Author Topic: [IC] humble40 - A 12.5u WKL 40 - $170 - GB is Live! Ends 8 July.  (Read 17677 times)
Offline joedinkle
  • Eye Oh Designs
    • Eye Oh Designs
Introducing the humble40
The Group Buy page is up!
Update (June 6 2022): Well, I didn't expect things to take this long, but this project is ready to go. This group buy will go live on 17 June at a time TBD. I'll be selling at www.eyeohdesigns.com The plan is this to run for 3 weeks, or until 75 units are sold, whichever comes first. Estimated completion is 4 months after the group buy is closed.
One big change is that the PCB was redesigned to run an RP2040. The firmware is now Vial.
Update (July 5 2021): Hey peeps! Protos have arrived and I'm very happy with the outcome! There are still some things to tweak and decisions to make before moving to GB. Namely, those are:
-Determine optional plate materials. Base kits will include FR4 and other materials will be available as an add-on. I have prototypes of brass, FR4, and POM. The POM may prove too flexy, but I won't know until I get to do a complete build with the new PCBs. Which brings me to the next decision point...
-Determine PCB thickness. I may end up going 1.2 mm PCBs instead of the standard 1.6 mm thickness. This would be in-lieu of a half plate option, which doesn't really make sense for the size and construction of this board.
-Determine manufacturer. This will determine pricing. The current protos I have are great quality and from a cheaper manufacturer. Unless the more expensive manu blows me away with their quality, I'll likely go with the less expensive option to help with pricing.
-Minor tweaks to the case.
I think my next update will be when I receive the next round of protos. Stay tuned!
The humble40 is the latest board from Eye Oh Designs and is the first keyboard in the humble series. The humble40 combines no-nonsense mounting in a simple yet handsome 40% package. Its features include:
Case/Plate:
-12.5u WKL layout
-Bottom mount. Compared to other bottom mount boards, there is a decent amount of flex due to the cutouts for the blockers and using only 4 mounting points for the plate/PCB.
-5.5 degree typing angle with 19 mm front height.
-Seamless, single piece CNC construction. Planned materials are anodized aluminum and polycarbonate based on interest check response.
-FR4 switch plate in standard stagger or uniform stagger configuration.
-Case foam likely for all kits. Plate foam available as an add-on. I'm still tweaking these details.
PCB:
-Compatible with MX style switches. Soldering iron required.
-Powered by a RP2040 running Vial
-USB C connection and circuit protection through the unified daughterboard
-Standard and uniform stagger configurations on the same PCB
-Single color LED backlight optional (All required circuitry will come on the PCB except the in-switch lighting. The customer can add this during the build if they desire)
Keycap compatibility:
-Complete legend and profile accurate coverage by most of the DSS sets coming out of the 40s Discord sold through store.aeternus.co, cbkbd.com, ringerkeys.xyz, etc.
-Depending on layout chosen, near GMK base kit coverage. The only out of profile key is tab (put 1.25u tab in base people).
Pricing: $170
Planned units: 75
Planned vendors: www.eyeohdesigns.com
Timeline for GB: 3 week group buy. Fulfillment 4 months after group buy completion.
Some notes on the humble series mentioned above:
The humble series aims to offer keyboards that don’t compromise on looks, sound, construction, or price. My aim was to provide something that is simple, yet handsome and refined. You won’t need the keyboard’s blueprints or an entire box of screws to put it together, but your typing experience will be just as enjoyable once it’s complete. I plan to offer a few more keyboards under the humble name with the same design language, so stay tuned.
« Last Edit: Sun, 19 June 2022, 11:39:35 by joedinkle »
Vixen
Offline joedinkle
  • Eye Oh Designs
    • Eye Oh Designs
Re: [IC] humble40 - A 12.5u WKL 40
« Reply #1 on: Wed, 19 May 2021, 19:33:41 »
Reserved.
Vixen
Offline C_L | Soup
« Reply #2 on: Wed, 19 May 2021, 20:04:01 »
YES YES YES YES YES!
Offline phatmasterq
« Reply #3 on: Wed, 19 May 2021, 21:41:59 »
so. _Much_ *YES*. soo. much. Yes. All the yes in the world.
Offline brodiegrizz
« Reply #4 on: Wed, 19 May 2021, 22:48:17 »
Neat looking board, been looking for a nice 40% but I think anything near $200 is far too much considering the case is 1 piece instead of multiple. Glwic  :cool:
Offline Ustinj
« Reply #5 on: Wed, 19 May 2021, 22:58:21 »
Looks like a nice package for under $200, but having feet might be a plus ;)
Offline MIGHTY CHICKEN
« Reply #6 on: Thu, 20 May 2021, 00:13:27 »
That wkl 40% sure is sexy
Offline ggggggg
  • schmeiß die forties durch den club
« Reply #7 on: Thu, 20 May 2021, 00:57:49 »
Sweet, a Whiskey I can afford. Let's go
Offline Chippy
  • sus chef
« Reply #8 on: Thu, 20 May 2021, 01:18:01 »
cute board though, but don't give it the gskt-00 treatment  ;D . I love the blockers.
1.2og | Buddy 6xx | Le Fishe V1 Proto | xyz60 Rev2 | Quartermaster | Chimera65 | Satisfaction75 | Realforce 84u | Zenith Z-150 | Realforce 86u | 378
This and the swiss cheese keyboard is the next generation of keyboards
Offline Ustinj
« Reply #9 on: Thu, 20 May 2021, 01:26:23 »
I think one-piece blocker boards with custom PCBs are going to really pop soon... :p It seems really cost-efficient!
Offline joedinkle
  • Eye Oh Designs
    • Eye Oh Designs
« Reply #10 on: Fri, 21 May 2021, 12:57:09 »
I appreciate the feedback! Under $200 means just that. The price isn't settled at the moment. Trust me, price is something that I am aiming to keep down. That being said, tarrifs (25%), and the rising cost of materials are at play here:
https://cdn.discordapp.com/attachments/546816697437519892/845138140036857918/unknown.png
https://cdn.discordapp.com/attachments/728572418481979403/844072576123797514/STM_notice_for_component_cost_increase.jpg
As far as the construction, this is going to be a high profile all aluminum case with 7.5mm thick walls. There's substantial material and splitting the case in 2 or adding a brass weight would only serve to further drive up cost and would get away from the design philosophy of the board.  :thumb:
I got impatient with the render, but not with the prototype.  ;) They'll be included.
Vixen
Offline joedinkle
  • Eye Oh Designs
    • Eye Oh Designs
« Reply #11 on: Mon, 05 July 2021, 11:29:05 »
Update bump. Check the top post  :)
Vixen
Offline yqqdrasil
Re: [IC] humble40 - A 12.5u WKL 40 - Prototypes received!
« Reply #12 on: Thu, 08 July 2021, 18:01:08 »
Love it!
Offline ESJvR
« Reply #13 on: Thu, 22 July 2021, 03:29:40 »
Are there any plans for ISO Enter?
Offline Mecxs
« Reply #14 on: Thu, 22 July 2021, 03:41:55 »
Prototype looks nice, though any chance of getting those corners rounded a little? I will legit injure myself on those things!
Offline Pickleguy
« Reply #15 on: Thu, 22 July 2021, 17:58:35 »
Looking forward to the GB!
Sent from my IN2019 using Tapatalk
Offline rpiguy9907
« Reply #16 on: Fri, 23 July 2021, 09:03:05 »
At $180 I can't say no...
Offline conternecticus
« Reply #17 on: Thu, 07 October 2021, 23:33:39 »
Did the GB happen?
Offline rpiguy9907
« Reply #18 on: Fri, 08 October 2021, 21:36:24 »
Don’t thin plates have issues with stabilizers? Or does that only happen when you go all the way down to 1mm.
« Reply #19 on: Mon, 11 October 2021, 07:50:59 »
I think that happens with 1.2mm PCBs. Just add band-aid or those foam that comes with some stabilizers kits nowadays, should fix that issue.
Offline joedinkle
  • Eye Oh Designs
    • Eye Oh Designs
« Reply #20 on: Mon, 11 October 2021, 08:31:20 »
Did the GB happen?
Not yet! Still waiting on SPRH to finish due to delays with the case manufacturer. That is supposed to ship to me at the end of this month. I think humble40 will go closer to the beginning of next year.
Don't be concerned with the delays for SPRH if you're interested in this board. I'll likely use a new manufacturer that has been able to deliver things to me a little more quickly.
Sent from my SM-N960U1 using Tapatalk
Vixen
Offline carmen2
« Reply #21 on: Thu, 21 October 2021, 17:10:19 »
Is there a email list for a group buy?
Offline niorob
« Reply #22 on: Thu, 21 October 2021, 18:10:56 »
this is so cute
Offline asianfork
  • Alice
« Reply #23 on: Thu, 21 October 2021, 23:03:16 »
Very cute board! Is there a discord to follow for updates?
Offline joedinkle
  • Eye Oh Designs
    • Eye Oh Designs
« Reply #24 on: Thu, 21 October 2021, 23:05:46 »
Check out the 40s Discord! https://discord.gg/Rjx4Xhks5x
Updates are posted in the channel #eye-oh you can grab a role to get pings there.
Vixen
Offline joedinkle
  • Eye Oh Designs
    • Eye Oh Designs
Re: [IC] humble40 - A 12.5u WKL 40 - $170 - Starts 17 June
« Reply #25 on: Mon, 06 June 2022, 22:22:13 »
https://eyeohdesigns.com/products/humble40
Updated details at the top. Let's go  :thumb:
Vixen
Offline menuhin
« Reply #26 on: Thu, 09 June 2022, 19:28:23 »
Is it possible to add flex cut on the plate and what's the other potential plate material options?
Btw, hope there'll be a hotswap pcb option.
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline treeleaf64
    • treeleaf64
« Reply #27 on: Thu, 09 June 2022, 23:46:22 »
12.5u cannot be humble
I crouch like a crow
Contrast in the snow
Everyone must pay the cat tax
Offline joedinkle
  • Eye Oh Designs
    • Eye Oh Designs
« Reply #28 on: Fri, 17 June 2022, 11:56:50 »
We're way past changes to the PCB, but it's a 1.2 mm thickness with lots of cutouts already. It's got a nice amount of flex for a 40.
Vixen
Offline joedinkle
  • Eye Oh Designs
    • Eye Oh Designs
Re: [IC] humble40 - A 12.5u WKL 40 - $170 - Starts 17 June at 3PM Eastern
« Reply #29 on: Fri, 17 June 2022, 12:01:00 »
We're going live in a few hours! I'll get a GB page up soon, but join us in the 40s Discord in the meantime!
Vixen
Offline joedinkle
  • Eye Oh Designs
    • Eye Oh Designs
Re: [IC] humble40 - A 12.5u WKL 40 - $170 - GB is Live! Ends 8 July.
« Reply #30 on: Sun, 19 June 2022, 11:40:34 »
The Group Buy is live! The link is here!
Vixen
