Author Topic: [IC] KAM Sewing Tin 🍪 GB live!  (Read 74958 times)
Offline minicap
« on: Wed, 19 May 2021, 20:51:07 »
group buy thread now live!
A tin of butter cookies! You lift the lid, but there are no cookies to be found: only pins, needles, and thread...
IC Form
https://forms.gle/V39KKPk1PD8R4pAb7
Website
https://kamsewingtin.com
Update (October 25th): Pricing!
Base kits are only $79 USD!
Also added new renders on the Absinthe, as well as previews of the THOK and Cookie Cables collabs and artisan box pricing.
See latest post for image with keycap samples!
About
KAM Sewing Tin is a novelty-heavy keycap set inspired by cookie tins filled with sewing supplies.
I’m a big fan of butter cookies (the swirly ones are the best), and I also love to sew.
The original idea I had was a sewing-themed set with all sorts of sewing tools. When thinking about the
colour scheme, I remembered the classic blue Danish butter cookie tin, and decided to combine the themes.
This is my first keyset design, I'm really excited to share it with you all and to refine it with your feedback!
GB will run from November 9th to December 9th!
Profile: KAM
Material: Dye-sublimated PBT with matte finish
Manufacturer: Keyreative
Vendors
US: Vala Supply
CA: Ashkeebs
CN: zFrontier
EU: mykeyboard.eu
UK: proto[Typist]
OCE: SwitchKeys
SEA: Zion Studios
Renders
J-02 by ProtoTypist
Mixed base kit, Cookie Parade deskmat
Absinthe by /u/velvetjaguar and /u/reggatronics
Alphas + TKL text mods (note: fj should be homing)
Fuji65 by CMM.Studio
Novelty base kit, Alternate numrow kit, Yellow accents kit
Planck and Preonic by OLKB
Planck: Alphas + Ortho + Yellow accents
Preonic: Alphas + Ortho
Rama Works U80-A
Mixed base kit (note: fj should be homing)
ErgoDox
Alphas + Ergo (note: fj should be homing)
Cypher by Cable Car Designs
Alphas + TKL novelty mods + Numpad + ISO
Maja by Vulcan
Novelty base kit + Spacebars
MiniVan by Trash Man (Case by The Royal)
Alphas, 40s
Bepovan by Taylor (KnoblesseOblige) from Aeternus Company
Alphas, 40s, Yellow accents
Portico by TKC
Alphas, TKL mixed mods, Alternate numrow, Sewing Tools - Deep Blue deskmat
Austin by driftingbunnies
Alphas + TKL text mods + Numpad (note: fj should be homing)
Nemui by Bachoo
Alphas + TKL novelty mods + alternate numrow kit (note: fj should be homing)
Absinthe, U80-A, ErgoDox, Austin and Nemui renders by Ltafuri
Other renders by me using Keyboard Render Kit
Kits
I wanted to provide both flexible kitting options (mods + alphas) and simple base kit options, plus
add-ons that can be combined with either.
Please let me know any comments, feedback or requests about kitting either here or in the IC form!
You can view all kits as an imgur album here.
Base kits - mixed and novelty
All-in-one kits that provide support for common TKL, 75%, 65% and 60% layouts.
Click "more" to see the rest of the kits!
Alphas, Alternate numrow, and Colevrak
TKL mods - text, mixed, and novelty
With alphas, supports TKL, 75%, 65%, 60% and HHKB. Includes alpha-coloured spacebars, F13 and stepped capslock cookie.
Spacebars, Numpad, and ISO
Combine with either a base kit or alphas + mods. Spacebars contains a 2nd B for Alice boards.
NorDe and Yellow Accents (Added September 17th)
NorDe kit created using this guide by Miguel Farah, thank you for the resource!
Yellow accent kit contains spacebars in common sizes plus accent arrow keys. 2c/2.25c/2.75c can be used for Alice bars plus 40s, double 2c is for ergo/ortho, double 2.25c for Whimsy, and double 1.5c is for split ortho boards.
Ergo, Ortho, and 40s
When combined with alphas or a base kit:
- the ergo kit supports Ergodox, Boardwalk, Sol
- the ortho kit supports Moonlander, Planck, Preonic, Lily58, Iris, Sofle, Corne, Ergodash
- the 40s kit supports Minivan, JD40, JD45, UT47.2, prime_e, dimple, whimsy
Note: These kits only have a novelty variant right now, as the gradient means text mods are a lot less flexible,
despite the uniform profile. Let me know if you'd like to see text mods variants for these kits!
Cookies and Buttons
For a macropad, macro column, or to just to have more of them! Also, cookie coloured versions 🍪
Tailor
To make it easier to visualise the different options and work out what kits you need, I made the Tailor:
an interactive website that lets you explore how Sewing Tin can look on different keyboards.
You can try it out here: https://kamsewingtin.com/#tailor
Colours and Samples
The set has a blue gradient to reflect the shininess of the tin. The numrow is cookie-coloured
as a fun way to incorporate and highlight the cookie colour against the vertical gradient.
Note: the colours are not an exact match to the tin. Because of the shininess, the tin looks
very different depending on the lighting and environment and has a vibrancy that can’t be captured
in matte plastic.
See below for a photo from Keyreative of the samples. Am holding off on assessing the colours until
I receive the samples in person (being shipped to me now) - will post more photos then!
Pantone chips and KAT Alpha keycap (Keyreative stock white)
Please ignore how the pins are pushed in to the pincushion.
Deskmats
Design 1 - Cookie Parade (rendered with J-02 by ProtoTypist)
I had the idea for this deskmat really early on while designing this set - cookies walking together,
the swirly cookie leading the way with a needle as a flag, with cute expressions and poses! I tried
to give each cookie their own personality and mood (hang in there pretzel ;___; ).
This deskmat will be available in both 900x400mm as well as a smaller 600x350mm size.
Design 2 - Sewing Tools
Since the Cookie Parade deskmat is mostly plain, for the second deskmat I wanted to design a tiling
pattern, and capture the other main theme of the set, sewing. Will be available in 900x400mm
size in both yellow and blue!
Artisan Box
I've designed a "Sewing Tin" artisan box to match the set, you can see pictures of the prototypes below!
It has a 3D printed body and engraved acrylic lid.
We are partnering with P3D Store to produce these boxes - they will be available for purchase as part of a small
group buy running at the same time as the keyset group buy. You'll be able to select from all of P3D Store's in-stock filament
and acrylic colours. The box will be available in 2 sizes (12 slot and 21 slot) and 3 maximum artisan heights (17mm, 21mm, 30mm).
Thanks Jake from P3D Store for making these samples, and anEmptyJarOfNutella for the original suggestion!
More photos here.
I also previously designed a fully 3D printed version of the box. This will not be available for purchase, but I plan to
make the files available for personal use for those who join the keyset group buy. Details TBD!
Collaborations
I'm super excited to be partnering with these awesome makers on Sewing Tin themed cables and artisans!
Cable Collaboration: Cookie Cables are making matching USB and TRRS cables in tin blue and cookie yellow!
Artisan Collaborations:
- Bowbie Keycaps
- Crafted By Annie
- Cantoclicks
- klaykaps
- meof caps
- Miroticaps
- Myth Caps
- n.Na works
- okeydokey studio
- shirouu.kaps
You can see some little doodles introducing each collaboration here!
THOK Encoder Knobs
THOK has created these "button" encoder knobs to match Sewing Tin!
Available in Mellow Yellow (powder coated yellow brass matched to the set) and Brass Gold (clear coated natural brass), combined MOQ 100. Pricing TBD.
Credits
I had a lot of help getting Sewing Tin to this point! Huge thank yous to:
- the lovely Keycraft Collective community for the support, and for giving this set a space to grow:
  there's too many amazing people to name everyone, special thanks to Rosie, Andromache, pwade,
  pluma, and Therese for the help and advice
- Ltafuri for the sweet sweet U80-A, ErgoDox, Nemui and Austin renders
- minimoonbun for the super cute banner and favicon, advice, proofreading, and help acquiring sample keycaps :P
- DrHigsby for all the help with the 40s kit
- ImperfectLink and Keyboard Render Kit for the fantastic rendering kit
- acitrin, Mirubere, NoPunIn10Did, matt, hali, and honorless for the kitting advice
Contact
Email: hi@kamsewingtin.com
Discord: minicat#0836
Instagram: @minicap.cat
I'll regularly post updates in this thread, my Instagram, and the #kam-sewing-tin channel in the Keycraft Collective Discord.
Signature
Support Sewing Tin with this signature banner by minimoonbun!
Code: [Select]
[url=https://geekhack.org/index.php?topic=112929.0][img width=280 height=120]https://i.imgur.com/sq2Epbl.png[/img][/url]
You can update your signature here - I appreciate the support!
IC Form
Thank you for reading this far! Please consider filling out the IC form and letting me know
your feedback, I’ll be reading each response carefully!
« Last Edit: Sun, 21 November 2021, 19:48:04 by minicap »
Offline minicap
Re: [IC] KAM Sewing Tin
« Reply #1 on: Wed, 19 May 2021, 20:51:37 »
Changelog
2021/11/01
- Samples complete, being shipped to me!
- Tweaked spacing of 6^ key in kit images and renders by me
2021/10/31 - Updated THOK knob images to newer versions
2021/10/25
- Added previews of Cookie Cables collab
- Added pricing information for Sewing Tin artisan box
- Added render of 600x450mm Cookie Parade deskmat
- Added yellow accents to the Tailor
- Received initial photo of samples from Keyreative!
2021/10/20
- Added pricing
- Added information about available deskmat sizes
- Added previews of THOK encoder knob
- Added renders of the Absinthe by /u/velvetjaguar and u/reggatronics, renders by ltafuri
2021/09/28
- Kitting updates:
    - Added additional keys to NorDe kit (ISO enters, 1.25u shift, <>, 2") so that you no longer need to purchase the ISO kit alongside it
    - Added 2nd 2c spacebar in blue and white to Ortho kit
- Kits have been submitted to Keyreative for quotes
- Added details about artisan box GB
2021/09/17
- Added new renders on the Fuji65 by CMM.Studio, Planck and Preonic by OLKB, and Bepovan by KnoblesseOblige/Aeternus Company
- Updated Austin renders to use new legends
- Kitting updates:
    - Added yellow accents kit
    - Added NorDe kit
    - Added scooped homing keys
        - Changed non-homing fj in base kits and alphas kits to scooped (they now have both scooped and barred homing fj)
        - Changed non-homing 5 in numpad kit to scooped
        - Added scooped homing hunta and non-homing fj to Colevrak kit
    - Added second 2.25u shift and 2u shift to TKL mod kits
    - Updated some text legends in the TKL text mods kit to shorter versions (ins, del, up, down, pause → break) and tweaked kerning on home and scroll
    - Rotated pin on TKL novelty mods and novelty base kit
2021/09/09 - Added more artisan collaborations
2021/08/30 - GB dates announced (November 9th - December 9th)
2021/08/18 - Added details about artisan box
2021/07/20 - Removed The Ave renders
2021/07/14 - Added renders of the Portico by TKC, MiniVan by Trash Man and The Ave by The Royal
2021/07/08 - Announced vendors and collaborations
2021/07/05 - ñ added to ISO kit
2021/06/23
- Added deskmat designs - "Cookie Parade" and "Sewing Tools" (yellow, deep blue and blue-grey versions)
- Added renders of the J-02 by ProtoTypist with the Cookie Parade deskmat
2021/05/29
- Added new renders of the Cypher by Cable Car Designs and the Maja by Vulcan
- Minor kitting updates:
    - 2nd B removed from alphas, added to spacebars kit
    - Blue 6.25u spacebar added to alphas, removed from TKL mods and 40s kits
    - Ergo kit: added support for Boardwalk and Sol (previously Ergodox only kit)
    - Ortho kit: 2 x 1.5c blue spacebars added
    - 40s kit: Second 2.25c spacebar in blue and white added for Whimsy, yellow accent backspaces in 1.5u and 1.75u added
    - Alternate numrow kit: Added dark blue backspaces
    - Numpad kit: Added dark blue numrow keys
- Brown legend colour in kit images slightly tweaked for accuracy
- Added Alice to the Tailor
2021/05/20 - Fixed mistake in novelty base kit & novelty TKL mods (1.25u right shift -> 1.75u)
2021/05/19 - IC posted
TODO
- Update kitting based on feedback
- Finish deskmat designs
- More novelty designs (more types of stitches, and novelty spacebars) - no longer planned
- Reach out to potential collaborators for artisans / cables
- Get colour-matched keycap samples made (in progress)
- Reach out to vendors
« Last Edit: Tue, 02 November 2021, 22:23:11 by minicap »
Offline kight
« Reply #2 on: Wed, 19 May 2021, 20:57:06 »
yooo this is in IC now? I love this set so much, great execution of a cute theme!
Offline ambulated
« Reply #3 on: Wed, 19 May 2021, 21:03:27 »
The theme brings me so much nostalgia, and the execution in the color arrangement and novelties is so good. Excited about KAM profile as well! <3
Offline purryoverlord
« Reply #4 on: Wed, 19 May 2021, 21:05:09 »
Absolutely love this. The novelties are wonderful and the website is really thoughtful
Offline adi
  • adi.kbds; Consider ePBT Fruit Chew
    • Adi Nikumbh
« Reply #5 on: Wed, 19 May 2021, 21:12:09 »
The website is great! Would love to see more sets have something like it. Colors look great as well!
Offline uwumi
« Reply #6 on: Wed, 19 May 2021, 22:15:35 »
so excited to see this in IC! the website is extremely helpful. love the theme and the novelties suit it perfectly <3
Offline yh
  • hyurinkb
« Reply #7 on: Wed, 19 May 2021, 22:27:29 »
wait i love this colourway, this is very cute. but please optimize your pictures since this is kam kitting,  it's killing me
Offline MIGHTY CHICKEN
« Reply #8 on: Wed, 19 May 2021, 22:35:41 »
Enjoy the website, quite the interesting
Offline minicap
« Reply #9 on: Wed, 19 May 2021, 22:40:15 »
aaaah thank you for the comments so far, everyone!! 💙
eek! could you explain a bit more about optimizing the pictures, please? are they taking a long time to load for you?
the individual image files are <200kb for kits and <1mb for renders, i can hide some of the images in "more" tag maybe
Offline Hakatype
« Reply #10 on: Wed, 19 May 2021, 22:56:25 »
I think they're asking you to hide the images and make them reveal with a button ( {hide} insert images here, use the correct brackets unlike me {/hide} ). It's a little hard to scroll from the amount of kitting, but not the end of the world
Offline Hakatype
« Reply #11 on: Wed, 19 May 2021, 23:01:17 »
Oh while I'm here I should also throw in my piece. I love this project so much! The tailor is such a fun and novel concept, and I can't wait to see this set come to life. The ergodox renders in particular are especially wonderful.
Offline minicap
« Reply #12 on: Wed, 19 May 2021, 23:22:22 »
gotcha! i've updated the original post to hide all of the kits apart from the base kit. thank you for the help and the comment, Hakata! ✈️
Offline Mwbowman
« Reply #13 on: Wed, 19 May 2021, 23:54:56 »
Would it be a possibility to get 2 1.5u convex space bars?
Offline adobau
  • https://adobaulabs.com
    • adobaulabs
« Reply #14 on: Wed, 19 May 2021, 23:57:21 »
love this! I'm getting the alphas + novelty mods + 40s for sure :) glwic!! 💖
Offline haplopoda
« Reply #15 on: Thu, 20 May 2021, 00:02:49 »
Oooh, I love the idea behind the set, and the blue gradients look sick! GLWIC!
Sent from my GM1900 using Tapatalk
Offline gbenz
« Reply #16 on: Thu, 20 May 2021, 00:51:05 »
This set is adorable! I kinda want the alphas to be blue too but it's great as is too.
Offline Chippy
  • sus chef
« Reply #17 on: Thu, 20 May 2021, 01:17:04 »
what on earth are these replies about the website lol.
really love this theme, it's so specific. glwic.
1.2og | Buddy 6xx | Le Fishe V1 Proto | xyz60 Rev2 | Quartermaster | Chimera65 | Satisfaction75 | Realforce 84u | Zenith Z-150 | Realforce 86u | 378
This and the swiss cheese keyboard is the next generation of keyboards
Offline DerBonk
  • I'm just this guy, you know.
« Reply #18 on: Thu, 20 May 2021, 02:20:58 »
A wonderful theme, very well executed. I think I need these cookies now. Amazing that such a specific thing seems to be common in so many different cultures!
 The Tailor website is also really cool, fantastic work. This is very helpful for KAT/KAM sets. Good luck with the IC!
Offline harlekein
« Reply #19 on: Thu, 20 May 2021, 03:05:53 »
This is one of the most well thought out and executed themes I've seen in a long time. The novelties are cute and the mods elegant.
Honestly not sure if KAM is for me, but it's a beautiful set.
Offline YMwoo
« Reply #20 on: Thu, 20 May 2021, 03:47:57 »
Nicely made IC and very interesting kits and color.
For Ergo kits, need support for 1.5u bottom row and 1u inner columns at the very least.
will be following this IC closely. GLWIC!
Edit: forgot to say, I'd like to have text mods but understandable that it will be hard with the gradient.
« Last Edit: Thu, 20 May 2021, 03:49:53 by YMwoo »
Offline atlanticise
« Reply #21 on: Thu, 20 May 2021, 08:12:56 »
I love this idea, the novelties and all the effort you put into the website!  :thumb:
Offline minicap
« Reply #22 on: Thu, 20 May 2021, 10:22:38 »
Thanks for pointing this out! I'll work on updating the ergo kit 👍
This should be possible! To make sure I add it to the right kit(s), what keyboard(s) do you need it for?
edit: I've been told they are for the Corne (thanks Matt!) so will put them in the ortho kit.
« Last Edit: Thu, 20 May 2021, 11:07:50 by minicap »
Offline Rumblethumps
« Reply #23 on: Thu, 20 May 2021, 13:23:10 »
Yessss. I like the option of the alternate numrow since the cookie layer was throwing me off at first, but the more I Look at it, the more it's growing on me. (And it ties into the theme so well!)
Offline gem
« Reply #24 on: Thu, 20 May 2021, 16:24:53 »
this is such a lovely set!! the website is super cute as well :D
the subtitles(?) on the kit images that list what keyboards the kits support are very helpful also! glwic:)
Offline minicap
« Reply #25 on: Thu, 20 May 2021, 17:12:05 »
Thank you to whoever pointed out the mistake in the novelty base kit right shift in the IC form (bottom one it should be 1.75u not 1.25u) - sorry about that!
I will fix that ASAP and follow up with more kitting updates (from IC feedback/this thread) later on. 💙
edit: Novelty base and TKL novelty mods kit images have been updated
(And thank you for all the sweet comments in this thread! I'm reading each one and appreciate them all - I'm not quoting them to keep the thread easier to read, but I am reading them all!)
« Last Edit: Thu, 20 May 2021, 17:25:15 by minicap »
Offline boneandbee
« Reply #26 on: Thu, 20 May 2021, 17:50:49 »
this is childhood nostalgia at its finest and i absolutely love it for that! the novelties are so dang cute
Offline avaciil
« Reply #27 on: Thu, 20 May 2021, 18:30:46 »
what a nice sense of nostalgia! i absolutely adore the colorway and the lowercase alphas, definitely would like to pick up this keycap set 🥰 my grandma always kept her sewing supplies in cookie tins, so i was always elevated then disappointed when i was younger 😂 i really love Tailor as well! it's so convenient (and honestly makes me consider copping the Ergodox). GLWIC!
Offline Vala
  • :smork:
    • Vala Supply
« Reply #28 on: Thu, 20 May 2021, 19:22:32 »
Love the banner.
That tailor site is also awesome! Really cool idea
Offline Vegas_
« Reply #29 on: Thu, 20 May 2021, 19:22:55 »
this set is absolutely phenomenal!! wonderful inspiration (always loved danish butter cookies) and fantastic execution. good stuff!
GLWIC!! :thumb:
Offline minicap
« Reply #30 on: Sat, 22 May 2021, 15:50:12 »
thank you!! im happy the set can bring back some happy nostalgic feelings for people 💖
im an ergodox user myself so definitely had to have ergodox support, hehe :D (and i highly recommend it, very comfy to type on!)
Love the banner.
GLWIC!! :thumb:
thank you, Vala & Vegas!! 🥺
Offline eljudio42
« Reply #31 on: Sat, 22 May 2021, 16:01:54 »
I would have really liked a reverse set. Blue mods with white alphas. I know it probably makes the kit more expensive and at that point it might start looking like KAT Great Wave. It's still a beautiful set regardless. GLWIC :)
Offline summerqm
« Reply #32 on: Sat, 22 May 2021, 16:19:00 »
This is so cute and nostalgia!! My mom uses tins to store medical supplies instead of sewing supplies (we had the red square tins that are used for egg rolls) :)
This may be a stretch but can we also include some alice/arisu style boards in the tailor? 🙏
GLWIC!
Offline minicap
« Reply #33 on: Sun, 23 May 2021, 16:46:34 »
GLWIC!
Thank you! 💙
Unfortunately the Tailor doesn't support angled keys right now, hence no Alice-style boards (it just looks weird having all the keys be straight...)
Not sure when I'll be able to add support for angled keys, but I am hoping to get some renders on an Alice style board soon, at least!
Hmm, did you mean white mods with blue alphas? 😅
I do really like the look of white-on-blue mods for the sewing themed mods - I feel that it captures the sewing tin vibe better than blue-on-white mods would, if that makes sense. But yeah, thanks for the comment!
Offline summerqm
« Reply #34 on: Sun, 23 May 2021, 17:15:55 »
Thank you! 💙
While it is not prefect I think I am totally happy if we use similar layout as QMK Configurator:
269039-0
It will help visualizing (to an extent) of what it could look like and most importantly it would be nice to use Tailor to figure out which kit(s) are needed -- that's my favorite feature of Tailor  :thumb:
Offline minicap
« Reply #35 on: Mon, 24 May 2021, 21:55:07 »
Thank you! 💙
Ooh, thanks for that suggestion/image! I'll have another go at adding Alice support with a layout more similar to that one :thumb: It'll take some time to add it, will post here once it's done.
It'll probably go live at the same time as I make the first round of kitting updates. I got a request to move the 2nd Alice B to spacebars from alphas so that you can cover an Alice board with a base kit + spacebars (rather than having to do TKL mods + alphas + spacebars).
Offline yh
  • hyurinkb
« Reply #36 on: Tue, 25 May 2021, 05:51:49 »
not what hakatype said. they load fine now, thank you for bothering!
Offline dxxbox
« Reply #37 on: Tue, 25 May 2021, 09:45:43 »
It will be a really good one.
Offline saam
« Reply #38 on: Wed, 26 May 2021, 00:52:27 »
Haha!
Great!
I totally see the colors working here!
Sam E
Offline Calm_Waters
« Reply #39 on: Wed, 26 May 2021, 13:25:03 »
Love the theme and the colors!
Offline Lazesummerstone
  • ҠѤӋϚΔΡѕ
    • MY Keycap set - Transmutation
« Reply #40 on: Wed, 26 May 2021, 23:34:36 »
Yeah love the calming feeling I get when I see this set, especially on the Nemui. WOwZERS!  :thumb:
Offline minicap
OK! I've been reading all of the IC feedback, and I'm here with a first round of minor kitting updates to address some of the feedback/requests. Thanks to everyone who gave suggestions in the IC form and in this thread!
- 2nd B removed from alphas and added to spacebars kit. This allows Alice users to cover their board with a base kit + spacebars.
- Blue 6.25u spacebar removed from TKL mods kits and 40s kit, added to alphas. I noticed there were many people interested in combining a base kit with TKL mods or 40s, or mixing and matching multiple TKL mods kits - this removes a duplicate spacebar for them while keeping the same compatibility for those who just want alphas + TKL mods/40s. This is also more consistent with other KAT/KAM kitting.
- Ergo kit: Extra keys added to support Boardwalk and Sol
- Ortho kit: 2 x 1.5c spacebars in blue added for Corne and similar keyboards
- 40s kit: 2nd 2.25c spacebar in blue and white added for Whimsy. yellow accent backspaces in 1.5u and 1.75u added
- Alternate numrow kit: added dark blue backspaces
- Numpad kit: added dark blue keys as an alternative to the yellow keys
There were some requests for larger changes or new kits (e.g. international support, yellow accents/spacebars) - I’m thinking about these and waiting for more feedback before adding completely new kits. I’ve also tweaked the brown legend colour on the butter yellow keys in the kit images to be more accurate (slightly more reddish/saturated).
In terms of other updates:
- New renders have been added, featuring Sewing Tin on a polycarb Maja (by Vulcan) and a dark blue Cypher (by Cable Car Designs).
- The Tailor has been updated for the above kitting changes. Additionally, the Alice layout has been added (thanks summerqm for the suggestion)
Offline jakk
I really like this set! great job!
Offline YMwoo
very nice update!
good job  :thumb:
Offline minicap
very nice update!
good job  :thumb:
Thanks! And thanks again for the ergo kit suggestion  :thumb:
Thank you, glad you like it! :D
Offline mr_foggy
  • neue = nope
much prefer this over lazurite. very nice work there. definitely considering.
Offline Pyurii
Wasn’t a fan of this at first, but it’s growing on me.
Offline Mr Chrome
I saw this set a while ago and thought the double theme (sewing and sweets) and the numrow accents were too much for me... but now I’m definitely converted and glad to see something different.
I hope the yellow won’t be too saturated. I think it looks great where it’s toned down with a bit of a cream/beige base tone. Most of the render colours don’t seem like a 1-1 match with the pantones, but likely just natural vs. artificial lighting?
Please don’t change the cookies kit for anything! I want so many macropads with it, and Coraline spooked me too much to use the buttons :-X
“This plastic rectangle is alright. The plastic rectangles on top of it, though...”
Offline minicap
Hello! I don't have any updates today, but I'm working on a few different things (deskmat designs, finding vendors and collaborators) and hope to post some updates in the next few weeks :D Colour-matched samples are also being manufactured, really excited to see how those turn out!
I'm glad to hear the set's growing on people! Definitely a niche theme, but I've been happy seeing that many people also feel nostalgically about these cookie tins.
I'd say the yellow is definitely on the pastel side, but more of an orange/yellow then a cream/beige.
I definitely want to make sure that people can be confident about the colours in the set when thinking about joining the GB. I'm buying a lightbox to take better quality photos of the colour-matched samples, and also hope to get full prototype sets made before GB so you can see the entire set on a keyboard.
I'm concerned to hear the render colours don't seem like a match - could I ask what you're comparing them to, and if there's specific things that seem off? The renders were colour-matched to a physical Pantone fan. Like you mentioned, there are a bunch of different factors that affect the colours (the renders themselves use different lightings, as well as the monitor and lighting you're using to look at the render) but they should be pretty close.
If you're comparing them to the photos of the Pantone fans/swatches, this is less accurate than a physical pantone book - when I took the photos, the colours already looked a bit different after being photographed, and there's differences between the different photos too...I included them since I still thought they'd be helpful, but I'm hoping that the lightbox helps with this problem.
And noted for the cookies kit! It's been much more popular in the IC than I expected as well, it's definitely here to stay :D
Offline Mr Chrome
Ah, I wouldn't worry about it! The render lighting just has a warmer tone than the photos you took, and the shadows in the renders just make the gradient look a little more subtle compared to the what we see in raw Pantones. If you're already waiting on colour-matched samples though, that's really what matters as far as giving an accurate representation is concerned! Really nice to see that you're doing that well ahead of time, too :)
Hell yes.
The work you've put into this set is more than enough reason for me to keep an eye on it. Now I'll just cross my fingers that Keyreative doesn't drop the ball on this one...
