Author Topic: [IC] 21XX - A modern unsaver keyboard  (Read 60259 times)
Offline Pontus
« on: Wed, 16 August 2023, 16:17:34 »
21XX
IC FORM IC FORM IC FORM
I am happy to announce that Cannonkeys has picked up this project as the lead vendor. We are currently working on figuring out potential regional vendors and the final group buy details!
https://cannonkeys.com/products/21xx
Specifications
Case:
▸ 5.5° typing angle
▸ 25.5° on F-rows
▸ 6063 Top and Bottom case
▸ PCB Top mount on the main alpha cluster
▸ Plate top mount for the f-row cluster utilizing a 5052 aluminum plate
▸ ~3900g unbuilt, ~4300g built (Current build is 4325g)
▸ WKL with cross nav cluster & WK with a 3x5 block nav
▸ 20.2mm front height (Inner bezel edge to bottom, with feet)
▸ 23.5mm EKH (Bottom row switch stem to bottom, with feet)
Blue, Black, & Warm gray ano options
Front height & angle diagram
PCB
▸ PCB designed by Cipulot
▸ QMK & VIAL compatible
▸ Indicator lights
▸ 5V solenoid mounted on the pcb
▸ Solder only
▸ Faux integrated cable with an Internal USB C port
▸ FFC Ribbon interconnect cable between main & frow pcb
▸ 1.6mm FR4
Layout support
Design & Mount
As shown in the renders, and implied by the name, the design takes heavy inspiration from Cherry’s 2XXX series boards, especially the chopped converted boards reminiscent of the ever-classic IBM Unsaver keyboards. It features everything you would expect: chunky bezels, rounded corners, a proper Cherry lip, exaggerated seam, stepped design for the angled F-rows, an integrated cable, and plateless mounting.
More renders
In true 2XXX fashion the F-row plate features an aluminum plate that is top mounted, while the main alpha & navigation cluster features a plateless top-mounted assembly as shown in the render below. Due to the nature of the layout, the F-row cluster requires a separate PCB that is excluded from the render so that the F-row mount is visible.
(PCB featured in all renders uses an old & outdated outline. I will update the IC when I have the updated PCB design ;D)
The 21XX also features a “faux” integrated cable, utilizing an internal USB-C port it gives a classic look without forcing you to solder a cable directly into the PCB. Furthermore to complete the vintage references the PCB supports a toggleable 5V solenoid.
Fancy renders
(Some of these renders are slightly outdated)
Prototype pictures
V1(newest prototype)
V0(Previous prototype)
Who am I?
hej hej I am Pontus, I’ve been in the hobby since ~2019. You might have seen my name attached to some renders or somehow stumbled upon the DCS Dolch GB I helped run earlier this year. I really like keyboards.
Timeline
▸ Design 1 (V0) – finished (2022)
▸ Prototype 1 (V0) – finished, typed on for roughly half a year (Early 2023 - Aug 2023)
▸ Design revision (V1) – finished (July 2023)
▸ Prototype 2 (V1) – received, currently testing (Aug 2023)
▸ Confirm design (Aug 2023)
▸ Review units (??)
▸ Potential revisions (??)
▸ Group buy (??)
Sale info and format
TBA
The purpose of this IC is to gauge interest in the project. I currently do not have any vendor or final details so there’s not much I can share. Hoping to be able to reach a MOQ of ~50 units but if there’s substantial interest it can be raised.
The price will almost certainly be more than 500EUR and hopefully less than 700EUR. I will share a more accurate price estimate once I have an understanding of the interest for the board.
Details such as colors and kit contents will also be added later down the line as this is a relatively early IC.
If you’re a vendor interested in running this board, please reach out to me on discord  ;D
Links
Discord
Instagram
IC FORM
Thanks
▸ The regulars who encouraged me to start this project
▸ All the people who have found and supported the project pre this IC through my instagram & discord
▸ Cipulot for being the greatest PCB designer and putting up with all my stupid requests
▸ James for his pretty feet
▸ Ankit for his proofreading
▸ Myself for doing all the renders
▸ You! for reading this  ;D
 :p :p :p
« Last Edit: Wed, 26 March 2025, 17:02:37 by Pontus »
Offline Pontus
Re: [IC] 21XX - A modern unsaver keyboard
« Reply #1 on: Wed, 16 August 2023, 16:17:53 »
FAQ
Questions from the IC form, will update as the IC progresses.
August 17 2023
Q: ALPS?
A: No. This is a cherry inspired board that has been designed to be used plateless. Adding alps support to the current PCB would be detrimental to the build experience for the majority of users who will build it with mx. Adding a separate alps PCB would increase cost and the amount of parts to be made. Resources such as PCB outlines (alternatively complete files) & plate files will be available if the GB runs
Q: WK? 3x5 nav? BAE?
A: Maybe. I will make a form to gauge what layouts people are interested in at a later date. Highly unlikely that the PCB will get more layout support but separate tops might be feasible. To my knowledge original Cherry BAE keys use a footprint that isn't compatible with modern ISO footprints so the chances of the PCB getting support for them are slim to none. Worth noting that plenty of modern sets, both in GMK CYL & SP DCS profiles with updated modern BAE keys that work on standard ISO/ANSI PCBs have ran recently all of which should work on the current pcb.
Q: Detachable cable?
A: Most of the people who have commented on this have seem to been worried about accidentally detaching the cable in use. From my experience this is not a problem, especially if you use cables that are on the thicker side. Cable cutout is 5.5mm wide, the silicone cable that I use with the board is friction fit into the cutout, if I want to get it out I have to use excessive force.
Q: Sticker, badge, weight, or something else on the back?
A: Maybe. I would love to add some personalisation on the back, most likely in the form of a sticker or badge. No plans for a weight, personally I don't feel like it would add anything except cost to the board.
Q: Can you do X colour or Y finish?
A: Colours are far from finished, GB options will most likely be quite limited due to the low moq. I hope to be able to offer at least one plain and one more fun colour. As for other finishes it would be something that I would have to prototype, if I find something that I love the feel and quality of I might try to offer it as an alternative to anodizing.
If you sent a question that I forgot to answer here don't be afraid to ask it again in my discord
« Last Edit: Thu, 17 August 2023, 14:19:38 by Pontus »
Offline ankit
  • Formerly ankit-sachdeva
« Reply #2 on: Wed, 16 August 2023, 16:18:53 »
i'll take 2
glwic pongus
Offline unusuaL_
« Reply #3 on: Wed, 16 August 2023, 16:19:17 »
my favourite sousa no frieren board  ;D ;D
collection: hibike 1/1, garderie tkl, casper60, hhkb pro2, matrix 2.0additional, f1-8x og
Offline whirlwind
« Reply #4 on: Wed, 16 August 2023, 16:19:35 »
Phenomenal work, best of luck Pontus :thumb:
Offline Meepergon
« Reply #5 on: Wed, 16 August 2023, 16:19:49 »
i need this. sincerely have been waiting for a board with this layout for so goddamn long. i'm in for one.
Offline Tulkas
« Reply #6 on: Wed, 16 August 2023, 16:20:06 »
I saw this in my dreams and it was beautiful!
Offline Fraaaan
« Reply #7 on: Wed, 16 August 2023, 16:20:09 »
yes yes yes yes
Offline The Pig
  • Oink!
« Reply #8 on: Wed, 16 August 2023, 16:22:08 »
Great project Pontus, really looking forward to more updates!  :eek:
Offline puggo69
« Reply #9 on: Wed, 16 August 2023, 16:22:30 »
i am so proud of you pontus
Offline Thebloodyez
  • Just a random keyboard builder.
« Reply #10 on: Wed, 16 August 2023, 16:22:51 »
rush rush GLWIC.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #11 on: Wed, 16 August 2023, 16:25:01 »
My affinity for Cherry-style boards makes me feel interested. Hope the price is not prohibitive!
Offline Dyno
« Reply #12 on: Wed, 16 August 2023, 16:28:14 »
I’ve waited a long time for this one!
GLWIC!
Looking forward to see more of this big boy
Offline Poesjuh
« Reply #13 on: Wed, 16 August 2023, 16:29:57 »
rush rush
Offline CoolPenguin1
« Reply #14 on: Wed, 16 August 2023, 16:30:03 »
rush rush
Offline Pyroo
« Reply #15 on: Wed, 16 August 2023, 16:32:32 »
Yes.  :D
Bunny enthusiast
Offline Sturmtiger
« Reply #16 on: Wed, 16 August 2023, 16:40:06 »
Finally, the dream becomes real.
Offline warhopper
« Reply #17 on: Wed, 16 August 2023, 16:40:19 »
Yes and yes please Mr. Pontus, for sure in for one
Offline ryoh
« Reply #18 on: Wed, 16 August 2023, 16:42:09 »
this board is so good, glwic
Offline The0rigina1
  • fumoposting
« Reply #19 on: Wed, 16 August 2023, 16:50:33 »
cool and good
Offline Jampot_298
« Reply #20 on: Wed, 16 August 2023, 16:55:54 »
The pontus and the rontus. I wish the side bezels were thinner, but this is a sick project. GL!
Offline MK47
  • Don't talk to me
« Reply #21 on: Wed, 16 August 2023, 16:56:16 »
I like big boards
Offline 51p50x
« Reply #22 on: Wed, 16 August 2023, 16:57:30 »
Looks really good I'm interested, and I like the color on the v1 proto. GLWIC.
Offline treeleaf64
    • treeleaf64
« Reply #23 on: Wed, 16 August 2023, 17:02:02 »
I was locked inside this keyboard for a week and I could hear the reverberations of the Pontus typings
Then I slowly transformed into the 21xx and the 31xx and Now we are together in the forest
With the cat and pat
From treeleaf
Everyone must pay the cat tax
Offline Moods
« Reply #24 on: Wed, 16 August 2023, 17:24:12 »
i love the 21sexsex
Offline jivex5k
« Reply #25 on: Wed, 16 August 2023, 17:31:47 »
i like it
Offline plag
  • Formerly pepperonichicken
  • i also go by plag
« Reply #26 on: Wed, 16 August 2023, 17:34:58 »
finally. unsaver custom. a REAL cherry lip, plateless, james feet, solenoid, cipulot pcb, and faux integrated cable? this is FREAKIN EPIC! glad to finally see the IC posted here. need one on my desk asap.  :thumb: :thumb: :thumb: :thumb: :thumb: :thumb:
Offline paperassgasket
« Reply #27 on: Wed, 16 August 2023, 17:36:30 »
N E Alps support avail?
Offline mcmaxmcmc
« Reply #28 on: Wed, 16 August 2023, 17:47:58 »
the faux integrated cable is kinda whackge (would personally like a more easily detachable cable that won't take unscrewing) but the board seems neat, hope the GB won't be too expensive :)
(obv Alps support would be nice but I won't beat you to death with it)
good luck with IC! looks good so far
Offline mcmcmc
« Reply #29 on: Wed, 16 August 2023, 18:45:29 »
very cool very based  :cool:
Offline ee
  • hi
« Reply #30 on: Wed, 16 August 2023, 19:09:00 »
this is hot
Offline growler
« Reply #31 on: Wed, 16 August 2023, 19:20:26 »
I sense great vulnerability. A man-child crying out for love. An innocent orphan in a post-modern world.
I see a parasite. A sexually depraved miscreant who is seeking only to gratify his basest and most immediate urges.
It's struggle is man's struggle. It lifts my spirit.
It is a loathesome, offensive brute. Yet I can't look away
It transcends space and time
It sickens me
I love it
Me too
Tappity tap tap tap
Don't just stare at it ...
Offline Tictac46
« Reply #32 on: Wed, 16 August 2023, 19:57:43 »
Looks absolutely fantastic! GLWIC
Offline demond_25
« Reply #33 on: Wed, 16 August 2023, 20:35:15 »
This is too hot to handle! I can definitely use it as pillow in the future. Looking forward to the progress. It's sad to see that boards are looking the same nowadays. This is a better one.  :thumb:
Offline CyCo
« Reply #34 on: Wed, 16 August 2023, 20:44:26 »
This is super sweet!!
1. Will the generic gray color be available?
2. Why no numpad?
3. The space on the top left and right are so empty. Maybe LED screen, logos or something else?
Offline nu_types
  • Formerly Iredeus
« Reply #35 on: Wed, 16 August 2023, 21:26:28 »
2. Why no numpad?
Because its unsaver layout
Offline Rhienfo
  • Why is everything I want here so expensive :(
« Reply #36 on: Wed, 16 August 2023, 21:41:06 »
I love this so much, especially that blue. I've always wanted an unsaver board cause they look so nice and this might be it. GLWIC :)
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
Offline Applet
« Reply #37 on: Thu, 17 August 2023, 00:59:59 »
Looking good! GL with IC and GB  :cool:
Offline FatefulStranger
« Reply #38 on: Thu, 17 August 2023, 02:05:45 »
This is awesome and very based! Hope to see solenoid and carrying case included in the kit! GLWIC  :thumb:
Offline Nonnegaard
« Reply #39 on: Thu, 17 August 2023, 02:31:15 »
make it out of brass
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline Nonnegaard
« Reply #40 on: Thu, 17 August 2023, 02:32:28 »
the carrying case in question
Offline jjolddahgoo
« Reply #41 on: Thu, 17 August 2023, 02:41:00 »
Been keeping an eye on this project for a little bit. Consider me interested.
Offline TjarleN
« Reply #42 on: Thu, 17 August 2023, 02:47:09 »
Thats one hot keyboard :nut:
« Reply #43 on: Thu, 17 August 2023, 03:57:10 »
Been looking forward to this for a long time - count me in :thumb:
Offline Rhienfo
« Reply #44 on: Thu, 17 August 2023, 04:18:18 »
real image of all the 21xxs when they start to ship
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
Offline -_-
« Reply #45 on: Thu, 17 August 2023, 04:34:41 »
this is the one
Lyn Dolphin v3  | HHKB Professional | REΛLFORCE 88u
Offline Something_Magical
« Reply #46 on: Thu, 17 August 2023, 09:47:57 »
The Pontus and the Rontus dropping an IC. I want this to have a bigger front bezel actually  ;D
Offline Pontus
« Reply #47 on: Thu, 17 August 2023, 14:20:48 »
Updated the post with a FAQ consisting of common questions from this thread & the IC form  ;D
« Reply #48 on: Thu, 17 August 2023, 20:47:11 »
I'm so happy to see this! I am definitely getting one. I'm really hoping for 3x5 support! I've been using that layout since 2012 since the original Phantom supported it and it's really great. The estimated price is about what I expected, so that's nice.
Offline LMarci
« Reply #49 on: Fri, 18 August 2023, 05:55:23 »
rush rush
