Author Topic: Upgrading my Razer Deathstalker (chicklet rubber dome) keyboard  (Read 4506 times)
Offline Nerif
« on: Mon, 16 August 2021, 16:18:50 »
Hello everyone! I got Razer Deathstalker keyboard recently and I like it even considering its flat keycaps design and its font (personally I like it). However, I think that this is not enough. The sound is somewhat loud and the keys tend to bind on off-center keypresses. So, how can I fix these two problems? btw, feel free to ask me anything about this keyboard
̷C̷M̷ ̷Q̷F̷ ̷X̷T̷ ̷[̷C̷h̷e̷r̷r̷y̷ ̷M̷X̷ ̷B̷l̷u̷e̷ ̷→̷ ̷C̷h̷e̷r̷r̷y̷ ̷M̷X̷ ̷B̷l̷a̷c̷k̷ ̷H̷y̷p̷e̷r̷g̷l̷i̷d̷e̷]̷
Anne Pro 2 [Gateron CAP Brown → Kailh BOX Dark Yellow]
Offline _rubik
Re: Upgrading my Razer Deathstalker (chicklet rubber dome) keyboard
« Reply #1 on: Mon, 16 August 2021, 16:34:31 »
Unfortunately there isn't all that much you can do. The deathstalker is a mostly proprietary board with little/no aftermarket support. "Chicklet rubber dome" isn't too much of selling point in the hobby. If it were a mechanical switch I could say things like 1) spring swap 2) lubing 3) o-rings but those aren't really an option.
_maybe_ you could add a thin layer of foam to deaden the sound? I guess you could also lube the key stem? That's not sealed system though, and is likely to attract dirt/dust and leak under the membrane.
My best recommendation is to get something with proper mechanical switches. They're not super common, but low-profile, uniform key profiles do exist.
« Last Edit: Mon, 16 August 2021, 16:36:12 by _rubik »
Offline Leslieann
« Reply #2 on: Mon, 16 August 2021, 23:42:31 »
The only way to fix those problems is to lube everything.
Being rubber dome chicklet, that's pretty much a death sentence for that board.
My advice, sell it and buy/build a board to your own specs.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline Nerif
« Reply #3 on: Tue, 17 August 2021, 03:04:58 »
talking about getting a mechancal keyboard, I will say that I have two of them: one with MX Browns (I like it) and one with Kailh BOX Whites (I like white boxes linearized)
returning to the question about my chicklet keyboard, I will ask one question: where do I need to apply the foam?
Offline Nerif
« Reply #4 on: Tue, 17 August 2021, 03:11:58 »
I decided not to sell keyboards no matter how bad they are in certain ways. I decided to upgrade this keyboard because I like how this keyboard looks and how it performs at typing (I am perverted, I know). So, I will buy some lube for this keyboard. :cool:
also I want to buy an Apex 100 keyboard with "mechanical feeling" domes, I heard this keyboard performs well at typing
Offline _rubik
« Reply #5 on: Tue, 17 August 2021, 10:43:07 »
That suggestion was more of a "I suppose it's possible, but I have no clue how it would be done or what it would sound like".
The only place where it would be possible is behind the pcb (instead of between the plate and pcb, as is more popular with mech boards these days), though it wouldn't do much. See how much space you have between the case and pcb, and go from there.
Offline Nerif
« Reply #6 on: Tue, 17 August 2021, 15:49:39 »
The case of this keyboard is pretty thin, there is nowhere to put some foam. I heard that it's possible to put some foam in the stem (some video about modding a membrane keyboard), but I am afraid that this wouldn't work in the chicklet
Offline _rubik
« Reply #7 on: Tue, 17 August 2021, 16:50:01 »
you wut m8? I hate to say it, but modding this thing sounds like a lost cause
Offline Leslieann
« Reply #8 on: Tue, 17 August 2021, 21:37:34 »
Be sure to read this.
https://geekhack.org/index.php?topic=108287.0
And did you miss the part where I said this is pretty much a death sentence for this board?
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline Nerif
« Reply #9 on: Wed, 18 August 2021, 05:57:18 »
I remember this part, but I don't really want to sell it, I want to do something with this to make it better
Offline Nerif
« Reply #10 on: Wed, 18 August 2021, 06:03:24 »
I have read this post about lubing. So, as I can see, there is no way out except selling it and buying a normal rubber dome keyboard, like Apex 100 or BTC Dome with Slider keyboard
