Author Topic: [IC] Phoenix - a TKL by Cable Car Designs  (Read 56331 times)
Offline westfoxtrot
    • Cable Car Designs
« on: Fri, 08 October 2021, 09:05:40 »
Group Buy is now live: https://geekhack.org/index.php?topic=116192
Date has changed please see below: March 4 - March 25
From the ashes rises Phoenix!
Featuring a beautiful curved side profile, Phoenix evokes a feeling of elegant luxury.
The board features a carefully thought out ground-up implementation of a sandwich gasket mounting system. It has been engineered to keep the typing feel not only consistent across the whole board but also make it one of the most pleasant experiences in keyboards.
Photo credit @thinkkwer
TL;DRplease fill in this form
Key Features
  • F13 Tenkeyless layout with ANSI and ISO support
  • Sandwich gasket mount designed for consistency and type feel (poron as default, see below)
  • USB Type-C w/ universal daughterboard support
  • PCB with south facing stabiliser support
  • Semi-seamless design with thin bezels
  • 6.5° typing angle
  • 20.268mm front height (with feet inc 7.8mm high profile) Effective Keyboard Height is 23.173. Details in Additional links
  • Weights: 4kg built with brass base, brass base alone is 3.2kg, alu base is just over 1kg so built with alu base will be approx 2kg
  • That curve
Note about the weights: they are approx due to limited access to precision scales, some private owners measure it at 4.1, some at 3.9 so consider it ~4kg rather than dead on
Group Buy Details
  • Pricing: $499 (Aluminium base) $599 (Brass base) - Pricing is subject to change due to fluctuating raw costs
  • Regional pricing will be added with the group buy post but is expected to mirror the exchange of the USD price above
  • Date: 2022 March 4th through to 2022 March 25th
  • Format: Unlimited (Subject to agreement amongst vendors)
Here is an excellent set of photos by the excellent @thinkkwer
Please consider this post a living document, I am currently in the process of finalising all arrangements with vendors and factories so dates and pricing will be updated as soon as I can.
In testing and amongst the private buy participants I’ve found people tend to prefer poron gaskets so that will be the default gasket material. If we get a sufficient volume of orders I intend to also include a set of silicone gaskets for a slightly firmer feel.
The PCB that comes with the kit will be customised though it is compatible with a.88 PCBs with daughterboard support.
Gaskets and feet are both custom cut for this board, there is a large AliExpress store that sells similar sized feet that will work down the line if you are unable to source your own. Though I will release the files for the gaskets as those are specific for this board.
Options
  • Colors: Dark Red, Silver, or Black
  • WK or WKL top (the PCBs and plates will only support a 7u bottom row unless there’s sufficient interest, please see IC form above)
  • Full brass or aluminium base
  • Plates: Polycarbonate or aluminium, ANSI or ISO
  • The PCB will be a customised version of mechstudio’s mk88 complete with daughterboard and JST cable
  • The board will ship with a hard case
  • Additional plates, PCBs, and gaskets
Vendors
Here is a list of the retailers with their respective prices and regions. There are no regional restrictions outside of where a store can normally ship to, please buy from whichever vendor is best for you! Anything not completed will be updated ASAP
RegionRetailer & LinkRegional priceNotes
Europemykeyboard.euTBD
USAMekiboTBD
CanadaApexKeyboardsTBD
OCEDaily ClackTBD
SingaporeHex KeyboardsTBD
East Asiakibou.storeTBD
IndonesiapluskbTBD
UKKeebCatsTBD
Due to the ongoing complications of the pandemic an exact timeline is hard to nail down, I would be hopeful everything can be manufactured and shipped in around 6-9 months. Though once we have a better idea of the volume of boards it will be easier to get a better timeline to share.
Plate files will be made available in my github plate repository once production files are confirmed.
Here is an exploded view
If you have any questions or comments about the case/pcb/buy etc. please ask here or by any of these contact methods: Reddit, Geekhack, email, discord.
I am most available on discord but will try to get back to you in a reasonable timeframe any way you reach out.
Thank you for your time
– Max
Additional links:
Soundtests pastelink
Github on Effective Keyboard Height
Thanks to:
Private Round buyers for their invaluable feedback
Morgana for an exceptional logo design
Kwerdenker/thinkkwer for being an extremely attractive human being
Lewis Flude for being an S-Tier proofreader
Everyone who was so enthusiastic to see the board come to life
you for reading the thanks section
Edit notes:
added weight to feature list
added EKH
added exploded view
added UK vendor
added pricing
« Last Edit: Mon, 07 March 2022, 03:10:04 by westfoxtrot »
Offline of_sam
Re: [IC] Phoenix - a TKL by Cable Car Designs
« Reply #1 on: Fri, 08 October 2021, 09:06:34 »
King ****.
Typing on: HHKB Pro 2 - Stock :aware:
Collection: F1.69, Police, Jubi, RF 87U, En Dash, Rosenthal, Soulless, Frog, Calliope, GAF 910, Sabre, W1-AT
Offline kk73715
  • Why are you even reading
« Reply #2 on: Fri, 08 October 2021, 09:07:17 »
:pogchamfer:
Offline The0rigina1
  • fumoposting
« Reply #3 on: Fri, 08 October 2021, 09:07:36 »
reserved
Offline Ella
  • Why is it called an oven
« Reply #4 on: Fri, 08 October 2021, 09:07:47 »
TKL
Offline NRbigfoot
« Reply #5 on: Fri, 08 October 2021, 09:08:02 »
Phoenix looks so good Max
HBCP | FLX Virgo | aanzee | Mira SE | Leaf 80 | HHKB pro 1 | qxp | Rukia | IDB60 | equinox | No1Rev1 | Whale | Montage | 268.2 | Anniversary Whale | Jer80 | Evolv
Offline terrad
« Reply #6 on: Fri, 08 October 2021, 09:08:08 »
Yes
Sent from my IN2023 using Tapatalk
Offline rookb
« Reply #7 on: Fri, 08 October 2021, 09:09:49 »
Give
Offline Yuray
« Reply #8 on: Fri, 08 October 2021, 09:12:11 »
The Swan evolved into a Phoenix. So excited for this!
Offline Sensetrigger
  • t.me/keebcult (for my friends from the CIS)
    • a community for my friends from the CIS
« Reply #9 on: Fri, 08 October 2021, 09:12:41 »
Finally! Good luck with that.
Offline Gvalch_ca
« Reply #10 on: Fri, 08 October 2021, 09:13:27 »
Looked at the thread name
Thought that this board will be the same as Prophet and Angel but in TKL size
Saw that it is just an isolation mount board
Disappointment was immeasurable and day was ruined
Lead Keyboard Cringeneer.
Alps and Space Invaders enthusiast.
Offline goya_dechi
« Reply #11 on: Fri, 08 October 2021, 09:15:13 »
IC form filled, can't wait. Best of luck Max!
Offline kiyoboard
  • https://www.youtube.com/kiyoboard
« Reply #12 on: Fri, 08 October 2021, 09:15:37 »
I have been following this on Discord. Happy that IC for it started finally. And thanks for trying to make it unlimited and open for a month. Looking forward to the GB  :thumb:
Offline PeppyToad
« Reply #13 on: Fri, 08 October 2021, 09:17:09 »
Let's go ;D
277123-0
Offline namidettje
« Reply #14 on: Fri, 08 October 2021, 09:20:34 »
Frog TKL , Mr Suit TKL , Angle TKL , Cloudline TKL (and others whom I forgot) and now this.
My wallet can't take this any longer u_u
Pretty interesting, will await for sound tests but looks like a banger!
GLWIC
Offline gautema
« Reply #15 on: Fri, 08 October 2021, 09:24:36 »
Finally it’s happening  :cool:
Board of the year for me
Offline westfoxtrot
    • Cable Car Designs
« Reply #16 on: Fri, 08 October 2021, 09:24:51 »
turns out I can do more than 1 thing
GLWIC
Knew I forgot something, added a sound test section to collect these. Thanks
Offline fortaye
  • 40's 40's 40's
« Reply #17 on: Fri, 08 October 2021, 09:25:14 »
This keyboard ran in July. Should be shipping soon. https://mechvault.net/products/phoenix-keyboard-kit
Phoenix was named after reviving the JD45 layout for the Phoenix45. A lot of people were asking ProjectCain for a premium version. So he ran the Phoenix. Aluminum case with beautiful brass weight. I thought you should know. Gl with gb!
Offline Zeelobby
« Reply #18 on: Fri, 08 October 2021, 09:26:46 »
Yoooo, this is it chief. Glad to see the IC drop. Max #1 A-OK
Offline westfoxtrot
    • Cable Car Designs
« Reply #19 on: Fri, 08 October 2021, 09:30:17 »
was not aware of this - thanks for the info!
Offline vi0till
« Reply #20 on: Fri, 08 October 2021, 09:32:11 »
I dont usually like black color, but with brass bottom, black is super nice.
Any chance for half plate option?
Offline Puree
« Reply #21 on: Fri, 08 October 2021, 09:33:37 »
 :thumb:
Offline mini_ninja_64
« Reply #22 on: Fri, 08 October 2021, 09:44:37 »
UwU
Offline ZavaZ86
« Reply #23 on: Fri, 08 October 2021, 09:56:02 »
Max so lit
Offline Exluna
« Reply #24 on: Fri, 08 October 2021, 10:02:52 »
Mmm very nice.
Offline actress
« Reply #25 on: Fri, 08 October 2021, 10:06:12 »
Damn, great job.
Really hope it's unlimited. Would you consider half plate option for this, or is it not possible ?
Offline peaceperfection
« Reply #26 on: Fri, 08 October 2021, 10:20:05 »
Can't wait for it! Hope it's unlimited similar to Prophet and Angle. Bought almost all of your boards so far!
Offline whirlwind
« Reply #27 on: Fri, 08 October 2021, 10:30:59 »
I love you Max.
Offline westfoxtrot
    • Cable Car Designs
« Reply #28 on: Fri, 08 October 2021, 10:39:46 »
Thanks for the support <3
Damn, great job.
Definitely will, please add it in to the IC form and if there's demand for it I will do my best to accommodate
Offline bert039
« Reply #29 on: Fri, 08 October 2021, 10:40:38 »
It's cool, man, got red bottoms on
Life is good
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
« Reply #30 on: Fri, 08 October 2021, 11:04:43 »
An absolutely beautiful, elegant keyboard by one of the best designers in the hobby. :thumb:
Offline Gvalch_ca
« Reply #31 on: Fri, 08 October 2021, 11:09:28 »
Sure you can. But pin mount TKL would be awesome! Please consider it as you future project.
Offline Finite
  • peer pressured into mk hobby, pls send help
« Reply #32 on: Fri, 08 October 2021, 11:43:23 »
Yeah, although the name isn't copyrighted, I still think it's a bit of a problem to name a keyboard the same as another one that already exists. I hope this one gets renamed so that there won't be any misunderstandings or confusion, but I won't blame the OP since it's obviously just an oversight on their part.
Offline c0d3r
« Reply #33 on: Fri, 08 October 2021, 11:52:23 »
I AM ALL IN!!!
Offline mmayhem17
    • Steam profile
« Reply #34 on: Fri, 08 October 2021, 13:42:18 »
:eggplant:
Enviado de meu SM-G780G usando o Tapatalk
Offline MIGHTY CHICKEN
« Reply #35 on: Fri, 08 October 2021, 13:48:41 »
looks very based
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
« Reply #36 on: Fri, 08 October 2021, 14:26:11 »
Phoenix (TKL) actually predates Phoenix (40%) by around a year. A private GB ran in February of this year. I can’t foresee any misunderstandings here.
Offline pngu
  • send noots
« Reply #37 on: Fri, 08 October 2021, 15:36:22 »
I think you're forgetting about fabled designer PhoenixStarr here, the inventor of the FRL TKL. I see a very real risk here with regards to people mistaking this keyboard for a person and then being disappointed when the door rings and all they get is a keyboard, and one with an F row at that!
Offline Gnome
« Reply #38 on: Fri, 08 October 2021, 15:38:44 »
Keybirb.
The asymmetry on the screwholes are driving me crazy.
Offline westfoxtrot
    • Cable Car Designs
« Reply #39 on: Fri, 08 October 2021, 15:46:08 »
Keybirb.
It's very deliberate in order to help the mounting system whilst being able to maintain the overall design language.
Offline _rubik
« Reply #40 on: Fri, 08 October 2021, 15:51:40 »
Interested, but I'll have to circle back with feedback once I've digested it. Looks nice on first glance though
Offline Zurg Eon
« Reply #41 on: Fri, 08 October 2021, 15:58:00 »
Very interested! Thank you for trying to make it unlimited
Offline Gnome
« Reply #42 on: Fri, 08 October 2021, 16:05:50 »
Keybirb.
I understand there's a reason for it. It's a very clean looking board so the asymmetry really sticks out like a sore thumb to me.
Speaking of mounting system, any exploded renders available?
Offline Ustinj
« Reply #43 on: Fri, 08 October 2021, 17:42:55 »
beautiful and unique, excellent all around ... i've always loved this board's unique silhouette
Offline Kinesiologist
« Reply #44 on: Fri, 08 October 2021, 20:46:48 »
yes please, im ready
Offline bert039
« Reply #45 on: Fri, 08 October 2021, 22:48:54 »
Now that you mentioned it I can't unsee it. Is there a way to hide the center screws? Love the bottom of the board but the asymmetry stains it.
Offline bananathock
« Reply #46 on: Fri, 08 October 2021, 23:00:40 »
YAY! I'm so happy! Thank you westfoxtrot for bringing us another wonderful keyboard!
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
« Reply #47 on: Sat, 09 October 2021, 05:38:44 »
The screw placement is done in the same way as the TGR Jane V2. This is quite common to fit around board internals.
Offline stidal
  • milo#3939
« Reply #48 on: Sat, 09 October 2021, 06:46:28 »
man, that back is something else. super clean :thumb:
transition tkl // aksara ce // bully // valhalla // voyager // rs60 // adiuvare // ciel60 // jules // prime e // ut47.2 // sequence // bumper // q1 // gaff60
Offline The0rigina1
  • fumoposting
« Reply #49 on: Sat, 09 October 2021, 08:12:35 »
You don't think the TKL in the title would've given it away?
