Poll
What type of options are you interested in?
lternate Orange G & H keys
25 (10.4%)
range GeekHack Key
44 (18.3%)
lternate Orange WASD keys
43 (17.8%)
lternate Control/Capslock key
43 (17.8%)
lternate OS Key(meta)
58 (24.1%)
nternational Keys(Specify in thread)
11 (4.6%)
eys for other keyboards(Specify in thread)
11 (4.6%)
ther(Specify in thread)
6 (2.5%)
Total Members Voted: 113
Author Topic: 104 US ANSI Double shot replacements for Filco Order  (Read 365553 times)
Offline Lanx
« Reply #750 on: Mon, 15 November 2010, 14:50:27 »
Quote from: keyboardlover;247114
Well I received confirmation that mine arrived today...can't wait to see them! Still haven't decided on selling them or buying a new keyboard for them yet though...
aren't you a topre guy?
Offline keyboardlover
« Reply #751 on: Mon, 15 November 2010, 14:52:25 »
Yea that's the only thing...I'm having a hard time justifying buying a Filco since I previously owned one and didn't love it.
Offline muchadoaboutnothing
« Reply #752 on: Mon, 15 November 2010, 14:55:25 »
Personally, I'd sell them, unless you're adept, have a lot of time, and can somehow modify them to fit a Torpe, which I'm kind of doubting. Not the first two parts, the last part.
Offline Phaedrus2129
« Reply #753 on: Mon, 15 November 2010, 14:55:33 »
Quote from: ripster;247123
The keys can make nifty fridge magnets.
I now know what to do with that last MY7000. :) Thank you ripster.
Now to buy a bunch of 1/4" fridge magnets and some Gorilla glue.
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline Lanx
« Reply #754 on: Mon, 15 November 2010, 14:57:54 »
gorilla glue is something fierce and awesome! I always look for the gorilla now when i need something in that section and look for the mad monkey first. Oh i wonder if i have a need for gorilla tape?
« Reply #755 on: Mon, 15 November 2010, 15:04:12 »
I'm also considering getting something (probably a Filco) for the new keycaps but either giving it away as a gift or keeping it around as an extra keyboard.
Edit: the gift idea was for my dad - he's a writer so he types a lot. He types on his Macbook Pro (which has a decent scissor switch keyboard that he likes already) though, so I'm not sure that it'd be necessary...
Decisions decision!
« Last Edit: Mon, 15 November 2010, 15:14:24 by keyboardlover »
Offline Lanx
« Reply #756 on: Mon, 15 November 2010, 15:13:56 »
i think you'll just get a few propositions to buy your unused set soon heh.
btw i'm starting to notice the little molding things holding the keycaps were cut off pretty novice like, at least from someone who has played with modeling sets in the past these molds were snipped off by a noob!
Offline ironman31
« Reply #757 on: Mon, 15 November 2010, 15:15:02 »
Just buy another realforce, lol.
Keyboards:
IBM Model M Space Saving Keyboard (Used), HHKB Pro 2 (White, Lettered), Realforce 87U all-45g in White, Filco Majestouch 2 TKL with Cherry MX Browns, Model F PC/AT,  Noppoo Choc Mini (MX Browns), Model F XT, IBM Model M 1397735 (bought NIB), (2) Siig Minitouch (GHSS) one with XM, one with complicated ALPs (modded),2 Dell AT101W, Cherry G80-11900HRMUS (modded with MX browns)
Pointing Devices:
« Reply #758 on: Mon, 15 November 2010, 15:16:02 »
Lol...but I don't need another keyboard...
Offline Lanx
« Reply #759 on: Mon, 15 November 2010, 15:23:09 »
it was probably all about the coloring, the orange keys hide the marks well and the darker keys does a good job too.
Offline TexasFlood
« Reply #760 on: Mon, 15 November 2010, 15:26:50 »
Quote from: Lanx;247128
It's pretty good.  Not as good as 100 mile an hour tape, but nothing much is.  My only complaint is I taped up an old vacuum hose with 100 mile an hour tape and then patched it with gorilla tape when I couldn't find the 100mah roll.  The gorilla tape got gooey and separated after a while, something the 100mah tape never does.
Offline Lanx
« Reply #761 on: Mon, 15 November 2010, 15:29:17 »
Quote from: TexasFlood;247161
i will use either this 100m tape or gorilla tape to fix my dyson hose on my next trip to harbor freight, sir!
Offline Lanx
« Reply #762 on: Mon, 15 November 2010, 15:33:20 »
Quote from: ripster;247167
A hose you want to use silicone self fusing tape.  Amazing stuff.
this?
http://www.amazon.com/RESCUE-Self-Fusing-Silicone-Tape-BLACK/dp/B000ZTK6CI
what's the difference between the self fusing and gorrila tape? or does it like do some chemical bond thing?
Offline TexasFlood
« Reply #763 on: Mon, 15 November 2010, 15:34:47 »
Quote from: Lanx;247165
I haven't used the silicone self fusing tape but it sounds like something you might want to consider Lanx.
Offline WhiteRice
« Reply #764 on: Mon, 15 November 2010, 15:50:05 »
Quote from: ripster;247172
Link
That stuff saved me once when during a party a pipe burst.
Offline ironman31
« Reply #765 on: Mon, 15 November 2010, 16:38:16 »
Question about the stabilizer keys: the white pieces fit very loosely (and sometimes so loosely they fall out when turned upside down) in the new key caps. Is there a simple solution to keep them snug inside the key short of gluing them in there?
Keyboards:
Pointing Devices:
Offline RoboKrikit
« Reply #766 on: Mon, 15 November 2010, 16:57:55 »
Quote from: ironman31;247217
I have this same issue; just tested the right shift key and the stabilizer inserts are basically falling out, such that if I don't hit the key dead center it doesn't press down.  I'm thinking of gluing them in, but I'm not sure where to get replacements for the original keys if I need them.
Edit: space bar inserts went in fine, btw.
Lovely day for a GUINNESS
Offline RoboKrikit
« Reply #767 on: Mon, 15 November 2010, 17:13:19 »
Cool, thanks for the tip. I'll have to pick some up tonight.
Offline sixty
    • http://deskthority.net
« Reply #768 on: Mon, 15 November 2010, 17:13:45 »
Don't ruin your keys by permanently glueing the stabilizer in.
Scarface recommended this for his SF Metal keys, it works fine for Cherry keys on Filco too:
Use two or even three layers if you must, until it fits tight.
Edit: Obviously apply it to the stabilizer stem, not the keystem for stabilizers.
Offline phate408
« Reply #769 on: Mon, 15 November 2010, 18:11:18 »
Received, installed, and awesome. Thanks for all your work WhiteRice.
-Das Keyboard Model S Professional Silent
-IBM Model M 82G2383 (Lexmark 1996)
-Compaq MX 11800
Offline nanu
    • http://T-T.be/portal
« Reply #770 on: Mon, 15 November 2010, 18:26:23 »
Quote from: phate408;247255
+1
Offline Kaishi
« Reply #771 on: Mon, 15 November 2010, 18:47:03 »
I just wrapped up the installation of the keyset on my RK-9000.  The stabilizers were a little tricky but the tape trick suggested above worked wonders.  I'm so satisfied.
Thanks again all.
Offline ironman31
« Reply #772 on: Mon, 15 November 2010, 19:26:23 »
Yeah, thanks sixty for bringing up the tape mod. I found that the red geekhack key looks better with this color scheme imo. And does anyone else think the spacebar is abnormally sharp?
Keyboards:
Pointing Devices:
« Reply #773 on: Mon, 15 November 2010, 19:49:47 »
Interesting to hear about these issues...did anyone install these without having to use mods? If so, on what keyboards?
Offline didjamatic
« Reply #774 on: Mon, 15 November 2010, 19:52:46 »
Got mine, woo hoo!!!
Offline Lanx
« Reply #775 on: Mon, 15 November 2010, 20:19:40 »
Quote from: ironman31;247273
i feel the same way actually and i think i'm going back with my old spacebar.
Offline ironman31
« Reply #776 on: Mon, 15 November 2010, 20:26:05 »
Quote from: Lanx;247295
I seems like the signature plastics key profile is made for a keyboard with taller legs than a filco.
Keyboards:
Pointing Devices:
« Reply #777 on: Mon, 15 November 2010, 20:35:28 »
I'm actually really liking the new spacebar, but perhaps that's just me.
Offline bitmap
« Reply #778 on: Mon, 15 November 2010, 20:43:24 »
Whoo! Just arrived. Pics soon.
Offline ironman31
« Reply #779 on: Mon, 15 November 2010, 20:51:57 »
Quote from: muchadoaboutnothing;247300
I'm pretty sure it's because I normally hit the space bar right at the edge. I guess I'll just change my typing habits once again..
Keyboards:
Pointing Devices:
« Reply #780 on: Mon, 15 November 2010, 20:54:16 »
Can't you just take some fine-grained sandpaper to it and smooth it out?
Offline Tr0j4nM4x1mus
« Reply #781 on: Mon, 15 November 2010, 21:00:41 »
got the keys today.... Thank you again
Keyboards - 4 Cherry G80-3000lscrc-2 (two with black DS keys one with black & white DS keys)
HHKB Professional white
2 ABS M1 (modded with complicated alps one with pinks & one with rubber bumper whites)
2 IBM Model M\'s one 89 & one 97
Dell AT-101W black (modded with rubber bumper whites- M1 keys)
Focus FK2001 with cover
Focus FK2000 with cover
Unicomp Model M black mighty mouse
Cherry G84-4100 white
Looking For - Compaq G80-1838
Offline ironman31
« Reply #782 on: Mon, 15 November 2010, 21:03:31 »
Quote from: Phaedrus2129;247315
To smooth it down that much you'd have to take off most of the corner wall, which would probably make that part of the spacebar quite thin. I could be wrong, but I'm not going to try it and find out :P.
Keyboards:
Pointing Devices:
Offline WhiteRice
« Reply #783 on: Mon, 15 November 2010, 21:11:52 »
Quote from: keyboardlover;247286
Everything works fine on my ducky. It uses cherry style stabilizers.
Offline Lanx
« Reply #784 on: Mon, 15 November 2010, 21:21:22 »
Aside from the fact that my board is custom, otherwise everything fit pretty much like standard.
Offline Hak Foo
  • Make America Clicky Again!
« Reply #785 on: Mon, 15 November 2010, 21:25:16 »
Quote from: WhiteRice;247328
They fit great on a G80-3000.
Thanks for including the stepped key.
The retro look really blends well.
Overton130, Box Pale Blues.
Offline mrbill
    • http://weblog.mrbill.net
« Reply #786 on: Mon, 15 November 2010, 21:28:34 »
Worked great here on a tenkeyless Filco.  My Backspace key feels a bit "muted" somehow, although I've checked it twice - but everything works fine once I get used to the slightly different key profile.
Keyboards:
IBM Model Ms: 51G8572 (\'94, \'96), 1391401 (\'90), 1369050 (\'95, Dell), 1394946 (\'89 Industrial)
Unicomp Model Ms:  Customizer 104, SpaceSaver 104
Chicony: KB-5181, KB-5191
Cherry:  MX11800 (x2), G86-6241 "Ricercar SPOS"
Filco: FKBN87M/EB x2, Cherry Browns
Sold: Matias Tactile Pro 1.0 (x2), Kensington Studioboard Mechanical, Scorpius M10, AEK II (x2), Compaq 11900 (x2), IBM Model F (AT), Filco FKB104MC/EB
Available Free for Cost of Shipping: ABS M1, Solidtek KB-6600ABU, KeyTronic KB101Plus
Offline jaynoon
« Reply #787 on: Mon, 15 November 2010, 23:02:06 »
I would be happy to buy the set from you if you decide to sell.
Home: Filco Tenkeyless Brown | Work: KBC Poker w/ Reds | Laptop: MacBook Air Keyboard
Offline Fwiffo
« Reply #788 on: Mon, 15 November 2010, 23:24:07 »
The sound on my Filco is pretty radically different; the keys are much thinner/lighter. On the other hand, I actually think I like the lower profile. Seems like it's more efficient without giving up anything.
Haven't installed the whole set yet; not sure if I want it at home or at work.
You can call me... Keyboard Otaku... or not quite...
Offline jnsjr
« Reply #789 on: Mon, 15 November 2010, 23:51:34 »
Here are some blurry cell phone pics!  I agree with the other posts that the spacebar is a bit sharper, and I had a hell of a time getting my backspace on because the stablilizers did not really fit.  I have not noticed too much of a sound difference.  The keys feel really nice!
Current Keyboards
Unicomp Space Saver (white) ~ HHKB2 ~ White Filco Red Cherry Limited Edition (Imsto Grey on White PBT + Group 3 keys + Awry keys)  ~ Realforce 87U 45g + Realforce 87U Variable + Realforce Numpad :biggrin1:+ MJ2 White Blue Cherry 87key
Keycaps
ClickClack Red Eye Skull *(2)* *(3)* *(4)*~ Black Eye Skull *(2)* *(3)* ~ Closeup ~  Topre WASD (Thanks Yak & DB!)
WTT & WTS
WTS White Filco Red Cherry Limited Edition (still deciding!)
Sold ~ Filco Blue Cherry; Majestouch 104 nonprinted keycaps; Noppoo Choco Mini 茶轴 (brown switches);  Topre 87u Variable ; Topre 87u 55g ; MY7000 Doubleshots ; Round 1 Doubleshots
[/FONT]
[SIGPIC][/SIGPIC]
Offline Fwiffo
« Reply #790 on: Mon, 15 November 2010, 23:55:17 »
Is the tenkeyless filco the most popular keyboard on the forums after the Model M? It seems like everybody has at least one, usually two.
woody
  •  Guest
« Reply #791 on: Tue, 16 November 2010, 04:07:09 »
Tenkeyless Filco is da bomb. Availability! If Diatec ever release double piece keycaps with quality as good as the rest of the keyboard, that'll be the keyboard to end them all. (For those with fine taste, of course)
Offline itlnstln
« Reply #792 on: Tue, 16 November 2010, 07:41:33 »
Old school all the way:
These keys are awesome, I really like the texture.  They are a little noisier than the stock Cherry ones, though.
Offline Kaishi
« Reply #793 on: Tue, 16 November 2010, 09:25:31 »
Quote from: itlnstln;247439
Agreed.  I love the look of your keyboard :cool:
I actually prefer the sound, key height, and key profile of these Signature Plastics keys over the stock keys from my Rosewill RK-9000.  More than that though, I prefer the sharpness and feel (really, lack thereof) of the legends on these new ones.  Aesthetically, they rub me the right way.
Offline sealcouch
« Reply #794 on: Tue, 16 November 2010, 10:45:12 »
I received my keys but I had them sent to my home address not my college address. Also, I have nothing to put the keys in at this point because I was going to order a Filco brown tenkeyless. Piss.
Offline mike
« Reply #795 on: Tue, 16 November 2010, 14:46:07 »
I had a bit of a surprise waiting in for a structural surveyor ... I wasn't expecting them to arrive so quickly. Saved me a trip to the post office ...
I don't know if it's just me, but the texture is reminiscent of the Unicomp keys ?
My pink highlights are no longer quite so in your face :-
And thanks to WhiteRice!
Keyboards: Unicomp UB40T56 with JP3 removed, Unicomp UB4044A, Filco Tenkeyless Brown (with pink highlights), Access AKE1223231, IBM DisplayWriter, Das Keyboard III, and a few others.
Offline celery
« Reply #796 on: Tue, 16 November 2010, 15:32:55 »
Installed mine last night. Thanks, WhiteRice!
The stabilizer inserts fit tightly into the spacebar, but the rest were fairly loose. I installed them without any tape or other mods anyway, and they seem to work okay. Might give that a shot if I run into problems later.
Offline RoboKrikit
« Reply #797 on: Tue, 16 November 2010, 16:29:28 »
I'm really liking these so far. The texture is great, and I like the lower profile of the keys.
I want a keyboard roof to keep the dust off.  Elitekeyboards is sold out. :/
Offline WhiteRice
« Reply #798 on: Tue, 16 November 2010, 17:27:55 »
Wow nice photos! I'd like to show these webwit on OCN and then see what he has to say.
Offline bakageta
« Reply #799 on: Tue, 16 November 2010, 17:31:23 »
He had nothing positive to say... Something about these being comparable to a child's toy... :P
http://www.overclock.net/11342498-post9.html
