Author Topic: [IC] Calice - 75% F13 Alice | 15/02/22 Update - R4 prototype received and built!  (Read 67913 times)
Offline Qwertle
Re: [IC] Calice - 75% F13 Alice | 21/9/21 Update - R2 photos, R3 design update
« Reply #50 on: Mon, 20 September 2021, 12:10:15 »
21/09/21 Update and Thoughts
After receiving the R2 prototypes and going over the design again I'm extremely happy with how the R3 redesign went to address some things that came up in the R2 prototypes.
These were mainly an issue with flexible plate materials not having enough case cavity to support them properly, but also required more mounting points to also achieve this. This seems like a better solution but also provides flexibility for the end user to choose what mounting points should be used, in my head I have it that for stiffer plate materials you'd be able to use less tadpoles for more flex. Also simplified the plate design all together, to be fair the first one was pretty memey and definitely not required, a bit over zealous on my behalf but I'm happy with where we've landed now.
Also made some changes to the case bottom, notably making the case bottom side profile perpendicular to the ground. This helps with making sure the USB Daughterboard is also perpendicular to the ground now for better user experience, but the flow on effect of this is that the case bottom itself no longer has a trapezium bottom face to it, meaning that the weight is now a normal rectangle which looks more pleasing to the eye. The case bottom also has a more flowy back profile, which I think with the other touches such as the softening of the front edge fillets in R3 have helped make the case less boxy and more refined.
I'm super happy with the forest green and plum red colours, I think they've come out a treat and will definitely be included in the final group buy
[Edit] Also as part of the R3 design, have designed an accompanying wrist rest and will be having this prototyped in the next round of prototypes
[Editedit] Was able to build the R2 prototype recently and record a sound test. I love how the pop of the hyperglides comes through the board, very happy with how it's sounding right now
« Last Edit: Sat, 15 January 2022, 07:17:58 by Qwertle »
Offline jakey
« Reply #51 on: Mon, 20 September 2021, 13:38:34 »
Thanks for the update Qwertle!
The forest green looks gorgeous, I love it! I'm looking forward to hearing & seeing more, and hopefully owning my own one day!
Offline treeleaf64
    • treeleaf64
« Reply #52 on: Mon, 20 September 2021, 20:32:03 »
That is a **** load of plate tabs  :eek:
Everyone must pay the cat tax
Offline hottrout
  • I'd Hit Dat Key
« Reply #53 on: Tue, 21 September 2021, 08:41:33 »
IC filled in.  Please provide a wrist rest to match at the time of production as it really is a requirement of such a board.  Love the colours by the way.  Please also keep me one of these. :)
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline Qwertle
« Reply #54 on: Tue, 21 September 2021, 10:05:14 »
I actually forgot to mention in my update that a wrist rest for the Calice was designed and will be prototyped, cheers for reminding me!
Offline hottrout
  • I'd Hit Dat Key
« Reply #55 on: Tue, 21 September 2021, 11:59:37 »
\( ゚ヮ゚)/
\( ゚ヮ゚)/
\( ゚ヮ゚)/
Systems -
  Keyboards -
Offline actress
« Reply #56 on: Tue, 21 September 2021, 12:20:15 »
Is ISO layout a possibility ?
Offline Qwertle
« Reply #57 on: Thu, 23 September 2021, 10:12:12 »
Unfortunately due to the design ISO layout isn't available for Calice
Offline hottrout
  • I'd Hit Dat Key
« Reply #58 on: Thu, 23 September 2021, 11:53:36 »
Very rarely is ISO an option on Alice style layout boards.  There a few exceptions, the best (so far IMO) being a board called FLX Virgo.  That said, I too am a die hard ISO fan but I also love the alice layout and once you use it you might even prefer ANSI as it works very well in this configuration.
Systems -
  Keyboards -
Offline darthcapn
« Reply #59 on: Sun, 10 October 2021, 22:04:09 »
75% is the best %. Love it. Glwic, defo coping one if I can.
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline Dyto69
  • 420 blaze it but dont forget 69
« Reply #60 on: Mon, 11 October 2021, 02:54:02 »
I love the rendered ano mismatch lmao. glwic
Offline japancakes
« Reply #61 on: Fri, 22 October 2021, 17:45:24 »
pumped on plum.
any chance of PE + case foam?
Offline Jacki
« Reply #62 on: Fri, 22 October 2021, 20:03:08 »
I like this.
I think theres a bit too many top mounting points.
4 on top and bottom of the plate should be enough.
[img width=267 height=120]https://i.imgur.com/in3VqH2.jpg[/img
Offline ArkOberon
« Reply #63 on: Fri, 22 October 2021, 23:29:31 »
The more Alice boards I see, the more fall in love with them. Best of luck.
Offline baka jiken
« Reply #64 on: Sat, 23 October 2021, 01:08:23 »
Lilac, Plum, and Dark forest are amazing colors!
Offline peacdesign
  • Design Studio
    • Peac Design
Re: [IC] Calice - 75% F13 Alice | 21/9/21 Update - R2 photos, R3 prototye ordered
« Reply #65 on: Thu, 16 December 2021, 05:41:02 »
Colours are hot. We simp for Calice.
Offline Shoe17
« Reply #66 on: Thu, 16 December 2021, 21:52:51 »
I've been looking at a 75 board that's a burgundy or plum color, and I just happened to see this. I also loved the alice style layout, so this would fit my needs perfectly. I'm excited to see where this goes!
Offline Nurseh
  • Sorry for always apologizing
Looking forward for this project!
Offline bansheetango
Really hoping there'll be a EU vendor for this. :thumb:
Offline Qwertle
15/02/22 Update and Thoughts
New year brings new updates with Calice!
R4 prototype was received late January (very much a pleasant surprise), and in it's current state is what I envisioned the Calice to be both in aesthetics and sound. The sound profile remains with a bias to a clacky sound signature, but the board sounds a bit tighter and fuller. The ABS plate was a very nice plate and in my opinion the best plate material on the Calice for a clacky, slightly chirpy sound signature. But the design can also go the other way and have a deeper sound as evidenced by the PBT keycap sound tests.
The R4 prototype will continue to go around to other Australian streamers to builds and to gather more feedback, but design wise I think I'm happy with where we've landed.
In terms of other updates with regards to the buy, there's still work being done in the background but things are chugging along nicely.
Offline EdgeOfInfinity
that r4 proto looking really good!
Offline KeeBnnuy
i hope you know this is a swear word akin to "****ing hell" in Canadian french 😂 Be careful with your Canadian vendor ;)
Offline SwellPeople
Really excited to see where you go from the R4 prototype, it looks so good ;D Would love to get one once it goes to GB!!!
Offline Jubileus
Interested! Would there be a posibility of hotswap PCB?
Offline customKBD
    • Custom KBD
Can't wait for this - banger job qwertle!
Offline enomooshiki
can't wait... please... GIB CALICE!!
Offline Nonnegaard
75% F13 Alice? All you need is a knob and you have all the buzzwords!
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline duxi90
This is definitely the layout I'm looking for. Alice's lack of the F-row and `/~ key makes it unusable for my usage.
Really looking forward to this one.
Offline QWER|key
I've been waiting for this for such a long time.
Offline joke
« Reply #79 on: Wed, 12 October 2022, 04:43:21 »
There's Keychron Q10 which supports ISO layout.
Offline hawkhandlerr
Is this still happening? I'd love to be notified when available?
Offline thocciness
Tadpole mount and full function row Alice... yes please!
Offline bananabreadchef
Mildy cursed but I still love it lol
Offline gktttwsam
Is it still available?
