Author Topic: [IC] k-star ORION 87 | GB Soon  (Read 30973 times)
Offline Kevin-3992
  • kindlestar team
« on: Fri, 26 November 2021, 13:24:48 »
update v2.0
We are really grateful for all your patience and support, we believe all those will be meaningful. We made several improvements in the last three months,:
The improvements on structure and appearance:
1. We lowered the screw column by 1mm, and the installation method is simpler and there won’t be any affects on the shaft body while the screw is invisible.
2. The upper shell surface is raised by 1mm as a whole, which further avoids the exposure of the shaft body.
3. We have customized new SCM435 grade 12.9 torx screws to adapt the high-intensity disassembly and assembly.
4. Regarding processes of the surface treatment, we have further reduced the fit gap, we successfully make it looks more refined.
5. After many times of communication with the factory, the designing for the front section of the upper shell has been restored as well, making it more interesting.
6. With standard titanium alloy logo, players can burn their favorite logo colors.
7. New mold-opening silicone sleeve replaces the original viscose poron strip, making the installation much more convenient.
8. The new positioning plate is slotted, so you do not need to adjust it after installation and the keycap is naturally centered.
9. The hole adjustment of the Enter key makes the Orion87 compatible with more pcb satellite axes.
The improvements on PCB:
1. Customized connecting cables are used and it is more convenient for repeated disassembly and assembly.
2. We replace the battery socket with zh1. 5mm2pin specification, so you can easily buy a suitable battery.
3. A dedicated battery power switch is added.
4. We used unified brushing needle port, so you only need to open the space bar if there is a need for brushing, the operation is so easy!
5. The circuit impedance is also optimized and adapt to more types of type-c data lines.
6. The antenna design is optimized to improve the wireless signal quality by 30%.
The improvements on firmware:
1. We get the hardware architecture and its supporting firmware redesigned.
2.We avoided the bluetooth bug of win10 and 11 systems, and solved the problem that the Windows system cannot pair again after deleting the bluetooth.
3. It will provide more and interesting RGB lighting effects.
4. The logic of keyboard sleep wake-up is optimized. In automatic sleep method, just click the space bar to wake up. It becomes more power saving and convenient.
5.Bluetooth power adaptive
6.Bluetooth real -time switching speed  up
7.Automatic Bluetooth anomaly detection and unbinding
8.New Bluetooth nkro scheme
9.Keyboard startup speed increased
What else have we done besides the above improvements:
1. The structure, appearance, PCB and software system of the keyboard have been comprehensively tested according to the standard of mass-produced keyboards.
2. Quality of all materials has been strictly inspected.
3. We designed and produced more accessories for Orion87. The sandblasted copper counterweight, compatible with Dopele pcb, FR4 positioning board and steel plate satellite axis positioning board will be produced in the future, to make it more playable.
4. The Orion pad keyboard with the same style common receiver as the orion87 is being developed.
5. The usb-hub for the desktop center of orion87 is planning to be designed.
6.We have provided an attached manual, hoping that the players who get it can use it more easily
Here we appreciate all the players for your support and love, and please kindly provide us more feedback or suggestions to get improved.
Details:
•   Name: ORION 87
•   Layout: TKL
•   Mounting: gasket mount with poron
•   Materials: 6063 Aluminum .Titanium logo
•   Weight & Size:  3.5kg
•   Typing Angle: 6.5 degrees
•   Plates:  Polycarbonate
•   PCB layout: TKL
•   PCB:wired 、Bluetooth 5.1(Support 6 decive switching)QMK&VIA
•   Price: $399(The price is different in different regions)
Q&A
Q:Is there a YouTube video?
A:here is the video from 3ildcat
Q: Will there be a sound test with no foam?
A:will update the sound test with no foam in our next IC
Q:Are 2.4G receivers and batteries included?
A:sorry, We can't provide it because of transportation restrictions.
Price: $399. (The price is different in different regions)
Sale in stock :  300pcs  March 30, 2022, (different agents and regions will be different)
Delivery time: within half a month after placing an order
Vendor:
            Worldwide:        kindlestar.online
            North America:    kono.store
            Australia:            dailyclack.com
            Europe:              mykeyboard.eu
            Southeast Asia:   keyfirst.cn
kindlestar orion87 IC
Hi, everyone,
this is Kevin from kindlestar studio.
Here we want to introduce our new project ORION87,hope all of you will fall in love with it.
Welcome to your active comments.
Exploring the outer space can be such an amazing and charming thing, and our future is also tied to the outer space.
The explosion of the outer space starts from observation, Radio Telescope, whose shape is also attractive, takes a great role.
Based on these aspects, we designed Orion.
About our team
We are a new  team that consisted of designer, players and engineer.
Please call us K-star or K-Team.
About ORION-87
When designing Orion, we used many golden sections to make its shape more natural and exquisite
 and all the lines and blocks could make sense.
For the connection between the upper&lower shells and the counterweight,
we make it interspersed with two corners,
which brings it a sense of formality.
Hereby, we think it Form is the function.
In the past November, orion87 has been shipped in the Chinese market.
We have received various feedback. Players have a good evaluation of its hand feel and sound performance.
Of course, the workmanship of the product has also been highly praised.
Links
Please feel free to join Discord and Instagram to get more updates.
Discord:https://discord.gg/xX3k8KGAQy
Instagram:https://www.instagram.com/kindlestar.offical/
web&store:https://kindlestar.online/
Typing sound
keyboard:ORION87
keycaps:GMK Lotus
switch:Cherry Hyperglide with gin 65g springs
https://www.youtube.com/watch?v=GfIJVOhy5U8
IC FORM :https://forms.gle/BGnWXynLYmRbmLKg9
update v1.0
there will be a compared type sound video without poron later
some photos from players
Thanks for your attention
Looking forward to your comments
Love you guys
« Last Edit: Sun, 20 March 2022, 10:56:15 by Kevin-3992 »
Offline Fraaaan
Re: [IC] ORION 87
« Reply #1 on: Fri, 26 November 2021, 13:31:18 »
You sold the board before and decided on a GB date already but price is still TBD?
Offline MIGHTY CHICKEN
Re: [IC] ORION 87
« Reply #2 on: Fri, 26 November 2021, 13:33:18 »
I'm kinda down for BT tkl, tsangan sounds amazing on this
Offline The0rigina1
  • fumoposting
Re: [IC] ORION 87
« Reply #3 on: Fri, 26 November 2021, 13:50:49 »
Sound test with no foam please.
Offline Kevin-3992
  • kindlestar team
Re: [IC] ORION 87
« Reply #4 on: Fri, 26 November 2021, 13:58:34 »
Yes, it's the first time we do global sales. We also need to communicate and coordinate the selling price with various sales channels, which will be confirmed before the middle of December
Offline Kevin-3992
  • kindlestar team
Re: [IC] ORION 87
« Reply #5 on: Fri, 26 November 2021, 14:10:28 »
Thanks for your recognition
Offline Kevin-3992
  • kindlestar team
Re: [IC] ORION 87
« Reply #6 on: Fri, 26 November 2021, 14:12:10 »
Offline Poesjuh
[IC] ORION 87
« Reply #7 on: Fri, 26 November 2021, 15:01:12 »
I mean I kinda agree on that one.
It’s hyperglides which should be relatively clacky but there is almost no clack at all. So clearly now it just sounds like a filled completely with foam board. Not saying it’s bad, but it doesn’t tell us anything about the sound signature and character of the board.
Talking about character: the exterior has a lot of it, so much that imho the badge can go. Looks a bit tacky to me.
Lastly, while I do understand that using international sales channels will increase the price, sharing a price range can’t hurt.
« Last Edit: Fri, 26 November 2021, 16:11:00 by Poesjuh »
Offline The0rigina1
  • fumoposting
Re: [IC] ORION 87
« Reply #8 on: Fri, 26 November 2021, 15:42:23 »
lol
lol, very nice cash grab, now take your cringe foam board out of here
Offline actress
Re: [IC] ORION 87
« Reply #9 on: Fri, 26 November 2021, 16:42:47 »
this reminds me of that other space keyboard from that other studio.
Has a very gimmicky design imo, also I have a feeling you're gonna charge premium for this even though it's designed around foam.
There is a reason it's frowned upon, it makes sense in budged boards but it doesn't make sense to mask the sound of your very expensive keybort and stiffen it.
sorry for rant
Offline wanf
Re: [IC] ORION 87
« Reply #10 on: Fri, 26 November 2021, 16:49:37 »
this is called the orion 87 but it isn't the duck orion. it's a small thing, but even though you'd already sold this board under the name orion, would you consider changing the name to avoid confusion?
Offline TheInverseKey
  • You can run but you cannot hide!
Re: [IC] ORION 87
« Reply #11 on: Fri, 26 November 2021, 17:17:26 »
Noi Quack Noi buy,
This is not the wrist breaker that we are looking for...
Offline nullinasou
Re: [IC] ORION 87
« Reply #12 on: Fri, 26 November 2021, 18:18:30 »
looks nice and it's refreshing  to see wireless tkl!
Do you have wkl option?
Offline Auxo
  • Formerly CJD_Anthony
Re: [IC] ORION 87
« Reply #13 on: Fri, 26 November 2021, 18:22:30 »
This,
There is already a very well known maker by the name of Duck who has created a TKL named the Orion already.
https://geekhack.org/index.php?topic=109033.0
Re: [IC] ORION 87
« Reply #14 on: Fri, 26 November 2021, 20:59:57 »
+1 on changing the name
really bad look
Offline soundstage
Re: [IC] ORION 87
« Reply #15 on: Fri, 26 November 2021, 22:14:16 »
Bluetooth support should be optional separate kit, will reduce price proportionally. Missing F13 key is let down. You claim gasket mount, but your exploded view does not portray clearly where those gaskets are.
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
Re: [IC] ORION 87
« Reply #16 on: Fri, 26 November 2021, 23:35:58 »
This is no Duck
Offline Tree_
Re: [IC] ORION 87
« Reply #17 on: Sat, 27 November 2021, 00:25:19 »
OH **** ANOTHER ORION RUN HERE WE GOOOOoh, not Duck.
Offline baka jiken
Re: [IC] ORION 87
« Reply #18 on: Sat, 27 November 2021, 02:20:53 »
Very nice! Much wow
Offline stidal
  • milo#3939
transition tkl // aksara ce // bully // valhalla // voyager // rs60 // adiuvare // ciel60 // jules // prime e // ut47.2 // sequence // bumper // q1 // gaff60
Offline tngpq
Re: [IC] k-star ORION 87 TKL BT & hotswap
« Reply #20 on: Mon, 29 November 2021, 08:51:30 »
What do you expect from a rip off. Classical.
Offline darthcapn
« Reply #21 on: Mon, 29 November 2021, 13:24:43 »
The black pvd looks rad. I love those curves and the colors. Will look out for the gb.
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline phinix
« Reply #22 on: Wed, 01 December 2021, 16:34:04 »
Beautiful. WKL version?
What is front height?
Offline Toad944
« Reply #23 on: Thu, 02 December 2021, 01:07:44 »
take my money!!!
Offline Packkkk
« Reply #24 on: Fri, 31 December 2021, 00:21:12 »
Looking forward to seeing the sound test without foam and the upcoming keymap solution.
Offline alper_maestro
« Reply #25 on: Mon, 03 January 2022, 13:41:43 »
Looks nice, any updates about the price? I mean it would be helpful if we have an estimate about the price, even if the price is not fixed at the moment.
Also would like to know if it comes with a Hotswap pcb?
« Last Edit: Mon, 03 January 2022, 13:43:19 by alper_maestro »
Offline IMZO
  • Matrix shill, and TKL WKL Lover
« Reply #26 on: Mon, 03 January 2022, 14:40:37 »
Looks good, but orion is already a taken name. +1 on changing the name  :thumb:
Current boards: Jane V2 CE , Matrix 1.2og Silver WKL , Matrix 2.0add coating black WKL, Matrix 2.0add WKL Coating yellow, Satisfaction75 R1 Cloud white, Korno65, Bloop65, HHKB Pro 2 white,Lin Whale Pink WKL, Gok 7v White, Gok 7v Black, Orion V3 Silver WKL, Orion V2.5 Red WKL, Geon F1-8x Silver WK, Haus65 BlueGray, Plume65, Vertigo, Frog TKL WKL GreenF13
Offline QWER|key
« Reply #27 on: Tue, 04 January 2022, 01:28:33 »
Get rid of that logo/badge. It looks tacky AF.
Offline Kevin-3992
  • kindlestar team
« Reply #28 on: Sun, 20 March 2022, 10:46:12 »
The video will be uploaded soon
Offline Kevin-3992
  • kindlestar team
« Reply #29 on: Sun, 20 March 2022, 10:48:44 »
Price: $399. (The price is different in different regions)and this comes standard with HotSwap PCB
Offline Kevin-3992
  • kindlestar team
« Reply #30 on: Sun, 20 March 2022, 10:52:02 »
Thank you very much for your advice
Offline Kevin-3992
  • kindlestar team
« Reply #31 on: Sun, 20 March 2022, 10:54:09 »
This will be a titanium  logo. Burn it and make it more beautiful
Offline Keeblet_257
Re: [IC] k-star ORION 87 | GB Soon
« Reply #32 on: Sun, 20 March 2022, 14:55:32 »
GB soon yet a simple yet important thing is missing.
a list with things we get when ordering the board.
All I know so far for sure is that there is going to be no batterie and receivers included even though its a bluetooth board and that it will come with the case, plate and pcb. Do we get more when ordering the board?
As for the batterie what dimensions will the board fit? If there isnt even a batterie included it would be best to give us the infomation to buy one beforehand instead of receiving the board and then meassure out what can fit inside of it
« Last Edit: Sun, 20 March 2022, 14:57:36 by Keeblet_257 »
Offline jackcalico
« Reply #33 on: Tue, 22 March 2022, 04:43:46 »
Awesome project! Would love to see a slightly smaller form factor keeb myself in the future (75% maybe?)
Offline Kevin-3992
  • kindlestar team
« Reply #34 on: Tue, 22 March 2022, 05:20:54 »
hi , thanks for your attention, will show the list in the GB ic, sorry to tell you that there will be no batteries and receivers, except the case ,plate and pcb, there will also come withthe equipped with foam, installation tools and instructions. The battery is normal size lithium battery, the battery compartment is also standard size , can be easy to buy, will show the details and purchase link of the battery later.
Offline Kevin-3992
  • kindlestar team
« Reply #35 on: Tue, 22 March 2022, 05:24:13 »
thanks for your attention , 75% is also in our plan in the future.
Offline Jefff
    • jlabs.co
« Reply #36 on: Tue, 22 March 2022, 16:08:54 »
There's already an Orion TKL that's better than yours: https://geekhack.org/index.php?topic=98581.0
Oh also, that's a lotta foam
Offline Kevin-3992
  • kindlestar team
« Reply #37 on: Thu, 24 March 2022, 06:42:38 »
Thank you for your feedback. We already know that the Orion of duck is also an excellent product. The name of K-star orion87 is the same as that of him, which is a wonderful coincidence. In addition, the two products are not much related.
Offline Kevin-3992
  • kindlestar team
« Reply #38 on: Sun, 08 May 2022, 01:23:32 »
Today is the last day of orion87  GB
Offline Deadline.Studio
« Reply #39 on: Tue, 10 May 2022, 20:45:13 »
NICE👍
Offline daja_nga_kavaja
« Reply #40 on: Thu, 14 July 2022, 23:06:32 »
Hello all
what the latency of BT reconnection ? How soon the kb wakes up ( connects to PC ) after the sleep ?
Where do i purchase the black/gray for Albania Europe ?
i tried on https://keyfirst.cn/ but there is no shipping to Albania Europe.  I tried on https://kono.store/  but there isnt the black/gray
Thank you
Offline RoyalOak88
« Reply #41 on: Fri, 15 July 2022, 04:12:11 »
Hello all
Thank you
Did you try Mykeyboard? They still have it in stock.
« Reply #42 on: Thu, 21 July 2022, 18:28:38 »
Hello all
Thank you
They don't have shipping to Albania Europe
« Reply #43 on: Thu, 21 July 2022, 18:50:01 »
Hello all
Thank you
hello my friend
your best bet is to find someone in a nearby country that the vendor ships to and then have the person ship it to you
good luck my friend
