Author Topic: [IC] Angle from VERTEX | GB orders shipped  (Read 134565 times)
Offline ClickClack.io
  • Find us on clickclack.io
    • clickclack.io
« on: Fri, 30 July 2021, 00:37:14 »
Hi everyone, Angle's GB post is live at Geekhack GB Post. And we will stop updating this post.
For questions and latest updates, please join our Discord:
To join Vertex Angle groupbuy:
Index
- Introduction
- Keyboard Build
- Typing Sound Test
- About “Angle”
- Form Factor
- Case Design
- Mounting Structure
- PCB Design
- Colorways
- IC Forms and Discord
- Q&A
- Latest Status
Introduction
Hi all, this is ClickClack!
We are thrilled to announce our first collaboration with the beloved Chinese custom keyboard studio - Vertex. And today, we are introducing Vertex’s new keyboard — Angle. Vertex studio has spent the past 12 months polishing the product, to perfect every single aspect of Angle. Now, without further ado, let’s check out what Vertex has to say in Angle.
Keyboard Build
Typing Sound
Angle TKL with lubed Cream MX
Angle TKL with Tangerine
Angle TKL with Wild
About Angle - "Play the angles, Know the angles."
Good design is open to interpretation and perspective is everything. Applying this philosophy, Vertex wanted to design a keyboard that is full of intentions yet subtle and inclusive. Angle aims to capture the very essence of a typing machine with precision and simplicity.
Form Factor
As Vertex’s founding project, TKL was chosen instead of other form factors. The meaning behind TKL/80% outweighs the potential structural design challenges.
Angle supports both ANSI and ISO Layout. Both layouts have options for Tsangan/WKL and stepped. To minimize the impact on typing sound and potential loosen stabilizers/switch installation introduced by bigger openings on Left Shift and Enter keys, Angle will have ANSI and ISO as different options.
Case Design
Vertex believes in simplistic design and values ease of use above everything else.
Right above the arrow keys, a moonstone is embedded. Moonstone is a sodium potassium aluminium silicate of the feldspar group that displays a pearly and opalescent schiller.
The visual effect of a moonstone is very subtle and will only reveal from a particular angle. It is a symbol of Angle design. Because Vertex believes your typing experience should not be disturbed.
Weight was arranged to be close to the lower edge in order to balance the angled bottom case. Angled bottom case made the lower edge thinner, which introduced challenges to add weight. This was overcomed by adding visual compensation on the bottom of weight with Vertex Logo on the lower right of weight.
Design is in the details. Vertex was founded on 03/05/2020, 庚子惊蛰 in Chinese Solar Calendar, which is engraved on the inner weight.
Side view is progressive and dynamic.
Dynamic sculpture with harmonious proportions.
8 degrees, based on experiments and research, is the most ergonomic angle for typing on average.
Mounting Structure
Clicky yet comfortable, firm but gentle, is what you would feel when typing with Angle’s Leaf Spring Structure.
Special Foams are added to absorb the vibrations from the Leaf Spring and improve the stability of the keyboard while typing fast.
Silicon Pad is added to make PCB better fit in the space and more tightly aligned with surrounding parts. Silicon Pad also helps balance out the structural differences between central area and corners, so the typing experience is more consistent overall.
In order to provide uniform softness, Flex Cuts are introduced throughout the inner parts from Plates, Silicon Pad to PCB.
Custom designed PET-Coated Poron Foams are added to prevent damages from leaf spring overload.
More vertical space is reserved for leaf spring.
Overall, with all the trials and errors, Vertex and we are confident to give keyboard lovers a brand-new typing experience.
We will also showcase how Vertex Studio designed Angle’s Structure in a follow up post. Stay tuned!
PCB Design
- Soldering only
- USB Type-C Port
- No built-in RGB Leds (however there are slots for Led for Caps Lock and Scroll Lock)
- 1.2mm Thickness
- QMK & VIA Support
Colorways
We have following 5 color themes to choose from:
1. Crow - 鸦
2. Lunar - 月
3. Chainmail - 铠
4. Bianco - 皑
5. Fog - 雾
Groupbuy Coming Soon
GB Time: 1/26/2022 - 02/27/2022
GB Website:
GB Format: Unlimited
Streams for R2 protos: 1. Andy (Monday 1/24 6:00PM PT); 2. Taeha (Tue 1/26 3:00PM ET)
Discord
Join our Discord for more updates.
FAQ
1. Is RGB supported?
No. You can only add Leds on Caps Lock and Scroll Lock. Vertex believes that RGB lighting is not a good companion for Angle.
2. Will there be choices of material for Plates?
During the prototyping phase, Vertex had tested plates Aluminum, Brass, PC, POM, FR4 and Carbon Fiber. Only Aluminum and Brass met expectations.
3. Hot-swap support?
No. Because Angle is using Leaf Spring Structure. Hot-swap will not be able to provide enough structural support for holding PCB.
4. How long will Angle production take?
Depends on the amount of Group Buy orders we receive. We will provide weekly production updates after the Group Buy conclusion.
5. Will there be more choices of colorway?
Vertex may consider more colorways if manufacturing technologies for new colors meet quality and design expectations.
6. Pricing?
We haven't set the international pricing yet. FYI, CN GB run's pricing is 2850 CNY (441.04 USD) for Anodizing version (other colorways) and 2950 CNY (456.52 USD) for Electrophoresis version (Bianco). It might be slightly more expensive than CN GB, because of the price hike of raw material and yield rate of CN GB.
Latest Status
(10/26)
- Mid layer: Silicon Pad will no longer be required. Instead PORON pad will be offered as an optional part. “Silicon Corner Pieces” will be provided as individual parts.
- Daughter Board: Angle International GB will replace its own design with ai03’s Unified-Daughterboard.
- Plates: In addition to ALU, plate using new materials will be provided. Vertex is experimenting with FR4, steel, PC and POM.
- Color options: Introduced new coloring process. Will have much more color options in GB.
- Vertex is working on optimizing typing sound of Angle.
(Before:)
- Base on the result from first round of GB, Vertex is confident to make Angle an UNLIMITED Group buy.
- Angle International GB will be starting around begining of December instead of Nov. Sorry about the delay! This delay was because new international GB options and optimizations need to be sampled and validated (base on feedbacks from Chinese GB). This sample making process is affected by the power shortage across China.
- Angle has been through 6 rounds of sampling to ensure quality.
- Samples are being mailed out to respected members in our keyboard community and please expect more thorough reviews coming out!
- Options in the International GB will include choice of different weight material, choice of F13, choice of WKL/WK.
- First round of GB orders are being fulfilled. There will be reviews from different content creators soon.
- We don't know the International pricing from Vertex yet, but soon.
- Reworked our website with brand new UI, focusing on featuring new products.
- GB will support both Shopify Payment and Paypal. We also added Shopify Installment Option.
« Last Edit: Fri, 30 September 2022, 20:53:35 by ClickClack.io »
Offline would?
  • Formerly wouldworks
    • Finder Works
Re: [IC] Angle from VERTEX | TKL, Leaf spring, Prototype Build
« Reply #1 on: Fri, 30 July 2021, 00:53:04 »
Looks wonderful. Mounting is considerd, side profile is fantastic! I love that transition. Keen!
Offline lalostad98
« Reply #2 on: Fri, 30 July 2021, 00:58:32 »
Interesting design, please make foam an add on rather than something included with the keyboard kit.
Offline Sissy
« Reply #3 on: Fri, 30 July 2021, 01:00:30 »
Super clean looking board and the moonstone adds a nice change from a logo or blank space.
Offline _ODIN_
« Reply #4 on: Fri, 30 July 2021, 01:40:07 »
Looks awesome, definitely interested
Offline OmoideAeternum
« Reply #5 on: Fri, 30 July 2021, 01:45:32 »
Definitely going to keep an eye on this. GLWIC!
Offline Ustinj
« Reply #6 on: Fri, 30 July 2021, 02:01:36 »
mega clean
Offline JohnYYZ
  • KanataKeys.co
« Reply #7 on: Fri, 30 July 2021, 02:28:21 »
Nice board and all.....but is your site a flipper site? It looks like you are flipping GMK sets on there...
Offline vi0till
« Reply #8 on: Fri, 30 July 2021, 03:14:40 »
Do we have the expected GB date and price?
Offline darthcapn
« Reply #9 on: Fri, 30 July 2021, 03:57:00 »
I really love the way the board looks, and the shots are just oommpphhhh! definitely interested in getting to know this board better!
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline AstralYT
« Reply #10 on: Fri, 30 July 2021, 07:08:55 »
A TKL that's actually exciting, hoping that the price wouldn't be too high. Around 500$ would be amazing. Please consider F13 WKL layout.
Offline HappyB0T
  • I'm a Piggie
« Reply #11 on: Fri, 30 July 2021, 07:13:47 »
oof - and boards
    • clickclack.io
« Reply #12 on: Fri, 30 July 2021, 08:12:08 »
    • clickclack.io
« Reply #13 on: Fri, 30 July 2021, 08:18:15 »
Thank you for bringing up your concern!
Like we mentioned:
Group Buy will be conducted on our drop & resell platform clickclack.io. Not only you can join new GB on clickclack, you can also sell your own boards on our platform with zero fee and enjoy free buyer/seller protections. Please find IC form link on the product page.
Like we mentioned, clickclack.io is not only carrying out GBs but also a marketplace for keyboard lovers to trade their own keyboards. We work as a middle man to protect both parties. Listing on the website is not owned by us. We don't flip anything.
Offline Jan02
« Reply #14 on: Fri, 30 July 2021, 08:36:02 »
Deleted Post
« Last Edit: Fri, 30 July 2021, 08:42:20 by Jan02 »
Offline Dunne
    • Dunne
« Reply #15 on: Fri, 30 July 2021, 10:00:46 »
Can you write the target/estimated price in your IC instead of in comments to gauge interest a bit better?
Offline mr_foggy
  • neue = nope
« Reply #16 on: Fri, 30 July 2021, 10:01:54 »
beautiful concept. hope the price stays within the $500 range.
Offline Lenux
« Reply #17 on: Fri, 30 July 2021, 10:21:03 »
A lovely keyboard ! GLWIC !
Offline 7empest
  • ༼ つ ◕ ◕ ༽つ
« Reply #18 on: Fri, 30 July 2021, 10:37:45 »
this looks super nice! those green traces on the pcb look amazing - i love little details like that.
« Last Edit: Fri, 30 July 2021, 10:56:46 by 7empest »
Offline NeonKid
« Reply #19 on: Fri, 30 July 2021, 11:26:12 »
Minimalist, yet still has lots going on. Plus the colors are on point. Im in.
Offline FaIIen
« Reply #20 on: Fri, 30 July 2021, 12:04:58 »
A nice sleek 8 degrees
Offline catamscott
« Reply #21 on: Fri, 30 July 2021, 13:36:44 »
it isn't great having to scroll halfway through the ic to get to a picture showing the entire board straight on, i'd move that towards the top. board looks really nice though, classic case design but with enough flair to make it stand out. not crazy about the side mounts on the plate but i'm sure it'll feel good either way. very nice!  :thumb:
Offline FaIIen
« Reply #22 on: Fri, 30 July 2021, 13:52:14 »
Board is acute.
Offline //gainsborough
  • MATRIXの日常
« Reply #23 on: Fri, 30 July 2021, 14:57:28 »
As a math teacher, I need this keyboard.
Even if I wasn't though - wow!  This is a hell of an introduction to this board!  Very well presented IC!
Offline pool
« Reply #24 on: Fri, 30 July 2021, 15:42:38 »
This is really nice. I'll be monitoring this
Minor critique, it would be nice to have a single picture at a straight angle where I can see the keyboard with a keycap set on.
The photography is great, don't get me wrong, but they focus too much on the aesthetic of photography than being functional in which I can see what the keyboard actually looks like with the keycap set on it.
EDIT: other than the thumbnail of the build video, there actually isn't a single picture of the full keyboard with a keycap set on.. pls fix.
« Last Edit: Fri, 30 July 2021, 16:00:51 by pool »
Offline synthtastic
« Reply #25 on: Fri, 30 July 2021, 16:25:13 »
Very beautiful design.
Expensive plastic makes me sigh.
Offline alwaysbless
« Reply #26 on: Fri, 30 July 2021, 16:44:22 »
Boards looks very clean. Please move a full pic up more though it took quite a bit of scrolling to get an actual look at the board.
Offline kuro0renji
« Reply #27 on: Fri, 30 July 2021, 18:16:31 »
I'm hyped!
Offline Kinesiologist
« Reply #28 on: Fri, 30 July 2021, 20:57:14 »
very clean indeed.
It is possible to add an F13 top variant?
Offline treeleaf64
    • treeleaf64
« Reply #29 on: Fri, 30 July 2021, 21:25:53 »
I love poron foam in my keyboard  I dont know anything else but poron foam  I live in the stuff I eat it I dream of it    I AM PORON !!!!
Everyone must pay the cat tax
    • clickclack.io
« Reply #30 on: Fri, 30 July 2021, 21:26:26 »
Hi guys,
Thanks for your suggestion!
We will ask Vertex to take some nice picture with the keycaps on.
Offline sup3r170va
« Reply #31 on: Fri, 30 July 2021, 21:26:52 »
Looks good! Very interested.
Just curious, why do the assembly video but stop short of a typing test? :)
    • clickclack.io
« Reply #32 on: Fri, 30 July 2021, 21:29:13 »
very clean indeed.
Vertex is considering adding F13 for international GB.
Offline fishnj
« Reply #33 on: Sat, 31 July 2021, 01:22:38 »
Because they have a dedicated series of typing test videos.  You can access them here: 【【AKS】Angle80打字音合集-哔哩哔哩】https://b23.tv/m6pk1F
Offline Phrillis
  • mod-colored pipe connoisseur
« Reply #34 on: Sat, 31 July 2021, 02:43:21 »
Praying for unlimited GB and F13 option  :-[
TGR Jane v2 ME | Mode 80 1st Ed. | KFE CE | Ottantaquattro | Freyr | CW88 | Frog TKL | Noxary 280 | Noxary 380 | U80-A SEQ-2 | KBD8X MK II | ElectroType 87
TC-V3 | CW60 | Ladybird | Kira EXS
Offline sutin_
« Reply #35 on: Sat, 31 July 2021, 06:47:25 »
Nice work, really love the details
Hope I can get one
GLWIC >▽<
Offline Mushroom
« Reply #36 on: Sat, 31 July 2021, 11:20:08 »
The moonstone struck me, I'll keep an eye on this
Looking forward to more on keycap displays
Offline Devastator
« Reply #37 on: Sat, 31 July 2021, 11:49:39 »
An excellent design! But I do wish development would include a hotswap pcb.  But nevertheless count me in :)
Offline chinchilla
Re: [IC] Angle from VERTEX | TKL, Leaf spring, Proto Build, Typing Sound
« Reply #38 on: Sat, 31 July 2021, 20:48:00 »
nice Keyboard,I want to get one
    • clickclack.io
« Reply #39 on: Sat, 31 July 2021, 22:43:06 »
Updated with type sound tests.
Offline badchad
« Reply #40 on: Sun, 01 August 2021, 01:35:24 »
Lots of fancy words. I’m in
BAD
Offline Jefff
    • jlabs.co
« Reply #41 on: Sun, 01 August 2021, 01:38:46 »
Beautiful! Can't wait.
Offline hottrout
  • I'd Hit Dat Key
« Reply #42 on: Sun, 01 August 2021, 04:02:03 »
I like the leaf spring design which really seems to work well.  The colours are also really good.  Interested even though I have too many TKL already.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
« Reply #43 on: Sun, 01 August 2021, 04:43:09 »
Fog is POG
Offline AIRPOTTER
  • Owner of Gray Studio
« Reply #44 on: Sun, 01 August 2021, 09:12:18 »
Good job!
Offline 傻子
« Reply #45 on: Sun, 01 August 2021, 09:45:38 »
开国外团的时间里国内会有期货版本吗?
Will there an extra GB this time domestically? I am not lucky enough to buy the first round.
Offline alwaysbless
« Reply #46 on: Sun, 01 August 2021, 14:39:55 »
True to your name that is a very clacky sounding board :)
Offline misswaffle
« Reply #47 on: Sun, 01 August 2021, 20:01:29 »
Looks great! I was too slow to snag it in the China drop so I have my fingers crossed for international.
Offline mcmcmc
« Reply #48 on: Sun, 01 August 2021, 22:25:02 »
i interested
« Last Edit: Wed, 04 August 2021, 23:43:22 by mcmcmc »
Offline zzkhan1996
« Reply #49 on: Mon, 02 August 2021, 12:47:14 »
What was the method in the Chinese GB? FCFS, raffle or unlimited?
