Author Topic: [IC] KAT Mori | Both Deskmat Designs Out!  (Read 139840 times)
Offline ThickJimmy
Re: [IC] KAT Mori
« Reply #50 on: Mon, 17 May 2021, 23:02:45 »
Great to finally see this set in IC! Good luck homie!!!
Offline LittleAad
  • Hello
Re: [IC] KAT Mori
« Reply #51 on: Tue, 18 May 2021, 20:07:11 »
Would you be able to move accent 7u in mods kit to sb kit? It feels inconsistent to have without accent 6.25 to accompany it.
Offline yh
  • hyurinkb
Re: [IC] KAT Mori
« Reply #52 on: Thu, 20 May 2021, 00:15:45 »
Yeah, I'll definitely change it so that the accent 6.25u and 7u will be in the same kit. Probs either both in mods or spacebars. ty for pointing that out
Offline KeyboardPeople
Re: [IC] KAT Mori
« Reply #53 on: Thu, 20 May 2021, 03:06:57 »
I dig this. Would go well with Bobagum switches!
Offline yh
  • hyurinkb
Re: [IC] KAT Mori
« Reply #54 on: Thu, 20 May 2021, 09:01:38 »
i hope you also consider starting colour matching early once you have some vendors figured out
+1 to this, getting physical samples before the GB is really the move—KAM Superuser and KAT Love got it right in this regard, whereas Space Dust has a LOT of custom colors and will not have physical samples before GB...doesn't inspire confidence to say the least
so a big yes to physical samples! the sooner the better  ;D
will definitely attempt to get my hands on physical samples before GB then, thanks for the heads up! Also thank you for the longstanding support zanhana! haha
Offline mirubere
Re: [IC] KAT Mori
« Reply #55 on: Thu, 20 May 2021, 09:16:59 »
Nice to see KAT sets starting to have TKL bases, for those who don't really want to order half-a-dozen kits and worry about not having bought the correct ones. Any chance of text mods for the TKL base instead of icon mods?
Offline yh
  • hyurinkb
Re: [IC] KAT Mori
« Reply #56 on: Thu, 20 May 2021, 17:41:56 »
Yes, the tkl kits are intended for users who just need those keys to be able to get more value. Tkl text mods highly unlikely, taking into the account the demand difference between icon and text mod kits. Thanks for the interest though!
« Last Edit: Thu, 20 May 2021, 20:57:29 by yh »
Offline Avijit
Re: [IC] KAT Mori
« Reply #57 on: Thu, 20 May 2021, 22:21:32 »
best to start as early as possible the back and forth with keyreative can take several weeks if not months
Offline yh
  • hyurinkb
Re: [IC] KAT Mori
« Reply #58 on: Fri, 21 May 2021, 14:18:52 »
I learned what a vtuber was because of calliope
Hoped for scythe key but glad to see skull
Yeah, skull was easier to implement into the iso enter as compared to the scythe design, though I really wanted to have that as well. I will continue trying to see if there is a way i can fit the scythe into iso enter/make the iso enter novelty look better! (I assume you are talking about iso enter lol)
Offline Izeri
Re: [IC] KAT Mori
« Reply #59 on: Fri, 21 May 2021, 14:43:39 »
Changes to be made:
- relabel spacebar to 6.25 instead of 6.00 in both TKL Kits
- add 1.5u bksp to both TKL kits
- add r2, r4 pipe/backslash to both alpha kits
- change 1.5u delete->bksp in text mods kit
- add r4 minus to numpad kit
- add UK ISO kit
- horizontally flipping second of each pair of flowers in novelties kit (for symmetry across board)
:thumb:
Offline Hetpet
Re: [IC] KAT Mori
« Reply #60 on: Sat, 22 May 2021, 06:39:03 »
Offline baksbaks
  • don't be so angry all the time
Re: [IC] KAT Mori
« Reply #61 on: Sat, 22 May 2021, 17:23:07 »
Offline shenshendei
Re: [IC] KAT Mori
« Reply #62 on: Sun, 23 May 2021, 20:00:00 »
guh
Offline soloplayer
Re: [IC] KAT Mori
« Reply #63 on: Mon, 24 May 2021, 02:22:24 »
ne row 5 avail?
Offline JSaintS
  • Formerly eNrageDSainT
    • JSaintS
Re: [IC] KAT Mori
« Reply #64 on: Mon, 24 May 2021, 03:30:54 »
Really like the colors of this one. Wondering though, any particular reason you went for R4 F-row instead of R5?
Offline thang3152001
  • Average Vtuber Enjoyer
Re: [IC] KAT Mori
« Reply #65 on: Mon, 24 May 2021, 08:07:04 »
Current: KBD67 MKII, Mode65, Tomo SE, Katze
On the way: KBD8x MKII
Offline yh
  • hyurinkb
Re: [IC] KAT Mori
« Reply #66 on: Mon, 24 May 2021, 14:43:39 »
ne row 5 avail?
Nope, sorry if you wanted it. KAT Mori is 443211 in terms of row profile
Offline yh
  • hyurinkb
Re: [IC] KAT Mori
« Reply #67 on: Mon, 24 May 2021, 18:36:06 »
various reasons, mainly I would say to reduce extra keys in kitting
« Last Edit: Mon, 24 May 2021, 18:55:07 by yh »
Offline Frayne
  • For deskmat inquiries: illu_zn
Re: [IC] KAT Mori
« Reply #68 on: Tue, 25 May 2021, 05:14:43 »
That ortho kit is poGggg. So nice to see blanks provided on both sides! Would love a red accented esc and arrows as well though!
Offline dxxbox
Re: [IC] KAT Mori
« Reply #69 on: Tue, 25 May 2021, 09:40:36 »
The 1st thing comes to my head is ice cream in strawberry flavor with oreo, looks yummy.
Offline yh
  • hyurinkb
Re: [IC] KAT Mori
« Reply #70 on: Tue, 25 May 2021, 23:36:30 »
Thank you! You mean *cough* 3 accented esc keys *cough* Will consider, thank you for the feedback! Do lmk in the ic form if there is anything else, tenQ!
Offline yh
  • hyurinkb
Re: [IC] KAT Mori
« Reply #71 on: Wed, 26 May 2021, 01:12:31 »
Some guy commented above in Swedish that it reminds him of berries and yogurt, lol.
I never knew my set was so delicious :p Glad you enjoy it!  :thumb:
Offline yh
  • hyurinkb
Re: [IC] KAT Mori | Vendors Added!
« Reply #72 on: Sun, 30 May 2021, 12:09:56 »
vendors added!
Offline jakk
« Reply #73 on: Sun, 30 May 2021, 16:13:36 »
Man I love this set! Super Unique and great concept!
Offline yh
  • hyurinkb
« Reply #74 on: Tue, 01 June 2021, 03:15:36 »
Set will not have JP vendor. iLumkb will be SEA vendor. vendors are final, no more changes expected.
« Last Edit: Wed, 02 June 2021, 14:09:02 by yh »
Offline Mr Chrome
Re: [IC] KAT Mori | Final Vendors!
« Reply #75 on: Thu, 03 June 2021, 22:08:57 »
Gotta second this. No love for accent red in the 40s kit? That red is perfect, you gotta milk it, man. Accent Enter never hurts, either.
“This plastic rectangle is alright. The plastic rectangles on top of it, though...”
Offline Skeil
  • I drink art and draw coffee
Re: [IC] KAT Mori | Vendors Finalised!
« Reply #76 on: Wed, 16 June 2021, 05:49:51 »
The colors are top notch and I adore the novelties, GLWIC and GB!
Offline Frayne
« Reply #77 on: Sat, 03 July 2021, 03:55:31 »
Great set cant wait to see wat the deskmat looks like.
« Last Edit: Tue, 06 July 2021, 00:21:47 by Frayne »
Offline yh
  • hyurinkb
« Reply #78 on: Tue, 06 July 2021, 00:11:10 »
Bump for deskmat teaser!  :p
Offline dvorcol
  • Discord: dvorcol_5071
Re: [IC] KAT Mori | Deskmat Teaser!
« Reply #79 on: Thu, 21 October 2021, 09:36:05 »
Awesome that you have two Colevrak+ kits!  A couple comments:
The KAT R2 apostrophe/quote in the kit renders is a standard QWERTY keycap.  You could replace it with KAT R2 right bracket/right brace for Wide mod.
Also, I'd ditch the KAT R1 apostrophe/quote.  Programmer's Dvorak is the only layout that uses it.  Keeping it in, 14 unique keycaps are still missing.
« Last Edit: Sat, 27 November 2021, 03:10:06 by dvorcol »
Offline Hiiro_XoXo
Re: [IC] KAT Mori | Both Deskmat Designs Out!
« Reply #80 on: Fri, 22 October 2021, 19:24:17 »
in for more updates!
Offline shenshendei
« Reply #81 on: Mon, 01 November 2021, 09:45:52 »
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #82 on: Mon, 18 July 2022, 15:29:15 »
Any updates?
One of the best colorways imo.
But I would rather have this set made by SP or GMK. Due to way lower lead times, yes even GMK. And also much better quality.
