Author Topic: [IC] GMK Spacebars (L9 & CR) - Update regarding GMK production & question  (Read 13042 times)
Offline Fredington
    • Instagram
Hi all,
This is a simple IC for some spacebars in L9.
Why?
Mainly because I'm tired of warped spacebars with my PBT sets. And because Originative has been sold out for a while now.
If interested, please do me a favor and fill out the IC form.
Thank you!
« Last Edit: Sun, 07 February 2021, 14:13:07 by Fredington »
Offline marcofriedrichs
  • Discord: Marco#8888
    • marcofriedrichs.com
Re: [IC] GMK Spacebars (L9)
« Reply #1 on: Mon, 01 February 2021, 07:17:43 »
nice
Offline hkiri
« Reply #2 on: Mon, 01 February 2021, 07:17:57 »
yes
Offline Qarmaa
« Reply #3 on: Mon, 01 February 2021, 07:25:36 »
OCO support said that they are awaiting shipement from GMK that contains spacebars. They didn't specify the date tho.
Offline Agilr
  • Never stop achieving
    • Discord Server
« Reply #4 on: Mon, 01 February 2021, 07:32:16 »
why do we need half the kit in 6u bars
Just run it with the most warped (and used) 7u bar and I'll pay whatever exhorbant shipping for it
Heck, just replace the 3 other bars with 7u bars
« Last Edit: Mon, 01 February 2021, 07:38:49 by Agilr »
Offline powwu
    • Discord
« Reply #5 on: Mon, 01 February 2021, 07:46:33 »
nice
Offline victorpre
« Reply #6 on: Mon, 01 February 2021, 08:04:24 »
GMK spacebars quality hasn't been so impressive lately
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #7 on: Mon, 01 February 2021, 08:15:02 »
I wonder how much it'll end up costing. Honestly, I just want like 6 7u spacebars. Had some coming from China but package ended up getting stolen feelsbadman
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #8 on: Mon, 01 February 2021, 08:28:51 »
Same here bud, in a perfect world we'd be able to just order 7u bars. Although I think GMK doesn't do runs of a single size (can't think of any good reasons for this TBH though) as even Oco's sets come with at least a 6.25u & 7u.
Offline Rob27shred
« Reply #9 on: Mon, 01 February 2021, 08:30:09 »
I think they have worked the issues out, just got my GMK Godspeed set with the space bar kit a few days ago & all the bars are perfectly straight like they used to be.
Offline wholypantalones
  • text and icon mods plz.
« Reply #10 on: Mon, 01 February 2021, 09:01:27 »
Same, the cost is the deciding factor and lots of 7u bars.
Maybe throw in some black (CR) and Dolch (CC) bars too?
« Last Edit: Mon, 01 February 2021, 09:03:45 by wholypantalones »
Offline Havattack
« Reply #11 on: Mon, 01 February 2021, 10:13:57 »
Is it not possible to heat pbt up with a hair dryer/heat gun and bend them straight? (I have ebt, but even the 20$ sets have straight bars, as far as I can tell at least.)
Offline Rob27shred
« Reply #12 on: Mon, 01 February 2021, 10:45:05 »
Sometimes warped PBT spacebars can be fixed like that, although it really depends on where the warping is on the spacebar. If it's just in the body itself it's possible to straighten them, but if there is warping in the stems then no, bending it to look straight will not work.
« Last Edit: Mon, 01 February 2021, 10:50:40 by Rob27shred »
Offline iinko_mk
  • Status: broke
« Reply #13 on: Mon, 01 February 2021, 11:13:53 »
it is, but annoying and not always perfect iirc
Offline honoka
« Reply #14 on: Mon, 01 February 2021, 11:26:25 »
6.25 and 7u bars would be OK. Only 7u would be great. But half the kit being unusable kills it. Sorry boss
Offline Fredington
    • Instagram
« Reply #15 on: Mon, 01 February 2021, 11:35:34 »
Not opposed to this idea, as I only use 7u myself. How many bars per kit? 3? 6? 12?!
« Last Edit: Mon, 01 February 2021, 11:37:24 by Fredington »
Offline honoka
« Reply #16 on: Mon, 01 February 2021, 13:39:21 »
not sure how many in each kit would work out the best. but i would probably make sure to have at least 3 spacebars. if you were to open up for black or other colors, that number would increase
Offline Agilr
    • Discord Server
« Reply #17 on: Mon, 01 February 2021, 19:42:19 »
Having a single 7u at higher MOQ pricing would probably make more sense than a kit with multiple 7u bars if there's enough demand
Maybe see if a vendor can quote multiple kit options and see what works best
Offline hineybush
  • student of error
    • hineybush keyboards
« Reply #18 on: Mon, 01 February 2021, 20:11:12 »
og longkeys
Offline kk73715
  • Why are you even reading
« Reply #19 on: Mon, 01 February 2021, 20:20:02 »
1x 10u chad spacebar please
(And like 3-4x 7u, I think most people will get more than 1 kit)
Offline Fredington
    • Instagram
Re: [IC] GMK Spacebars (L9, maybe CR)
« Reply #20 on: Mon, 01 February 2021, 20:53:45 »
Alright, given the responses so far and after talking with hiney, I've decided to trim down the kit to include only 6.25u and 7u bars. This should help with pricing for people who want multiples. How is this different from Originative, you ask? Well, you can actually buy it.
Also under consideration...adding CR?
Offline Pylon
Re: [IC] GMK Spacebars (L9, maybe CR) - Trimmed down to 6.25u and 7u
« Reply #21 on: Mon, 01 February 2021, 21:33:21 »
Would be interested, as I have two OG Cherry WoB sets that need bars.
Offline Newsbusel
« Reply #22 on: Mon, 01 February 2021, 22:28:00 »
nice
« Reply #23 on: Tue, 02 February 2021, 06:35:21 »
CR and CC for dolch would be a good addition.
Offline Agilr
    • Discord Server
« Reply #24 on: Tue, 02 February 2021, 06:53:17 »
Please keep it beige
Thanks
Offline ttom
  • Formerly tvaro
« Reply #25 on: Tue, 02 February 2021, 07:20:20 »
CR yes please, got a 6.25 og set that i’d like to make wkl compatible
Hoarder Collector and designer
Classifieds
Offline Fredington
    • Instagram
« Reply #26 on: Tue, 02 February 2021, 07:58:16 »
Thanks
Will likely be a separate kit if added.
Offline elisyan
« Reply #27 on: Thu, 04 February 2021, 02:28:44 »
Might just be my luck but I've never received a GMK set without warped spacebars. Warped GMK bars are not hard to fix with a heat gun but I have definitely worked with some unfixable pbt spacebars before.
Offline ideus
  • Björkö.
« Reply #28 on: Thu, 04 February 2021, 08:23:03 »
As others have already stated: How lousy GMK's quality assurance may warrant to deliver unwarped bars?
Answering the question, what I need are 6.25 bars in classic beige, black and dolch colors, may accommodate getting some 7u's along with standards, but I do not need them. Maybe we could pair orders with some others that just need the longest.
Offline Fredington
    • Instagram
Re: [IC] GMK Spacebars (L9 & CR) - Update regarding GMK production & question
« Reply #29 on: Sun, 07 February 2021, 14:12:59 »
Okay, so I've been asking around the vendor community regarding GMK's production timeline and practices, because I don't think it makes sense for them to place this at the end of their queue given all the delays and how small this set is. However, I also wouldn't want to delay sets any longer than they have been.
I think the best solution is if they can produce this along side others sets already in the queue that use the same colors (L9, CR). However, the consensus among the vendors seems to be that it would indeed go at the end of the queue but the actual production time would be short since it's just spacebars.
So I guess the question is...how patient are you guys given it's just spacebars? I also wonder if Originative might restock by then.
« Last Edit: Sun, 07 February 2021, 18:21:56 by Fredington »
Offline Pylon
« Reply #30 on: Sun, 07 February 2021, 16:31:33 »
Okay, so I've been asking around the vendor commuting regarding GMK's production timeline and practices, because I don't think it makes sense for them to place this at the end of their queue given all the delays and how small this set is. However, I also wouldn't want to delay sets any longer than they have been.
Would say, JTK be an option? If they can match to L9 and CR well, and their lead times are shorter, it might be a good alternative. Keyreative also makes Cherry-profile ABS blanks, though I owned their black set and their black is lighter and greener than CR. Not sure of other vendors - everyone else does PBT (might be viable depending on if they can nail the color matching).
For CR - I also ordered a GMK Bleached spacebar kit a while back, which comes with black CR 6.25u and 7u spacebars. I'm splitting up the kit with some other people (the WS2 bars are going to a friend who went in on GMK Noel but forgot to order the minibars, and I'm selling off the CR minibars - 3 people have PM'ed me on Reddit about taking the CR split spaces for their GMK WoB sets), so it should run me only maybe $5-$10 to get the 6.25u and 7u bars. Bleached is shipping out now, and there will probably be extras available soon, so this is probably a viable option for people looking for CR bars. There can probably be arrangements made between people to split up the WS2 bars, 6.25u and 7u CR bars, and the mini-bars, as there's different audiences looking for each.
Offline paczki
« Reply #31 on: Sat, 30 October 2021, 14:56:51 »
I filled the IC form. I'm tired of the terrible QC on GMK spacebars lately. My GMK Kaiju Spacebar is warped like a banana and it's already cracking on the inserts. OCO is also out of stock till next year so its just been a painful experience.
Offline noxtace
« Reply #32 on: Sat, 30 October 2021, 15:03:28 »
Lately epbt has been killing it with straight space bars. Straighter than my gmk ones.
Offline paczki
« Reply #33 on: Sat, 30 October 2021, 15:32:52 »
How's NicePBT? Just bought a set out of frustration. CannonKeys Winter Tundra for my IKKI68 Mizu as I wait for GMK Shoko R2 Q1/2022. Hope that set doesn't have a warped spacebar too.
Offline noxtace
« Reply #34 on: Sun, 31 October 2021, 19:05:03 »
Idk, I've never had experience with them.
