Author Topic: [IC] LINE FRIENDS TKL  (Read 24847 times)
Offline minokeys
« on: Mon, 24 April 2023, 11:34:29 »
LINE FRIENDS TKL
The LINE FRIENDS TKL is an official licensed keyboard designed by JJW for Mino Keys
IC Form
Discord
What is LINE FRIENDS?
PANGYO, MOON, CHOCO, CONY, EDWARD, SALLY, BROWN, BOSS, LEONARD, JESSICA, JAMES
LINE FRIENDS is a global character brand that originally started with the Original Characters lineup including BROWN, CONY, and SALLY, created for use as stickers for leading mobile messenger app LINE and its 200 million active users worldwide.
Specs
Layout: F12 TKL, WKL or WK
Mounting: Friction Fit O-Ring Mount or Top Mount-Burger Mount
Top & Bottom Material: Aluminum 6063
Bottom Weight: Sandblasted Stainless Steel
Accent Weight: Polished Stainless Steel
Dimensions: Approx. 364mm x 136mm x 34mm  (L x W x H)
Weight Unbuilt: Approx. 4.1lbs
Typing Angle: 7 Degrees
EKH: 22.35mm
Plate Options: Aluminum, Aluminum Half Plate, PC, PC Half Plate, Polypropylene
PCB Layout
Layout will be available in WKL and WK
Fixed Tsangan Bottom Row
PCB Thickness: 1.6 mm
Soldered & Hotswap available
QMK and VIA available
Solder PCB Layout
Hotswap Layout
Colours
Purple, Pink, Blue, Silver
Adding:
BROWN Edition with Brass weight
Forest Green - if there is enough demand
GB Info
Sale Date: May 1 - May 19, 2023
Format: Limited GB
Price: Starting from $570 USD
Region: Exclusive to North America: Canada & USA
Where to purchase: https://minokeys.com/collections/line-friends
Kit includes: Keyboard, Full Aluminum Plate, PCB of choice, Daughterboard, Custom LINE FRIENDS carrying case, Microfiber Cloth, 50A O-Ring
Media
Build Streams:
Typing Tests:
Taeha - H1's on full Aluminum plate
Taeha Types
Lulzthax - Oil Kings on PC Half Plate
Lulzthax: Modifiers - O ring mount
Lulzthax: Alphas - O-ring mount
Lulzthax: Modifiers - Burger mount
Lulzthax: Alphas - Burger mount
More Photos:
edit: 4/28 - added keyboard dimensions, weight, front height, PCB compatibility
edit: 4/29 - added polypropylene plate option
« Last Edit: Sat, 29 April 2023, 07:52:40 by minokeys »
Offline minokeys
Re: [IC] LINE FRIENDS TKL
« Reply #1 on: Mon, 24 April 2023, 11:34:58 »
reserved
Online o3okevin
« Reply #2 on: Mon, 24 April 2023, 11:46:13 »
first also poggers
Offline irithyll
« Reply #3 on: Mon, 24 April 2023, 11:49:11 »
Nice colors.
GLWIC!
Offline ligongduck
« Reply #4 on: Mon, 24 April 2023, 11:51:38 »
Reserved
Offline Zyrophr
  • https://zyrophr.com
    • zyrophr.com
« Reply #5 on: Mon, 24 April 2023, 12:19:27 »
need
French keyboard streamer
Offline 0hh.Hello
« Reply #6 on: Mon, 24 April 2023, 13:34:06 »
I filled out the IC. I really hope the pink stays that rose gold color 🤩
Offline synthetics
  • very cool
« Reply #7 on: Mon, 24 April 2023, 18:01:48 »
very cute! like the look, seems like a banger, price feels a little steep but i guess it's not terrible for what it is.
glwic <3
Offline BlivionIaG
« Reply #8 on: Mon, 24 April 2023, 19:20:47 »
Brown ano lobby, pls make it happen !
Offline DanHamJunKie
« Reply #9 on: Mon, 24 April 2023, 21:54:33 »
Would there be any engraving difference for any of the other characters? Say.. Cony?
Offline stidal
  • milo#3939
« Reply #10 on: Mon, 24 April 2023, 21:58:17 »
not a want but a need
transition tkl // aksara ce // bully // valhalla // voyager // rs60 // adiuvare // ciel60 // jules // prime e // ut47.2 // sequence // bumper // q1 // gaff60
Offline uigofermagic
« Reply #11 on: Tue, 25 April 2023, 02:53:26 »
Very happy that the project managed to get license from Line! I hope everyone who is interested can get it !
Offline aa212121
« Reply #12 on: Tue, 25 April 2023, 04:16:35 »
Would be nice to show mounting renders, bottom of keyboard pic, full top view, keyboard total weight, keyboard weights - both bottom and accent, front height, usb pic+location, pcb fit/layout compatibility(h87? cuz this doesnt have ISO), pcb led support and unit count for a 570$ keyboard on this geekhack IC has-a-GB-date post without having to go through 5 hour stream vods thank you.
Thank you for adding most of this info in the OP and photo of internals.
« Last Edit: Sat, 29 April 2023, 06:50:03 by aa212121 »
Offline LMarci
« Reply #13 on: Tue, 25 April 2023, 19:43:10 »
Nice board but the gb is in 5 days so this isn't really an ic post. Also pretty light on info, would like some pics/renders of the internals, front height and etc.
Offline tactilesbad
« Reply #14 on: Thu, 27 April 2023, 05:27:59 »
this "IC" is missing:
-height/weight data
-mount details
-pcb compatibility details
-unit cap/count
-projected fulfillment date/period
what we know is it's gonna be geolocked, priced similarly to instock equivalents and the GB is already scheduled and ready to run (making this not an IC at all).
while I love the designer's work and the inspiration/licensing, the whole presentation is absolutely not it.
Offline minokeys
« Reply #15 on: Fri, 28 April 2023, 21:39:33 »
Thank you all for your feedback and apologies on the lack of information for the IC. I've made updates per your requests.
Unfortunately not. This will only have the BROWN engraving.
Some of the images were hidden, but "show more" has now been removed.
Unbuilt weight is approx 4.1 lbs. Front height is ~22.35mm.
USB is center located. Keyboard is compatible with H87a North Facing. PCB will have Caps and Scroll LED support.
photo of internal: https://imgur.com/dQcFCAe
updated post with more information
-height/weight data - info added
-mount details - o-ring friction fitted, mounted to the bottom case or top mount burger mount
-pcb compatibility details - H87A North facing compatible
-unit cap/count - No set limit, but will be capped once we think that our team cannot handle the number to QC and fulfillment
-projected fulfillment date/period - aiming to fulfill before the end of the year
Offline cottonnykitten
  • Checking out the click-clacks
« Reply #16 on: Sun, 30 April 2023, 22:12:43 »
What does the brown edition with brass plate look like? Also what kind of space bars does it accept? is it only 6.25? I can't tell but I'm going to assume there's no RGB right?
Like the other posters said, it would be awesome if cony was an optional engraving.
Offline minokeys
« Reply #17 on: Mon, 01 May 2023, 09:28:36 »
We do not have a proto of the brown anodization, but you can see the ano sample chips here
It does not have a brass plate, but a brass bottom weight.
The LINE FRIENDS PCB is fixed to 7U spacebar, but is compatible with H87A North Facing if you wanted to 6.25U compatibility. It will not have any RGB.
This will only have the BROWN engraving option.
Offline herfalerf
« Reply #18 on: Mon, 01 May 2023, 12:49:03 »
why an NA only board based on IP of a product that isn't used by people in NA?  fwiw i had never heard of this company until this gb.  seems like the wrong target market for the theme.
Offline Popopo
« Reply #19 on: Mon, 01 May 2023, 15:32:40 »
Cute board :thumb:
Offline moonsearch
    • Visit our website
« Reply #20 on: Fri, 05 May 2023, 12:02:19 »
cute engravings
Offline Evasive
« Reply #21 on: Fri, 05 May 2023, 16:40:48 »
cute board but yea as an American I never heard of line before this
