Author Topic: [IC] Calice - 75% F13 Alice | 15/02/22 Update - R4 prototype received and built!  (Read 68491 times)
Offline Qwertle
Calice - A 75% F13 Alice
The 'Complete' Alice.
IC Form     |     Discord
R4 Prototype
Background
Heya Geekhack, for the longest time as an Alice user I always wanted something that I could use on the daily for work, but never found something that exactly met my needs in an Alice layout (F-Row and Arrows). The focus was to create an Alice with a function row and arrows while trying to keep the form-factor as close as possible to a normal Alice layout in width.
Features
  • Case Angle: 5.0°
  • Case Material: 6063 Aluminium & Sandblasted Brass Weight
  • Weight: 2.4kg
  • Colours: TBD (poll in IC form)
  • Plate: 1.5mm Aluminium (other plate materials to be confirmed)
  • Mounting: Geonworks Tadpole + M3 O-ring
  • Feet: SKUF Feet
  • PCB: Custom PCB designed by Jels (MX Compatible, Encoder Support, QMK and VIA Compatible)
  • Alphas Tilt: 10.0°
  • Front Ledge: 18mm
  • Optional Wrist Rest
  • Layout - Layout supports normal/stepped caps, 2U+1.25U Left Spacebar and Split Backspace and Rotary Encoder at Home key
Pricing and Vendors
    Target Pricing - $550 ~ $600USD @ 150 units
  • Oceania - Switchkeys
  • South East Asia - TBD
  • North America - TBD
  • Canada - TBD
  • Europe - TBD
Current Status / Timeline
        8/May/21 - R1 Prototype ordered
        08/Jul/2021 - R2 Prototype ordered, awaiting manufacturing
        20/Jul/2021 - Initial IC
        01/Sep/2021 - R2 Prototypes received
        21/Sept/2021 - R3 Design Finalised, design log updated, R2 prototype photos added to IC
        09/Oct/2021 - R3 Prototype Ordered
        01/Dec/2021 - R3 Prototype Received
        22/Dec/2021 - R4 Prototype Ordered, ETA mid-March 2022. IC Updated
        25/Jan/2021 - R4 Prototype received and built Twitch Build VOD
        15/Feb/2022 - R4 Prototype pictures and typing tests added to IC
        28/April/2022 - FnF Round Ordered
        18/July/2022 - FnF Round Delivered, currently fulfilling
R4 Prototype Photos
R4 Prototype Sound Test - Stock Epsilons - ABS Plate - GMK Olive
R4 Prototype Sound Test - Stock Epsilons - PP Plate - GMK Olive
R4 Prototype Sound Test - Stock Epsilons - ABS Plate - PBT British Racing Green
R4 Prototype Sound Test - Stock Epsilons - PP Plate -  PBT British Racing Green
R3 Prototype Photos
Pictures courtesy of Warmthoughts
R3 Prototype Sound Test - Marshmallows lubed with 3204 - PP Plate. Built by Warmthoughts
https://clips.twitch.tv/RamshackleLovelyEggGOWSkull-GljfUGU5YGXwMSYC
R3 Prototype Sound Test - Kailh Black Stem Cherry MX Blacks lubed with 205g0 - Aluminium Plate. Built by SwitchDoctor
R2 Prototype Photos
R1 Prototype Photos
Frequently Asked Questions
What does the tadpole and o-ring mounting look like?
Special Thanks
  • CAZ and TaeKeyboards for being in the fabled Discord call where the Calice started from, as well as their constant support throughout this process
  • Thank you to Geon for making the tadpoles available!
  • Avocadoughh and Forehead for being on the design journey and learning Fusion360 together, even if one of us didn't watch Quantrik's 65% Keyboard Case Design video like we told him to 100 times
  • Jels for helping create the PCB and helping with checking my design
  • ClassicRory for doing the renders as well as passing his eye over at the design and providing invaluable feedback
  • The SK Chill VC gang over at SwitchKeys for their continued support for this project
  • Ant over at CustomKBD and 0ldmate for their help with the initial prototypes
« Last Edit: Tue, 20 September 2022, 08:32:34 by Qwertle »
Offline Qwertle
Re: [IC] Calice - 75% F13 Alice
« Reply #1 on: Tue, 20 July 2021, 09:20:52 »
Updates & Design Log
23/Jul/21 - Thanks for the amazing IC responses, I'm overwhelmed by the interest in the Calice! I've updated design to add the C3 Unified Daughterboard. USB port still horizontally centred to F6/F7, vertically it's located centre to the height of the bottom piece.
Updated USB port design has been included in the R2 prototypes
21/Sep/21 - Following changes were made based on R2 prototype
  • Case angle changed 5° for a more comfortable typing experience, as well as lowering the case by about 4mm on the back. Makes the back less chunky but also more proportionate to the top piece
  • Simplified plate design, added more tadpole mounting points to better support flexible plate material
  • Increased bottom cavity by 2.5mm to better support flexible plate materials
  • Case bottom side profile is now perpendicular to ground, this also has a flow on effect in that the weight is now rectangular
  • Handles have had curves increased as an aesthetic choice for a more 'flowy' back profile
  • Removed Calice engraving on top face
22/Dec/21 - Following changes were made based on R3 prototype
  • Front ledge decreased by 2mm to 18mm
  • Simplified plate design with less mounting points more evenly distributed
  • Back ledge was added, changed design aesthetic for back profile
« Last Edit: Sat, 15 January 2022, 07:05:55 by Qwertle »
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #2 on: Tue, 20 July 2021, 09:21:23 »
interesting butt and mounting, glwic
Offline Rory
« Reply #3 on: Tue, 20 July 2021, 09:22:27 »
Calice is my bias
Offline CAZ
  • Project Manager for Switchkeys
    • Switchkeys AU
« Reply #4 on: Tue, 20 July 2021, 09:23:56 »
I stand by my original convictions that this layout is cursed. That being said you have done a fantastic job and I have enjoyed acompanying you on your design journey. I look forward to adding one of these beautiful monstrosities to my collection.
CAZ Approved
Offline shutuphamish
« Reply #5 on: Tue, 20 July 2021, 09:26:18 »
Hype, been waiting a while for this
Offline 0ldMate
« Reply #6 on: Tue, 20 July 2021, 09:26:32 »
This looks amazing. Willing to forgive that you didn't pick up your proto that I printed. Very excited to see this come to fruition.
Offline checkboy
« Reply #7 on: Tue, 20 July 2021, 09:39:09 »
Amazing work mate! Proto pics lookin good, and them renders  :cool:
Offline forehead
« Reply #8 on: Tue, 20 July 2021, 09:51:08 »
Can't wait for my first premium board!
Offline El_Jackador
« Reply #9 on: Tue, 20 July 2021, 09:57:01 »
Its not for me but that's pretty cool!
Offline FamilyJoule924
« Reply #10 on: Tue, 20 July 2021, 10:01:49 »
looks amazing, if possible make it a alice sat 75 with rotary encoder and led. or even just one or the other would be a really nice addition
Offline WejB
« Reply #11 on: Tue, 20 July 2021, 10:17:55 »
Instant buy. Good job mate. All that hard work paid off!
Offline keeganzero
  • huhu
« Reply #12 on: Tue, 20 July 2021, 10:33:33 »
This feels wrong, but I can't look away.
Offline Alessio
    • YT Channel
« Reply #13 on: Tue, 20 July 2021, 10:46:50 »
could we get a render with greg on it? reckon it'd be funny as ****
« Reply #14 on: Tue, 20 July 2021, 10:47:18 »
has science gone too far
Offline hexa
« Reply #15 on: Tue, 20 July 2021, 11:45:17 »
Chonky yet elegant. Excited to see this develop  :thumb:
Offline Tyson
« Reply #16 on: Tue, 20 July 2021, 13:46:06 »
Board sounds good, I'd be down to get one when the GB starts!
Offline YoloKeebs
« Reply #17 on: Tue, 20 July 2021, 13:53:28 »
Lemme book a cab to hit that escape key
Offline PvtSkittles
« Reply #18 on: Tue, 20 July 2021, 15:11:10 »
Looks real nice. I can 't help but think the F row looks like eyebrows though...
Offline MrBingo
« Reply #19 on: Tue, 20 July 2021, 17:24:20 »
It is.... Precious.
Offline waylaidwanderer
« Reply #20 on: Tue, 20 July 2021, 17:48:21 »
Instead of Calice (which sounds like "callus"), taking the same idea, we could use Arisu as the base word, then it would be Carisu -> Carrie? :)
Very interested in this layout btw!
Offline Surostu
  • switchkeys.au x keyboardfinder.com
    • keyboardfinder
« Reply #21 on: Tue, 20 July 2021, 17:54:40 »
This is a need, not a want.
Science has gone just the right distance. What a time to be alive.
Offline Sinpra
« Reply #22 on: Tue, 20 July 2021, 18:04:31 »
Hello I would like to know where I can put down my deposit! :gibcalice:
Offline lpcables
    • lpcables
« Reply #23 on: Tue, 20 July 2021, 19:02:28 »
Lettttssss goooo, I need it, if it only had HHKB layout support :)  :cool:
Offline Nuap
« Reply #24 on: Tue, 20 July 2021, 19:10:51 »
OH man this is nice. The bottom profile reminds me of an old Telstra beige house phone  :))
The layout shows no support for split backspace - is that the case?
Offline Nothatso
« Reply #25 on: Tue, 20 July 2021, 19:46:56 »
I've been hoping for someone bold enough to try this layout for some time. It's weird/different and I love it. I want it yesterday.
« Last Edit: Tue, 20 July 2021, 19:54:39 by Nothatso »
Offline SwitchKeys
    • SwitchKeys
« Reply #26 on: Tue, 20 July 2021, 21:28:32 »
Great work Qwertle! Looking forward to this one.  :)
Offline ZeroStressLevel
« Reply #27 on: Tue, 20 July 2021, 22:37:48 »
I SIMP FOR CALICE
Offline grumpy213
« Reply #28 on: Tue, 20 July 2021, 23:17:40 »
Looking solid, thick, tight. Keep me updated on your progress.
Offline JAKP
  • peac.design
« Reply #29 on: Wed, 21 July 2021, 05:04:53 »
Love the lilac. Looking forward to seeing r2 prototypes!
Offline Rx003
« Reply #30 on: Wed, 21 July 2021, 08:26:15 »
I think this would be my first alice, loving the lilac! Glwic
Offline Mistyyy
« Reply #31 on: Wed, 21 July 2021, 08:32:34 »
I have been waiting for this day to come , can we get the show on the road ASAP
Offline Xanniard
« Reply #32 on: Wed, 21 July 2021, 09:31:28 »
This is really amayzeeng a Complete Alice sounds like a board for me! <3
Offline japancakes
« Reply #33 on: Wed, 21 July 2021, 12:25:15 »
It's the plum red thiccness for me.
Offline tarokeebs
  • TMOv2r2 || Kikuichimonji
« Reply #34 on: Wed, 21 July 2021, 14:01:42 »
really looking forward to this board! that plum red color is amazing :)
collection: tmov2 | kikuichimonji
Offline UGunaLOSE
« Reply #35 on: Wed, 21 July 2021, 15:35:24 »
Oh this looks nice!!! GLWIC
Offline Klexos
« Reply #36 on: Wed, 21 July 2021, 15:58:31 »
I've been wanting to build an Adelheid for about as long as I can remember but never got around to it. This gives me a reason not to. Cursed? More like the superior layout!
« Last Edit: Thu, 22 July 2021, 02:51:20 by Klexos »
Offline EnlargedCrouton
« Reply #37 on: Wed, 21 July 2021, 20:33:27 »
great looking board, ive been looking for something just like this  :thumb:
Offline DatYellowAsian
« Reply #38 on: Thu, 22 July 2021, 04:55:45 »
So excited to see how far this idea has come from the start. Congrats and can't wait to get one myself!
Offline forsee
« Reply #39 on: Thu, 22 July 2021, 05:44:13 »
Oooh I love this! GLWIC!
I'd be totally down for buying one of these! :D Please try to get a UK proxy if you can
Offline booncakes
« Reply #40 on: Fri, 23 July 2021, 05:31:41 »
Looking very nice.
Offline highpur
« Reply #41 on: Fri, 23 July 2021, 23:04:56 »
Excited to see the progress for this board ;D
Offline treeleaf64
    • treeleaf64
« Reply #42 on: Sat, 24 July 2021, 00:41:03 »
Yes Mr Puddsy it has gone too far I dont like the alice but this one doesn't look too bad  I guess it's just another aluminum keyboard at teh end of the day nothing very special
Everyone must pay the cat tax
Offline hottrout
  • I'd Hit Dat Key
« Reply #43 on: Sat, 24 July 2021, 05:12:32 »
I am very interested in this layout.  Will you be providing a wrist rest at the same time with this board?
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline zea
  • yeh
« Reply #44 on: Sat, 24 July 2021, 22:37:39 »
please consider centering the usb port, it's killing me. otherwise I really love this keyboard, it looks really good!
Offline rmendis
  • Artisan addict
« Reply #45 on: Sun, 25 July 2021, 01:43:57 »
Like it
Offline godofdeath
« Reply #46 on: Sun, 25 July 2021, 08:10:53 »
Keep the USB off centered, so less people will want it KEKW
Sent from my SM-G960U1 using Tapatalk
Offline bansheetango
« Reply #47 on: Sun, 25 July 2021, 10:19:32 »
^ this
Also like the chonker.
Offline jakey
« Reply #48 on: Sun, 25 July 2021, 17:47:33 »
Love this, I need arrow keys for work - so this is perfect for me! I'm in.
Offline HutchoJ
« Reply #49 on: Sun, 25 July 2021, 21:48:35 »
Thankyou for making the most useful and comfortable board ever, this won't ever leave my desk! Love the colours and design <3
