Poll
What type of options are you interested in?
lternate Orange G & H keys
25 (10.4%)
range GeekHack Key
44 (18.3%)
lternate Orange WASD keys
43 (17.8%)
lternate Control/Capslock key
43 (17.8%)
lternate OS Key(meta)
58 (24.1%)
nternational Keys(Specify in thread)
11 (4.6%)
eys for other keyboards(Specify in thread)
11 (4.6%)
ther(Specify in thread)
6 (2.5%)
Total Members Voted: 113
Author Topic: 104 US ANSI Double shot replacements for Filco Order  (Read 365374 times)
Offline AndrewZorn
« Reply #950 on: Mon, 13 December 2010, 00:32:17 »
I know the Leopold stabilizers are different than a Filco, but are the keys the same?
I would love to buy some doubleshots if so, and man oh man, with proper Ctrl/Caps flip and Meta keys... they would be perfect.
Offline WhiteRice
« Reply #951 on: Mon, 13 December 2010, 00:35:46 »
If they are similar to the cherry stabilizers then yes. Ducky 1087s use cherry stabilizers and my keys fit fine.
Offline sixty
    • http://deskthority.net
« Reply #952 on: Mon, 13 December 2010, 00:54:13 »
They will fit fine, but won't fit the spacebar, which kinda instantly ruins the colorscheme.
Offline Moogle Stiltzkin
« Reply #953 on: Mon, 13 December 2010, 04:46:41 »
The spacebar should fit both ducky and leopold since the cross points match.
It is the cherry keyboards that won't fit because the spacebar crosspoint is slightly off center.
Royal Kludge discount code:
Lowyat15
15 USD discount.
Offline sixty
« Reply #954 on: Mon, 13 December 2010, 04:56:18 »
Quote from: Moogle Stiltzkin;262124
Until you actually get a mechanical keyboard, please stop talking about stuff you do not have the slightest clue about.
Ducky will fit, Cherry will fit (g80-3000 winkey, g80-1800 winkey) since the Korean guys who originally ordered the set that we cloned designed it to fit both the Filco and Cherry.
Leopold does not fit because it uses an entirely differently aligned spacebar, because it is made by an entirely different OEM.
« Last Edit: Mon, 13 December 2010, 04:59:27 by sixty »
Offline laden3
« Reply #955 on: Mon, 13 December 2010, 05:19:49 »
the stabilizers are nearer to the switch? btw, are the keys pbt? I couldn't find any clue abt them talking abt the material used for their keycaps. I am assuming that if they use pbt, they will talk abt it.
I rrrove brrracks.
Offline sixty
« Reply #956 on: Mon, 13 December 2010, 05:39:19 »
Quote from: laden3;262129
Yes, thats right. Cross-Stabilizers are closer to the switch, leaving more space on each side of the spacebar.
Offline laden3
« Reply #957 on: Mon, 13 December 2010, 05:44:10 »
what abt the keys...ima assume they r abs ^^
I rrrove brrracks.
Offline sixty
« Reply #958 on: Mon, 13 December 2010, 05:47:49 »
Quote from: laden3;262139
Yeah, its ABS. I originally assumed PBT, but had corrected it later after I had received confirmation from my contact.
« Reply #959 on: Mon, 13 December 2010, 06:29:21 »
Quote from: sixty;262125
Well just cause i dont have one yet doesn't mean i don't know some stuff i've read about.
"So long as we do not depend on the facts entirely, incomplete knowledge is better than complete ignorance."
Sorry if i can't get 100% facts straight sometimes; i'm still learning. Like everything on the internet take with a grain of salt :/ But it's distasteful how you seem to think that your the sole authority on mech keyboard just cause you own some :/ let others have their own assumptions; and yes i'll gladly learn from my mistakes. But i can do without your condescending tone thank you very much your lordship.
I checked the underside of the gh set and there seems to be an extra cross point off center. So you might be right. Careless mistake on my part.
This i was not aware of. But honest mistake seeing as how leopold and ducky look very similar don't they. I am aware that some keyboards have longer and shorter spacebars; but i thought ducky spacebar is the norm size and standard ?
« Last Edit: Mon, 13 December 2010, 10:15:41 by Moogle Stiltzkin »
Lowyat15
15 USD discount.
Offline sixty
« Reply #960 on: Mon, 13 December 2010, 07:46:40 »
Quote from: Moogle Stiltzkin;262155
Well just cause i dont have one yet doesn't mean i don't know some stuff i've read about. You'd be a fool to ignore that even if some stuff are half truths. Sorry if i can't get 100% facts straight sometimes; i'm still learning. Like everything on the internet take with a grain of salt :/ But it's distasteful how you seem to think that your the sole authority on mech keyboard just cause you own some :/ let others have their own assumptions; and yes i'll gladly learn from my mistakes. But i can do without your condescending tone thank you very much your lordship.
Didn't really mean to be that offensive, apologies. However, I don't think its a good idea to spread half-truths and total guesses though. Especially not when questions have been answered correctly several times in several threads including this very one (including once just two posts before your post), for example by people posting pictures of them working fine on Cherry keyboards and elsewhere of people reporting the spacebar not to work on the Leopold board.
Knowledge is not about the amount of keyboards you own, some of the most knowledgeable people on this board barely own a few. But if you want to learn and gain knowledge you should at least bother to invest some time researching (or in this case, even only scrolling back a few posts) instead of mindlessly spreading wrong info.
You just happened to be in the target of my monday-morning-rage. Apologies again.
Offline squarebox
  • In Omnia Paratus
« Reply #961 on: Mon, 13 December 2010, 08:55:53 »
My G80-3494
Filco Yellow Edition  | Filco Brown | Filco 2 Brown TKL | G80-1950 | G80-3494 | G80-11900 | Leopold FC500R | Noppoo Choc Mini
« Reply #962 on: Mon, 13 December 2010, 09:09:19 »
Quote from: sixty;262171
If it wasn't your intention then i believe you.
You must forgive me because part of my thought process is conjectures and yes i have a habit of speaking them out.
But this to me is good cause then you or others can correct me then i can learn something :X
I'll try to keep it at minimum :/ (but don't expect miracles)
Anyway :X like squarebox showed in his pics the cherry keyboard does support it.
That looks seriously sexy :d
Lowyat15
15 USD discount.
« Reply #963 on: Mon, 13 December 2010, 09:16:14 »
Quote from: ripster;262221
Actually I have spent a lot of time Moogle correcting your false statements.
Chill with the speculation dude.  Even MW at 4000+ posts at least owns a couple of mechanical keyboards.
This isn't OCN.
bad news. Seems Walrus has said the keyboard has been delayed for another week :rip:
This isn't OCN.
Funny because i saw on  a few occasions you kept saying Topre was nKRO. technically it is but functionally it doesn't because you need to mod to get it to work so i am told. So you too are spreading misconceptions which i helped to correct :/
« Last Edit: Mon, 13 December 2010, 09:32:32 by Moogle Stiltzkin »
Lowyat15
15 USD discount.
Offline itlnstln
« Reply #964 on: Mon, 13 December 2010, 09:38:30 »
Moogle's new avatar reminds me of
Offline RoboKrikit
« Reply #965 on: Mon, 13 December 2010, 10:47:08 »
Careful, that music is contagious.
Lovely day for a GUINNESS
Offline armenws
« Reply #966 on: Mon, 13 December 2010, 20:53:46 »
looking forward to the next batch of these.
« Reply #967 on: Tue, 14 December 2010, 03:42:08 »
Quote from: armenws;262615
Panda is working on it but most likely won't be the same :X
http://geekhack.org/showthread.php?t=12682
Lowyat15
15 USD discount.
Offline armenws
« Reply #968 on: Wed, 16 February 2011, 20:33:28 »
Just to clarify - is this buy to order This:
If not, where can I get the set in the pic??
Offline keyboardlover
« Reply #969 on: Wed, 16 February 2011, 20:36:35 »
Those were from a group buy that came and went. We are doing a new version now so hurry up and send in your vote/order. The color scheme is the same on the standard set in said group buy.
Offline armenws
« Reply #970 on: Wed, 16 February 2011, 21:07:43 »
thanks
« Reply #971 on: Wed, 16 February 2011, 21:22:42 »
You're welcome!
Offline AgentZen
« Reply #972 on: Sun, 06 November 2011, 22:14:34 »
Where can I get a set of keys like this for my Filco? That group buy 4 thread is so confusing to me :(
KUL ES-87 w/ Clears (GMK Hyperfuse) | Working on: Custom 60% w/ 65g feelios (BSP blanks)
Offline RColinTaylor
« Reply #973 on: Sun, 06 November 2011, 22:16:36 »
Quote from: brsp25;447066
There is a RD4 for Dummies wiki within the RD4 Wiki.
I like my Browns more than my Blues.
« Reply #974 on: Sun, 06 November 2011, 22:23:21 »
that specific set?
ROUND3/STANDARD
email youremailhere@email
send that to 7bit_R4
Offline AgentZen
« Reply #975 on: Sun, 06 November 2011, 22:28:22 »
Quote from: demik;447072
that specific set?
ROUND3/STANDARD
I'm gonna give that a shot thank you!!
« Reply #976 on: Sun, 06 November 2011, 22:30:05 »
np
« Reply #977 on: Sun, 06 November 2011, 22:31:56 »
Remember that Round3/Standard does NOT come with a spacebar.
Offline AgentZen
« Reply #978 on: Sun, 06 November 2011, 22:38:19 »
Hmm I'll have to go through and read the round 4 wiki again. Any suggestions on what I should do for a space bar that matches? Also should I get like a confirmation email after sending this PM to 7bit_r4
« Reply #979 on: Sun, 06 November 2011, 22:46:51 »
Quote from: brsp25;447079
Well theres different size spacebars for each keyboard. If you have a Filco, I think its just RD3/Spacebar/Filco or something like that. There is still a design in the works/background that encompasses several spacebars but that is up to 7bit to include later.
« Reply #980 on: Sun, 06 November 2011, 22:47:44 »
ROUND3/SPACE
or
ROUND3/SPACELEO if u need one for a leopold
and sometimes it takes awhile to get the email, just hang tight
Offline AgentZen
« Reply #981 on: Sun, 06 November 2011, 23:01:03 »
Thanks for your help.
Offline PointyFox
« Reply #982 on: Sat, 16 June 2012, 23:58:03 »
I want these :O
