Author Topic: [IC] Hira70 - Aesthetic, Leafspring gasket mounted, FRL  (Read 36052 times)
Offline saab
« on: Mon, 04 July 2022, 15:33:34 »
Hira70
Hira70 is a frl tkl that features leaf spring gasket mount with a unique sand blasted brass weight. Front height of 19mm
and great aesthetics to add on to that. This board also features clacky acoustics from the brass weight.
The inspiration behind this project is "hira" which means a diamond/gem in Punjabi. Punjabi most commonly spoke in my birth place Punjab.
Hira being the main point of the board, the wide brass weight is CNCd and sand blasted that resembles a diamond.
IC Form
Discord
Specs:
Typing Angle : 7.5 degrees
Front Height : 19mm
Mounting : Poron Gasket
Layout : WKL & WK
Top & Bottom Material : Aluminium 6063
Daughter Board Cover : Polycarbonate
Weight : Sand Blasted Brass
PCB : 1.60mm
Total Build Weight : 2.15kg / 4.75lbs
Sound Test
Group Buy Details:
Price : 430$ at 100MoQ
GB Date : Till 31st March
Plate Options : Aluminium, Polycarbonate, FR4
Vendors :
US : Bolsa Supply
EU : Keygem
UK : ProtoTypist
AS : HexKeyboards
AU : MtnKbd
Prototype Pictures (by CaptainSterling):
Internal Design (Renders):
Plate Design:
Prototype Pictures:
Layout Options:
Hira70 will be available in Win Key Less and Win Key Layout.
Along with WKL and WK, Hotswap and solder PCBs will also be offered.
Top Options
Solder PCB Layouts
Hotswap PCB Layouts
Color Options:
Noir, DarkGray, Silver, Lavender
What will be included in the kit?
1x Case
1x Set of Screws
1x Set of Gaskets
1x Feet
1x Pcb
1x Daughter Board w Jst Cable
1x Carrying Case
Thank You
Hira70 has developed and improved over the year, almost being 2 years since i started working on this project. There have been multiple versions of this IC, This being the latest version.
I’ve put effort in improving renders, design, changing manufacturers and what’s most important is the feedback. The entire project has been evolving as my design skills improve,
i make changes and care how the user will view this board. I have made some changes and added additional colour after doing a poll in the discord.
After changing 3 manufacturers and Prototyping 3 different version of the Hira70.
I am extremely proud and confident to do a group buy for the Hira70, letting others enjoy the typing experience and aesthetics of this board.
All the support that I’ve gotten from my friends and people in the discord has deeply motivated me to carry on developing this. Thank you reading my Interest Check for the Hira70.
« Last Edit: Sun, 26 March 2023, 17:07:20 by saab »
Offline ankit
  • Formerly ankit-sachdeva
Re: [IC] Hira70 - FRL TKL
« Reply #1 on: Mon, 04 July 2022, 15:46:13 »
This is a cool project. Love the weight. FRL TKLs are cool. GLWIC
Offline zekth
« Reply #2 on: Mon, 04 July 2022, 16:27:07 »
FYI: discord link is dead
Offline saab
« Reply #3 on: Mon, 04 July 2022, 16:34:15 »
Thanks for letting me know, its fixed now <3
Offline saab
« Reply #4 on: Mon, 04 July 2022, 16:34:44 »
Thanks man :) Appreciate the kind words
Offline LegendsWorks
  • thocc
« Reply #5 on: Mon, 04 July 2022, 17:23:58 »
nutting so hard rn
GLWIC bby gal
Offline TjarleN
« Reply #6 on: Tue, 05 July 2022, 00:27:09 »
cool looking board, good luck with the project
Offline Lysol_
« Reply #7 on: Tue, 05 July 2022, 01:02:06 »
nice project and concept. only thing of note to me is the stab cutouts for the plate, there arent any wire cuts or clearance cuts like you usually see on plates like the jane v2 plate for example.  is there a reason for that or did you find it wasn't necessary?
Offline ZAND4
« Reply #8 on: Tue, 05 July 2022, 02:58:19 »
Love the design, yet less the format
Offline saab
« Reply #9 on: Tue, 05 July 2022, 07:37:52 »
Thanks <3, as for the format. do you mean the FRL layout?
Offline saab
« Reply #10 on: Tue, 05 July 2022, 07:40:14 »
The stab cut outs clearance are perfectly fine on all the plates I have tested, so far ive tested Tx stabs, durock stabs and cherry. none of them had any issues
Offline Ansenki
  • Keybort
« Reply #11 on: Wed, 06 July 2022, 10:12:49 »
I love frltkl’s. Really cool weight design and overall very simplistic, I dig. GLWIC  :thumb:
Offline The Japple
  • PC/Keyboard enthusiast, techy, Essentials designer
« Reply #12 on: Wed, 06 July 2022, 11:13:27 »
So, how would a half plate and hotswap pcb work? AFAIK those sockets don't really grip the switches with a ton of force, I'd be a bit worried about the switches falling out
If it ain't broke, fix it 'till it is
Offline ZAND4
« Reply #13 on: Wed, 06 July 2022, 13:06:30 »
Correct !
With it, instabuy
Offline saab
« Reply #14 on: Wed, 06 July 2022, 18:04:47 »
Half Plate is best suited for Soldered PCB and not for Hotswap pcb at all. Half Plate is really an option for people who would like a bit of bounce near the alphas region when typing with a soldered PCB. I would try my best to inform people before buying the keyboard about Hotswap and Half Plates :)
Offline saab
« Reply #15 on: Wed, 06 July 2022, 18:17:09 »
Thanks a bunch :)
Offline The Japple
« Reply #16 on: Wed, 06 July 2022, 20:26:51 »
Yes, I agree, if they're both an option it would be best to either have a very visible disclaimer about it or just not allow the purchase of a hotswap PCB/half plate configuration for a full board.
Offline Pensa73
« Reply #17 on: Thu, 07 July 2022, 12:56:37 »
Both brass weights look awesome
« Reply #18 on: Sun, 10 July 2022, 05:48:18 »
Looks dope and would fit great with my 21KB Punjabi set. Nice to see some Punjabi inspiration in the community. There are dozens of us!
Offline saab
« Reply #19 on: Sun, 10 July 2022, 17:11:06 »
Thanks man, cant believe I missed out on the keyset. Would have loved to grab in red sublegends.
Offline Hiiro_XoXo
« Reply #20 on: Sun, 10 July 2022, 21:30:22 »
weight looks sexy. wkl a possibility? posting for future updates on this board. GLWIC
Offline saab
« Reply #21 on: Mon, 11 July 2022, 06:39:43 »
Hi! WKL is confirmed :)
Getting a prototype for it soon
Offline saab
Re: [IC] Hira70 - FRL TKL (Updated Design, NEW Prototype)
« Reply #22 on: Sat, 15 October 2022, 21:41:01 »
The IC google form has been updated, if you could take your time to answer that would highly appreciated. Thank you
Offline smollchungus
Re: [IC] Hira70 - FRL TKL (New Design, NEW Proto arrived)
« Reply #23 on: Sun, 16 October 2022, 07:55:20 »
looking crisp
Offline infinitum
  • i buy expensive plastic
« Reply #24 on: Mon, 17 October 2022, 09:03:32 »
i love this weight. following
Offline gotgoodiez
« Reply #25 on: Mon, 17 October 2022, 14:31:02 »
Very clean and nice looking board. For sure interested in silver or black.
Offline Evasive
« Reply #26 on: Mon, 17 October 2022, 15:41:29 »
looks great, especially the weight design. glwic
Offline IconlabsOfficial
  • Where makers make art!
    • Iconlabs
« Reply #27 on: Tue, 18 October 2022, 01:42:13 »
The weight looks sick!
Offline crookey
« Reply #28 on: Tue, 18 October 2022, 10:33:52 »
Love the weight design.
Offline Sieglinde
« Reply #29 on: Wed, 19 October 2022, 17:29:13 »
Looks good, just not a fan of the "signature" above the arrow cluster.
Offline thocciness
« Reply #30 on: Thu, 17 November 2022, 10:34:37 »
That geometric weight design is so spicy! Big fan  :D
Offline dantambok
« Reply #31 on: Fri, 18 November 2022, 00:37:46 »
that weight looks awesome!
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
« Reply #32 on: Fri, 18 November 2022, 10:51:09 »
Totally agree. I wish the script fad would go away in keyboard design lol
But love the board otherwise. Seriously great job on the weight! If you switched the signature Hira with the text Hira that is on the inside of the weight, it'd be down for this board. Nice job  :thumb:
Offline saab
« Reply #33 on: Fri, 18 November 2022, 17:21:41 »
The option for blank top (no signature) will be given in the gb 100% <3
Ill add some renders for the blank version too.
Offline Slimey
« Reply #34 on: Sat, 19 November 2022, 22:43:38 »
Hopefully it runs soon, been meaning to pickup a board in this layout :thumb:
Offline actress
« Reply #35 on: Sun, 20 November 2022, 05:57:49 »
Beautiful design and renders. Unfortunately not a fan of mounting style, but great job and gl ^-^
Offline Rationalkeys
Re: [IC] Hira70
« Reply #36 on: Mon, 21 November 2022, 09:17:37 »
Love the weight.
Offline saab
Re: [IC] Hira70 - Aesthetic, Leafspring gasket mounted, FRL (US Vendor Announced)
« Reply #37 on: Fri, 16 December 2022, 19:07:20 »
Geekhack update:
US vendor is decided.
Waiting for UK vendor, alongside renders have been updated and improved upon.
Offline VXQN
« Reply #38 on: Tue, 20 December 2022, 07:17:49 »
Board looks absolutely lovely, seriously considering it but not sure what colour I would get...
Would you care to explain what the "frame" around the weight is?
Offline saab
« Reply #39 on: Tue, 20 December 2022, 10:58:46 »
Thanks alot for the kind words. The polycarbonate frame around the weight is to cover the daughter board, so its mostly hidden. I chose PC because of acoustic reasons, i have been thinking of releasing the file of the cover once gb is done. so people can experiment with different materials. Stainless Steel, brass, copper etc.
Offline ttonk
« Reply #40 on: Sat, 24 December 2022, 08:18:25 »
I love the weight. what other materials are you going to offer?
Offline VXQN
Through sheer chance I found out that this is actually live! Wanna maybe update this post? Make GB post?
Offline Lewis_Lyron
It seems that this style is very popular recent days.
eat an enter
Offline SE7EN_ate_NINE
« Reply #43 on: Mon, 06 March 2023, 08:01:12 »
Where is this option on the Bolsa site? Wanted to order one but don't see a way to choose no logo.
Offline Sieglinde
« Reply #44 on: Wed, 08 March 2023, 11:02:16 »
Given the OP hasnt given updates then that option was most likely dropped. I was interested but only without the signature.
Offline Rilow
Will plate files be released?
Offline saab
« Reply #46 on: Wed, 15 March 2023, 03:10:32 »
Hey, Apologies for this. As a designer i wanted to give the buyers freedom to choose different top options for the engraving but from a vendor view it’s too much hassle and logistical annoyance. Unfortunately it’s no longer an option. Also the plate files will be released for those who want to get it a different material, edit it etc.
