test in original post.
      Switches go live today
