Author Topic: [IC]GMK Pharaoh : GB ENDS TOMORROW!! Don't miss out!  (Read 193634 times)
Offline SxM Designs
  • https://sxmdesigns.com
    • Website
Re: [IC]GMK Pharaoh : Deskmats revealed!
« Reply #150 on: Mon, 10 May 2021, 17:21:39 »
GMK Pharaoh Deskmat Reveal
Presenting the 2 deskmats we have been working behind the background! Some of you have already seen the sneak peak but here is the real deal!
Artifact 1 : Giza Nights :
Artifact 2: Ankh
I would really appreciate if you could leave some feedback/ comments.
Offline iShibe
« Reply #151 on: Mon, 10 May 2021, 17:28:15 »
Simply astounding!!! My recommendation would be for Giza Nights to add maybe some gold on the temple in the background? It kind of lacks that Black/Gold theme that the keycaps have, and I'd say doesn't fit as much as the Ankh does. I'm simply in love with both and will buy them both anyways!!!
Offline SxM Designs
    • Website
« Reply #152 on: Tue, 11 May 2021, 01:03:42 »
Thanks for the kind feedback. Much appreciated.
The reason for keeping the to make is more pleasing. The nightscape one has elements on both sides. So a small amount of gold would just emphasize that area. We did try this but were not satisfied with the end result.
The ankh on the other hand is a single element which needed to pop out of the hieroglyphics and hence the yellow.
Offline WillyWortel
« Reply #153 on: Tue, 11 May 2021, 02:18:07 »
Both are very nice.
I'm going for the Ankh :)
Offline VAMP
  • VAMP
    • Buy me a Ko-fi maybe?
« Reply #154 on: Tue, 11 May 2021, 05:25:44 »
I had this idea before. Now I'm really glad that someone made it into reality. Definitely gonna cop! GLWIC
Your friendly neighbourhood graphic designer. Hit me up if you need any graphic works! ✏️
https://www.instagram.com/by.vamp/
Offline SxM Designs
    • Website
« Reply #155 on: Tue, 11 May 2021, 09:39:39 »
Thank you :)
Offline SxM Designs
    • Website
« Reply #156 on: Fri, 14 May 2021, 02:35:17 »
Both are very nice.
Really glad that you like it :)
Offline Myaanz
« Reply #157 on: Sun, 16 May 2021, 16:45:36 »
Even more excited to see the Artisan collab now! These deskmats are amazing!
Offline SxM Designs
    • Website
« Reply #158 on: Tue, 18 May 2021, 02:09:13 »
Thanks a lot!!!
Currently we are waiting for more than a month for GMK to reply.
The artisans will be crazy as usual ;)
We will announce the collabs very soon.
Offline YangYoga
« Reply #159 on: Wed, 19 May 2021, 07:50:58 »
Please add latin alphas kit. I love the colors but I'm not a fan of the sublegends
Offline Tomn
« Reply #160 on: Wed, 19 May 2021, 19:24:11 »
I love the theme!
« Last Edit: Wed, 19 May 2021, 21:18:31 by Tomn »
Offline SxM Designs
    • Website
« Reply #161 on: Thu, 20 May 2021, 02:10:14 »
Sadly no latin only alphas are planned for this set.
Offline SxM Designs
    • Website
« Reply #162 on: Fri, 21 May 2021, 02:49:42 »
Offline SxM Designs
    • Website
« Reply #163 on: Mon, 24 May 2021, 12:02:46 »
Bump  :cool:
Offline Banned
« Reply #164 on: Mon, 24 May 2021, 12:15:23 »
Offline SxM Designs
    • Website
« Reply #165 on: Mon, 24 May 2021, 12:23:01 »
Bump  :cool:
Why bump with no updates
To raise expectations and share my disappointment that GMK has not given quotes for almost 2 months   :(
Offline Timber Mech
« Reply #166 on: Thu, 27 May 2021, 18:42:52 »
I love it. I'll be keenly waiting for any updates from GMK, samples and the GB dates :)
Offline SxM Designs
    • Website
« Reply #167 on: Sun, 30 May 2021, 16:20:52 »
I am pleased to announce the D60Lite collab with KBDFans, a gasket mounted affordable keyboard. I hope you guys like it!
More info on prices and specs will follow close to the launch date.
Offline brunosan_.
Re: [IC]GMK Pharaoh : D60 Lite X Pharaoh collab
« Reply #168 on: Sun, 30 May 2021, 18:07:52 »
reserved
Offline codecoffeecode
  • refill needed by Glenn Jones
« Reply #169 on: Sun, 30 May 2021, 22:38:12 »
Is there any possibility of including an alphas set with Arabic sublegends?
Offline SxM Designs
    • Website
« Reply #170 on: Mon, 31 May 2021, 00:19:34 »
sadly no  :(
Offline SxM Designs
    • Website
« Reply #171 on: Mon, 31 May 2021, 04:46:31 »
D60Lite x GMK PHARAOH
Group Buy Date:Undetermined
Estimated Ship Date:2 months after the group buy
Structure:Gasket mount
Layout:60% WK and HHKB
Designers:KBDfans Wei ( D60lite ); SxM Designs ( GMK PHARAOH )
Specs
PCB: DZ60RGB-WKL/DZ60RGB ANSI V2, RGB hot-swappable PCB ( QMK and VIA supportable, Type-C, support Windows, Mac, Linux )
Plate: Polycarbonate
Stabilizers: KBDfans transparent stabs
Gasket: 2 sets of gaskets, injection-molded silicone gaskets, foam gaskets
Mute mat: install between PCB and Plate
Bottom silicone pad:which is tightly fitted. Compared with kbd67lite, it is a newly added configuration.
Case: PC+ABS material, using an injection molding process, the surface is matte, opaque
USB-C Cable
Colors: color matched with GMK PHARAOH
Typing angle: 6°
Offline thicthock
« Reply #172 on: Mon, 31 May 2021, 08:28:49 »
Specs
USB-C Cable
Typing angle: 6°
I reckon the board will only be sold via kbdfans page?
They did sell theirt lite67 on the keygem.store page and I would love if they would do the same here.
Offline SxM Designs
    • Website
« Reply #173 on: Mon, 31 May 2021, 08:53:51 »
 I will be contacting the other vendors of the set to see if they will also be selling this alongside the keycaps.
Offline AshF
Re: [IC]GMK Pharaoh : D60 Lite X Pharaoh collab + specs
« Reply #174 on: Mon, 31 May 2021, 17:13:03 »
This set looks amazing
« Last Edit: Mon, 31 May 2021, 17:16:04 by AshF »
Offline SxM Designs
    • Website
« Reply #175 on: Tue, 01 June 2021, 03:05:00 »
Thank you  :thumb:
Offline Cryptographical
« Reply #176 on: Tue, 01 June 2021, 03:14:00 »
bruh the caps lock key looks like a face in the top image
Offline SxM Designs
    • Website
« Reply #177 on: Tue, 01 June 2021, 08:56:13 »
Yes it does.
The right eye or the eye of Ra represents the sun, protective, symbol of luck and masculine/ yang energy. On the other hand lies the eye of Horus, representing the moon, protective and feminie/yin energy. In the middle lies the Ankh , the symbol of life.
Basically what I wanted to point out is that there are 2 balancing forces which encircles our lives and this is the depiction.
Offline SxM Designs
    • Website
Re: [IC]GMK Pharaoh : D60 Lite X Pharaoh collab $119
« Reply #178 on: Tue, 01 June 2021, 14:14:17 »
Update:
D60Lite X Pharoah version price $119
The keyboard doesnot come with the keycaps
Offline KopekWasTaken
« Reply #179 on: Wed, 02 June 2021, 03:02:31 »
Amazing set, can't wait for the GB to start!
« Last Edit: Wed, 02 June 2021, 03:31:46 by KopekWasTaken »
Offline SxM Designs
    • Website
« Reply #180 on: Wed, 02 June 2021, 19:32:30 »
Offline Bits
« Reply #181 on: Thu, 03 June 2021, 00:07:17 »
The D60Lite addition looks amazing! Even more hyped for the GB now
Sent from my ONEPLUS A6013 using Tapatalk
Offline scottdesigns
« Reply #182 on: Thu, 03 June 2021, 21:06:04 »
Those deskmat designs are amazing
Offline SxM Designs
    • Website
« Reply #183 on: Fri, 04 June 2021, 04:55:52 »
Thanks a lot!!!
Offline SxM Designs
    • Website
« Reply #184 on: Fri, 04 June 2021, 04:56:08 »
I am glad you liked them :)
Offline Mistah
« Reply #185 on: Fri, 04 June 2021, 13:44:24 »
This is phenomenal. Can't wait!
Offline SxM Designs
    • Website
« Reply #186 on: Fri, 04 June 2021, 14:12:58 »
Thanks a lot!! Really appreciate it!
Offline SxM Designs
    • Website
« Reply #187 on: Sun, 06 June 2021, 05:25:49 »
Some updates:
1. Officially we are waiting for 2 months for GMK to send us quotes. This project is extremely complicated and I want to see to it that everything is done correctly. Since all work is done ( minus any changes if GMK requests) , we will announce GB dates when we receive quotes from GMK.
2. Rama designs have been submitted and we are waiting on renders from them. I can make unofficial renders but I rather wait for Rama to send us the official ones.
3. For this set, we will have multiple metal artisans ( some in the GB format and some more in the raffle style). I am waiting for some exquisite artisan protos from a few artisan makers to show you guys!
4. There will be wrist rest collabs as well in different meterials. Also waiting for proto pics to share.
5. Resin artisans: you bet! We have confirmed collabs with the best artisan makers in this hobby. I will share all new shortly.
6. High end Keyboard collab : There is ongoing discussions with a very custom and limited (10 , all numbered) collab. Once this is finalized I will share.
7. Keyboard sleeves : Yes sir, we have also collaborating with some great makers to give you guys some options to cover those sexy keyboards of yours.
8. Mouse: Do you really want a Egypt themed setup with a normal looking mouse? I hope not! We are in discussions with leonardodamouse to prepare a themed mouse paint job for you guys.
Plenty more collabs and news in the coming weeks :) Thanks for all the love and support. I hope to make this set a really good one and worth it to you all!
Sneak peaks, reveals and future projects are shared often in our discord. Join us at https://discord.gg/HfQvUExspC
Offline iShibe
« Reply #188 on: Mon, 07 June 2021, 16:23:08 »
While you have my wallet, do you want my kidney too? Maybe a lung?
In all seriousness, i'm SO happy there's so much creative effort going into this set. I may just have to buy EVERYTHING.  :eek:
Offline LunoVonFancala
« Reply #189 on: Tue, 08 June 2021, 04:38:13 »
I just want you to know that your keycap set is the reason why I'm on this forum. It is realy something special. And fun fact I'm really planing to use egyption keycap set with my generic gaming glorious model O mouse :D :D
Offline SxM Designs
    • Website
« Reply #190 on: Tue, 08 June 2021, 05:53:17 »
I am sorry xdddd  :p jk jk
Thanks a lot for the appreciation!
Offline SxM Designs
    • Website
« Reply #191 on: Tue, 08 June 2021, 05:55:08 »
It means a lot to me and I am really happy that you like the set!
Haha. Is it truly generic if it has gaming on it :P jk since I am also using my "gaming" razer viper mouse  :p
Offline saam
« Reply #192 on: Tue, 08 June 2021, 17:10:40 »
This is very unique!
Awesome, and very great idea.
Sam E
Offline SxM Designs
    • Website
« Reply #193 on: Tue, 08 June 2021, 18:20:02 »
Thanks a lot. Really appreciate it!
Offline SxM Designs
    • Website
« Reply #194 on: Mon, 14 June 2021, 08:42:45 »
Update:
Still waiting on GMK to reply. Has been around 2.5 months I think.
Collaborators are working on designs. So thats exciting.
I have already teased some in my discord. Once we are close I will reveal all here as well.
Till then!!!! Stay safe! :thumb:
Offline SxM Designs
    • Website
Re: [IC]GMK Pharaoh : Kohaku65 Renders + Waiting on GMK quotes
« Reply #195 on: Thu, 17 June 2021, 02:39:16 »
As we are still waiting on GMK to send their quotes, I decided to make some cool new renders.
Presenting the GMK Pharaoh on the Kohaku65 by SingaKbd
Kohaku65 by Singa kbd.
Offline SxM Designs
    • Website
Re: [IC]GMK Pharaoh :RAMA artisans + Still Waiting on GMK quotes
« Reply #196 on: Tue, 22 June 2021, 01:39:45 »
Revealing the Rama artisans.
Offline WillyWortel
« Reply #197 on: Tue, 22 June 2021, 02:06:15 »
 :eek: These Rama's are jummy jummy.
My wallet is going to hurt
Offline SxM Designs
    • Website
« Reply #198 on: Tue, 22 June 2021, 09:02:28 »
Really happy that you like the Rama artisans.
I gave up thinking about my wallet when I joined this hobby  :p
Offline alwaysbless
« Reply #199 on: Tue, 22 June 2021, 09:52:10 »
Pyramid(s) rama wouldve been dope af  :-[. I like the Horus one though and the deskmats are very clean too.
