Author Topic: [IC] GMK WOB Arabic Addon Kit (kit update)  (Read 112016 times)
Offline paulgali
    • SKME
« on: Wed, 29 September 2021, 01:39:02 »
IC Form
I would like feedback on the color combo and idea of running it as an alpha kit (based on notes below specifically for kitting). I do not have a current indication of GMKs new pricing for a kit like this, at this time.
A simple alpha addon kit, providing coverage alongside Drop’s WOB kit, or Qarmaa’s WOB Cyrillic, to use on multiple boards.
The extra tab allows for complete coverage of a board with an alternate bottom row, while the extra pipe keys (to be added) will provide coverage with WOB Cyrillic (arabic has no subs on pipe).
Sublegends are UV Printed. UK ISO addon keys are included as well as the extra B for ergo layouts. This set has an entirely new set of sublegends
White on Black Addon:
Sublegend color - V2
Old kitting
Old kitting, and notes to be aware of:
- The current version is kitted out to have full compat with Drop's WOB kit.
- Will add Row 1, 2, 3, 4 pipe - for compat with Qarmaa’s WOB Cyrillic if you don't buy from Drop. Support Qarmaa!
- Z key has misalignment, will be fixed in render
- Parenthesis to be swapped
- < >, DF, CV to be swapped
For those wondering about swapped parenthesis, etc. This should not be done. Open MS word and check. It depends on the application's language settings, not just the OS.
If you're using Microsoft software, it will behave in a similar fashion to SAA. If you use a non-MS editor, or are in apps like discord, it will behave like Arabic 101 subs. I am sticking to SAA. See the difference here.
Some notes on the thought process with the legends:
- Disconnected glyphs are being used for each sublegend, unlike SAA, which mostly uses the connected character variant. For the sake of consistency with this character version, the sub on "I" key will remain as ه
- Symbols are repeated on number row, a nod to many people's endgame Arabic set, SAA. This isn't necessary but for the sake of consistency, I wanted this
Vendors and Pricing
No vendors / pricing yet, I need to gauge interest
Renders
For now, just a kit render. Renderman is extremely busy right now too. I'll get one up ASAP <3
Credits
- Marco, your patience has been tested with this, thank you for the render work
- Qarmaa, of_sam, Swomi
Discord
Its my house, don't smash the doors in!
Show your support by adding this to your banner!
Code: [Select]
[url=https://geekhack.org/index.php?topic=114788.0][img width=300 height=120]https://imgur.com/OpWyagu.png[/img][/url]
« Last Edit: Sat, 23 October 2021, 12:39:29 by paulgali »
Offline paulgali
    • SKME
Re: [IC] GMK WOB Arabic Addon Kit
« Reply #1 on: Wed, 29 September 2021, 01:39:35 »
Reserved for updates
I got a funny response to the google form already
I do not see the Islamic significance with orange, maybe a green would be nice
Green might be nice, but lets take a break for a second. There are plenty of people who speak arabic, and aren't Muslim. Please do not fill out the IC form with what has become "Green = Islam" joke in this scene. Orange was chosen because it looks good, and I have not seen many sets with it done in this fashion. Sidenote, if you live here, you'll know the desert is orange  :p
2021/10/17 - Kit updated with missing pipe keys
« Last Edit: Sun, 17 October 2021, 02:36:12 by paulgali »
Offline Qarmaa
« Reply #2 on: Wed, 29 September 2021, 01:40:11 »
nut
Offline Shoobs
« Reply #3 on: Wed, 29 September 2021, 01:40:20 »
nut
Offline mixistor
« Reply #4 on: Wed, 29 September 2021, 01:42:45 »
yes
Offline lalostad98
« Reply #5 on: Wed, 29 September 2021, 01:43:03 »
POG, finally a set with good Arabic sub legends. I'm all in.
Offline Bachoo
« Reply #6 on: Wed, 29 September 2021, 01:43:18 »
nut
Offline productkun
« Reply #7 on: Wed, 29 September 2021, 01:44:36 »
nut
Offline Sicowa
« Reply #8 on: Wed, 29 September 2021, 01:44:55 »
Nut
Collection: Khajit 60, Leopold FC980C, Pepper, Ex. Visa, Daedalus
pfp:https://twitter.com/kuroseP/status/1305179874429079553?s=19
Offline sup3r170va
« Reply #9 on: Wed, 29 September 2021, 01:45:19 »
Nice. What colour will the Arabic sublegends be?
Offline 7h3of7
« Reply #10 on: Wed, 29 September 2021, 01:45:45 »
nut
Current Board: OTD 356 Mini v1 Black
Offline Branno
« Reply #11 on: Wed, 29 September 2021, 01:46:10 »
nut
Offline ephemeral25
« Reply #12 on: Wed, 29 September 2021, 01:46:24 »
Nut
Offline Juan.
« Reply #13 on: Wed, 29 September 2021, 01:47:07 »
its beautiful  :D
(but its missing the islamic green)
rubber cup
Offline whirlwind
« Reply #14 on: Wed, 29 September 2021, 01:48:19 »
Nut
Offline paulgali
    • SKME
« Reply #15 on: Wed, 29 September 2021, 01:53:29 »
Using GMK's V2 orange. It looks fantastic imo, but im always open to feedback :D
Offline Bunn3y
  • 绊
« Reply #16 on: Wed, 29 September 2021, 01:54:10 »
gaynut
Collection: Ivery Praxis | HHKB Pro 2 | JTD.Works Ovinnik | Realforce R1 87u | Switchplate iiA Sanction
Offline lovidore
« Reply #17 on: Wed, 29 September 2021, 02:11:54 »
nut
Offline Fraaaan
« Reply #18 on: Wed, 29 September 2021, 02:56:06 »
nut
Offline Klyback
« Reply #19 on: Wed, 29 September 2021, 03:03:20 »
not a fan of WoB but as someone who uses Arabic a lot, I support this.  :thumb:
Offline suffeler
« Reply #20 on: Wed, 29 September 2021, 03:03:48 »
nut
Offline konstantin
  • Formerly constexpr
« Reply #21 on: Wed, 29 September 2021, 03:21:49 »
You can't have partial ISO-UK support and then have R4 1u <>. It's either one (full ISO-UK) or the other (terminal ISO).
On a separate note, I think it makes little sense to base the kit's ISO support on ISO-UK when there is an actual ISO-AR layout (Arabic 102) that can be used.
Speaking of which, there are two types of Arabic keyboard layout: 101 and the aforementioned 102, and your kit seems to only cover one of those types (101).
I believe the parentheses on the Arabic layer should be flipped: 9 → ), 0 → (.
« Last Edit: Wed, 29 September 2021, 03:35:34 by konstantin »
Offline kk73715
  • Why are you even reading
« Reply #22 on: Wed, 29 September 2021, 03:38:02 »
nut
Offline paulgali
    • SKME
« Reply #23 on: Wed, 29 September 2021, 03:39:00 »
If you check above the kit render, I am adding the necessary pipe keys to fill out ISO support. The current kit supports coverage for Drops kit, and is being updated to full ISO coverage
Yes, youre correct, parenthesis need to be swapped. Stupid mistake, thanks for spotting it <3 whilst checking i realized i swapped < and > too.
« Last Edit: Wed, 29 September 2021, 04:04:41 by paulgali »
Offline Pyroo
« Reply #24 on: Wed, 29 September 2021, 03:40:42 »
Nut
Bunny enthusiast
Offline paulgali
    • SKME
« Reply #25 on: Wed, 29 September 2021, 03:53:08 »
102 coverage would be nice, but it would require a substantially bigger kit as there are at least another 10 keys to be altered. It would make this a fair bit more expensive too - I would be fine with running it but I'm not sure if thats a cost people would be willing to pay for what is essentially a simple addon.
Adding subs on the UK ISO variant makes a lot more sense for people i have already spoken to. Honestly if I was running 102 i would prefer a full kit.
« Last Edit: Wed, 29 September 2021, 03:58:46 by paulgali »
Offline Uryftw
« Reply #26 on: Wed, 29 September 2021, 04:00:13 »
nut
Offline sourmk
« Reply #27 on: Wed, 29 September 2021, 04:02:22 »
Fresh as a sliced pan there Pauly
Some Work: GMK Wasabi | GMK Pono | GMK Dandy | ePBT DuO | GMK Hooty | Petals Sixty
Some Collabs: ePBT Ivory | GMK Deep Navy | GMK Fundamentals | GMK Polybius | GMK Blurple | GMK Deepwell | GMK Fuji | GMK Pacific
Some Boards: Daji Seis Cinco, Ocho Quattro, Seis Cero | MatrixLab 2.0 ADD + CP, 2.0 Xmas + CP, 1.2OG | Keycult 1/60 | Hiney Ladybird | QXP | Noxary 268.2
Discord - https://discord.gg/j3PxfJ4rBC | Instagram - https://instagram.com/sourmk | Web - https://www.sourmk.com/
Offline denibhoxha
  • cock and balls technology
« Reply #28 on: Wed, 29 September 2021, 05:31:39 »
almond
Offline totalemon
  • good morning :)
« Reply #29 on: Wed, 29 September 2021, 06:03:36 »
I'm in. Could look really nice with dolch mods
Offline Vono
« Reply #30 on: Wed, 29 September 2021, 06:38:25 »
I'm in! Very good
Offline of_sam
« Reply #31 on: Wed, 29 September 2021, 06:44:26 »
I will nut
Typing on: HHKB Pro 2 - Stock :aware:
Collection: F1.69, Police, Jubi, RF 87U, En Dash, Rosenthal, Soulless, Frog, Calliope, GAF 910, Sabre, W1-AT
Offline infectedqt
« Reply #32 on: Wed, 29 September 2021, 07:05:04 »
chai a7mar nut
Offline Neely_12
« Reply #33 on: Wed, 29 September 2021, 07:34:05 »
It's so good. Please add a blue kit. Good luck!
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #34 on: Wed, 29 September 2021, 08:00:07 »
ily
Offline Baka Bot
« Reply #35 on: Wed, 29 September 2021, 08:55:33 »
gib
Offline JomiKarloz
« Reply #36 on: Wed, 29 September 2021, 10:00:12 »
PeaNut
Offline sub0001
« Reply #37 on: Wed, 29 September 2021, 11:32:30 »
insta cop
Offline derpturtle
« Reply #38 on: Wed, 29 September 2021, 12:36:16 »
This is it
Offline MIGHTY CHICKEN
« Reply #39 on: Wed, 29 September 2021, 15:04:32 »
I'm down
Offline Kinesiologist
« Reply #40 on: Wed, 29 September 2021, 18:58:09 »
yes please
Offline Remsky
  • Lubed switch count > Puddsy post count
« Reply #41 on: Wed, 29 September 2021, 19:24:54 »
hot af
TGR Jane v2 - GSKT00(coming) - TGR Jane CE V2 - TGR Poly alice - LZ Physix - Matrix 8XV 2.0 - RS - LZ FE - Dalco 959 Mini GT edition (coming) - Mc65 - Hiney TKL one - HHKB Pro 1 - 25th anniversary edition HHKB pro Hybrid - 30th anniversary Filco 2S keyboard
Offline paulgali
    • SKME
« Reply #42 on: Thu, 30 September 2021, 08:58:31 »
Offline Arithmetics
« Reply #43 on: Mon, 04 October 2021, 21:49:44 »
this is sick
Offline IMZO
  • Matrix shill, and TKL WKL Lover
« Reply #44 on: Mon, 04 October 2021, 21:58:01 »
cashew
Current boards: Jane V2 CE , Matrix 1.2og Silver WKL , Matrix 2.0add coating black WKL, Matrix 2.0add WKL Coating yellow, Satisfaction75 R1 Cloud white, Korno65, Bloop65, HHKB Pro 2 white,Lin Whale Pink WKL, Gok 7v White, Gok 7v Black, Orion V3 Silver WKL, Orion V2.5 Red WKL, Geon F1-8x Silver WK, Haus65 BlueGray, Plume65, Vertigo, Frog TKL WKL GreenF13
Offline RA Can
« Reply #45 on: Tue, 05 October 2021, 05:35:54 »
YES!
Offline Dyto69
  • 420 blaze it but dont forget 69
« Reply #46 on: Tue, 05 October 2021, 06:07:50 »
nut?
Offline Kokoboro
Re: [IC] GMK WOB Arabic Addon Kit (kit update)
« Reply #47 on: Sun, 26 December 2021, 03:53:14 »
Fat nut
Offline ephemeral25
« Reply #48 on: Fri, 18 February 2022, 10:16:50 »
This deserves more love so I am just gonna up it in the list  :thumb:
Offline blunt
« Reply #49 on: Thu, 11 August 2022, 18:45:47 »
Make this happen
