Author Topic: [IC] Domikey "Gift" Triple Shot Cherry Profile Keycap Set by Zero-G Studio  (Read 31096 times)
Offline jackzyg
  • https://elboard.store/
    • ELBoard Discord Channel
Table of Contents
(0) TL;DR
(1) Introduction
(2) Kit Pricing and Vendors
(3) Render Pictures
(4) Prototype Photos
(5) Timeline and Updates
(6) Contact
(0)   TL;DR
Designed by Zero-G Studio and manufactured by Domikey, the Domikey "Gift" Triple Shot Cherry Profile Keycap Set is now in IC.
Please fill out this IC form if you're interested: https://forms.gle/r5abyeC6Kkfa9Y8y5
(1)   Introduction
About Zero-G Studio
Zero-G, G as in Gravity, is a China-based designer studio. They are dedicated in bringing more fantasies to your desk that will take your gravity away and float you to a dream world in the sky. This keycap design is a greeting "gift" from Zero-G, which is inspired by the famous movie Castle in the Sky. The story tells the adventure of Sheeta and Pazu to discover the mystical floating city.
Domikey Triple Shot Cherry profile
DMK is launching their brand new triple shot manufacturing technique. Here are some sample pictures to illustrate the "Triple shot" technique. The sample keycaps are not related to "Gift".
Typing Test Comparison
DMK Triple Shot:
GMK Double Shot:
Kit Prices
Base Pro A/B: $TBD
Novelties: $TBD
Alpha: $TBD
Mod Plus: $TBD
NumPad: $TBD
Alt Color: $TBD
ISO: $TBD
Spacebars: $TBD
Vendors
SPECS:
  • DOMIKEY
  • Designed by Zero-G Studio
  • Profile: Cherry (1-1-2-3-4-4)
  • Material: ABS
  • Triple-shot legends
  • Compatible with Cherry MX switches and clones
(3)   Render Pictures
New Renders 7/2/2021
Rendered with FLAME 60% Gasket Keyboard
Rendered with Rama Works 65-B
Rendered with Alice
Rendered with Rama Works 80-A
This prototype is in production and the photos will updated here!
Color code and color cards:
Mykeyboard EU has joined the party and we intend to open up the GB in late July to early Aug 2021.
Production period is estimated to be around three months after the GB ends.
(6)   Contact
Discord Server: https://discord.gg/3F6pCVPrzy
Our Instagram: https://www.instagram.com/elboard_keyboard/
The store front: https://elboard.store/
r/mm post here: https://www.reddit.com/r/mechmarket/comments/nz7ofi/ic_domikey_gift_triple_shot_oem_profile_keycap/?utm_source=share&utm_medium=web2x&context=3/
« Last Edit: Sat, 24 July 2021, 17:22:18 by jackzyg »
Offline jackzyg
Reserved
Offline MIGHTY CHICKEN
Suggestions
images stinky, so hard to zoom in
Kitting will need to be modified for sure, a good minimal base should at the very least support tsangan and super basic 65/75, your base will support only the most oem of keyboards
iso base pls
Offline Rubbermilitia
Suggestions
iso base pls
This. Needing to buy 2 kits just for those 1.5u bottom row keys and the 1.75 shift is unfortunate. Those are pretty standard for all 65/75.
Colorway is really cute though, wouldn't mind this being my first triple shot set
Sent from my SM-G950U1 using Tapatalk
Offline iinko_mk
  • Status: broke
this doesn't look like oem mate
Offline Pyurii
I like the colors, just not the way you presented them. It’s hard to have a good look at them.
Offline scottdesigns
The profile profiler himself
Offline keeganzero
  • huhu
Combine 'Mod Plus' and 'Base Pro' into a single base kit
Offline jackzyg
Suggestions
iso base pls
Thank you so much for the feedback!! As for the kitting, our initial thought is that there are still some audience who only use one very standard TKL/Full size, and forcing them to buy more mods is unnecessarily costly for them. The price will reflect the number of key caps though, we will try to make the price for a base pro + mod plus kits same as the "ideal" base you mentioned. If that makes sense lol.
Offline jackzyg
Suggestions
iso base pls
Thanks a lot for the input!! As I mentioned above, we will try to justify this kitting plan by the pricing, like base pro + mod plus would be very close the more supportive bigger base.
Offline jackzyg
Re: [IC] Domikey "Gift" Triple Shot OEM Profile Keycap Set by Zero-G Studio
« Reply #10 on: Fri, 18 June 2021, 08:58:06 »
Thanks for pointing that out!! I will double check with Zero-G. But the prototype is coming really soon, we are hoping to update with more actual product photos.
Offline jackzyg
« Reply #11 on: Fri, 18 June 2021, 08:58:45 »
Tyty!! We will try to update with more render/ proto photos
Offline jackzyg
« Reply #12 on: Fri, 18 June 2021, 08:59:17 »
Prof Kayne my man!!
Offline jackzyg
« Reply #13 on: Fri, 18 June 2021, 09:01:06 »
Thanks for the suggestion, but our initial thought is to cater for the group of people who only use a standard TKL, and they can get the set with lower price.
Offline NoPunIn10Did
    • NoPunIn10Key
« Reply #14 on: Fri, 18 June 2021, 09:28:36 »
Are you going to offer any sort of all-in-one pricing discount, similar to what Domikey does for its SA sets?
Offline jackzyg
Yes! That’s is def something we will offer
Offline Ella
  • Why is it called an oven
« Reply #16 on: Fri, 18 June 2021, 09:50:22 »
all oem looks different. just compare razer's oem and corsair's oem
    • NoPunIn10Key
« Reply #17 on: Fri, 18 June 2021, 10:04:21 »
Since you already have R4 End in the pro mods kit, could you swap out the one in the Numpad kit for a Tab instead? That’s a rather typical key for stand-alone Numpads. Also not sure if Shift is actually the best choice there: maybe Fn or Equals?
    • NoPunIn10Key
« Reply #18 on: Fri, 18 June 2021, 11:00:09 »
Other kitting notes:
  • In the spacebar kit, a 1.75u bar is rarely used by itself.
    • Typically it shows up in pairs when it exists at all.  Is there some specialty board that uses this?  Because that's typically a 40% thing, which this kitting doesn't support in general.
  • I would go ahead and include a 1.25u Shift in ISO.
    • That's currently in the pro mods kit.  The ISO kit really does need that shift key, or it means that every ISO user must buy the pro mods, which isn't a great approach.
  • Likewise, ISO is missing R1 backslash-pipe (\|), which is currently on R2.
    • You can optionally keep the R2 copy (for US ISO support) or ditch it.
  • You have 1.5u Alt Gr in the pro mods kit, but 1.25u Alt Gr is nowhere to be found.  Couple possibilities for this:
    • One might be to just go ahead and force the righthand Alt in your base kit to be Alt Gr.
    • The other would be to put 1.25u Alt Gr in the ISO kit.
  • If you're going to bother with an Alt Gr key at all, you might as well put the broken bar in the tertiary legend of the UK-ISO backtick-negation key (`¬¦).
  • You have mod tilde in the pro mods kit, but not mod 1.5u backslash.  That's pretty popular for 60% boards in particular.
  • You're so close to having this kitting work well for Ortho.  Suggested 1u additions to make that work:
    • R3 Escape in accent color for the Alt Color kit
    • R3 Out in mod color for Pro Mods (or provide both R3 Tab and Escape in mod color)
    • R2 Fn/Meta/Cmd (or both Tab and Escape, again)
    • R2 Enter
    • R2 Quote-doublequote (mod color)
    • R1 Enter
  • If you need to make some room for other keys, you could drop R3 Home, which is super rare.
Offline hzsh
  • aspiring renderman
« Reply #19 on: Fri, 18 June 2021, 11:36:13 »
Set is really interesting to be honest, it's good to see more custom OEM sets in the market. The colorway definitely isn't for me because I mainly like more bland sets, but this is cool, it reminds me of cotton candy. GLWIC!
Offline Magnificent Bureaucrat
  • Sooooo much red tape
« Reply #20 on: Fri, 18 June 2021, 12:05:05 »
Not sure about the colourway but it's good to see a manu expanding their services so I hope this goes well.
(As an aside I'm actually digging the brown/white/yellow sample set)
Offline iinko_mk
  • Status: broke
« Reply #21 on: Fri, 18 June 2021, 12:12:42 »
bu-bu, this looks like cherry lmao
Offline Sax_______
« Reply #22 on: Fri, 18 June 2021, 13:24:02 »
Yeah but if you call it cherry then people can't complain about it being 0.00002mm higher like some manufacturers who sell cherry profile.
Or IFK who makes OEM and calls it cherry.
Offline Cylent
  • Formerly cylentshadows
« Reply #23 on: Fri, 18 June 2021, 13:40:17 »
Other than the kitting feedback nopun has already provided, please render your kits in image dimensions that show off the designs. You worked hard on the novelties designs, so why require customers to use a magnifying glass to see your cool designs? Please just put each kit on its own render image and zoom in so the keys fill most of the image.
Offline iinko_mk
  • Status: broke
« Reply #24 on: Fri, 18 June 2021, 14:46:36 »
Cherry profile is called cherry because it was originally made by the company cherry. Now, the only manu that owns the molds to "true" cherry profile is GMK. All other keycap manus that sell "cherry" profile just mimic it to as close as possible, it is very clear that in the renders and the samples that they were mimic-ing cherry profile. This is muuuuuuuch closer to cherry than oem (including the different variations), so it wouldn't be accurate to say that this is oem. Same goes for ifk. I would just personally say that what the renders and samples show is not what comes to mind when someone says oem profile.
The same argument can be made with SA caps, are all cheap sa marketed caps available that aren't SP oem? Because the original molds for SA are owned by SP.
    • NoPunIn10Key
« Reply #25 on: Fri, 18 June 2021, 17:32:21 »
Y’all, I think this is a bit of a tangent. If Domikey says it’s OEM, let’s just assume that.
Offline keybo_hobo
« Reply #26 on: Mon, 21 June 2021, 09:22:37 »
What are those grey keycaps with yellow hiragana sublegends?
Thnx
Offline ideus
  • Björkö.
« Reply #27 on: Mon, 21 June 2021, 10:57:49 »
I would be interested in a classic color in triple shot. Good luck with this.
Offline santela
« Reply #28 on: Mon, 21 June 2021, 11:14:42 »
I'm sure something is lost in translations, this does not look like OEM profile and is almost definitely cherry profile.
你这个是原厂高度,翻译过来是cherry高度,oem是另一种高度。
Offline jackzyg
Kitting pictures have been slightly updated. Also there was a miscommunication - the profile should be Cherry not OEM. Sorry about the confusion!!
The OEM in the renders are actually referring to Original Equipment Manufacturer, not the profile. That was the reason for this miscommunication. :-[
« Last Edit: Tue, 22 June 2021, 21:41:15 by jackzyg »
Offline Havattack
It'd be cool if this helpes draw people away from using GMK to make everything.
Offline mr_foggy
  • neue = nope
lol. can't blame u man.
yeah kitting needs rework but it's been said already. the set itself is great and will definitely consider. I really want a tripleshot set.
Could you share color codes or pantone maybe? I'm wondering how close to bento this is
Offline ThomasLT
    • ThomasLT Studio
Triple shot :eek:
Offline Valgaut
Nice colorways. How long has Domikey been doing triple-shot cherry profile? I thought they were SA only. Like Havattack said, it would be nice to have more alternatives to GMK.
Offline DJ Clicks
May I know what set that blue F keycap sample is from and whether it's available for purchase?
Offline keybo_hobo
Probably Domikey x iNKY Silent Sea Cherry Profile Keycaps. You can find an IC thread for this here on GH.
Offline Cubic // esc lab
  • Formerly 'esclab'
    • esc lab
I am so in! Any new competition against GMK is always very very welcome.
Also, ngl, I like that grey/yellow/white set a lot more than your IC set. Is that buyable anywhere?
« Last Edit: Tue, 29 June 2021, 17:40:06 by loop | esc lab »
Offline jackzyg
Color code and color card have been updated. See the original post above.
Offline vienarr
This thread is in Times New Roman 🙄
Thanks! Yeah bento is much bolder, and the white is whiter. This set is a cute pastel color, and I like that the white is warmer. Very cozy color scheme.
Offline jackzyg
New renders updated!!!!
off topic but where can i buy that weeb yolch
Offline mr_foggy
  • neue = nope
love it. my fav set currently in IC.
Offline keybo_hobo
Yeah, i also want to know. The only thing i found that it's some sort of prototype. https://www.zfrontier.com/app/flow/DANxJm1RElbr
Offline honorless
Can you please add the ortho kit as seen here, on Drop's Domikey Dolch?
Offline EnlargedCrouton
good idea, but the base kit needs to be expanded and the kit renders are too bright on the white background and it is hard to see
Offline GLOVE
Cute keycap haha ;D
  • Formerly 'esclab'
    • esc lab
Hey OP
What is the gray, yellow, and white set? Where can I get that?
Offline jackzyg
Please check above for the sound comparison between the DMK triple shot and GMK double shot keycaps.
