Author Topic: [IC] OGR - Retro 65XT  (Read 41958 times)
Offline Alchemist Keyboards
    • Alchemist Keyboards
« on: Thu, 17 February 2022, 07:35:46 »
GB THREAD LIVE HERE:
Links:
INTEREST CHECK FORM
AKB Website
AKB Discord
AKB Instagram
Background Info:
The OGR was originally designed as an entry for the OG Summer competition on r/customkeyboards in 2019, which it won. It was originally inspired by various vintage keyboards, but chiefly the Cherry/NCR G81-3077 for the iconic Cherry nose, the pronounced seam and the large forehead. It also drew inspiration from the Cherry G80-0832 for the accented piece around the keycaps to give it a truly unique look. The name is a portmanteau of OG Summer and NCR, whose branding on the aforementioned G81-3077 was also the inspiration for the retro-styled AKB logo. While the PCB is USB-C compatible, the port is enclosed deep inside the case and the case parts gently clamp the cable down to give the aesthetic of a hard-wired cable.
Also, for those who are interested, there will be a numpad (OGR-N) available either as an optional extra or separately.
Specs/features:
  • Inspired by Cherry G81-3077/G80-0832
  • 10° typing angle
  • Full 6063 aluminium construction
  • Bead-blasted and anodised finish
  • Top mounted plate
  • 21.5mm effective front height (with bumpons)
  • QMK and VIA/VIAL-compatible USB-C PCBs
  • LED indicators on caps lock, numlock on numpad
  • Two colourways (Dolch & Blue/grey)
  • Integrated cable aesthetic
  • Bold, pronounced seam
  • Period-authentic product stickers
  • Plate materials: 5052 Aluminium, Polycarbonate, Carbon Fibre (may change)
  • Is an absolute unit
  • 2.9kg (6.5lbs) / Numpad 0.9kg (2lbs) [unbuilt]
Prototype photos:
Kit contents:
Not including extras
  • 1 x Top Case - 6063 Aluminium
  • 1 x Bottom Case - 6063 Aluminium
  • 1 x Accent - 6063 Aluminium
  • 1 x Plate - 5052 Aluminium OR Carbon fiber leaf spring (undecided)
  • 1 x Badge - 6063 Aluminium
  • 1 x Solder PCB - Black FR4 with green solder mask
  • 4 x AKB Bumpons - Injection molded silicone
  • 1 x Bottom sticker
  • 10 x Torx button screw M3 x 6mm in A2 stainless steel (plate)
  • 5 x Torx button screw M3 x 6mm in A2 stainless steel (accent)
  • 6 x Torx button screw M3 x 12mm in A2 stainless steel (case)
  • 2 x Torx countersunk screw M3 x 5mm in A2 stainless steel (badge)
  • 1 x Instruction manual
Current group buy plans/details:
Not all is set in stone yet, but:
  • Will be limited to somewhere around 250 units, plus extras and F+F units.
  • GB launching on Saturday April 16th. GB Delayed until further notice
  • Sale will be conducted via my own website through a raffle checkout system.
  • Pricing isn't yet finalised, due to the fluctuation of raw aluminium prices but I'm aiming for ≤£440 (~$575 USD) for the OGR, and ≤£200 (~$270 USD) for the OGR-N. (+VAT for UK)
Layout Support:
Two tops will be available - one for 7u bottom row with dual 0.75u blockers, and one with a single small blocker for 6.25u support.
The OGR-N PCB will have support for regular and southpaw configurations, as well as the option to have a full 1u setup. The plate available will support regular and southpaw layouts, due to its reversible design.
Special Thanks:
  • Blacksimon for running the OG Summer competition, and playing a crucial part in bringing this board to life. Without that kick up the arse I may not have caught the designing bug I have today.
  • Martin for his excellent work on the PCB designs.
  • Flexerman (FLX) for his crucial input with the board’s design and improvement.
  • Koen for his beautiful photos of the prototype.
  • Lulzthax, for his great build stream.
  • ThereminGoat, Hot Trout, Lewis, BK, Archetype and countless others for their support throughout.
To-do list:
  • Typing test
  • Sort my life out
  • Confirm pricing, pencil in a new date
edit: added numpad layout support
« Last Edit: Fri, 06 May 2022, 13:48:19 by Alchemist Keyboards »
Re: [IC] OGR - Vint-Inspired 65XT
« Reply #1 on: Thu, 17 February 2022, 07:36:07 »
Responding to some questions/points raised from the IC form:
"Please consider adding a weight to this"
A this is 6.5lbs for just the case and plate the board is definitely not needing additional mass. The sticker on the bottom provides a much more authentic design detail than a weight in this instance, in my opinion.
"Will you consider a WK option?"
There will be a WK option available in GB. Shown in this render kindly provided by Snurrebassen https://i.imgur.com/fpGHNm8.jpg
"Why only 150 units?"
Because this is such a passion project for me I don't feel entirely comfortable leaving its fate with other vendors. I've been full-time in keyboards since April 2021 and AKB is a registered business, and I will soon have a proper workspace available to handle a public GB too. Given that we often see people crumble under the weight of responsibility with GBs I would rather walk before I can run, and once I have the process dialled down I will scale up subsequent sales if the people demand it. I have increased the max quantity to 250 units.
"$610/$270 is too much"
Given the design and the quantity I believe it is reasonable compared to various other offerings we've seen. However like noted in the post above, I am aiming at those prices or less, so the listed prices are the absolute maximum. A few components to the GB are still conservatively estimated and awaiting confirmation so if there's room to bring down the price between now and GB, I will absolutely do that. Current pricing for the OGR has been updated to (est) $575. Further updates to follow before launch.
"Will you sell the numpad only?"
If a large number of people ask for this between now and the GB I will consider this, but so far the plan has been to run that as an optional extra. The numpad will be now be offered as a standalone purchase and will be fully open (no raffle)
Typing test video from Koen:
Typing test clips from the build stream from Lulzthax (cf leaf spring plate, oil kings w/stock springs, deskeys films & 205g0):
https://clips.twitch.tv/FineColorfulPelicanKreygasm-BVstEvlt9y3nAY3I (plate foam only)
https://clips.twitch.tv/BlitheWiseClintmullinsYouDontSay-FEZvuzIMNHEE2XUL (plate foam only)
https://clips.twitch.tv/DreamyAltruisticPeachNerfRedBlaster-nMRmeJKy2IvacGnJ (plate and case foam)
Full stream here:
https://www.twitch.tv/videos/1474475487
« Last Edit: Wed, 04 May 2022, 01:39:43 by Alchemist Keyboards »
Offline ilikerustoo
« Reply #2 on: Thu, 17 February 2022, 07:38:42 »
Hot
Offline Bleddyn
« Reply #3 on: Thu, 17 February 2022, 07:39:22 »
Have watched this from the very beginning until now, looks awesome and glad you pursued it to the end.
Offline of_sam
« Reply #4 on: Thu, 17 February 2022, 07:39:51 »
Super well done. Very good ic, good luck with this project!
Typing on: HHKB Pro 2 - Stock :aware:
Collection: F1.69, Police, Jubi, RF 87U, En Dash, Rosenthal, Soulless, Frog, Calliope, GAF 910, Sabre, W1-AT
Offline MSA_Vision
« Reply #5 on: Thu, 17 February 2022, 07:40:22 »
Nice!
Sic Parvis Magna
Offline robrobro
« Reply #6 on: Thu, 17 February 2022, 07:41:04 »
Really, really nice!
Offline Supersnicks
« Reply #7 on: Thu, 17 February 2022, 07:45:58 »
This is HOT!
Offline Pyroo
« Reply #8 on: Thu, 17 February 2022, 07:46:24 »
Amazing
Bunny enthusiast
Offline Moods
« Reply #9 on: Thu, 17 February 2022, 07:47:18 »
This looks really smart, great work. It is a bit out of my price range but GLWIC x
Offline Bub
    • big bub's beepers
« Reply #10 on: Thu, 17 February 2022, 07:47:50 »
i like it
Offline dmatx1
« Reply #11 on: Thu, 17 February 2022, 07:49:03 »
Oh, finally it's happening :thumb:
Offline daintySPLASH
« Reply #12 on: Thu, 17 February 2022, 07:53:20 »
If you end up winning a raffle for the board will you be given priority when it comes to the macro pad?
Offline Peathyyy
« Reply #13 on: Thu, 17 February 2022, 07:54:54 »
Can't wait for this but wow my wallet is going to hurt
Offline Zeelobby
« Reply #14 on: Thu, 17 February 2022, 07:59:59 »
So cool to finally see this in IC. Looks great
Sent from my Pixel 3 XL using Tapatalk
Offline Alessio
    • YT Channel
« Reply #15 on: Thu, 17 February 2022, 08:00:35 »
Absolutely stunning, as a Cherry simp this board ticks of all boxes for me. Unfortunately the 65 XT layout is one thing that's holding me back personally. Beautifully presented IC  :thumb: Best of luck!
Offline snurrebassen
  • mechanical keyboard designer and enthusiast
    • Linktree
« Reply #16 on: Thu, 17 February 2022, 08:04:28 »
following  :D
Offline Aiwanei
    • ThocKeys.com
« Reply #17 on: Thu, 17 February 2022, 08:04:42 »
So excited to see the IC for this posted. Can't wait for GB, take my money.
ThocKeys.com
« Reply #18 on: Thu, 17 February 2022, 08:04:46 »
The current format I have in mind is that if you win a spot in the raffle you have the option to add the numpad to your order.
I've had a couple people already mention that they just want a numpad though, so I may reconsider this if the majority lean that way.
Offline uhugo
« Reply #19 on: Thu, 17 February 2022, 08:05:46 »
Beautiful! Take my money :eek:
Offline whirlwind
« Reply #20 on: Thu, 17 February 2022, 08:06:12 »
If you told me this board was from the 80's, I would have believed you, looks stunning. Good luck with IC!  :thumb:
Offline Jo_hannes
  • You can never learn less. You can only learn more.
« Reply #21 on: Thu, 17 February 2022, 08:07:17 »
So great to see this finally happening. I've been following this board in Discord for quite a while now - really hope I can snag one. It scratches all of my old school itches, sweet! /Johannes
Offline 7empest
  • ༼ つ ◕ ◕ ༽つ
« Reply #22 on: Thu, 17 February 2022, 08:07:26 »
So cool to finally see the IC for this! Love this project. The retro look of this board is awesome, I really dig the look! Certainly interested in getting one.
Offline Visionaire
« Reply #23 on: Thu, 17 February 2022, 08:15:27 »
FINALLY! Really love the vibe of this board.
Offline mcmcmc
« Reply #24 on: Thu, 17 February 2022, 08:22:47 »
great work. i really hope i can get one. :thumb:
Offline hottrout
  • I'd Hit Dat Key
« Reply #25 on: Thu, 17 February 2022, 08:25:39 »
Incredible job James, possible end game for me.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline jshufelt
« Reply #26 on: Thu, 17 February 2022, 08:26:54 »
I've been following this one for a while - excellent design and vintage vibe.  Good luck with the GB!
Offline Screen.jing
« Reply #27 on: Thu, 17 February 2022, 08:28:18 »
Good ass job! GLWIC
Too many projects going on at once
Papilio
MF60
Disco
Vlad
65
Adamo
Offline Enemy
« Reply #28 on: Thu, 17 February 2022, 08:30:24 »
Been waiting over 2 years for this. So excited this is finally happening.
Offline paulgali
    • SKME
« Reply #29 on: Thu, 17 February 2022, 08:32:24 »
YES
Offline Pontus
« Reply #30 on: Thu, 17 February 2022, 08:45:49 »
I love it, I’ll definitely be going for one when it runs :thumb:
Offline Seoulcialite
    • MechSeoul
« Reply #31 on: Thu, 17 February 2022, 09:21:51 »
Interested!
Offline snicket
  • Formerly lucalink
« Reply #32 on: Thu, 17 February 2022, 09:42:19 »
so cool
Offline Laur
  • Formerly dudeship
  • gmk retro runic
    • wip
« Reply #33 on: Thu, 17 February 2022, 10:02:49 »
finally, nice.
« Reply #34 on: Thu, 17 February 2022, 10:19:33 »
Updated the top comment addressing some questions so far
Offline MoarCoffeePlzzz
  • Formerly Deeptek
« Reply #35 on: Thu, 17 February 2022, 11:17:09 »
koen with the goat photos
Offline Belled
  • I like shoobs
« Reply #36 on: Thu, 17 February 2022, 11:31:09 »
Let's gooo
Offline hottrout
  • I'd Hit Dat Key
« Reply #37 on: Thu, 17 February 2022, 12:37:11 »
This has the potential to make 2022 the best keeb year ever. Thanks for the shout out, but honestly this amazing board is all you. Whatever the price ends up at, it will be acceptable as this is a level above many so called 'big name' boards that have cost more and delivered less.
Systems -
  Keyboards -
Offline JackPikatea
« Reply #38 on: Thu, 17 February 2022, 12:41:59 »
I'm way more excited for this then I thought I would. Best of luck!
Offline darthcapn
« Reply #39 on: Thu, 17 February 2022, 13:28:51 »
I love how this looks! Glwgb! Hopefully I can buy in!
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline Rik.caffeinated
« Reply #40 on: Thu, 17 February 2022, 13:45:12 »
This is so so good.
Can we get a side shot of that seam?
Offline severin
« Reply #41 on: Thu, 17 February 2022, 14:09:26 »
This is beautiful.
Offline gotgoodiez
« Reply #42 on: Thu, 17 February 2022, 14:44:27 »
Good looking board, hope I get a chance to have one!
Offline unusuaL_
« Reply #43 on: Thu, 17 February 2022, 14:45:54 »
dig the layout, glwic  :thumb:
collection: hibike 1/1, garderie tkl, casper60, hhkb pro2, matrix 2.0additional, f1-8x og
Offline andromache
« Reply #44 on: Thu, 17 February 2022, 15:04:13 »
I love this board. Red/gray colorway is <3
« Reply #45 on: Thu, 17 February 2022, 15:05:04 »
This is so so good.
There's one in the Prototype Photos section  ;) 2nd image after clicking "more"
Offline Ensaum
« Reply #46 on: Thu, 17 February 2022, 15:05:19 »
Not usually into 65% but this is hawt, damn
Offline treeleaf64
    • treeleaf64
« Reply #47 on: Thu, 17 February 2022, 16:21:55 »
Waited 2 year for this
very worth it and I love the  singular Jame and all of his fellow James
Happy time Happy time!
Everyone must pay the cat tax
Offline Ustinj
« Reply #48 on: Thu, 17 February 2022, 16:24:13 »
simply amazing
Offline Meowsaur
  • I don't like that.
« Reply #49 on: Thu, 17 February 2022, 16:29:21 »
